Staro 23.04.2011., 12:42   #1051
MiroGavran
Datum registracije: Feb 2011
Postovi: 190
imaš operin block content, Opera AdBlock ti ne treba jer je to isti k samo malo pojednostavljuje stvari
http://my.opera.com/Tamil/blog/ad-block
MiroGavran je offline   Reply With Quote
Staro 26.04.2011., 15:17   #1052
reboot
Lokacija: Zgb
Postovi: 1,108
jel vas upozorava da je stranica nacionalnog parka plitvicka jezera opasna?
reboot je offline   Reply With Quote
Staro 26.04.2011., 17:05   #1053
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,580
Autor reboot Pregled postova
Jep, Malware Warning.
Staro 26.04.2011., 21:16   #1054
reboot
Lokacija: Zgb
Postovi: 1,108
sad je malware i www.gmail.com? wtf opera....
Staro 26.04.2011., 21:18   #1055
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,580
E to mi ne javlja
Staro 26.04.2011., 21:49   #1056
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
I meni je maloprije javio to za GMail
rams je offline   Reply With Quote
Staro 03.05.2011., 11:10   #1057
Facelessone
Facelessone's Avatar
Postovi: 4,205
11.50 (Swordfish) Alpha
Plavi Opera gumb.
Ekstenzije za Speed Dial. Za sada postoje samo 3.
Sinkronizacija passworda.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Zadnje izmijenjeno od: Facelessone. 03.05.2011. u 11:30.
Staro 03.05.2011., 18:13   #1058
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
napokon spremanje sifri
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je online   Reply With Quote
Staro 07.05.2011., 12:24   #1059
domis
Lokacija: Hrvatistan
Postovi: 4,165
Autor fre@k Pregled postova
upravo htio isto napisati
to me zasad na ovoj verziji smeta pa ne koristim
Staro 17.05.2011., 10:33   #1060
rodriguez
rodriguez's Avatar
Postovi: 2,066
Brisao sam windowse i obrisao i normalno i bookmarkse od opere.al ih imam sejvane u opera linku,na svom accountu?
Kako da ih sada najednostavnije importam u novosnimljenu Operu?
edit
Hvala Snake!!
Zadnje izmijenjeno od: rodriguez. 17.05.2011. u 10:58.
Staro 17.05.2011., 10:40   #1061
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Imas ikonu opera link u donjem lijevom kantunu u operi. Klikni na nju i odaberi sign in ako imas account. Kad se otvori prozor odaberi sve opcije i to je to...
Staro 18.05.2011., 15:41   #1062
rak21
COD2 expert
rak21's Avatar
Postovi: 1,920
Staro 20.05.2011., 15:05   #1063
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Vec neko vrijeme me jedna stvar jako zivcira kod opere. Naime, zanima me kako stavit da default opcija na "browser identification" bude "identify as Opera" a ne "mask as Firefox"? Hrpa stranica mi ne radi dobro dok ne stavim na "identify as Opera" a nisam naso nigdje opciju da to promjenim za sve stranice neg moram jednu po jednu u site preferences mjenjat.
njuskalo je offline   Reply With Quote
Staro 20.05.2011., 18:11   #1064
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
The above process can also be achieved using the opera:config interface. Follow these steps:
In the Opera address bar, type opera:config and press Enter. The Preferences Editor is displayed. In the search box adjacent to Show All, type Spoof UserAgent ID. This is the flag that was amended in the main guide, using the Opera graphical interface.
Amend the current value to 1, 2, 3, 4 or 5 (refer to Step 3 of the main guide for descriptions):
1. Identify as Opera
2. Identify as Firefox
3. Identify as Internet Explorer
4. Mask as Firefox
5. Mask as Internet Explorer
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 23.05.2011., 13:43   #1065
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 917
Pitanje!
Koristim 2 gmail accounta. I kad se odlogiram iz jednog u drugi, istovremeno mi se odlogira na youtubu. Kako to sprječiti? Žifcira me..
Btw od kad mi se opera nadogradila na v11.11 imo sam 3 crash-a, a do sad je bilo sve 5.
Staro 23.05.2011., 13:58   #1066
ONeill
ONeill's Avatar
Datum registracije: Mar 2008
Postovi: 347
Youtube je od Googla, koriste isti login sistem, zato te odlogira s Youtube čim se odlogiraš od neke druge Google usluge.
Postoji opcija "Sign in to multiple Google Accounts", ali trenutno ne pokriva Youtube.
ONeill je offline   Reply With Quote
Staro 23.05.2011., 14:01   #1067
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 917
Ma da, znam. Sad eto pokušavam spojit, ako je to uopće moguće, da dobivam mail od oba acc-a u jedan. Tj. da u jednom mail acc-u imam 2 inboxa. Pa ću tako izbjeći logout..
Staro 24.05.2011., 17:37   #1068
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Hvala fre@k
Autor domina Pregled postova
Jednostavno forwardas s jednog maila u drugi, ili cak importas acc i napravis label i podesis da ti svi mailovi sa tog drugog acca idu automatski u label i arhiviraju se (ako ne zelis da ti ne budu u istom inboxu)...
Staro 25.05.2011., 10:30   #1069
vladosch
vladosch's Avatar
Lokacija: Garešnica
Postovi: 100
Od OPERE sam nažalost upravo odustao. GOdinama ju koristim i bio sam zadovoljan sa njom ali ova zadnja mi nije sjela. Javili su se problemi spore veze i stalno mi javlja da sam na sporoj vezi dok u Mozilli sve radi super.
Ako netko ima kakvo rješenje slobodno neka javi.
vladosch je offline   Reply With Quote
Staro 25.05.2011., 13:33   #1070
dedaWraith
Datum registracije: Jan 2010
Postovi: 140
Meni na amisu to nikad nije javilo, dok doma na tcomu svako malo, al vjerujem da je to normalno kaj javlja, jer mi tcom steka dozlaboga. Al vjerujem da si mos iskljucit taj turbo ak bas mislis da je u tome problem.
dedaWraith je offline   Reply With Quote
Staro 25.05.2011., 13:53   #1071
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,580
Autor vladosch Pregled postova
Vraćanje na stariju verziju?
Ja sam na 11.01 i ne planiram ić na novu.
Staro 25.05.2011., 18:03   #1072
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
samo udji u config od opere iskljuci turbo ko i sam sto sam napravio i nikad nikakvih problema do sada, eventualno si baci oko da ti mozda nerostiljaju torrenti ili nesto slicno u pozadini
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 26.05.2011., 17:59   #1073
MiroGavran
Postovi: 190
ma ne treba mu uopće opera turbo biti uključena da mu se to pojavi
samo odi na configure opera turbo i makni kvačicu sa notify me about network speed
Staro 26.05.2011., 21:28   #1074
keyser_s()ze
Postovi: 590
za sve koji žele napravit jednostavni backup opere predlažem Stu's Opera Settings Import & Export Tool.
koristim ga toliko dugo da više neznam ni jednu šifru iz wanda, samo import/export.
keyser_s()ze je offline   Reply With Quote
Staro 27.05.2011., 00:53   #1075
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Autor MiroGavran Pregled postova
Upravo to. Prva stvar koju sam iskopčao nakon instalacije nove verzije.
Staro 27.05.2011., 22:04   #1076
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
njuškalo i opera
Potpuno sam novi u operi. Imam problem; ne radi mi njuškalo... odn, ne mogu vidjeti izlistane oglase. Eto, pa tko ima rješenje, neka trzne. Ja ću dotle preko firefoxa na pijac.
Tomtam je offline   Reply With Quote
Staro 27.05.2011., 23:31   #1077
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
probaj desni klik "edit site preferences..." > tab "network" i dole browser identification: "indentify as firefox"
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 28.05.2011., 14:57   #1078
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
i dalje ne radi... samo na tren pokaže oglase i odmah nestane. Zaboravio sam reći... vide se samo izdvojeni oglasi. Ne kužim zašto se onda nebi vidjeli svi.
Staro 28.05.2011., 18:04   #1079
MiroGavran
Postovi: 190
- daj print screen
- navedi šta imaš od ekstenzija (da nisi kojim slučajem blokirao koju skriptu na stranici s nekom adblock ekstenzijom)
Staro 28.05.2011., 19:41   #1080
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Ekstenzija je opera adblock
SSovi
EDIT: evo dizejblo sam blocker i radi. Sad, može li se podesiti ili ga moram paliti/gasiti? E da, hvala!
Zadnje izmijenjeno od: Tomtam. 28.05.2011. u 21:32.
