#181 |
Postovi: 7,568
ECS A75F-A Llano APU FM1 ploča
Elitegroup Computer Systems (ECS) introduces the latest AMD based motherboard series – ECS Black Deluxe A75F-A, and ECS mainstream series A75F-M and A75F-M2 motherboards. ECS A75 series motherboards powered by AMD Hudson D3 chipset support the latest AMD A series APU. ECS Black Deluxe A75F-A, A75F-M and A75F-M2 all support the latest AMD A series APU with AMD Hudson D3 chipset and AMD FM-1 socket. With native USB 3.0 and SATA 6.0Gb/s powered by AMD Hudson D3 chipset, ECS A75 series represents the official arrival of new age of high transportation speed, and that USB 3.0 and SATA 6.0Gb/s have also officially become the basic equipment for every computer.Izvor: VR-Zone i techPowerUp Zadnje izmijenjeno od: McG. 21.05.2011. u 02:14. |
#182 |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,158
Koje su im folirancije s trpanjem toliko PCI-a? Prve dvije godine (s pocetka PCI-e price) izbacise gomilu ploca s 1x-e chupercima, za koje osim ponekog TV Tunera, prakticno nista drugo nije postojalo. Onda konacno trziste pocne loviti vlak, i vise manje, sve se 'ponovi' korisno na expressu. Onda neko vrijeme, redovita praksa je bila jedan ili max dva PCI-a. Pobacah vise manje sve s PCI-a i sad mi pocnu redati PCI, upravo kad hocu vidjeti vise PCI-e tracnica? Gledam dosta najnovijih ploca i po 3x PCI-a uopce nije slucajnost. Pa kaj to delate? ![]() |
#183 |
Datum registracije: Mar 2009
Lokacija: Zagorje
Postovi: 1,001
Zato jer su strahovito zajebali s ukidanjem PCI slotova, ljudi imaju vrhunskih audio-media-controller PCI kartica koje su platili 500-1000$ i zasto bi svoje prodavali u bezcjenje i kupovali uber skupe nove i losije samo radi konektora? i velika vecina je povukla pametan potez i odjebala ploce ako su imali izbora... |
#185 |
Postovi: 7,568
Asus 990FX Sabertooth AM3+ ploča
With the socket AM3+ platform, Asus wants to rally around its top motherboard brands, including Republic of Gamers (ROG), with the Asus Crosshair V Formula, and the The Ultimate Force (TUF) Sabertooth 990FX, for AMD's next top of the line 990FX chipset that is designed to run up to four discrete graphics cards. The 990FX Sabertooth keeps up with the color scheme of the other TUF-series members. It boasts of highly durable components. The AM3+ socket is powered by a 10-phase Digi+ VRM. It is wired to four DDR3 DIMM slots supporting dual-channel DDR3-1866 MHz memory, and connects to the 990FX chipset over a HyperTransport 3.1 link.Izvor: techPowerUp |
#186 |
Lokacija: VG
Postovi: 1,758
MSI 990FXA-GD80 Socket AM3+ Motherboard Detailed
Earlier referred to as "Big Bang Conqueror", MSI's next top-end AMD platform motherboard has emerged under its final name, 990FXA-GD80. The socket AM3+ motherboard that supports AMD's upcoming FX series processors, is based on the AMD 990FX + SB950 chipset. The CPU is powered by a 10-phase VRM that makes use of tantalum-core capacitors, and SFC chokes (that don't whine), driver-MOSFETs (DrMOS). Expansion slots include four PCI-Express 2.0 x16, supporting NVIDIA SLI and AMD CrossFireX; two PCI-E x1, and a PCI.Izvor: techpowerup; mygarage.ro Zadnje izmijenjeno od: bluefluid. 20.05.2011. u 11:37. |
#187 |
Postovi: 7,568
AMD A-Series, FX-Series preliminary pricing revealed - kak je i bilo predviđano; osmerojezgreni Bulldozer ~300$, dok najjači četverojezgreni Llano ide za za manje od 200$. ![]() |
#188 | |
8-bit Gen.
Postovi: 3,158
Zeljeznicki promet na Asusici vec bolje izgleda ![]() |
#191 |
Lokacija: Daruvar
Postovi: 1,744
A kad dolaze 8 modulaši. Ček jel nebi trebo jedan modul imat 1 jezgru sa hardverskim HT-om pa zato se govori da ima 8 jezgri, ali je to ubiti jedna jezgra.
![]() Zadnje izmijenjeno od: McG. 01.09.2011. u 21:41. |
#192 |
Postovi: 7,568
Nema HT-a, jedan modul=dvije jezgre. The Bulldozer chip code-named Zambezi will feature eight x86 processing engines (cores) organized in pairs (called a "module", which is invisible to the OS).Osmerojezgreni Bulldozer modeli su najbolje kaj AMD ima spremno za desktop tržište, dok serverska strana priče raspolaže sa 12 i 16-erojezgrenim Interlagos Opteronima baziranim na Bulldozer arhitekturi. Zadnje izmijenjeno od: McG. 21.05.2011. u 01:52. |
#194 |
Postovi: 7,568
Bilo je govora da budu možda nudili nekaj slično Intelovom HT-u, ali to je bilo prije skoro dvije godine i na kraju je stiglo službeno priopćenje da ništa od toga. ![]() ASRock A75-Extreme6 AMD FM1 Llano APU Ovaj FM1 socket podsjeća na stare 754 ploče.The third-largest motherboard company released the first picture of its upcoming socket FM1 motherboard that supports AMD's upcoming performance A-series accelerated processing units. The ASRock A75 Extreme6 as it's called, is based on AMD's Hudson-D3 A75 single-chip chipset. With the northbridge component completely relocated to the APU die, what's left of the chipset is a little more than a southbridge. The 905-pin socket is significantly different from the 940-odd pin sockets from AMD in recent times, though its cooler retention brackets haven't essentially changed. So most AM3-supportive coolers should fit on FM1.Izvor: techPowerUp ![]() Zadnje izmijenjeno od: McG. 26.05.2011. u 00:39. |
#195 |
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Oduševljen sam s cijenama, ako su istinite bit će prava milina. Ja sam se ionako odavno odredio, za jednog šesterojezgrenog, pogotovo sad kad vidim da mu je cijena ispod dvije milje pa to je čudo. Očekivo sam da će mu cijena bit oko 2500kn, ipak je 6 jezgri u pitanju. Samo je upitnik u cijeloj priči, koliko je zapravo jak procesor u odnosu na konkurenciju iz intela? Pretpostavljam da neće razočarat u vezi performansi, a to je ono najvažnije. |
#196 |
Postovi: 525
Jasno ti je da ce se ti dolari kod nas pretvoriti u eure???taj Zambezi quad bi trebao kostati 1300 kn kod nas a da ne pricam o cijeni six i eight core procesora. Zadnje izmijenjeno od: McG. 01.09.2011. u 21:41. |
#197 | |
Datum registracije: Feb 2004
Postovi: 1,030
Hoće li u FM1 socket ići sljedeća generacija APU-a sa Bulldozer jezgrama? Inače ne vidim potrebu za ovako natrpanom pločom za procesor koji će biti na razini današnjih Athlona II. Citiraj:
#198 | |
Lokacija: Zabok
Postovi: 3,397
Next gen. FM1 procesor će imati 2 BD modula, navodno već za godinu dana. I da, ovo je prva FM1 ploča koja ima više od 4-fazne regulacije. Zadnje izmijenjeno od: stef. 21.05.2011. u 13:18. |
#201 |
Postovi: 1,030
Imaš li neki link za to? Mislim na to da će ići u isti socket? Za Trinity znam što će biti, samo me socket zanima jer ako je tako, onda ovih 10 faza i 3 PCIe na Asrokici imaju nekog smisla. Zadnje izmijenjeno od: cccp. 21.05.2011. u 14:58. |
#202 |
Postovi: 7,568
Da je Intel u pitanju, onda ne bi bilo sumnje o dolasku novog socketa samo godinu dana nakon kaj je predstavljena nova arhitektura, ali AMD ipak ima tendenciju malo duže zadržati socket. Čak i ovaj AM3+ nije ništ radikalno novog, a ipak podržava kompletno novu liniju procesora i još k tome nudi kompatibilnost s aktualnim AM3 modelima. FM1 bi trebal ostati i za nadolazeće Bulldozer APU modele. Zadnje izmijenjeno od: McG. 21.05.2011. u 22:28. |
#203 | |
Postovi: 260
-A gle, poprilično sam siguran da će u performansama bit odličan, vjerojatno za nijansu slabiji od intela, al ništa naročito taman za onoliko za koliko je jeftiniji. Za mene kao kućnog korisnika, koji koristim samo internet i gamerski dio ni ne treba nešto pretjerano jako, niti mi je pretjerano bitno da taj procesor jede malu djecu, već da služi svrsi a kažem poprilično sam siguran da će služit svrsi. I nemam namjeru čekat recenzije, i dojave korisnika kakav je, jer jedan od prvih kupaca kad dođe u hrvatsku ću bit upravo ja. PONOSNI JA. Zadnje izmijenjeno od: McG. 21.05.2011. u 22:45. |
#204 | |
Postovi: 7,568
#207 |
matori
Datum registracije: Feb 2011
Lokacija: ZADAR
Postovi: 168
Pa, ako je ovo curenje iz Asusa koliko toliko realno onda su cijene i vše nego povoljne. AMD FX-8130P – 8 Core, 3.8Ghz, Max T.C 4.2Ghz, 125W (320$)Read more Zadnje izmijenjeno od: McG. 22.05.2011. u 18:11. |
#208 |
Postovi: 7,568
Gigabyte GA-990FXA-UD7 AM3+ ploča
Gigabyte's GA-990FXA-UD7 is one of the more impressive boards we've seen so far, but it's not very likely to be the last new AMD motherboard to show up before Computex which is now barely a week away. It's very clear that this is a UD7 board as the chipset and PWM heatsinks are all carrying the “gold” trim that we first saw on Gigabyte's P67A-UD7. The 990FX chipset itself is located in-between the PWM and the top PCI Express slot, but even so there are no comprises being made in terms of slot count, unlike Asus' TUF Sabertooth 990FX. The board sports an 8+2 PWM design us driver MOSFETs.Izvor: VR-Zone Masovna proizvodnja i slanje partnerima je počelo u travnju, a službeno predstavljanje i prodaja slijede u ovim ljetnim mjesecima, tj. sredina/kraj šestog mjeseca. Zadnje izmijenjeno od: McG. 26.05.2011. u 00:26. |
#210 |
Postovi: 7,568
Intelov 32nm Xeon iz nove E7 serije sa svojih deset jezgri ima TDP od 95W do 130W, dok 32nm šesterojezgreni Core i7-990X ima TDP od 130W pri 3.47GHz i još ima lufta za Turbo mod. Tak da nije nemoguće da AMD za svoje 32nm osmerojezgrene FX modele uspije izvući 3.8GHz + Turbo sa 125W TDP. Sve ovisi kakve tehnologije su implementirali u sam procesor, pa da se potrošnja zadrži u granicama normale i regulira ovisno o opterećenju. Intel to ima jako dobro riješeno i veći dio procesora se "gasi" kad se ne zahtijeva sva snaga koju ima na raspolaganju. Istinabog i 3.0GHz ili malo iznad tog takta bi bilo i više nego dosta za octo-core Bulldozere, ali ako su na neku foru izvukli i više - teško da bude se neko bunil. ![]() |
