Staro 18.04.2011., 19:20   #1
frankycro
frankycro's Avatar
Postovi: 65
Nvidia Forceware v270.61 WHQL driveri
Evo izašli su prvi 270.xx WHQL driveri, osobno ih još nisam instalirao ali ako netko bude neka javi dali sve šljaka ok tj. da sa isplati prelazit sa 266.58.
Download Win7 x64
Download Win7 x86
New in Release 270.61
GPU Support
Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs.
Performance
  • Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers. The following are examples of some of the most significant improvements measured on Windows 7. Results will vary depending on your GPU and system configuration:
GeForce GTX 580:
    • Up to 516% in Dragon Age 2 (SLI 2560x1600 8xAA/16xAF Very High, SSAO on)
    • Up to 326% in Dragon Age 2 (1920x1200 8xAA/16xAF Very High, SSAO on)
    • Up to 11% in Just Cause 2 (1920x1200 8xAA/16xAF, Concrete Jungle)
    • Up to 11% in Just Cause 2 (SLI 2560x1600 8xAA/16xAF, Concrete Jungle)
    • Up to 7% in Civilization V (1920x1200 4xAA/16xAF, Max settings)
    • Up to 6% in Far Cry 2 (SLI 2560x1600 8xAA/16xAF, Max settings)
    • Up to 5% in Civilization V (SLI 1920x1200 8xAA/16xAF, Max settings)
    • Up to 5% in Left 4 Dead 2 (1920x1200 noAA/AF, Outdoor)
    • Up to 5% in Left 4 Dead 2 (SLI 2560x1600 4xAA/16xAF, Outdoor)
    • Up to 4% in H.A.W.X. 2 (SLI 1920x1200 8xAA/16xAF, Max settings)
    • Up to 4% in Mafia 2 (SLI 2560x1600 AA on/16xAF, PhysX = High)
GeForce GTX 560 Ti:
    • Up to 461% in Dragon Age 2 (SLI 1920x1200 8xAA/16xAF, Very High)
    • Up to 241% in Dragon Age 2 (1920x1200 4xAA/16xAF, Very High)
    • Up to 19% in Just Cause 2 (SLI 2560x1600 8xAA/16xAF, Concrete Jungle)
    • Up to 13% in Just Cause 2 (1920x1200 4xAA/16xAF, Concrete Jungle)
    • Up to 5% in Call of Duty: Black Ops (1920x1200 noAA/AF, Jungle Map)
    • Up to 5% in H.A.W.X. 2 (SLI 1920x1200 4xAA/16xAF, Max settings)
    • Up to 4% in Call of Duty: Black Ops (SLI 2560x1600 4xAA/16xAF, Jungle Map)
    • Up to 4% in Civilization V (1920x1200 noAA/AF, Max settings)
    • Up to 4% in Left 4 Dead 2 (SLI 1920x1200 4xAA/16xAF, Outdoor)
    • Up to 4% in Metro 2033 (SLI 1920x1200 4xAA/16xAF, PhysX on)
frankycro je offline   Reply With Quote
Staro 21.04.2011., 09:30   #2
Verbum
Postovi: 682
Je li isprobao netko drivere, ako je bilo bi ljepo da napise nekakve dojmove.
Verbum je offline   Reply With Quote
Staro 21.04.2011., 10:39   #3
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Probao ja s GTX460 768MB no jedino u DA2 gdje se vidi solidan skok. Znači, na 1680x1050, DX11, Very High i sve ostalo uključeno osim AA, average fps je dobio gain od čak 10 te je sad 35 (mjereno Frapsom, 5min gameplay). Naravno, nestali su i artefakti koji su se javljali na tim postavkama.
doky je offline   Reply With Quote
Staro 21.04.2011., 11:20   #4
Antiša
Datum registracije: Dec 2010
Postovi: 147
Neigram DA2, ono što igram trenutno od novih igara su Shift 2, Crysis 2. Sve radi slično kao i prije (tu i tamo koji fps boost). Tako da je ovo zapravo, samo DA2 Hot driver.
Antiša je offline   Reply With Quote
Staro 21.04.2011., 14:34   #5
flyer1
flyer1's Avatar
Lokacija: home
Postovi: 572
Autor frankycro Pregled postova
GPU Support
Performance
GeForce GTX 580:
/cut/
GeForce GTX 560 Ti:
/cut/
ajd bar svi mi koji nemamo karticu 4xx/5xx serije se ne moramo više zamarat s nikakvom revizijom gpu performancea u budućnosti, nego skinit divere sa nevidijinog servera čisto da malo testiramo brzinu downloada
flyer1 je offline   Reply With Quote
Staro 22.04.2011., 22:35   #6
windfucker
A, jbg, u zadnje vrijeme je to tako u oba tabora
Potvrda za gorenavedeni boost u DA2 na 460-ki i 560-tki uz bitno bolju stabilnost (meni su prethodni služb. driveri rušili u DA2 čim bi napravio OC 460-tke preko 800 za GPU, sada nemam taj problem više ).
Staro 23.04.2011., 10:58   #7
Godly
Postovi: 36
stavio sam drivere i mogu reci da mi rade puno bolje od starih drivera. radi daleko bolje i ne rusi se nikako iako sa starim se znao srusit tu i tamo
ne da bas trebam da radi bolje sa mojim kompom sada ali svaki mali + je dobrodošao
takodjer mi i 3d markovi daju malo bolje rezultate
Godly je offline   Reply With Quote
Staro 30.04.2011., 20:38   #8
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,826
Evo, samo da nadopunim, BFBC2 na mojoj GTX 560 radi puuuuno bolje od 266.66, nema više lagova kod kompleksnih scena sa puno eksplozija, sve je nekako fluidnije i općeniti dojam je da su popravili puno stvari koje su bile usko grlo kod starih drajvera. Moja preporuka za instalaciju...
EDIT: Za one koji se pitaju za ovo oko BFBC2, ispadalo je da mi se u kompleksnijim scenama sa puno eksplozija (Arica Rush, scene u drugom dijelu mape sa naseljem, navodim kao primjer), pogotovo kod mortar attacka ili kad netko ispali RPG, pojavljuje lag (ne pad FPS-a!!!) pa se dešavalo da pucam u neprijatelja i ne uspijevam ga nikako pogoditi sa cca 2-3 metra udaljenosti. Sada pada protivnik pokošen kao trava pod Stihl kosilicom .
Zadnje izmijenjeno od: Sinac. 01.05.2011. u 11:16.
Staro 01.05.2011., 10:03   #9
athlon64
Datum registracije: Apr 2011
Postovi: 8
hoce li bit ikakve razlike za gtx285?
athlon64 je offline   Reply With Quote
Staro 02.05.2011., 12:02   #10
Sinac
Sinac's Avatar
Postovi: 2,826
Autor athlon64 Pregled postova
U performansama vjerojatno neko poboljšanje, ništa vrijedno spomena. U pogledu stabilnosti i funkcionalnosti da, tako da svakako preporučam instalaciju novih drajvera.
Staro 04.05.2011., 22:00   #11
Antiša
Postovi: 147
Poboljšanja za stare serije su uvjek nikakva ili minimalna. Novi driveri se uvjek koncetriraju na izvlačenje maksilanih perfomansi iz nove serije kartica i nove arhitekure. Tako da, vjerujem poboljšanja se u 99% slučajeva odnose na GTX 4xx i 5xx seriju.
No u pogledu peglanja bugova i stabilnosti, tu da svakako imaju i na umu i stare serije, jer im je cilj priuštiti drivere bez bugova i problema.
Staro 05.05.2011., 09:35   #12
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
U bfbc2 ovi driveri izazivaju crno bljeskanje ekrana pa treba ostati na 266 seriji.
Staro 05.05.2011., 09:52   #13
Sinac
Sinac's Avatar
Postovi: 2,826
Autor xulos Pregled postova
Gdje točno? Igrao sam jedno 3-4 sata i na GTX 560 niti jedna puknuta tekstura, nebulozan pad FPS-a, lag niti bljeskanje ekrana. Inače, sad sam imao priliku vidjeti kako je tip sa cca 50 metara udaljenosti ispalio RPG prema meni, vidim raketicu kako leti prema meni i još se stignem okrenuti i potrčati a sve bez ikakvih zastoja. Nažalost, bio sam u kući i raketa je zveknula u plafon pa sam ipak morao na respawn . Sa starim drajverima mi se dešavalo da vidim da nešto leti prema meni ali sam imao nekakav lag pa uopće nisam uspjevao okrenuti se i potrčati, eventualno sam uspjevao pomaknuti se u stranu. Namjerno kažem lag jer nije bio pad FPS-a, dešavalo se da u scenama sa puno eksplozija ne uspijevam pogoditi protivnika sa 2, 3 ili 4 metra udaljenosti, pucam u protivnika i vidim da ga ne pogađam, nema one indikacije >< kad nekog pogodiš. Sada više nemam tih problema.
Bljeskanje ekrana ti se pojavljuje odmah na početku mape ili kasnije tijekom igre?
Staro 05.05.2011., 10:10   #14
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
Cijelo vrijeme dok igram, cak ima i topic na nvidia forumu da je do drivera, nisam ni a znao tocno zbog ceg je
Staro 05.05.2011., 10:25   #15
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
nisam to primjetio
DeadMan+ je offline   Reply With Quote
Staro 05.05.2011., 13:18   #16
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
Ocito exipa sa GTX 5xx serijom nema takvih problema , ja sa svojom 460kom sam imao gadnih i sad vratio na stare, ko podmazano
Staro 05.05.2011., 15:44   #17
asibulj
Misanthrope
asibulj's Avatar
Lokacija: Neumünster
Postovi: 571
Meni je isto sa novim driverima BC2 trzala sa GTX470 tako da sam se vratio na 266.58. Doduše ne u vidu ovog bljeskanja kao kod Xulosa.
x230
asibulj je offline   Reply With Quote
Staro 05.05.2011., 18:54   #18
Sinac
Sinac's Avatar
Postovi: 2,826
@ xulos
Daj probaj ručno mijenjati postavke DX u 9, 10 i 11 pa vidi da li problem nestane na određenom DX-u. Sad sam bacio pogled, nemaju svi sa GTX 460 taj problem pa je lako moguće da je neki problem u postavkama BFBC2. Isto tako savjetuju na forumima da se stavi Bloom=False pa vidi da li je to riješilo problem.
Staro 06.05.2011., 19:58   #19
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Meni sve ok radi, isto ko i prošli.
Core2Duo22 je offline   Reply With Quote
Staro 06.05.2011., 22:40   #20
Meni trzne PES 2011 kod animacije kad se zabije gol ili kad se igrači "potuku". i to onako malo zatrzne na 1-2 sekunde i to je to.
Call of Pripyat radi glađe.
Staro 07.05.2011., 11:19   #21
Antiša
Postovi: 147
Meni je sve isto sa ovim driverima. GTX 470 u pitanju. BC2 radi bez problema (MP).
Staro 07.05.2011., 12:00   #22
ARazer
ARazer's Avatar
Datum registracije: Feb 2011
Lokacija: Delnice
Postovi: 21
Ja pred par dana stavio gigabyte gtx 580 i probao i stare i nove drivere,BC2 na novima radi puno bolje ali naravno ima problem, koji puta nakon nekog vremena samo se pojavi bijeli ekran i ne preostaje mi ništa osim restarta, probam DX 10 a tamo cijelo vrijeme blinka bijelo..čitam po forumima da zna bit do drivera kartice, zvučnih drivera, punkbustera..formatirao sam komp i stavio sve na novo i opet isto,jučer sam napravio update punkbustera pa ču danas vidjet..je imao ko sličnih problema? do sada samo imao HD4890 i nikad ništa..s ovom karticom mora letit a meni stvara problem
ARazer je offline   Reply With Quote
Staro 07.05.2011., 12:50   #23
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Autor ARazer Pregled postova
jesi li nanovo reinstalirao sistem ili si samo stavio karticu unutra i instalirao drivere? ako si samo stavio karticu i drivere, onda se kolje sa starim driverima od ATI-a. Ili ocisti sistem od ATI drivera (driversweeper) ili reinstall sustava.
alengrosevic je online   Reply With Quote
Staro 07.05.2011., 12:50   #24
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
GTX 580 na taj atlon!? OMG. Uglavnom obrisi igru i snimi je ponovno.Obrisi drivere i ocisti driver sweeperom.Snimi 266.xx drivere i vidi jel ti se to dogada, opet uninstal i sweep i 270 drivere.I probaj neku drugu igru.
EDIT : alen ti je rekao sec prije mene...
Staro 07.05.2011., 12:57   #25
ARazer
ARazer's Avatar
Lokacija: Delnice
Postovi: 21
Na novo sam instalirao win i sve drivere, znači cijeli format sam napravio..stavio sam sada nove drivere, update punkbustera i na novo igru istalirao, probao sam igrat crysis warhead, nikakvih trzaja nit ništa, sve na entuzijast i 16x AA leti ko podmazano i nakon sat i nešto igre. to mi se dešava samo u BC2
Staro 07.05.2011., 13:18   #26
alengrosevic
Postovi: 3,775
http://forums.steampowered.com/forum...php?p=20459556
koliko vidim, savjetuju instalaciju starijih drivera s kojima radi sve ok...
EDIT: jos rijesenja:
http://www.evga.com/forums/tm.aspx?m=907810&mpage=1
vidi pa javi jel sto pomoglo...
Staro 07.05.2011., 13:26   #27
ARazer
ARazer's Avatar
Lokacija: Delnice
Postovi: 21
čitao i isprobavao sam to već..sada sam igrao 2 runde i ništa..samo sam na novo instalirao igru i punkbuster..vidjet čemo navečer kad budem duže igrao pa javim rezultat..a inače na novim radi puno bolje neg na 266
Staro 07.05.2011., 13:36   #28
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 454
meni je bila slićna stvar
takodjer prijelaz sa 4890 na gtx560
samo bijeli ekran,cujes zvuk ostalo kujac,uglavnom ja sam samo malo dao struje procu i od onda ništa,sada dali ima logike neznam ali meni pomoglo!
takodjer ćista instalacija os-a sa gtxicom!
bc2 sa gtx560 leti naspram 4890 tako da mislim da sa tvojom tek bi bilo ludo!
dart_tom je offline   Reply With Quote
Staro 07.05.2011., 14:14   #29
ARazer
ARazer's Avatar
Lokacija: Delnice
Postovi: 21
hm, ne znam dal ima logike, ja sam jučer vidio da imam instaliran dual core optimizer, kako je došao u komp poima nemam kad je sve na novo stavljeno, izbrisao sam ga naravno sad dal isto ima kakve veze s tim ...za sada je bolje, vidjet čemo nakon malo duže igranja
Staro 07.05.2011., 15:58   #30
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 422
Autor Antiša Pregled postova
Meni s ovim, ali i sa onim prije driverima BFBC2 radi savrseno, GPU load je 99% kad god pogledam (G15 display) i s "bjesnim" grafickim postavkama jos uvijek je FPS visok.
Znam da se prije ekipa sa Fermi karticama zalila na low GPU load u BFBC2, ali ja to stvarno nisam nikada osjetio. Doduse, igram BFBC2 tek od prije nekih 3-4 mjeseca, pa je to mozda bilo prije mog vremena
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
