Staro 30.03.2011., 17:17   #1
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia ForceWare v270.51 beta driveri
GPU Support
Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs.
Performance
Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers. The following are examples of some of the most significant improvements measured on Windows 7. Results will vary depending on your GPU and system configuration:
GeForce GTX 580:
Up to 516% in Dragon Age 2 (SLI 2560x1600 8xAA/16xAF Very High, SSAO on)
Up to 326% in Dragon Age 2 (1920x1200 8xAA/16xAF Very High, SSAO on)
Up to 11% in Just Cause 2 (1920x1200 8xAA/16xAF, Concrete Jungle)
Up to 11% in Just Cause 2 (SLI 2560x1600 8xAA/16xAF, Concrete Jungle)
Up to 7% in Civilization V (1920x1200 4xAA/16xAF, Max settings)
Up to 6% in Far Cry 2 (SLI 2560x1600 8xAA/16xAF, Max settings)
Up to 5% in Civilization V (SLI 1920x1200 8xAA/16xAF, Max settings)
Up to 5% in Left 4 Dead 2 (1920x1200 noAA/AF, Outdoor)
Up to 5% in Left 4 Dead 2 (SLI 2560x1600 4xAA/16xAF, Outdoor)
Up to 4% in H.A.W.X. 2 (SLI 1920x1200 8xAA/16xAF, Max settings)
Up to 4% in Mafia 2 (SLI 2560x1600 AA on/16xAF, PhysX = High)
GeForce GTX 560 Ti:
Up to 461% in Dragon Age 2 (SLI 1920x1200 8xAA/16xAF, Very High)
Up to 241% in Dragon Age 2 (1920x1200 4xAA/16xAF, Very High)
Up to 19% in Just Cause 2 (SLI 2560x1600 8xAA/16xAF, Concrete Jungle)
Up to 13% in Just Cause 2 (1920x1200 4xAA/16xAF, Concrete Jungle)
Up to 5% in Call of Duty: Black Ops (1920x1200 noAA/AF, Jungle Map)
Up to 5% in H.A.W.X. 2 (SLI 1920x1200 4xAA/16xAF, Max settings)
Up to 4% in Call of Duty: Black Ops (SLI 2560x1600 4xAA/16xAF, Jungle Map)
Up to 4% in Civilization V (1920x1200 noAA/AF, Max settings)
Up to 4% in Left 4 Dead 2 (SLI 1920x1200 4xAA/16xAF, Outdoor)
Up to 4% in Metro 2033 (SLI 1920x1200 4xAA/16xAF, PhysX on)
NVIDIA Update
This is a new feature in Release 270 and later drivers. NVIDIA Update keeps your PC up-to-date with the latest NVIDIA drivers by notifying you when a new driver is available and directing you to the driver on www.nvidia.com. When you install a Release 270 or later GeForce driver from www.nvidia.com, you will be presented with the option to install NVIDIA Update. Click here to learn more about NVIDIA Update.
Win7 64bit:
Code:
http://www.nvidia.com/object/win7-winvista-64bit-270.51-beta-driver.html
ostale potražite:
Code:
http://www.nvidia.com/Download/Find.aspx?lang=en-us
Staro 30.03.2011., 22:59   #2
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,307
"I think with this driver the video card is heating up a little. Do you noticed that ? It heats in idle, when i'm browsing "
pripazite
Staro 31.03.2011., 08:38   #3
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 430
pripazite
Meni sa nekih obicno cca. 40'C u idlanju/browsanju sinoc i jutros (nakon instalacije drivera) prijavljuje cca. 45'C tako da bi moglo tu nesto biti.
Malo cudno jer svejedno su frekvencije downclockane, ventilator vrti istom brzinom i load kartice je isti (0-5% loada).
Pod loadoma (igranje) temperature su iste kao i prije.
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 31.03.2011., 09:09   #4
Antiša
Datum registracije: Dec 2010
Postovi: 147
Holy shit
Antiša je offline   Reply With Quote
Staro 31.03.2011., 09:56   #5
geronimo_2
geronimo_2's Avatar
Postovi: 4,307
Autor Antiša Pregled postova
Holy shit
Staro 31.03.2011., 12:31   #6
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Bad company 2 i GTX580 s ovim driverima = crno treperenje slike iako je temperatura oko 70 stupnjeva
Staro 31.03.2011., 12:45   #7
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
To je ionak samo Dragon age 2 performanse driver. Ovo drugo je sve brzveze tak da ako se ne ira Dragon Age 2 nema ni potrebe instalirat ove beta drivere. Rade pricekat oficijalne.
Jutros je vani bilo nesto toplije nego jucer, oko 3,4 stupnja tako da je normalno da u idleu temp bude nesto visa posto idle jako reagira na temperaturu ambijenta. Nema razloga da driver poveca temp u idleu, osim ako ne sje.. 2d klokove ili brzinu venta.
Staro 31.03.2011., 13:05   #8
the.elles.d
Datum registracije: Jul 2010
Postovi: 552
Nema veze to s driverom. Ako stranica ima animirane gifove a browsate FF 4-om, očekujte da ventilator radi na 100% :\
the.elles.d je online   Reply With Quote
Staro 31.03.2011., 14:09   #9
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor the.elles.d Pregled postova
Da, FF4 i njegov tupavi Direct2D radi kojeg kartica stalno mijenja taktove. Kao, ubrzava iscrtavanje stranice, a opet je osjetno sporiji od Chromea. Dobio je odheb sa mog kompa zbog toga.
Staro 31.03.2011., 14:28   #10
geronimo_2
geronimo_2's Avatar
Postovi: 4,307
jel to vrijedi i za v3? v4 ne zelim stavljat. nadam se samo da ce nastavit support/update za v3.
Staro 31.03.2011., 15:17   #11
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
samo da napomenem, meni na 9800gt nema nikakve razlike s prošlim driverima 266.58
temp ista i fps u igrama se nije poboljša, itako su ovo driveri za novije grafičke
Staro 31.03.2011., 19:54   #12
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Isprobao sam Dragon Age 2 i framerate je bolji, ali nije bas 300%, nego vise 20 do 40%. Sad je dx11 v.high sa svim kerefekima i 8xaa sasvim solidno igriv na gtx 580. Prije bas i nije bio.
Staro 31.03.2011., 20:23   #13
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,833
Mislim da će ipak drajveri doživjeti promjene prije nego izađu iz bete. Oni 266.66 su mi sasvim OK...
Staro 09.04.2011., 17:17   #14
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,753
Autor pci_e3x Pregled postova
A kaj bi ti na 4 - 5 godina staroj kartici osjetio ?
Staro 09.04.2011., 20:46   #15
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
