Staro 26.01.2011., 16:53   #1
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
AMD Radeon HD 6990
Here's the Radeon HD 6990 up close. The HD 6990 is AMD's new dual-GPU graphics card that extends the performance leadership held by Radeon HD 5970. The pictures put rest to some speculation surrounding the cooler design. It now appears that the cooler design is similar to that of the GeForce GTX 295 single-PCB, as far as air-flow is concerned. A single long PCB holds two GPU systems on either sides, a centrally-located blower pushes air on either sides. The exhaust from one GPU is sent out of the case, while that from the other is pushed out of the card from its rear portion.
The Radeon HD 6990 uses two 40 nm Cayman GPUs, it packs a total of 3072 stream processors, and 4096 MB of memory between the two GPU systems. It also features a new kind of display output that consists of one dual-link DVI and four mini-DP 1.2. Power is drawn in from one 6-pin and an 8-pin PCIe connector. The card can pair with another of its kind for 4-GPU CrossFireX. It is expected to be released a little later in this quarter.
Izvor : techPowerUp!
fran123456 je offline   Reply With Quote
Staro 26.01.2011., 17:45   #2
Flake
Lokacija: Mostar
Postovi: 203
jedva cekam uporedbe sa hd5970 i gtx580
Flake je offline   Reply With Quote
Staro 26.01.2011., 19:00   #3
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nekako mi je to premalo otvora za cirkulaciju zraka na kućištu hladnjaka, ipak je tu riječ o dvoglavoj beštiji.
C L O W N I N G A R O U N D
Staro 26.01.2011., 19:15   #4
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,559
"This time, AMD is toying with a revolutionary new cooler design that makes use of a cylindrical blower (like ones used in air-curtains, on a much smaller scale) to draw air from the rear portion of the cooler, and circulate through the complex vapor-chamber enhanced heatsink inside. In other words, the card lacks a fan intake hole where it's typically located, but the rear portion serves that purpose."
Izvor : TechPowerUp
Staro 26.01.2011., 19:36   #5
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Autor Flake Pregled postova
Pitanje je samo na kojem ce taktu delat i performanse ce vjerojatno bit izmedu 6950 cf i 6970 cf. Usporedbe sa gtx 580 su nepotrebne jer nisu u istoj ligi. Ak jedna 6970 uspjesno parira jednoj 580, onda nije neka znanost zakljuciti da ce ju dvije rasturit.
Jos samo da dodu igre vrijedne takve zvijercine. Ne znam kaj je u zadnje vrijeme ali vec dost dugo nije izaslo nista posteno..
MAGARAC je online   Reply With Quote
Staro 27.01.2011., 12:05   #6
dzura
bla bla...
dzura's Avatar
Postovi: 244
http://www.youtube.com/watch?v=fwQLAYGRdAs negde na 1.8 objasne sistem...fora, makar mi se ne cini nist revolucionarno.....a kaj se tice kartice, vec mi sline cure 3840 stream procesora,307 gb propusnost...uh, opce neznam kakvu kompu bi trebal slozit da to ima smisla.....
dzura je offline   Reply With Quote
Staro 27.01.2011., 12:20   #7
Momir
Momir's Avatar
Postovi: 1,011
Odakle ti brojka o 3840 SP-a?
Ako jedna HD6970 ima 1536, znaci li da HD6990 moze imati najvise 3072 (2*1536) ili je neki drugi cip u pitanju ili "Cayman" ima jos zakljucanih SP-a
Momir je offline   Reply With Quote
Staro 27.01.2011., 12:54   #8
dzura
bla bla...
dzura's Avatar
Postovi: 244
Staro 27.01.2011., 13:44   #9
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
To su sve stare glasine, još iz vremena kad se nije znalo niti za caymana koliko će imati SP-ova
X
Staro 27.01.2011., 14:38   #10
dzura
bla bla...
dzura's Avatar
Postovi: 244
istina, 3072 bu imal http://www.overclock3d.net/news/gpu_...ils_revealed/1
makar i to je tomuch....sad sa ovih svoji devetsto i nekaj sam i prezadovoljan.....
Staro 27.02.2011., 02:56   #11
hooligan.no1
matori
hooligan.no1's Avatar
Datum registracije: Feb 2011
Lokacija: ZADAR
Postovi: 168
AMD Radeon HD 6990 "Antilles" Sneek Peek
"" It is here in our hands and it screams. "Performance!" The wait is nearly over as AMD's next generation "Antilles" video card sporting two high performance GPUs on a single printed circuit board is in our hands. We comment on our gameplay experiences in Dragon Age II in Triple-Display Eyefinity. ""
hooligan.no1 je offline   Reply With Quote
Staro 27.02.2011., 15:01   #12
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Autor hooligan.no1 Pregled postova
šteta šta nisu stavili neke benchmark rezultate :/
Staro 28.02.2011., 11:23   #13
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Ne očekujem ništa revolucionarno u svakom slučaju. Tko je čitao recenziju vidio je i sam da niti jedna postavka nije bila na max, što zbog činjenice da su vrtili demo igru, što zbog toga jer kartica nije mogla održavati fluidni fps. Istina, 3 monitora su u igri, ali svejedno, kartica takvih specifikacija bi to morala vrtjeti.
Tko zna, možda driveri i poprave štogod, no opet, tko zna-možda su i u šumi
D-I-A-B-L-O je offline   Reply With Quote
Staro 28.02.2011., 12:31   #14
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
March 8 Launch Date for Radeon HD 6990
The consumer graphics industry is about to see yet another round of competition between top market players AMD and NVIDIA in March, with reports suggesting that the red team (AMD) has chosen March 8 as the launch date of its Radeon HD 6990 graphics card. NVIDIA's response, the GeForce GTX 590 is slated for sometime later in March, as well. AMD is said to be finalizing the SKU, and it should be launched by partners on the 8th of next month. The Radeon HD 6990 is a dual-GPU "CrossFire on a stick" solution, in which two AMD Cayman GPUs with 2 GB of memory each, work in tandem.
http://www.techpowerup.com/141260/Ma...n-HD-6990.html
EDIT:
AMD Radeon HD 6990 Press Deck Leaked
In the HD 6990, each Cayman is configured to use all 1536 of its VLIW4 stream processors. The GPU core is clocked at 830 MHz, and memory at 1250 MHz (5.00 GHz GDDR5 effective). The 256-bit wide memory interface of each GPU is populated with 2 GB of memory, setting the total board memory to 4 GB. Display IO includes five connectors, including one DVI and four mini-DisplayPort 1.2. While the HD 6990 is said to outperform GeForce GTX 580, AMD is also bracing itself for NVIDIA's dual-GPU GTX 590, with HD 6990 OC variants following an official specification of 880 MHz core, and the same 5.00 GHz memory.
http://www.techpowerup.com/141317/AM...ck-Leaked.html
Zadnje izmijenjeno od: pci_e3x. 01.03.2011. u 13:41.
Staro 07.03.2011., 15:04   #15
Doink the Clown
Postovi: 6,214
ASUS Radeon HD 6990 Listed on Pre-Order
European retailer salland.eu listed ASUS' upcoming Radeon HD 6990 graphics card on pre-order. It can be pre-ordered for € 715 (about US $1,000). Items put on pre-order can tend to be a little expensive, but € 715 is a staggering price. Even if (the big if) the retailer set its pre-order price a good 20% above the release price, we're looking at a € 572.25 ($ 802) retail price for the ASUS HD 6990, at least in EU.
The listed card carries the SKU EAH6990 3DI4S/4GD5. Specifications listed show that the card carries clocks of 830 MHz core, and 1250 MHz (5000 MHz effective) memory. It packs 4 GB of total memory. AMD's Radeon HD 6990 graphics card is expected to be launched tomorrow.
Staro 07.03.2011., 23:27   #16
Minox
Minox's Avatar
Postovi: 565
jeli se zna mozda kolko je ovo cudo dugacko =) ?
Minox je offline   Reply With Quote
Staro 08.03.2011., 08:29   #17
Antiša
Datum registracije: Dec 2010
Postovi: 147
Od svega mi je najzanimljivije što jedna HD 6970 jednako brza kao i GTX 580 na 2560x1600 u Metro 2033, dok prelaskom na Full HD već gubi dosta.
Očito 500-ak MB više VRAM-a čini osjetnu razliku na većim rezolucijama (što je i očekivano).
Antiša je offline   Reply With Quote
Staro 08.03.2011., 09:01   #18
Garro
Postovi: 2,390
Autor Minox Pregled postova
Otprilike kao i 5970, oko 12 inča, izgleda da je malčice i kraća zbog oblika hladnjaka.
Inače, gledam malo po netu review-ove i jedino što mogu reći je da je kartica precijenjena. A strah me i pomisliti koja će cijena biti u RH kada je MSRP u Americi 700$...
Staro 08.03.2011., 09:40   #19
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
AMD Radeon HD 6990 Graphics Card Review
Staro 08.03.2011., 09:43   #20
Doink the Clown
Postovi: 6,214
Autor Garro Pregled postova
Mene je strah pomisliti kolika će cijena GTX590 biti kad ju izbace
Btw. review Asusice sa techpowerup-a:
http://www.techpowerup.com/reviews/A...HD_6990/1.html
Staro 08.03.2011., 10:04   #21
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
HD6990, HD6970 CF, GTX580 SLI, GTX570 SLI, na više monitora na HardOCP.
cccp je offline   Reply With Quote
Staro 08.03.2011., 10:16   #22
Wolverine
Wolverine's Avatar
Postovi: 12,425
Odabir broj 1 ako želiš
A) zapalit kuću
B) bankrotirat zbog računa za struju
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 08.03.2011., 10:21   #23
Jelc
Super Moderators
Postovi: 17,485
A) zapalit kuću
Ali imaš manji račun za grijanje
Staro 08.03.2011., 10:35   #24
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Pitam se koliko ce kostati neka uber-fensi-mega-kewl verzija...
Staro 08.03.2011., 11:08   #25
Jerry
Jerry's Avatar
Postovi: 1,816
A) zapalit kuću
A GTX580/570 SLI trosi manje?
On topic - jeste li vi vidjeli brojke na rezi 5760x1200 (vs 580/570 SLI)
http://www.hardocp.com/article/2011/..._card_review/1
MONSTRUM... samo mi ta rijec pada na um.
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 08.03.2011., 12:16   #26
Flake
Lokacija: Mostar
Postovi: 203
Autor Jerry Pregled postova
golemo, bas sam to vidio ovdje
Staro 08.03.2011., 15:06   #27
Postovi: 33,996
Staro 08.03.2011., 15:24   #28
Wolverine
Wolverine's Avatar
Postovi: 12,425
A kaj si se sad opet tak napalio? Odi guglat sarkazam.
Ne moraš mi linkat nikakve grafove znam sam iz prve ruke koliko što cucla struje
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 08.03.2011., 16:17   #29
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Znači iz ovih testova koliko sam na netu vidio nvidia mora da bi mogla parirat AMD-u napravit GTX590 sa dvije GTX570, a ako želi preuzet titulu onda dvije GTX580.
Staro 08.03.2011., 17:34   #30
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
lako je tako bit pametan
1. Nervira me što crossfire nediše kako spada u 90% naslova( koji se povlače po testovima)
2. Ipak ju neću kupiti
3. Možda Jelc kupi (opet) za soma u nekoj našoj trgovini pa ćemo ju vidjeti i na forumu
