Staro 14.12.2010., 18:18   #61
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Eh što marketing radi ...
Ta napajanja i nisu baš na tragu svoje prethodne braće koja su bila itekako cijenjena prije nekoliko godina.
The Secret ...
Staro 27.12.2010., 15:31   #62
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Staro 29.12.2010., 00:25   #63
SetH
SetH's Avatar
Lokacija: ZG/Borongaj
Postovi: 3,324
ali neeeee! to su napajanja samo za Gejmere
SetH je offline   Reply With Quote
Staro 29.12.2010., 06:12   #64
Postovi: 33,944
Kao i Corsevi GS šrotovi.
Staro 29.12.2010., 15:19   #65
extacod
extacod's Avatar
Lokacija: Milkywhey
Postovi: 202
plizz delete
Zadnje izmijenjeno od: extacod. 29.12.2010. u 15:29.
extacod je offline   Reply With Quote
Staro 08.01.2011., 20:43   #66
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nikad čuo za ovaj Huntkey iako je navedeno da se radi o poznatijem brandu i još se tu nekim 80+ platinum certifikatom qrče
Može kratak osvrt kolega dh41400, good or no good?
Huntkey Enterprise Group announces that Huntkey 500W rated power supply has been certified by 80PLUS PLATINUM, which stands for that Huntkey 80PLUS line-up products finished from standard 80PLUS certification to the highest level of 80PLUS certification -- PLATINUM.
80PLUS certification has been well-known by most of end-users. On October 2009, 80PLUS organization had added specification for Platinum efficiency level as its highest level for efficiency. For the higher certification levels, the requirement of 0.9 or better power factor was extended to apply to 20% and 50% load levels, as well as at 100% load. The Platinum level requires 0.95 or better power factor for servers.
This is another good news from Huntkey, after it released 300W and 1200W 80PLUS Gold certified power supplies in succession. "We are in pursuit of finding the best solution for end-users not only for electric bills saving, but also for environmental protection. Huntkey 500W 80PLUS PLATINUM certified power supply is a new step for this goal," Huntkey global product manager Villa Li said.
This is Huntkey first time to work together with Infineon's experts. The final plan successfully get through the strict 80PLUS PLATINUM certification, with efficiency up to 90.63%, 92.62%, 90.31% at separately 20%, 50% and 100% load condition. "This is our first time to cooperation with Infineon's experts. However it is an impressive and nice cooperation. Their focus on professional field is admirable. We want to show our greatly appreciation for them," A Huntkey spokesman said.
http://www.techpowerup.com/137996/Hu...ification.html
C L O W N I N G A R O U N D
Staro 08.01.2011., 21:19   #67
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
kako bilo da bilo,napajanje sa platinum certifikatom koje ce kostat 150$ a da nema omotane kablove ?!
fail
siloman je offline   Reply With Quote
Staro 08.01.2011., 21:23   #68
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
LC Power je dobrim dijelom imao u ponudi Huntkey platforme, npr.
OEM: Huntkey
Super Silent LC6350 ~15A
Super Silent LC6420 ~20A
Super Silent LC6550 ~24A
Super Silent LC6550 V2.2 ~NG
Super Silent LC6600 V2.2 ~29A
Silent Giant LC6420G ~NG
Silent Giant LC6420GP ~NG
Silent Giant LC6420GP V2.0 ~28A
Silent Giant LC6550G ~NG
Silent Giant LC6550GP ~31A
Crown LC6550C ~19A
Titan LC6560T ~NG
Green Power LC6600GP2 V2.3 ~36A
U zadnje vrijeme se Huntkey poprilično "razbahatio" pa grize iz dana u dan na sve veći dio tržišta ... koliko vidim, trebalo bi biti uspješno, a jedina presudna stavka će biti cijena.
Inače, napajanja sa visokom efikasnošću ne moraju automatski značiti i da su kvalitetna, jer je to samo jedan od brojnih kategorija u ocjenjivanju napajanja.
Trebalo bi pričekati prve testove prije nego što se da preporuka, ali koliko sam čuo, zasad im ide vrlo solidno na preliminarnim testovima.
Autor siloman Pregled postova
fail
Ovo su preliminarni testovi i ustvari ta napajanja još nisu u prodaji ... vjerojatno će ih malo ušminkat prije puštanja u opticaj
Staro 08.01.2011., 21:47   #69
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
vec su ih malo usminkali pa su mogli malo buzira stavit
vjerovatno vrhunsko napajanje koje kao i puno drugih nece biti dobavljivo u nasoj ljepoj RH
Staro 17.01.2011., 09:09   #70
Doink the Clown
Postovi: 6,214
FSP Group Unveils Aurum Series 80Plus Gold Certified PSUs
FSP Group, a channel brand distributor of reputed PC and server power supply manufacturer Fortron, unveiled its latest line of high-efficiency PSUs for PC enthusiasts. Named FSP Aurum (Latin for Gold), the PSUs are 80Plus Gold certified, with over 90 percent efficiency at all times. The first wave of Aurum series will consist of 400W, 500W, 600W, and 700W models. The PSUs use granite-touch casing which is starting to get common with high-end PSUs from manufacturers such as Enermax, Cougar, Cooler Master, etc.
The 400W and 500W models feature a double "Hybrid Synergy" 12V rail design, while the 600W and 700W ones feature a quad-rail design. A "Multiple Intelligence Ability" (MIA) chip keeps control over various performance and protection functions. The PSUs use high-grade Japanese capacitors to contribute to the efficiency. The PSUs are ATX12V v2.3 & EPS12V v2.92 compliant. A 120 mm fluid dynamic bearing fan keeps the units cool. The PSUs will be backed by a 5-year warranty. The FSP Aurum series will be officially released at the upcoming CeBIT event in early March.
http://www.techpowerup.com/138606/FS...fied-PSUs.html
Staro 06.03.2011., 18:35   #71
Doink the Clown
Postovi: 6,214
Staro 29.03.2011., 22:36   #72
Doink the Clown
Postovi: 6,214
Cooler Master Announces GX Series 450W Power Supply
In a continuous effort to provide a wide array of power supplies that integrate high-grade features into a value-aware package, Cooler Master’s GX Series unveils its GX450W powersupply. Casual users and budget gamers alike will enjoy the quality construction and extensive features that make the GX Power Supply Series reliable, efficient, and cost-effective.
Uncompromising Quality
The hallmark of the GX Series of power supplies is that they feature a single, highly robust 12V rail that efficiently and consistently delivers clean power to all of your critical components such as your processor, drives, RAM, motherboard, and graphics cards.
An included double-layer EMI filter, intelligent 120mm controllable fan, and an active PFC/PWM combo controller all contribute to the overall efficiency of the power supply. All of the many features found within the GX Series contribute to its 80 Plus Certification. This efficiency allows the power supply to utilize most of the power it takes in with minimal waste, saving your electric bill. It makes the GX450W a perfect addition to a home theater PC or mid-range computer setup.
The GX Series carries a MSRP of $49.99 and will be available on March 29th.
For more information, visit the product page.
http://www.techpowerup.com/143157/Co...er-Supply.html
Staro 04.07.2011., 19:49   #73
Doink the Clown
Postovi: 6,214
Corsair Professional Series HX1050
Staro 02.04.2012., 19:36   #74
Doink the Clown
Postovi: 6,214
Scythe Unveils Gouriki Mid-Range PSUs
Scythe Japan unveiled its Gouriki mid-range PSU series. Consisting of 500W (SPGRN-500), 600W (SPGRN-600), and 700W (SPGRN-700) models, the series consists of 80 Plus Bronze-certified PSUs with fixed-cabling. The cables are not sleeved, and the PSU's body doesn't have any paint. It appears, however, that Scythe tried to spin this to its advantage, by referring to it as a design element it calls "Naked Herculean Strength" (not a case of bad-translation, it's literally what Scythe prints on its PSUs).
All three models feature a single 12V rail design, and a compliance/feature-set that includes ATX12 Ver2.3/EPS 12V, OCP, OVP, OTP, SCP, and UVP. A 120 mm fan is employed to cool the units. PCI-Express power connectors include 6+2-pin and 6-pin power connectors for all models. The power connector loadouts of the three models differ only with the numbers of SATA and Molex connectors available. The 500W (SPGRN-500), 600W (SPGRN-600), and 700W (SPGRN-700) models are priced at 5,980, 6,980, 7,980 JPY, respectively (US $72, $84, $96, respectively).
http://www.techpowerup.com/163434/Sc...ange-PSUs.html
