Staro 16.02.2011., 18:22   #331
Facelessone
Facelessone's Avatar
Postovi: 4,204
r_ShaderCompilerServer=127.0.0.1;127.0.0.1
r_ShadersRemoteCompiler=0
r_displayInfo=0 - da ne pokazuje one naporne informacije
A za MP preko LAN-a.
g_enableInitialLoginScreen = 0 ; disable login screen at game startup
g_gamespy_loginUI = 0 ; disable multiplayer login screen
net_lanbrowser = 1 ; find LAN (local) matches instead of internet matches in multiplayer serverbrowser
net_initLobbyServiceToLan = 1 ; make LAN (local) lobbies instead of internet lobbies in multiplayer
dodati u system.cfg
Daj baci tu to kaj si našo u spoiler, da se nađe
Probaj dodat sve iz toga u system.cfg u game folderu.
S ovim bi se igra manje trebala rušit
dodati u system.cfg
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 16.02.2011., 18:25   #332
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
; crysis2
sys_game_folder=GameCrysis2
sys_dll_game=CryGameCrysis2.dll
sys_user_folder=Crysis2
sys_spec_Full=4
Change resolution r_width= example 1280,800,1600,1680
r_height=example 720,1024,1050,1080
Activate SLI or CF r_MultiGPU=[1,2] 0=SINGLE CARD
r_MultiGPU=0
r_driver=DX11
r_width=1680
r_height=1050
q_quality=3
q_ShaderGeneral=3
q_ShaderMetal=3
q_ShaderGlass=3
q_ShaderVegetation=3
q_ShaderIce=3
q_ShaderTerrain=3
q_ShaderShadow=3
q_ShaderWater=3
q_ShaderFx=3
q_ShaderPostProcess=3
q_ShaderHDR=3
q_ShaderSky=3
q_Renderer=3
log_IncludeTime=1
Change language
sys_languages="english"
Turn on\off FPS on=1 off=0
r_displayInfo=0
!!!Attention!!!
This version of the game does not support full DX11, but with this configuration the game will use some of DX11 and all the settings are in very high instead of just hight. Making the game even more beautiful.
Evo izvoli,ne znam idem probati pa ako vidim pomake javim.
Hocemo negdje oko 10 probati zaigrati malo?
; crysis2
sys_spec_Full=4
r_MultiGPU=0
r_driver=DX11
r_width=1680
r_height=1050
q_quality=3
q_ShaderGeneral=3
q_ShaderMetal=3
q_ShaderGlass=3
q_ShaderIce=3
q_ShaderTerrain=3
q_ShaderShadow=3
q_ShaderWater=3
q_ShaderFx=3
q_ShaderHDR=3
q_ShaderSky=3
q_Renderer=3
log_IncludeTime=1
Change language
r_displayInfo=0
!!!Attention!!!
Zadnje izmijenjeno od: blava. 16.02.2011. u 18:34.
Staro 16.02.2011., 18:40   #333
Facelessone
Postovi: 4,204
Neznam ako ću biti doma. Može se preko Tunnglea-a igrati. Potraži malo :P Kolko sam dosada našao ima dosta servera
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 16.02.2011., 21:40   #334
Minox
Minox's Avatar
Postovi: 565
; crysis2
sys_spec_Full=4
r_MultiGPU=0
r_driver=DX11
r_width=1680
r_height=1050
q_quality=3
q_ShaderGeneral=3
q_ShaderMetal=3
q_ShaderGlass=3
q_ShaderIce=3
q_ShaderTerrain=3
q_ShaderShadow=3
q_ShaderWater=3
q_ShaderFx=3
q_ShaderHDR=3
q_ShaderSky=3
q_Renderer=3
log_IncludeTime=1
Change language
r_displayInfo=0
!!!Attention!!!
u koji se cfg ovo dodaje ?
Autor blava Pregled postova
; crysis2
sys_spec_Full=4
r_MultiGPU=0
r_driver=DX11
r_width=1680
r_height=1050
q_quality=3
q_ShaderGeneral=3
q_ShaderMetal=3
q_ShaderGlass=3
q_ShaderIce=3
q_ShaderTerrain=3
q_ShaderShadow=3
q_ShaderWater=3
q_ShaderFx=3
q_ShaderHDR=3
q_ShaderSky=3
q_Renderer=3
log_IncludeTime=1
Change language
r_displayInfo=0
!!!Attention!!!
Minox je offline   Reply With Quote
Staro 16.02.2011., 22:40   #335
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
U system.cfg, on ti se nalazi Crysis 2 folderu gdje je igra, otvori sa notepadom i samo zamjeni podatke, prije toga si napravi kopiju system.cfg ako nesto zafrknes da radi.
Blava, Face, Crysis 2 onlajn?
Ako je BETA u DX9 i moze se prebaciti u DX11, moze li se onda prebaciti u DX 10?
r_driver=DX11
da stavim r_driver=DX10? Oće'l upalit?
NovA Squadron
kripton je offline   Reply With Quote
Staro 17.02.2011., 01:31   #336
Minox
Minox's Avatar
Postovi: 565
malo sam odigrao betu , i ovi cfg setingsi sljakaju , igra se ne rusi tako kao prije , samo neke dump filove louda svako malo , tj ima neke errore nekuzim kaje to
bdw ide mi oko 55-60 fpsa iako se cini da je puno više radi motion blura , na otvorenom neide ispod 50 ,grafika je mrak iako se radi od djelomičnom dx 10 na medium setingsima ,bojim se pomislit kak bu na very high @ dx11 ufff ..
Staro 17.02.2011., 14:48   #337
kripton
Cars & Tunning
kripton's Avatar
Postovi: 536
Gamer - DX9
Advanced - DX 10
Hardcore - DX11?
Wot? Ja sam mislio da su sve postavke na dx 9.
NovA Squadron
Staro 18.02.2011., 15:48   #338
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Tek sam sad uhvatio malo vremena da catch-upam na novostima oko igri nakon ispita na faksu i smjeni na poslu za koje sam se mjenjao da sam imao filing da sam više na poslu nego doma.
Znači igra se već igra (takva kakva je). Trenutno nabavljam, makar me SP ne zanima nešto previše, no odigrat ću ga.
Gledam MP po youtubu i čini se OK, zapravo, i više nego OK. Kažu da je za MP bio zadužen totalno drugi tim ljudi i da su ga razvijali paralelno sa igrom, dakle da nije samo ubačen tu tek toliko da ga ima. Ukoliko u ovoj beti MP bude zadovoljio, sigurno ću kupiti original.
blaa
Staro 18.02.2011., 18:30   #339
Danko86
Danko86's Avatar
Datum registracije: Jul 2009
Postovi: 600
cek je se može sejvat u ovoj beta verziji?
probat cu jos jednom (prvi put sam se iznerviro i pobriso sve pa sad ponovo skidam pa ako bude okej cu kupovat oriđiđi..
dankojunasevic.tk
Danko86 je offline   Reply With Quote
Staro 18.02.2011., 23:40   #340
hammer_of_thor
Postovi: 5,430
Odigrao sam malo MP, koji definitivno ima potencijala.
Nije nimalo loš.
blaa
Staro 19.02.2011., 02:49   #341
Danko86
Danko86's Avatar
Postovi: 600
oke skino ga napokon. je iamte kakve informacije kako sta i di upisat ili kakav crack da radi sto stabilnije, sto bolje.
thanks in advance
edit: dodje do prvog cutscena u drugoj misiji i tu zablesira nemilo. svaku put. i 32 bitna i 64 bitna verzija. ima ko kakav lijek?
dankojunasevic.tk
Zadnje izmijenjeno od: Danko86. 19.02.2011. u 03:24.
Staro 19.02.2011., 08:59   #342
thesekiman
Pr0d1gy
thesekiman's Avatar
Postovi: 288
Autor Danko86 Pregled postova
u folderu od crysisa imas jos jedan folder GameCrysis2 i u njemu ces naci fajl videos.pak, taj fajl premjesti u neki drugi folder i onda bi ti trebalo raditi.
thesekiman je offline   Reply With Quote
Staro 19.02.2011., 12:01   #343
Danko86
Danko86's Avatar
Postovi: 600
doso sam do trece misije i uvijek kad mi neko dojavljuje ono ingame neke objective zasteka. ma najbolje se ne trudit nego se strpit mjesec dana i uživat.
dankojunasevic.tk
Staro 19.02.2011., 13:00   #344
hammer_of_thor
Postovi: 5,430
Nalupao sinoć u MP-u do 7. lvl-a, mislio da će ostati sačuvano nakon gašenja igre.
How wrong was I?
Mislim da ću uzeti original, MP je stvarno zabavan.
blaa
Staro 19.02.2011., 14:44   #345
jurbAs
jurbAs's Avatar
Postovi: 2,583
Autor thesekiman Pregled postova
de malo bolje to objasni di se to treba preselit?! taj video.pak jer koliko vidim to me najvise zeza
I vidim da imam problema nakon sto zaginem stisnem load last save i krepa igra ima li za to ljeka?
Staro 19.02.2011., 16:43   #346
Danko86
Danko86's Avatar
Postovi: 600
ma nije to cutscene sto mene muci. nego ono ingame kad primas objective od nekog lika. konkretno je sad u trecoj misiji nakon sto ubijes onog prvog aliena kad si upalis onu infrared kameru.. pa kad ga ubijes nakon tog dobivas objective i oscrta se na ekranu neki k**** i onaj tvoj ti nesto objasnjava. e tu se meni zaledi svaku put.
tako da mislim da to nema veze sa cutscenovima..
a tako bi ju igro jer mi se cini dosta okej
dankojunasevic.tk
Staro 20.02.2011., 16:57   #347
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Meni ovo čudo ide jako dobro, nikakvih problema, danas igram cijeli dan i nije se nijednom smrznulo. Baš sam gledao, na hardcore max memory usage mi je bilo 540 mb. Bit će da su ovo stvarno tek neki medium detalji
Staro 20.02.2011., 17:23   #348
hammer_of_thor
Postovi: 5,430
Igram na 1920x1080, advanced detalji i ne pada ispod 50 FPSa
Prosjek je 65.
Na hardcore je prosjek oko 35 ali nekako imam feeling da ima laga na tim detaljima. Jednostavno neide tako fluidno kao na advanced.
Makar sam tek odigrao 2 misije, i to napreskokce, pošto su sve misije otključane i može se birati level. Neda mi se sad igrati da pratim priču, to ću raditi kad izađe full verzija.
Igram MP, igrača ima, lako se nađe server, samo neznam dali je moguće, ali kao da već ima pokoji cheater, neki killcamovi su vrlo sumnjivi.
blaa
Staro 20.02.2011., 17:58   #349
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Kod mene je igra lockana na 63 fps pa me zanima kako si uspio maknut vsync.
MAGARAC je online   Reply With Quote
Staro 20.02.2011., 18:09   #350
hammer_of_thor
Postovi: 5,430
Tipfeler^^ 55 FPS-a
Moj bed
blaa
Staro 20.02.2011., 20:10   #351
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Meni se svaki put poniste oni bodovi za upgrade...ima neko rjesenje za to?
Drift_King je offline   Reply With Quote
Staro 20.02.2011., 20:40   #352
hammer_of_thor
Postovi: 5,430
Kažu da je ovo riješenje za sejvanje levela odnosno statsa u MP-u:
After you finished an MP match switch to single player mode and then quit the game. That does help to keep your stats saved
Baš ću probati.
blaa
Staro 21.02.2011., 16:46   #353
Minox
Minox's Avatar
Postovi: 565
Autor MAGARAC Pregled postova
na kojim postavkama ti je 63 ,jel HC ?
Staro 21.02.2011., 16:56   #354
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Da HC I ide super. Samo u jednoj situaciji sam vidio 48fps a veciNu vremena je na 63. Primjetio sam da gtx 580 radi punom parom jer je u ovoj igri par c toplija nego obicno. Mislim da ni dx11 nece bit problem a nebi se iznenadio da ide i bolje.
Staro 21.02.2011., 18:48   #355
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Napravio preorder ovu trenutnu verziju neću ni probati.
Eto tako puklo mi u glavu i uzet ću Idem sada prelaziti warhead
Michel je offline   Reply With Quote
Staro 21.02.2011., 22:42   #356
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Ja si isto uzeo preorder, mislim da je igra fakat vrijedna tih sto i neš kuna koliko me došao cdkey.
doky je offline   Reply With Quote
Staro 22.02.2011., 09:02   #357
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Autor Anphonic Pregled postova
Ja sam uzeo preko gamecouk retail kutiju preko 250 kn ali me nije briga.
Želim je imat s kutijom.
Staro 22.02.2011., 17:15   #358
bruno_x
bruno_x's Avatar
Lokacija: split
Postovi: 240
igra je odlicno napravljena!
ja zavrsio misije
igrano u xp-u samo jedan put blokalo
Zadnje izmijenjeno od: bruno_x. 22.02.2011. u 22:52.
bruno_x je offline   Reply With Quote
Staro 22.02.2011., 17:29   #359
Danko86
Danko86's Avatar
Postovi: 600
grozno mi je dosadno i igra mi se ovo ful al nemogu nikako proc taj dio na trecoj misiji kad mi zablokira. odmah nakon onog kad pokupim alienski tissue. pa dobijem dojavu i uvijek na tom mjestu blok
dragi teen sta da radim?
dankojunasevic.tk
Staro 22.02.2011., 22:22   #360
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Probaj sa restartom levela ili promjene grafickih preformansi...ne pitaj nista, nemam pojma zasto ali meni je na Hardcore svaka misija blokala, a na Gamer sam prosao bez problema :O
