Staro 17.01.2011., 18:13   #31
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Autor Milentije Pregled postova
Titanium is back? Fino zvuči, ako ništa drugo.
Budi stare uspomene.. MSI 4200 TI 64 mb
Na to i igraju...
Staro 17.01.2011., 19:35   #32
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Necemo vise, otisli smo u OT.
Milentije je online   Reply With Quote
Staro 19.01.2011., 15:56   #33
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
MSI GeForce GTX 560 Ti Twin Frozr II caught on camera
A German store made a booboo and published MSI's GeForce GTX 560 Ti Twin Frozr II on its website. This new card features the Twin Frozr II cooling solution with two 80mm fans, 8mm heatpipes and a large aluminium fin array. The core is overclocked to 880MHz (820MHz stock) and the 1GB GDDR5 has a 4200MHz frequency (4000MHz stock).
The expected launch date is January 25th.
Izvor: guru3d
Staro 20.01.2011., 15:42   #34
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Gigabyte GTX 560 Ti Super Overclock Graphics Card Detailed
Gigabyte is ready with a Super Overclock (SOC) variant of its upcoming GeForce GTX 560Ti graphics card, already. The GV-N560SO-1GI clocks at an impressive 1000 MHz core (vs. 822 MHz reference), and 1145 MHz (actual) or 4580 MHz (effective GDDR5) memory speed, with a CUDA core clock speed of 2000 MHz. Apart from these, the card features 384 CUDA cores, and 1 GB of memory over a 256-bit wide GDDR5 memory interface.
The GV-N560SO-1GI uses Gigabyte's Ultra Durable VGA+ PCB, which is rich in copper and uses top-grade components. It is cooled by a larger version of WindForce 2X, which the company earlier used on older high-end GPUs. Gigabyte also run its own performance tests on the card. The card yielded X11515 points in 3DMark Vantage Extreme preset, and P24590 in Performance preset. The card is said to be at least made public, if not released to market, on the 25th of this month.
GeForce GTX 560 Ti Reference Board Pictured
Here are the first pictures of an NVIDIA reference design GeForce GTX 560 Ti graphics card. The pictures reveal quite a bit about the PCB layout and the cooling assembly. To begin with, the card is longer than the GTX 460, and uses a more refined cooler. The GF114 GPU uses a rectangular package, much like the GF104. The eight GDDR5 memory chips lie adjacent to the GPU. Powersupply consists of 4-phase GPU, single-phase memory, and is drawn in by two 6-pin PCI-E power connectors. SLI is restricted to 2-way, and display outputs include two DVI and one mini-HDMI. Although the PCB is green, one can expect it to come in various colors depending on the partners' specifications.
The cooling assembly, as mentioned earlier, is much more refined compared to the previous generation. The GTX 460 cooler was not much more than a GPU heatsink with radially-projecting aluminum fins, covered by shroud. With the GTX 560 Ti, NVIDIA used a base-plate unisink, which collects heat from other components such as the memory and VRM, and conveys it to the GPU heatsink, which is much more elaborate, and uses 8 mm thick copper heatpipes to spread heat across a much larger heatsink. The design of this heatsink seems to be inspired from MSI's Cyclone cooler. Don't mind the flowery-green "sticker" that's Photoshop'd to the shroud, it's not part of the reference design. That's where partners can either demonstrate their creativity, or show off their anime fantasies.
http://www.techpowerup.com/
C L O W N I N G A R O U N D
Staro 20.01.2011., 16:37   #35
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Graficke su postale modni detalj,nema veze sto stoje zatvorene u kucistu i sto se ne vide, moraju lijepo izgledat a manje funkcionalno
NovA Squadron
kripton je offline   Reply With Quote
Staro 24.01.2011., 13:31   #36
Doink the Clown
Postovi: 6,214
Galaxy GeForce GTX 560 Ti Graphics Cards Pictured
Galaxy's first wave of graphics cards featuring NVIDIA GeForce GTX 560 Ti graphics processor includes at least two non-reference designs. The first one, the GC Version, makes use of Galaxy's publicized "Gemini" GPU cooler, which uses two large 90 mm fans to cool a large aluminum heatsink which is fed by four copper heat pipes. The GC Gemini features slightly upped clock speeds of 835/1670/1000 MHz (core/CUDA core/memory actual).
The second card is the Galaxy GTX 560 Ti White Edition, which features a white PCB, possible digital PWM circuitry, a full-coverage single fan cooling assembly, and high overclock speeds of 950 MHz core, and 1100 MHz memory. Both cards feature Galaxy's typical spacecraft-styled cooler shrouds, connectivity that includes two DVI and a mini-HDMI. While the GC Version draws power from two 6-pin connectors, the White Edition requires 6-pin plus 8-pin. Based on the 40 nm GF114 GPU, GeForce GTX 560 Ti features second-generation Fermi architecture, and is powered by 384 CUDA cores, and aided by 1 GB of GDDR5 memory over a 256-bit wide memory interface. The GTX 560 Ti is slated for release on the 25th of this month.
http://www.techpowerup.com/139040/Ga...-Pictured.html
Staro 24.01.2011., 14:34   #37
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Regulacija napona?
Staro 24.01.2011., 18:01   #38
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
kad bi trebale izaci van sutra?joj ak budu oko 1700-1800 kn taman...
hobitxxx je offline   Reply With Quote
Staro 25.01.2011., 11:19   #39
Astral
Postovi: 2,523
nista od review-a?
Astral je offline   Reply With Quote
Staro 25.01.2011., 11:42   #40
hobitxxx
hobitxxx's Avatar
Postovi: 412
trazim po netu ali nemrem najti nikaj konkretnoga ....da ju nije mozda nvidija odgodil?
Staro 25.01.2011., 11:49   #41
Ivan123
Postovi: 191
Ivan123 je offline   Reply With Quote
Staro 25.01.2011., 12:13   #42
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Ovaj score od 5135 u 3d11 sa naklokanom 560 mi se cini los..
Mislim da to nebu jace od 6950 a mozda ce bit jace od gtx 470 jer dela na 820mhz.
Zadnje izmijenjeno od: MAGARAC. 25.01.2011. u 12:20.
Staro 25.01.2011., 13:55   #43
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Koliko GTX 460 1GB s nekim quadom dobiva, oko 3500? Meni se čini ok, samo da cijena stvarno ne bude toliko koliku ju misle staviti.
Matth€w je offline   Reply With Quote
Staro 25.01.2011., 14:52   #44
generic
generic's Avatar
Postovi: 1,079
Autor hobitxxx Pregled postova
Results removed due to some changes in NDA date which I wasn't informed.
Sorry guys, everything gotta go.
Bude valjda brzo.
Izvor
edit:
Komentari su dobri:
beat a gtx570 OCed edition. hehehe... O.O
- pri 1070MHz core / 1200MHz mem
the OC vantage result is nearly the same as my GTX460 SLI with 800/1600/4000.....
Staro 25.01.2011., 15:17   #45
Verbum
Postovi: 682
Autor Matth€w Pregled postova
creativo91 - P4451, ORB | MSI GTX460 Hawk Talon Attack @ 970/1940/1100 MHz, zrak | i5 750 @ 4.20GHz, zrak | ASUS P7P55D |
Slažem se sa Magarcem, ovaj rezultat u 3DMark11 i nije baš nešto obećavajući.
Verbum je offline   Reply With Quote
Staro 25.01.2011., 15:45   #46
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
http://www.hardwarecanucks.com/forum...gb-review.html
Meni 5100 bodova nije nesto za overklokiranu graficku jer je usporedujem sa svojom 470 koja ide preko 5900 bodova. Usporedujem sa 470 jer mislim da ce bit slicna cijenom i nesto brza zbog visokih klokova, sto moze i gtx 460.
"7% faster than GTX470, 5% slower than 6950 1GB."
btw. svaka cast Creativo, konacno da je netko pokazao Hawkicu na pristojnim taktovima
Zadnje izmijenjeno od: MAGARAC. 25.01.2011. u 23:12.
Staro 25.01.2011., 16:08   #47
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
DeadMan+ je offline   Reply With Quote
Staro 25.01.2011., 16:48   #48
Astral
Postovi: 2,523
jel ima negdje di se usporeduje gtx 460 1gb na istim clockovima ko gtx 560 1gb?
Staro 25.01.2011., 16:49   #49
Jerry
Jerry's Avatar
Postovi: 1,816
Giga GTX560 SoC 1G trosi kao jedna GTX480... ili 100W vise od 6950 2GB.... ili vise nego 2x6850 u CFX!
Mislim grafa ide ali sto je previse - previse je!
http://www.tweaktown.com/reviews/379...d/index18.html
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 25.01.2011., 17:56   #50
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Techpowerup
Ionako je to furmark... Vjerovatno ati udara protekciju koju imaju od 5870...
Radje pogledajmo rezultat u 3d marku gdje nema ograničenja, powertunea (nove ati) i slične gadarije...
40-tak wati više... ništ strašno...
Referentna je jako tiha... ajlajkit...
Zadnje izmijenjeno od: Alfa_R. 25.01.2011. u 18:06.
Staro 25.01.2011., 18:05   #51
Jerry
Jerry's Avatar
Postovi: 1,816
Autor Alfa_R Pregled postova
Techpowerup
Ajd prvo PROCITAJ u cemu je benchano pri mjerenju potrosnje pa onda napisi neki komentar....
Staro 25.01.2011., 18:45   #52
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Autor Jerry Pregled postova
Mislio sam na techpower up i veću razliku koja se odnosi na furmark.
Maximum: Furmark Stability Test at 1280x1024, 0xAA. This results in a very high non-game power consumption that can typically be reached only with stress testing applications. Card left running stress test until power draw converged to a stable value.
Oni u 3d marku imaju potrošnju 147:109 560:6850 (samo 38W) i 147:128 (samo 19W) 560:5950 kao peak.
Anandtech dobiva u krizi razliku od 61 i 22W naprema 6850 i 6950...
Tak oda o nekakvoj ogromnoj potrošnji nema govora...
Sad, možda to mjesto o kojemu oni pišu lupa u atijev limiter pa zato ili su oni nešto zeznuli.... (osim što si izabrao OC vs ref za uspotredbu za tih 100W)
Po meni izgleda da je ta kartica zvijer.. tiha, jaka.... Dobar izbor umjesto turbine 470...
Zadnje izmijenjeno od: Alfa_R. 25.01.2011. u 18:59.
Staro 25.01.2011., 19:35   #53
Doink the Clown
Postovi: 6,214
Zadnje izmijenjeno od: Doink the Clown. 25.01.2011. u 20:34.
Staro 25.01.2011., 22:29   #54
NinX
NinX's Avatar
Datum registracije: Jan 2010
Lokacija: Lyon/Zagreb
Postovi: 296
NinX je offline   Reply With Quote
Staro 25.01.2011., 23:25   #55
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Gigabyte GeForce GTX 560 Ti SOC review
Stvarno ide ova Gigabyte-ica, zvijer je - u velikoj vecini slucajeva riba GTX570 ko od shale ili je u najmanju ruku jednaka u performansama...
Staro 26.01.2011., 00:03   #56
Autor Sn4k3 Pregled postova
po ovom reviewu, ovo je doslovno duplo jača grafička od GTX 260, u nkim igrama i više nego duplo.
čak je i referentnu poderala pošteno. ovo je za nas koji baš nismo neki fanatici u klokanju grafičkih, lijepo tvornički nabrijana. ako rikne, tu je gara 2 godine i amen.
uglavnom, nakon dugo vremena, grafička iz Điđibajta koja mi se sviđa i koju bi uzeo u obzir.
No, čekat će se S.T.A.L.K.E.R. 2, a onda će se kupovati grafa (probably GTX 660 ). sada ovako i onako nemam šta sa njom igrati. za sve je dovoljna GTX 260
Staro 26.01.2011., 00:08   #57
generic
generic's Avatar
Postovi: 1,079
Sad sam malo gledao cijene po Njemačkoj i 220 € mislim da je zbilja fer cijena za tu karticu. Međutim, po istoj cijeni se prodaje i 5870 koja mi se čini dobar protukandidat jer s novim driverima u igrama (pustimo benčeve po strani) nudi jako dobre performanse. Treba samo vidjeti koliko će biti SOC
alienbabeltech benč
Staro 26.01.2011., 10:02   #58
Antiša
Datum registracije: Dec 2010
Postovi: 147
Ja sam i više nego zadovoljan perfomansama. Bolje od GTX 470 i od HD6870, a u rangu HD5870 kartica. Mrvicu sporija od R6950.
Antiša je offline   Reply With Quote
Staro 26.01.2011., 13:05   #59
Astral
Postovi: 2,523
kad mislite da bi se mogle pojavit kod nas u prodaji?
i sta na kraju ovaj Ti znaci?
Staro 26.01.2011., 13:38   #60
Doink the Clown
Postovi: 6,214
Autor Astral Pregled postova
Titanium. Pisalo se o tome na prethodnoj stranici.
http://forum.pcekspert.com/showpost....9&postcount=28
