Staro 18.12.2009., 03:17   #1
Postovi: 7,568
HWiNFO i HWiNFO32 dijagnostički alati
HWiNFO and HWiNFO32 are professional hardware information and diagnostic tools supporting latest components, industry technologies and standards. Both tools are designed to collect and present the maximum amount of information possible about computer's hardware which makes them suitable for users searching for driver updates, computer manufacturers, system integrators and technical experts as well. Retrieved information is presented in a logical and easily understandable form and can be exported into various types of reports.
  • Comprehensive hardware information
  • System health monitoring (Thermal, Voltage, Fan, Power)
  • Basic benchmarks
  • Text, CSV, XML, HTML, MHTML report formats
  • Periodical updates
  • OS: Windows 9x/2000/XP/Vista/Server 2003/2008/Windows 7
  • Platform: 32-bit (IA-32), 64-bit (x64, IA-64)
  • Available as HWiNFO32 SDK (Custom Client)
Download
Tražilica nije našla nikakvu temu vezanu za ove alate, osim jednog posta u kojem korisnik samo spominje korištenje. Pošto je izašla nova verzija, IMHO nek se nađe zasebna tema i za ubuduće.
Staro 11.02.2010., 01:54   #2
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
HWiNFO32 version 3.40
Changes
* Added reporting of TRIM command capability (for SSD).
* Improved sensor monitoring for Giga-Byte series: H55, 790FXTA.
* Improved support of nVidia GT21x series.
* Fixed support of several nVidia GPU sensors.
* Added monitoring of nVidia GPU temperature for G92, G94, GT200, GT21x.
* Added reporting of ATA drive media rotation rate in RPM (if drive supports reporting).
* Fixed detection of first DIMM on certain nVidia chipsets.
* Improved sensor monitoring for MSI series: Big Bang Trinergy (MS-7580), P55-GD80 (MS-7581), P55-GD65 (MS-7583), P55-CD53 (MS-7586), H57M-ED65 (MS-7587), P55M-GD41/45 (MS-7588).
* Improved general handling of sensor monitoring, added possibility to clear stored preferences.
* Enhanced reporting of PCIe properties for GPU.
* Added preliminary Sandy Bridge support.
* Improved sensor monitoring for Biostar series: TPower I55 and X58.
* Improved sensor monitoring for MSI series: MS-7032, MS-7046, MS-7100, MS-7185, MS-7204, MS-7236, MS-7250, MS-7260, MS-7267, MS-7327, MS-7350, MS-7369, MS-7373, MS-7376, MS-7388, MS-7501, MS-7577, MS-9130.
* Improved sensor monitoring for Giga-Byte series: 945P, 945G, 946, G31MX, 965P, 965Q, N650SLI, M55S, M57SLI, M56S, M61P, M61SME, M61VME, M68SM.
* Improved sensor monitoring for ECS series: 945P, P55H, X58, RS480, RS482, RS485, A740GM, A785GM, A790GXM.
* Improved sensor monitoring for DFI series: CFX3200, RDX200, NF590, NF4, 790FX.
* Improved sensor monitoring for Biostar series: N750, TA780, TP35.
* Improved sensor monitoring for Foxconn series: 945, 946, 965, 975, P31, G31, G33, P35, X38, G41, Q45, G43, P43, P55, C55, MARS, BlackOps.
* Improved sensor monitoring for Foxconn series: CK804, VX800, RS690, RS740, RS780, RX780, RD790, RS880, A79A, N570, C51G, MCP55, MCP61, MCP65, MCP68, MCP72, MCP78, MCP73, MCP7A.
* Improved sensor monitoring for Biostar series: NF520, NF560, TA770, TF520, TF560, TF570, TF7025, TF7050, TF7100, TF7150.
* Improved sensor monitoring for several Supermicro and ASUS workstation boards using W83793 and W83795 sensors.
* Improved sensor monitoring for Intel series: DX58, D5400XS (SkullTrail).
* Added identification of nVidia MCP89.
* Added support of Fintek F71872F and F75334DG sensors.
* Improved sensor monitoring for several EPoX motherboards.
* Improved sensor monitoring for EVGA series: E173, E178, E179, E180.
* Improved sensor monitoring for Foxconn series: BLOODRAGE, Flaming Blade, Destroyer.
* Added preliminary support of AMD Hudson FCH.
* Improved sensor monitoring for Supermicro series: C2SBX, X8SII, X8SIL.
* Improved sensor monitoring for Albatron series: PX975X.
* Improved sensor monitoring for JW series: 780G, 790G.
* Improved sensor monitoring for Shuttle series: P35, X38.
* Added new AMD Family 10h CPU models.
* Fixed reporting of temperatures in Farhenheit in tray.
Download
Staro 01.08.2010., 07:04   #3
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
HWiNFO32 v3.56 Build 877 Beta
http://www.hwinfo.com/beta/hw32_356_877.zip
Need a Gigabyte latest BIOS?
GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz
G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2)
G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1)
Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 SP1
stasio je offline   Reply With Quote
Staro 12.01.2011., 09:17   #4
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
HWiNFO32 v3.66-1087 Beta
http://www.hwinfo.com/beta/hw32_366_1087.zip
* Added Smart Battery monitoring into sensors.
* Enhanced sensor monitoring on ASRock P67 and H67 series.
* Added reporting of BIOS EFI capability.
* Enhanced sensor monitoring on ASUS P8P67, P8H67 and SABERTOOTH P67 series.
* Enhanced sensor monitoring on ASUS Maximus IV Extreme.
* Enhanced sensor monitoring on GIGABYTE P67 and H67 series.
* Enhanced Ivy Bridge support.
