Staro 27.12.2010., 21:59   #121
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
05.01.2010. će biti predstavljeni na CES-u i "shortly" nakon toga će biti pušteni u prodaju. To "shortly" bi trebalo značiti 24-48h.
Ima njih vec u prodaji na dalekom istoku.
Staro 28.12.2010., 00:40   #122
Autor Ranma 1/2 Pregled postova
Asrock je konačno uvrstio ploče s novim chipsetom na službenoj stranici
http://www.asrock.com/mb/index.asp?s=1155
i MSAN na svoj lager.
http://www.msan.hr/katalog/CatalogDe...?prodId=159879
Extreme6 neće tako skoro. No ploče izgledaju opako. Cijena ove Extreme4 je cca 1100kn, što je krajnje prihvatljivo.
Staro 30.12.2010., 10:01   #123
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Nakon katane i flamingblade za dosadasnje intele s novim procesorima stize i nova quantum force ploca:
Foxconn Channel Ready with Quantum Force P67 Motherboard
the Quantum Force P67 from Foxconn uses bleeding-edge components such as digital PWM offering precise voltage control for the processor, multi-phase VRM for the four DDR3 memory slots, and is rich in connectivity options.
The LGA1155 socket is powered by a 14-phase digital PWM circuit using independent single-phase PWM inductors made by CPL, and memory using a 2-phase VRM. Expansion slots include two PCI-Express 2.0 x16 (electrical x8/x8 with both populated), three PCI-E x1, and one PCI. Both ATI CrossFireX and NVIDIA SLI are sure to be supported. Storage connectivity includes two internal SATA 6 Gb/s, four internal SATA 3 Gb/s, two eSATA 3 Gb/s, and one ATA connector supporting up to two IDE devices.
Izvor: techpowerup
Zadnje izmijenjeno od: bluefluid. 30.12.2010. u 16:58.
Staro 30.12.2010., 16:55   #124
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
MSI Big Bang Marshal mobo Pictured
a forthcoming XL-ATX motherboard that features eight PCI Express x16 slots, eight USB 3.0 ports and three BIOS chips! The motherboard is expected in Q1 2011 but the site notes the specifications are still subject to change, perhaps the final edition will have room for more DIMMs.
This XL-ATX board packs a total of eight PCI Express lanes (though it only has the bandwidth to simultaneously feed four x16s or eight x8s -- relevant if you're crazy enough to think about using more than four GPUs), three separate BIOS chips, extra 8-pin and 6-pin 12V power intakes, and a thoroughly excessive set of power regulation components.
Izvor: guru3d
Staro 31.12.2010., 13:43   #125
omnik
Datum registracije: Dec 2010
Lokacija: Beograd
Postovi: 8
MSI Sandy Bridge
Postovanje,
Zelim da najavim da su MSI SB vec stigle na trziste i dostupne kod ovlascenih distributera.
P67S-C43
P67A-C43
P67A-C45
P67A-GD55
P67A-GD65
Glavna novina je OC Genie 2.
Sve ploce imaju SATA3 (iliti SATA 6 ). Modeli sa oznakom A (P67A-XXX) imaju i USB 3.0 od P67A-C43 (2 x USB 3.0) pa sve do P67-GD65 (4x USB 3.0).
Za 1st wave, planira se jos nekoliko modela. P67A-GD80 i exkluziva - MSI Big Bang Marshal (XL-ATX ploca ).
Toliko za sada...
Zadnje izmijenjeno od: Jelc. 31.12.2010. u 17:39. Razlog: prevelike slike
omnik je offline   Reply With Quote
Staro 02.01.2011., 02:51   #126
pingmachine
machine that goes ping!
Postovi: 478
koliko mislite da će trebati proći vremena da razni početni bugići na raznim pločama budu ispravljeni? obično early adopteri imaju puno problema.
pingmachine je offline   Reply With Quote
Staro 02.01.2011., 15:03   #127
Wolverine
Wolverine's Avatar
Postovi: 12,433
Jednako koliko i ostalim platformama prije.
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 03.01.2011., 03:07   #128
pingmachine
Postovi: 478
da, ali ja nisam od onih koji se bace glavom u hardver, pa nemam pojma koliko je to samo znam da na početku uvijek postoje razni problemi i da treba proći par revizija ploča (i BIOS-a) kod svih proizvođača dok se ne isprave dječje bolesti.
misliš da bi tamo negdje do svibnja ili lipnja trebalo biti "kupljivo"?
Staro 03.01.2011., 11:18   #129
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Malo opsežniji review na techpowerup!-u.
Intel Core i5-2500K Sandy Bridge GPU Performance
C L O W N I N G A R O U N D
Staro 03.01.2011., 11:39   #130
krešo
Administrator
krešo's Avatar
Datum registracije: Sep 2002
Lokacija: PCE Lab
Postovi: 3,990
Sandy Bridge test na PCE-u!
krešo je offline   Reply With Quote
Staro 03.01.2011., 12:03   #131
snob
Majo
Datum registracije: Dec 2009
Postovi: 186
Samo fali i7 proceosr,poput 920 na istom taktu,da vidimo sto moze .
Sve u svemu,brutalni procevi!
koj je defaultni mnozitelj i7 2600 bez sufiksa K ?
Aha, 34 .Znaci moguce ga je OCat na 3.8Ghz za 24/7,al kolko vidim kod vas,ni 5Ghz 24/7 vise nije daleko .
snob je offline   Reply With Quote
Staro 03.01.2011., 12:21   #132
krešo
Administrator
krešo's Avatar
Lokacija: PCE Lab
Postovi: 3,990
Autor snob Pregled postova
Nije, nije samo treba malo bolji hladnjak
Staro 03.01.2011., 13:29   #133
Antiša
Postovi: 147
Jako ljep i opširan review na portalu, mada će mi trebati da ga 2-3 puta pročitam da shvatim cjelu arhitekturu i zbrku, jer je Intel napravio totalni kaos po pitanju imenovanja modela.
Core i5, i7... Ovo K, Ono K.... Ovo Sandy Bridge, Ovo Nehalem.... Totalna zbrka, mješam sve.
Antiša je offline   Reply With Quote
Staro 03.01.2011., 14:54   #134
Autor krešo Pregled postova
svaka čast na reviewu. konačno nam je objelodanjeno da nema potrebe mjenjati s1156/s1366 i7 procesore jer razlika je neisplativa kroz troškove koji bi se akumulirali.
Staro 03.01.2011., 16:53   #135
danijel_b
danijel_b's Avatar
Datum registracije: Jun 2004
Lokacija: Sj. Njemacka
Postovi: 504
Slažem se u potpunosti s tobom. Iz priloženog reviewa na PCE i ostalim stranicama, evidentno je da se uopce ne isplati prelazak sa 1156 na 1155, bar za one koji imaju i5 i i7 proceve.
Za mene koji imam i5-750, najbolje bi bilo uzeti jedan i7-875K i produziti zivot platformi kad za to dođe vrijeme poštenim OC-om, samo se nadam da ce ih se moci nabavit makar i polovne.
A da ne spominjem da oni koji koriste racunala za igre uopce nece imati dobitak od s1155 u odnosu na s1156
danijel_b je offline   Reply With Quote
Staro 03.01.2011., 18:12   #136
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Bit će zanimljivo vidjet šta će Bulldozer donesti.
Jer ovo kak je sad nevrijedi ni Phenoma II mijenjat.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 03.01.2011., 19:13   #137
pingmachine
Postovi: 478
djeluje mi kao dobar upgrade na ovaj moj E4300. nadam se da se može fino undervoltati
Staro 03.01.2011., 21:08   #138
jucca
jucca's Avatar
Postovi: 1,709
Staro 04.01.2011., 00:57   #139
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Da ak tak povrsno gledas, onda starije arhitekture ispadaju kao bottleneck. Usporedba i5 750 na 2.66 i 2500k ili 2600k tako izgleda. Puno realniju sliku daje usporedba i7 975 i novih jer su na slicnim taktovima. Fino se vidi da je razlika ispod 10% i to na nizoj rezi sa medium detaljima. Ima jos dosta zivota u sadasnjim procevima i bit ce sasvim dovoljni jos dosta vremena. Nema govora o bottleneckanju jer su svi oni jako dobri OCeri i ovdje to 90% ljudi obilato koristi.
Zadnje izmijenjeno od: MAGARAC. 04.01.2011. u 01:06.
MAGARAC je online   Reply With Quote
Staro 04.01.2011., 01:12   #140
NumbDigger
Lokacija: kae
Postovi: 17
Nego na kojoj rezi/settingu ces gledati utjecaj proca na gejming? Ne valjda kad udres u gfx bottleneck, 2560x1600 16xQ CSAA ULTRA gdje isti FPS daju i7-980X i i3-550.
A problem je i taj sto Sandy Bridge ima dosta nizu potrosnju i jaako dobro se OC-a
NumbDigger je offline   Reply With Quote
Staro 04.01.2011., 01:23   #141
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
A sta ce neki ponosni vlasnik 6950 ili gtx 570 igrat na medium postavkama?
Mene za sad OC nije impresionirao iako se slazem da je dobar ali ima jos par jako bitnih upitnika, bar meni. Generalno nebi proglasavao nista dok se ne vide cijene. Nekako sumnjam da ce bit u prvih par mj. isplativi pored povoljnih i7 proceva..
Staro 04.01.2011., 02:11   #142
omnik
Lokacija: Beograd
Postovi: 8
Stizu prvi reviews MSI ploca... za pocetak P67A-GD65 @ HardOCP:
http://www.hardocp.com/article/2011/...erboard_review
The Bottom Line
The MSI P67-GD65 showed to be a top class performer and overclocker. This motherboard is supposed to come in at the $200 price point, and for that much cash, it is a GREAT value. The P67-GD65 is the easiest motherboard in the world to overclock. Simply push the OC Genie II button and you have a 4GHz + Sandy Bridge system without ever looking at a BIOS screen. So simple...and forum troll can do it.
Staro 04.01.2011., 03:59   #143
NumbDigger
Lokacija: kae
Postovi: 17
Autor MAGARAC Pregled postova
Prosjecan air OC od 4.7 te nije impresionirao.
4.9, 5.1 itd...? hmm...doduse ima bit da su binani.
Garantiranih efektivnih 4 GHz bez dizanja napona je jako lijepo imho.
Staro 04.01.2011., 04:56   #144
extacod
extacod's Avatar
Lokacija: Milkywhey
Postovi: 203
stigli i biosi koji omogućuju još veće multije za proceve
i evo nekih finih rezova na zraku, izgleda da 01 voli sandy brige i to podosta
extacod je offline   Reply With Quote
Staro 04.01.2011., 09:32   #145
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor NumbDigger Pregled postova
I to je isto 10tak% posto boje od sadasnjih proceva i na mene nije ostavilo neki dojam. 4.7 do preko 4.9 mogu i sa svojim procem na zraku i tu je jedina kocnica temperatura. Tesko me i mogu impresionirat pored 980x koji me je vec sokirao kaj se OC tice.
Zadnje izmijenjeno od: MAGARAC. 04.01.2011. u 09:40.
Staro 04.01.2011., 10:50   #146
Lignja
Re Di Calamara
Lignja's Avatar
Datum registracije: May 2002
Postovi: 570
znaci sa tim novim procom, mi ne treba graficka jer ce biti integrirana u proc ?
xxx
Lignja je offline   Reply With Quote
Staro 04.01.2011., 11:04   #147
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
I dalje će ti trebati grafička kartica za "ozbiljnije" igranje, performanse te integrirane u proc su bolje od low end klase danas (brža od Radeona HD5450). Znači, onome komu ne treba jače ili ne pati na jače ta integrirana će biti sasvim OK.
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 04.01.2011., 11:12   #148
luks 88
luks 88's Avatar
Postovi: 477
piše ti u testu da je ta integrirana HD3000 u rangu grafičkih do 300-400 kn.
Dal 1155 platforma ima dual ili triple channel memoriju?
luks 88 je offline   Reply With Quote
Staro 04.01.2011., 11:21   #149
Doink the Clown
Postovi: 6,214
Autor luks 88 Pregled postova
Dual Channel.
Staro 04.01.2011., 11:21   #150
GetRight
GetRight's Avatar
Datum registracije: Apr 2009
Lokacija: Frkjevci
Postovi: 344
Dual,pa pogledaj koliko je mem utora na matičnoj za 1155.
Gigabyte-ov odmak od tradicionalnog plavog
http://www.legitreviews.com/article/1411/1/
CPU: Phenom II x4 960T@Phenom II x6 1605T
MBO: ASRock 880G Extreme 3
RAM: 2x4GB DDR3 Corsair Vengeance Red
HDD: Hitachi 320GB
VGA: VTX3D Radeon HD 6850
PSU: Coolermaster 600w Silent Pro
Monitor: Samsung SM 2233BW
OS: Windows 7 Ultimate
Ostalo: CM 690 II Advanced,ROCCAT Kone[+]
CPU: Phenom II X2 555 BE@Phenom II X4 B55
MBO: ASRock M3N78D
RAM: 2x2GB DDR3 Corsair XMS3-1600
HDD: WD 320GB,Hitachi 160GB SATA
VGA: Sapphire Radeon 5670 512MB DDR5
PSU: XFX Core Edition 450W
Monitor: 17 "Dell E173FP
OS: XP Pro SP3
Ostalo: Thermaltake VC3000BWS
Zadnje izmijenjeno od: GetRight. 04.01.2011. u 11:54.
GetRight je offline   Reply With Quote
