Staro 25.11.2010., 21:24   #1051
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,755
Autor Astral Pregled postova
nemam tu opciju, samo gpu temp, framerate, fan speed, core clock, mam clock, shader clocks
Skini zadnju verziju ?
Ati freak je online   Reply With Quote
Staro 25.11.2010., 21:47   #1052
Astral
Postovi: 2,523
pa skinuo sam ga prije 2 dana, pretpostavljam da je zadnja?
edit: ovo sam skinuo, http://downloads.guru3d.com/MSI-Afte...load-2392.html
ah, ok...sad vidim da ima novija ver, cudno da guru3d ne daje zadnju ver,...heh, probat cu sad pa javim
edit2: ok, ima sad sry, nisam ni posumnjo da nije zadnja ver...tnx
Astral je offline   Reply With Quote
Staro 26.11.2010., 17:23   #1053
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,856
inače, za one koji planiraju clockati MSI 460 Hawk/Hawk Talon Attack, koristite Nvidia Inspector, jer (ironično, potvrđeno od MSI-a) MSI Afterburner ne radi kako treba, bar ne još. Ako kome treba moddani BIOS za Hawk Talon Attack, nek se javi na PM.
Staro 26.11.2010., 21:14   #1054
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
MSI Intros GeForce GTX 460 OC with New Single-Fan Cooler
MSI released a new factory-overclocked GeForce GTX 460 1 GB graphics card that makes use of the company's new sporty-looking single fan cooler the company first introduced with its Radeon HD 6850 graphics cards. The uses the same PCB as the one on the GTX 460 Cyclone OC graphics card. The cooler uses a 90 mm fan to blow air onto a large aluminum fin array, to which heat is conveyed by 8 mm thick heatpipes. The clock speeds are also identical with those of the Cyclone OC: 725 MHz core, 1450 MHz CUDA cores, and 900 MHz (3600 MHz effective) memory. The card also features software voltage control, which when combined with increased frequencies, up performance by 30%. Released in Europe, the new GTX 460 OC is priced at €155.
http://www.techpowerup.com/135248/MS...an-Cooler.html
Sve slično Cyclone izvedbi osim hladnjaka i nekako sam pod dojmom da je ova ipak glasnija.
C L O W N I N G A R O U N D
Staro 26.11.2010., 21:21   #1055
sliver
Datum registracije: Jan 2010
Postovi: 149
Čitao sam da je solidan taj hladnjak, umjerene buke i niskih temperatura na visokim taktovima (kod Radeon verzije ).
sliver je offline   Reply With Quote
Staro 26.11.2010., 22:00   #1056
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,835
Daj nabaci koji podatak što je točno izmjenjeno, tek toliko da te svatko ne cima na PM...
Staro 26.11.2010., 22:37   #1057
Ivo_Strojnica
PRO
Postovi: 4,856
Autor Sinac Pregled postova
Max voltaža je povećana hex editorom, povećana PPL volaža jer na MSI Afterburneru ne radi povećavanje.
Staro 26.11.2010., 23:07   #1058
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Skinuo sam taj nvidia inspektor ali kad ga pokrenem izbacuje skroz neki error.
Probao sa par mijesta skinuti i uvijek isto, zna li netko u čemu je problem nadam se da nije radi Win XP-a kao OS-a.
Idem probati i ja skinuti za Win7 imam dual-boot XP i Wins 7 pa da vidim jel možda do toga.
Evo radi bez problema na Wins 7 dok na XP-u neradi.
Zadnje izmijenjeno od: ECHO. 26.11.2010. u 23:23.
Staro 26.11.2010., 23:14   #1059
Ivo_Strojnica
PRO
Postovi: 4,856
Verzija 1.9.4.1 koju imam radi bez problema. No opet, ja sam na Win 7 x64. :S
Staro 26.11.2010., 23:32   #1060
ECHO
Postovi: 2,354
Zašto je zatamnjena mogučnost podešavanja slajdera od GPU clock dok ostale 3 opcije mogu podešavati u koracima 1, +10, +20 prvi put se susrečem s tim toolom trebam li još što podesiti.
Evo uspjeo riješiti problemčić slajder se miće kako podižem shader-clock.
Zadnje izmijenjeno od: ECHO. 26.11.2010. u 23:37.
Staro 26.11.2010., 23:38   #1061
Ivo_Strojnica
PRO
Postovi: 4,856
Autor ECHO Pregled postova
Inače ti je kod Fermija Shader Clock glavni, pa čak i modificiranju BIOS-a. Uopće nemaš opcije za sam core clock, već samo shader clock.
Staro 28.11.2010., 13:22   #1062
ddoxy
Lokacija: home
Postovi: 236
Kupio sam Gigabyte GTX460 768MB...još nikad nisam imao tako hladnu i tihu grafičku...Idle 25, load 42 dosad max...a vent na 40%...nemoguće...
Po meni, best buy do 1.400 kn.
ddoxy je offline   Reply With Quote
Staro 28.11.2010., 13:44   #1063
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Autor ddoxy Pregled postova
Hmm, pa i nije baš, kad za oko 1500-1550kn imaš MSI ona Hawk izvedba, 1GB..
BTW, ovaj mjesec idem u Zg i uzeo bi navedenu grafu MSI Hawk, nemora bit baš ona talon izvedba.. interesira me gdje da to kupim jer u ADM-u i Protisu nemaju na lageru tih kartica, plaćao bi American Ex karticom ("gotovina")..
Imate kakav savjet kad i gdje da naručim, rezerviram, ali da cijena ne prelazi 1600kn..
Thx
Omerta je online   Reply With Quote
Staro 28.11.2010., 13:59   #1064
snob
Majo
Datum registracije: Dec 2009
Postovi: 186
1150kn je ta grafa u protisu ako se ne varam.
1400kn,netko te opro
snob je offline   Reply With Quote
Staro 28.11.2010., 14:29   #1065
Ivo_Strojnica
PRO
Postovi: 4,856
Autor Omerta Pregled postova
Thx
Nažalost, nitko ti ne može reći sigurno. Zovi sve dućane (ADM, Protis, MagazinRS, Instar Informatika, Diskont24) i pitaj da li imaju i kad bi mogla stići, ako ne znaju, pitaj ih tko je dobavljač tih kartica pa nazovi njih, oni će najbolje znati.
Sretno!
Staro 28.11.2010., 15:26   #1066
Omerta
Omerta's Avatar
Postovi: 3,254
Sretno!
Imaš pravo, tako ću i napravit dan-dva-tri prije puta u Zg, i ako tko ima,naravno probat naručit, valjda će mi vjerovat na riječ, da ću grafu uzet kad ju rezerviram
Staro 28.11.2010., 15:28   #1067
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Ma tako i onako svi imaju istog dobavljača, tako da ako ima jedan dučan, imaju svi. Ako nema jedan, nemaju ni ostali... (osim onih sa svojim lagerom tipa ADM)
Core2Duo22 je offline   Reply With Quote
Staro 28.11.2010., 16:44   #1068
Verbum
Postovi: 682
Thx
Imas u Instar Informatici, prosli tjedan su dobili 30-ak komada, samo je cijena sada 1600,00 kn zbog rasta tecaja dolara.
http://tinyurl.com/2v3h9w5
Verbum je offline   Reply With Quote
Staro 28.11.2010., 18:13   #1069
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
uzimam gtx 460 768mb,pa može neka preporuka,koji proizvođač? do 1300kn...znači odnos coolera i garancije i možda bundlea
SetH je offline   Reply With Quote
Staro 28.11.2010., 18:36   #1070
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,755
Pa rezerviraj ju na ime , a ne da samo nazoveš i veliš ja bi ju rezervirao , a oni si nek misle koji je to duh zval
Staro 28.11.2010., 19:11   #1071
Omerta
Omerta's Avatar
Postovi: 3,254
Malo pametuješ ili?
Naravno da bi ju rezervirao na ime, prezime, broj osobne, samo da mi ju sačuvaju ali u današnje vrijeme teško da to pali, čast iznimkama..
Kao što sam rekao, dan-dva prije vrtim brojeve dućana u Zg..
Staro 28.11.2010., 19:16   #1072
Doink the Clown
Postovi: 6,214
Autor SetH Pregled postova
http://www.adm.hr/product_info.php?c...oducts_id=8778
Ili da možda još dodaš 50-ak kuna za gigu?
http://www.protis.hr/products/detail...gb-gddr5/36850
Staro 28.11.2010., 19:49   #1073
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,755
Malo pametuješ ili?
Dobronamjeran savjet. Mnogi se zalete, pa kad uspiju dobiti nekog na telefon vele da bi samo rezervirali.. a ta je rezervacija ravna nuli.
Staro 28.11.2010., 19:56   #1074
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
hm... garancija? 2 godine?
Staro 28.11.2010., 19:59   #1075
Doink the Clown
Postovi: 6,214
Yup, i za MSI (nažalost odnedavno) i za Điđibajt.
Staro 28.11.2010., 20:01   #1076
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Pise na ADMovim stranicama da na MSI grafe i ploce ide 36mj. jamstva.
http://www.adm.hr/jamstvo.php
tole_ je offline   Reply With Quote
Staro 28.11.2010., 20:06   #1077
Doink the Clown
Postovi: 6,214
Autor tole_ Pregled postova
Hm, da im nije to ostalo od ranije?
Znam da je MSI smanjio trajanje garancije kod nas sa tri na dvije godine.
Staro 28.11.2010., 20:09   #1078
tole_
Casual Racist
tole_'s Avatar
Postovi: 422
a e, zato treba nazvat i pitat. il ak ima netko tko je kupio tamo msi grafu/plocu da vidi sta mu pise na jamstvenom listu.
Staro 28.11.2010., 20:17   #1079
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Pa šta je tu čudno? MSI daje garanciju od 3godine a trgovina od 2 godine. Ni prvi ni zadnji takav artikl. Kad ti istekne garancija u trgovini, jedini RMA što ostaje je direktno u MSI.
Staro 28.11.2010., 21:33   #1080
slinko
slinko's Avatar
Datum registracije: Aug 2008
Lokacija: Koprivnica
Postovi: 7
audio output
pozz. imam jedan problem. htio bih zvuk imati preko grafičke kartice tj. hdmi kabla, al nezz kak da to složim da funkcionira. ovo je moja shema kak sam spojio. Asus P5Q3-> MSI N460GTX-Hawk TA-> HDMI kabel->Yamaha RX-V363 DVD input-> kabel HDMI to DVI -> Samsung SyncMaster 2243. E sad dal postoji nekakva ''caka'' u softweru za to uključit ili što. imam windows 7 64-bit i u volume mixeru pod playback devices nema nigdje ponuđeno GPU audio output, samo realtek 3 funkcije (Speakers, Digital output (RCA+Optical) i Digital Realtek Output) dok sam s atijevom 4770 imal tu ponuđenu opciju gpu audio output... Nezz dal treba negdje u nvidijinim postavkama uključiti digital out ili što. Hvala!!
slinko je offline   Reply With Quote
