Staro 21.11.2010., 10:48   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX590
Nvidia's dual chip card waits for Antilles
Nvidia has a dual GF110 card that is supposed to launch very soon. However, since AMD has postponed its dual-chip card for Q1 2011 it looks like Nvidia will do the same.
Sources close to company are saying that Nvidia partners are more or less ready and that the company can pull a quick launch even in 2010, but it looks like it will only happen after AMD's Antilles Radeon HD 6990 dual chip card comes out. Nvidia badly wants the two-chip card performance crown and has to see and study Antilles before its launch. The rumoured name for dual GF110 card is Geforce GTX 590.
We still have to see Cayman Radeon HD 6970 and HD 6950 cards in late 2010, and whether they can beat Geforce GTX 580 and soon to launch Geforce GTX 570. The challenge for AMD is that making a big chip and clocking it high is not that easy.
Last time ATI did this was with R600, more than three years ago and things didn't go as smooth as planned. The chip was quite hot and didn’t perform that well. After that the head of graphics Rick Bergman said that ATI is changing the course to make RV770 and a year later RV870, two chips that were chasing AMD's performance-per-watt dream.
Now this dream is apparently over as Cayman, a massive chip is powering Antilles, Radeon HD 6990. Let’s hope it all goes well for AMD.
http://fudzilla.com/graphics/item/20...s-for-antilles
Čeka se potez AMD-a
C L O W N I N G A R O U N D
Staro 21.11.2010., 17:32   #2
Postovi: 7,568
Potez AMD-a se zna još od dana lansiranja i predstavljanja HD 5000 serije, jer su već tad (slično ko i sad s HD 7000 serijom), počele kružiti prva nagađanja i neslužbene vijesti o HD 6800 i HD 6900 modelima. Ovo kaj sad gledamo, je samo nastavak priče o dual-GF104 i dual-GF100 karticama koje su bile i ostale koncept na radost svih inženjera. Kaj bude iz ovoga ispalo, zna samo Fuad koji je ko i obično i superpouzdanih izvora dobil prva saznanja o novoj čudovišnoj kartici iz Santa Clare.
Staro 21.11.2010., 17:36   #3
Doink the Clown
Postovi: 6,214
I na techpowerup-u je iskrsnula slična vijest samo se spominje naziv kartice GTX595.
NVIDIA Readying Dual-GF110 Graphics Accelerator, Eying Total Performance Leadership
NVIDIA stunned the computing world with a speedy launch of the GeForce GTX 580. The GPU was able to increase NVIDIA's single-GPU performance leadership, and also iron-out some serious issues with the power-draw and thermal characteristics of previous generation GeForce GTX 480. It is now that a dual-GPU implementation of the GF110 graphics processor, on which the GTX 580 is based, looks inevitable. NVIDIA seems to be ready with a prototype of such a dual-GPU accelerator, which the Chinese media is referring to as the "GTX 595".
The reference design PCB of the dual-GF110 accelerator (which still needs some components fitted) reveals quite a lot about the card taking shape. First, it's a single PCB card, both the GPU systems are located on the same PCB. Second, there are slots for three DVI output connectors present, indicating that the card with be 3D Vision Surround ready in a single card. You just have to get one of these, plug in three displays over standard DVI, and you're ready with a large display head spanning three physical displays.
Third, it could feature a total of 3 GB of video memory (or 1.5 GB per GPU system). Each GPU system has six memory chips on the obverse side of the PCB. At this point we can't comment on the memory bus width of each GPU. The core configuration of the GPUs are also unknown. Fourth, power is drawn in from two 8-pin PCI-E power connectors. The card is 2-way SLI capable with another of its kind.
http://www.techpowerup.com/134846/NV...eadership.html
Ne preostaje nam ništa drugo nego da pričekamo i vidimo što će od toga biti, vjerujem da je nakon rezanja potrošnje i zagrijavanja čipa sa novom generacijom realno očekivati i dvoglavu zvjerku
Zadnje izmijenjeno od: Doink the Clown. 21.11.2010. u 17:42.
Staro 21.11.2010., 17:44   #4
snob
Majo
Datum registracije: Dec 2009
Postovi: 186
cini se prilicno moguce.
ko GTX295 SinglePCB,sa svake strane GPU,odvojeni hladnjaci,na sredini vent.
nek naprave tako nesto slicno,s efikasnijm hladenjem,i to je to.
snob je offline   Reply With Quote
Staro 21.11.2010., 17:45   #5
Postovi: 7,568
Sve su to varijacije na temu i uzorak je dobro poznat - kinesko-ruski-rumunjko-japansko-mongolski forum ima spy-shot kartice, a Fuad bez problema sve to prevodi.
Tak je bilo 100% da nVidia izdaje dvojezgrenu GTX 475, GTX 485, GTX 490, ma nema kombinacije koju nisu okrenuli i svim tim vijestima.
Staro 21.11.2010., 19:02   #6
nexusone
Datum registracije: Apr 2008
Postovi: 139
Zasto nebi izasla GTX590 kartica, ne kuzim?
Ako se dobro siječam to isto ste govorili i za GTX580 karticu, marketinski trik, ovo, ono, a sad je tu, i to prije HD6950 i HD6970 kartica koje su vec nekoliko puta bile odgođene..
A sto ako HD6990 kartica ne postoji, sto ako je to marketinski trik?
Mislim tako govorite kao da ste najpametnije i da vi znate bolje od svih novinara...
nexusone je offline   Reply With Quote
Staro 21.11.2010., 19:41   #7
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Zbog povijesti dotične firme, čestih marketinških spinova i njene iskrenosti prema svojim kupcima. Mislim da je to glavni razlog Kada ATI nešto najavi onda se to uglavnom i ostvari, sa nvidijom to nije slučaj.
Tu je još i visok TDP jednog čipa, a kada se dva upare morat će napraviti neke kompromise da bi ostali unutar 300W TDP-a. Malo je čudno i to da se čeka Antile. Ako je kartica gotova zašto je ne izbaciti na tržište i zaraditi nešto. Jedino ako žele čekati pa vidjeti što nudi konkurencija pa prema tome izbaciti specifikacije.
cccp je offline   Reply With Quote
Staro 21.11.2010., 21:47   #8
Postovi: 7,568
Autor nexusone Pregled postova
Zašto bi, jer su na netu zblurane slike PCB-a neke GeForce kartice? Usput se slične slike sa svakom novom generacijom vrte još otkad je nVidia imala svoj zadnji izlet u dual-GPU vode s GTX 295. Otkad je predsjednik i direktor nVidije krajem 2009. pred cijelim auditorijem novinara i IT recenzenata držal komad plastike i bezočno lagal, (zaboravil spomenuti da je to samo maketa i svima napričal) da imaju spremne prve Fermi kartice, sve, pa i najmanje vijesti o bilo kakvim novim GeForce karticama se ne doživljavaju kao legitimne. Pogotovo ne dual-GPU monstrumi za koje nVidia nema realne potrebe, a bome ni s prijašnje dvije generacije nisu imali sredstva i sposobnost da ih realiziraju.
nVidia sve više postaje ko Apple, čiji veliki obožavatelj je direktor i predsjednik nVidije. nVidia (baš kao i Apple) svake godine prodaje "novi" proizvod koji se od prošlogodišnjeg razlikuje u nijansama (1, 2), a pritom ljude (baš kao i Apple) tretiraju ko ovce. Dok ljudi s druge strane misle kak su super prošli s kupnjom, npr. "nove" GTX 580 i kak je to super kartica, a zapravo su kupili karticu koja im je trebala stići još krajem 2009. skupa s HD 5000 serijom. Nemoj se čuditi, ako u godinama (5+) koje dolaze, nVidia (bahato kakva i je) najavi povlačenje s tržišta grafičkih čipova namijenjenih masama i kompletno se orijentira na HPC i GPGPU segmente. Kolko imamo prilike vidjeti nVidia forsira profesionalnu namjenu/primjenu di god stigne i sljedeće dvije nove generacije im isto tak dolaze s profesionalnim temeljem.
GTX 580 za koji smo "mi" govorili da je glupost je ona nakupina nebuloza od specifikacija, a izgleda ovak; 512 do 768SP-a udomljeno s 512-bitnom sabirnicom. Da li je takva ili slična kartica ugledala svjetlo dana? NIje, niti ikad bude. Kaj se tiče HD 6900 serije, kartice nisu već po nekolko puta odgađane, već su odgođene samo jednom, a koji je razlog tome zna samo AMD, pošto (HD 6950 i HD 6970) kartice već jedno vrijeme gostuju u kojekakvim internim testovima i recenzentskim redakcijama. Kaj tolko dugo rade s njima, je isto tak misterij - za koji sam siguran Fuad ima odgovor.
Koju karticu od fijaska s HD 2900XT, pa nadalje, je AMD-ATi najavil i pripremil, a da ju nije izdal i ponudil u slobodnoj prodaji?
Fuad nije novinar, nego fanboy onoga ko mu napravi više klikova na stranici, a da ti, ja ili bilo ko drugi cijele dane namata sranja na svojim web-stranicama i blogovima, tu i tam bi pogodili poneku specifikaciju.
To kaj ljudi vjeruju da Fuad stvarno ima interne špijune i pouzdane izvore i sve kaj pročitaju na netu uzimaju zdravo za gotovo - e to je već priča za sebe.
Zadnje izmijenjeno od: McG. 21.11.2010. u 22:27.
Staro 21.11.2010., 23:10   #9
nexusone
Postovi: 139
Maah, s vama se ovdje prepirati nema smisla, uvijek se nađe neko ko je najpametnije...
Uglvnom vrijeme će pokazati što će biti..
I još jedna informacije za McG-a, nije samo fud, već i Guru3d,techpowerup, expreview, a još njih najvjerojatnije možeš pronaći pomoću googla....
Staro 21.11.2010., 23:17   #10
Postovi: 7,568
Gle, meni tog sranja od "vijesti" i "glasina" stigne more na RSS tokom dana i svi imaju jedan-jedini izvor, a Fuad to onda interpretira kak ga volja. Pročitaj kaj su drugi (i ja) napisali dosad na ovoj temi i skužil budeš da je sve to kaj si ti sad linkal u svojem postu - već linkano i svima je izvor isti. Fuad i zblurane slike s turskog i kineskog foruma. Kaj se tiče rasprave i toga ko je najpametniji - ja sigurno nisam, niti se kao takav postavljam. To kaj ja pričam i pišem ono kaj se meni čini logično i kaj ne pušim sranja koja mi stižu na RSS i kaj se ljudima ne sviđa moje razmišljanje - to je sasvim deseta stvar. Vi, vjerujte kaj vas volja i tumačite sve ove "vijesti" i "glasine" kak god hoćete. Uostalom pročitaj si službene forume tih stranica koje si linkal, pa budeš skužil da ja nisam jedini koji misli da je ovo predstava za javnost. Svaki iole relevantan IT portal ima temu na svojem forumu i na svima se vode slične rasprave. Mora da su svi ludi, a samo Fuad zna pravo stanje stvari.
Zadnje izmijenjeno od: McG. 22.11.2010. u 00:07.
Staro 22.11.2010., 00:32   #11
Overhaul
Overhaul's Avatar
Postovi: 517
Ma gle ovdje su sve osobni stavovi, ako se tebi nečiji stav ne dopada, to je sasvim legitimno Stvar e samo u tome sa se zdravim razumom i iskustvom (sa vijestima i web izvorima "informacija") pokušava razlučiti glasine od činjenica, marketing od propagande.
Nije nemoguće da se napravi dvoglava grafička, ali po sadašnjim specifikacijama, to nebi po atx standradu stalo u potrošnju u pciexpres... Dakle i najoptimiziraniji model, morao bi biti baziran na još usporenijoj
gf104 bazi nego je to sada single stock gtx 460. I drugo stvarno ne drži vodu, da "netko nekog čeka". Da Nvidija ima karticu, pucala bi SADA, pred Božić, i dok konkurencija nema svoj odgovor, jer u prvom mjesecu je bonaca za prodaju. Ili to, ili su stvarno i ati i nvidija ista firma.
Overhaul je offline   Reply With Quote
Staro 22.11.2010., 01:28   #12
Postovi: 7,568
nVidia je firma koja pošto-poto mora zadovoljiti ego i taštinu svojeg gazde i zato budu uvijek kolale (možda se i jednog lijepog dana i obestine) kojekakve informacije o najbrutalnijoj grafičkoj kartici ikad. Zotac je za svoju dušu napravil dual-GTX 460, Galaxy dual-GTX 470, a Asus ima dual-GTX 480 i sve to stoji u njihovim uredima nakon kaj su prikazane po raznim sajmovima, jer im je otpočetka bilo jasno da te kartice ne budu vidjele police dućana. Sigurno im je jeftinije napraviti jedan-jedini prototip, pa pustiti nek slike iscure diljem neta, nego ulagati mnoštvo novci za skupi i posebno dizajnirani PCB i optimiziranje ionak brutalnog monolitnog čipa za masovnu produkciju ultra skupih dual-GPU kartica.
Primjera radi, ovo je trenutačno najmoćnije dual-GPU rješenje - Asus Ares baziran na dva RV870, tj. dva HD 5870 čipa s cijenom od $1.000, a kod nas 9.000 do 10.000 kn.
Kolko god izgleda veliko, glomazno, kompleksno i monstruozno, prema ovome iz nVidije se čini ko mainstream kartica za par stotina kuna.
Jedino kaj "jednostavnošću" izvedbe ima smisla je Zotacovo dual-GTX 460 čudo, a ni to do dan-danas nije ušlo u masovnu proizvodnju.
Zadnje izmijenjeno od: McG. 22.11.2010. u 01:51.
Staro 07.01.2011., 10:43   #13
nexusone
Postovi: 139
Staro 07.01.2011., 12:43   #14
Doink the Clown
Postovi: 6,214
O da, nadam se da će svi nevjerni Tome uskoro biti iznenađeni
Btw. je l' ja to vidim samo 2x8 pin PCIe konektora za napajanje?
EDIT - ma, to sam i mislio, gripa čini svoje
Zadnje izmijenjeno od: Doink the Clown. 07.01.2011. u 13:15.
Staro 07.01.2011., 12:56   #15
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Btw. je l' ja to vidim samo 2x6 pin PCIe konektora za napajanje?
2x8
fran123456 je offline   Reply With Quote
Staro 07.01.2011., 14:09   #16
Antiša
Datum registracije: Dec 2010
Postovi: 147
Ma uglavnom sve što je rekao McG potpisujem. Nema šanse da naprave dual gpu temeljen na GF110 čipom. Jednostavno TDP bi bio ogroman i van PCIe specifkacija.
Eventualno GF114 sa nižim takvotima. Kako se očekuje da će GTX 560 koji je temeljen na GF114 čipu biti u rangu Radeona HD 6950, a poznavajući nvidijino skaliranje u SLI sustavima i dual gpu karticama, Dual GTX 560 sa nešto nižim taktovima i TDP-om od 300-ak W bi mogao biti ipak kolko tolko konkurentan (TDP GTX 560 je 180W).
Antiša je offline   Reply With Quote
Staro 07.01.2011., 15:10   #17
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Treba u Hr. sagraditi par nuklearki, inace cemo zbog ovih kartica morat uvozit jos vise struje
Skaliranje SLi-a GTX 570 je odlicno, tako da ce performanse vjerojatno biti odlicne. 3gb memorije
NovA Squadron
kripton je offline   Reply With Quote
Staro 07.01.2011., 15:42   #18
Antiša
Postovi: 147
Autor kripton Pregled postova
Valjda mislis na GTX 580 Jer 570 ima 320bit sabirnicu pa time i 1280 DDR5 VRAM memorije.
No i dalje je sigurno da dual GF110 čip teoretski, za serijsku proizvodnju nije spreman. Štoviše, čak je opasan za nvidiju jer je prevelik rizik; Yield bi bio smješno nizak, potrošnja sigurno 500-ak W u igrama, a moraš biti doslovno specijalac da bi kupio karticu koja se 2 do 3 puta više grije i troši, iako je brža, no to nikako neopravdava njenu glomaznost i spomenute probleme.
Radeon HD 69xx Dual će biti mnogo, mnogo bolja solucija.
Jedino Dual GF114 ima kakve takve šanse. No treba još vidjeti. 25.1 je predstavljanje GTX 560. Ako perfomanse budu dobre i u rangu Radeona 6950 (ili čak malo lošije) uz dobro skaliranje i drivere mogli bi skrpat dual karticu sa nižim taktovima uz TDP koji graniči sa PCIe specifikacijom.
Zadnje izmijenjeno od: Antiša. 07.01.2011. u 15:43. Razlog: jebiga
Staro 07.01.2011., 15:48   #19
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Moje osobno mišljenje je da ne vjerujem da će izaći tako nešto, ali isto tako, gospon McG, ti si bogu hvala već imao vrlo uspješne prognoze vezane za mnoge kartice, pa me i dalje fascinira koliko tupiš jedne te iste gluposti.
NVidia je kao i svaka druga kompanija, ima cilj zaraditi što više novaca i nagraditi svoje dioničare kroz dividende, povećanje vrijednosti dionica itd. i više si presmiješan time kako ti je glavni argument da cijela kompanije i sve što radi služi za podizanje ega jednoj osobi. Iskreno i dobronamjerno ti savjetujem da prestaneš gledati američke akcijske filmove, meksičke sapunice i tekstove o urotama na globalnoj razini, možda se bude vidio napredak neki u tvojim stavovima...
A možda isto tako jednog dana shvatiš da je i AMD kompanija koja ima iste ciljeve, a to je zarada....
Ja eto, koristim i Nvidijine proizvode trenutno i Appleov mobitel imam i zadovoljan sam njima, onog trenutka kada ne budem zadovoljan prestat ću "hraniti ego velikog vođe" i kupiti recimo AMD-ovu karticu ili HTC-ov, Samsunogov ili ne znam koji već mobitel...
Stoga te lijepo molim, da u svrhu normalne rasprave na forumu, prestaneš koristiti termine tipa hranjenje ega velikog vođe i slično, jer time itetkako gubiš objektivnost u očima većine ljudi, čak iako možda čak i kažeš točne stvari...
LP
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 07.01.2011., 16:01   #20
cccp
cccp's Avatar
Postovi: 1,030
Antiša, yield bi ostao isti, to su isti GF110 čipovi, samo idu dva na istu ploču.
Staro 07.01.2011., 16:12   #21
Antiša
Postovi: 147
Autor cccp Pregled postova
Da ali ionako slab yield GF110 čipova bi još više potonio nvidiju kad bi morali trpati 2 ista takva na jedan PCB sa 500W TDP-om i 100C temperaturama i tek 20% većim perfomansama od konkurencije (mislim na dual 69xx) Malo sam se krivo izrazio jer na brzinu tipkam.
Zadnje izmijenjeno od: Antiša. 07.01.2011. u 16:17. Razlog: Opet zaboravio
Staro 07.01.2011., 17:55   #22
AlphaDog
AlphaDog's Avatar
Lokacija: Ri
Postovi: 37
Ajde, ajde ne maštajte o grafi unutar ATX specki, to je s GF100 arhitekturom nemoguće, a GF104 s TDP-om od 300W nećete vidjeti jer bi kartica bila shranje naspram Antillesa.
nvidia je s GF104 do kraja srezala karticu i bolje od toga se ne može, a da performanse ostanu konkurentne. kad bi dual Fermi bio unutar 300W, unutra bi bila dva GTX460 192bit čipa ili 1GB s dodatno skresanim taktovima. i jedna i druga opcija bi gledala u leđa dual Caymanu, koji će po svemu sudeći također biti izvan ATX specki.
dakle kako god okreneš, <300W grafe nebudete vidjeli
AlphaDog je offline   Reply With Quote
Staro 08.01.2011., 12:36   #23
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
@AlphaDog
Pa neće nVidia koristiti stari GF104 chip , gledaj minimalno GF114 (GTX560) pa onda uspoređuj s AMD-om.
doky je offline   Reply With Quote
Staro 08.01.2011., 20:47   #24
AlphaDog
AlphaDog's Avatar
Lokacija: Ri
Postovi: 37
Autor Anphonic Pregled postova
@AlphaDog
care, slobodno ti lupaj u zid ali moj post itekako stoji.
GTX560 je ništa drugo doli GF104 (GTX460) s enejblanih 8 clustera i povišenim taktovima. Raspored shadera je jednak, imamo 48 shadera i 8 TMU po clusteru što će ti dati 384 CUDA jezgara. Vjerojatno će tu još biti manjim optimizacija u z-cull engineu i teksturnim unitima
Mogu je oni nazvati GF150 što se mene tiče no to je ništa drugo nego full GF104 čip kakvog je nVidia otpočetka imala u rezervi, a ta promjena naziva iz 4 u 5 bazira se isključivo na marketinškoj osnovi.
Staro 08.01.2011., 21:09   #25
doky
doky's Avatar
Postovi: 1,942
Autor AlphaDog Pregled postova
Ma sve to stoji šta govoriš, lupanje u zid se odnosi za nVidiju, a ne na tebe. Samo kažem da nema šanse da nVidia stavi dva GF104 chipa već punokrvne GF114 chipove te tu ne dolazi do usporedba s dvije GTX460 kako si računo već GTX560 za koju se očekuje da će na kraju biti nešto malo slabija od HD6950.
Staro 08.01.2011., 23:35   #26
AlphaDog
AlphaDog's Avatar
Lokacija: Ri
Postovi: 37
mogu oni stancati što hoce i nazivati kako god hoce no GF104 i GF114 su dizajnom isti cip, samo sto je na GF114 otkljucan cluster iliti streaming multiprocessor kako ga nvidia voli zvati.
GF110 = GF100b
GF114 = GF104b
jasno da ce u slucaju stavljanja GF104 cipa u dual GPU ici na full GF no kad se govori o karticama konkretno onda je GF104 ista stvar kao GF114 samo sto ces u slucaju potonjeg ajmo reci bolje precizirati o kojem se modelu radi
Staro 09.01.2011., 10:53   #27
Ivan123
Postovi: 191
nVidia nece koristiti GF104 ili GF114 za GTX590/595.
Ako ste pratili CES, sama EVGA je rekla da je ovo njezin custom dizajn i da nema veze s 590/595
Ivan123 je offline   Reply With Quote
Staro 11.01.2011., 11:20   #28
red_bull
red_bull's Avatar
Lokacija: Varazdin
Postovi: 66
Neznam cemu prepirka ljudi, kartica koja slijedeca izlazi iz nvidije bit ce jaca i brza od trenutne najjace amd-ove kartice. nadmetanje nece prestat i tome moramo bit zahvalni.. a sto se tice tog da ce nvidia prestat radit mainstream kartice, jednostavno nevjerujem, jer mogu prodat 1000 tesli a par milijuna mainstream kartica koje su puno veci profit od kompliciranih i specijaliziranih tesli. svaki geek u kompu mora imat graficku karticu a to je ili amd ili n.vidia mainstream.
fly me to the moon
red_bull je offline   Reply With Quote
Staro 29.01.2011., 19:41   #29
nexusone
Postovi: 139
The card will sport two GF110, which means 1024 juicy CUDA cores and 3GB of GDDR5 memory. The reason NVIDIA has chosen to use all the CUDA cores instead of locking shader blocks and pumping up the core frequency is because it is a more efficient solution. That's why the GTX 590 will be clocked lower and therefore require less voltage than the GTX 580, which has a single GF110 GPU. This is necessary as the GTX 580 has a rated TDP of 244 watts with just one GPU, so you can only imagine the heat if they had both GPUs running at GTX 580 speeds and voltages.
Izvor
Staro 29.01.2011., 19:48   #30
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
TRebat ce onda puno downclockat GPUe..
Kolko bu to kostalo kod nas. 1000 eura?
MAGARAC je online   Reply With Quote
