Staro 11.08.2010., 13:14   #121
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Lokacija: Virovitica
Postovi: 466
ima jedan jedini HDMI, prebacim na njega na daljincu
no u panelu windowsi ili nvidia uopce ne detektiraju plazmu dok je sekundarni monitor, ni force detekt ništa ne nađe,
Tihomir111 je offline   Reply With Quote
Staro 11.08.2010., 13:46   #122
Autor Tihomir111 Pregled postova
zanimljivo. možda ti se negdje signal izgubio u prenosu sa HDMI na DVI ili obrnuto.
probaj nabaviti kabel i spojiti HDMI na grafi sa HDMI-ijem na TV-u, možda će tu biti više sreće. samo mi nije jasno kako grafa nije prepoznala još jedan monitor (tvoju plazmu).
Staro 11.08.2010., 13:53   #123
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Postovi: 466
Kad stavim plazmu na mjesto LCD-a radi plazma (lcd ne)
kad stavim drugi LCD na mjesto plazme i on radi...
Staro 11.08.2010., 13:59   #124
Dakle, da rezimiramo.
Kad su spojeni i LCD i Plazma zajedno, radi smo jedno od tog dvoje, ovisno o konektoru.
Kad su spojena 2 LCD monitora, onda rade oboje normalno...
a bokte mazo...
Staro 17.08.2010., 10:37   #125
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Evo i jednog bencha Gigabyteovog SOC modela.
On The Bench: Gigabyte GeForce GTX 470 Super Overclock
C L O W N I N G A R O U N D
Staro 18.08.2010., 13:54   #126
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Gigabyte GeForce GTX 470 SOC review
From what we measured, this card consumes roughly 215 Watts when 100% utilized, compared to the competition that's too high, but we discussed the Fermi TDP many times already, nothing new there. It is a choice you have to make.
So overall we really like what Gigabyte did here with this SOC model, the custom cooler is certainly really good and you'll notice severe improvement in cooling at an absolute low noise level. The biggest difficulty obviously remains ATI, lined up against the GTX 470 would be the Radeon HD 5850 which can be purchased at 275 EUR these days saving you roughly 50 EUR while consuming less power with its TDP at 170W. The reality however is that the SOC edition is competing with the similar priced Radeon HD 5870, thanks to it's pre-overclock.
That product could make more sense if the price is right. But, this product comes pre-overclocked and you'd also forfeit on PhysX and CUDA though.
Whatever your choice may be, Gigabyte did a really nice job on the GeForce GTX 470, they transformed and morphed it into a product with a somewhat bad reputation to something really nice and inaudible. TDP remains high, but other then that this card is very much recommended. But make sure you have proper ventilation in your PC chassis though.
Izvor:guru3d
evo jos jedan
Zadnje izmijenjeno od: bluefluid. 18.08.2010. u 14:01.
Staro 20.08.2010., 01:54   #127
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Vanatage scor na 860/1900 1.1v sa 2x1900rpm na Spitfireu. Max temp 62c.
MAGARAC je online   Reply With Quote
Staro 20.08.2010., 08:12   #128
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 422
Evo moje na 850/1900
Score puno manji nego kod Magarca jer sam ja na C2Q, a ne i7.
No pitanje:
GPU score je kod mene manji vise nego 1000 bodova iako su grafe na skoro istim frekvencijama.
- koliko je to zbog CPU - ne ukupni score nego samo GPU score, odnosno da li CPU moze imati toliki utjecaj na sam GPU score
- koliko je to zbog PCI-E 1.1 koji je kod mene, tj. da li moze biti tolika razlika izmedju 1.1 i 2.0. Ovo mi se taman cini kao razlika u PCI-E 1.1 vs 2.0 jer sam negdje citao test za HD5870 i GTX480 i za njih je u prosjeku razlika izmedju PCI-E 1.1 i 2.0 bila cca. 5%
Tumor je offline   Reply With Quote
Staro 20.08.2010., 13:35   #129
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
10mhz sa ovom grafom radi razliku u scoru a i proc je bio na 4.5 tak da je to normalno. 8mhz +200 bodova
868/950
Velika je razlika između c2q na 3.8 i i7 na 4.5 sa 8 threadova .
Zadnje izmijenjeno od: MAGARAC. 20.08.2010. u 13:45.
Staro 22.08.2010., 18:18   #130
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
GTX470 na 886/1010. Najviši klok koji su mi dozvolile voltaže u biosu, 1.167v. Kad malo zahladi radim bios sa 1.21v i mislim da bu onda palo 900mhz. Temperatute su super 61c max na GPU a PCB ne prelazi 40 stupnjeva. Bilo bu to bolje kad zahladi i kad nabavim brže ventove.
Staro 23.08.2010., 22:16   #131
luks 88
luks 88's Avatar
Postovi: 477
http://www.bug.hr/vijesti/jeftiniji-...70/103432.aspx
vjerujem da će ovo sniženje dodatno uzburkati pad cijena kod Atija
luks 88 je offline   Reply With Quote
Staro 22.10.2010., 18:42   #132
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Staro 22.10.2010., 22:38   #133
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,311
Budemo vidjeli cijenu kada dođe. Tako stoji cijena od 1800 kn. za gigabyticu, ali naravno nije raspoloživa.
Staro 22.10.2010., 22:46   #134
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
I gtx460 Hawk je pala na 1440 al opet vidit cemo kad dode ako dode. Ovih 100kn vise za MSI se kod 470tke jako isplati. 15c manje i puno tise.
Uglavnom to je okvirna cijena kakva bi trebala bit iduci mj.. 460 1GB na razini slabije 460tke i 470 jeftinija 20tak$. Inace je u nekim zemljama EU 470 ispod 200eura.
Staro 22.10.2010., 22:51   #135
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,311
Da, sada baš vidim da 460 1GB Cyclone ide po 1460 kn, nije loše, iako kako je krenulo...
Moram priznati da lijepo izgleda tržište (ponuda) u ovom trenutku.
Staro 22.10.2010., 22:53   #136
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Da, lijepo su pricekali da isprazne lager pa spustili cijene. Jutros je bila jos jedna Hawkica raspoloziva i cim su je prodali su spustili cijene za iducu turu. Btw. prije 20 dana je bila 1850kn.
Staro 25.10.2010., 16:29   #137
brunex
brunex's Avatar
Lokacija: Osijek City
Postovi: 97
sutra stiže hrpica GTX 470 MSI Twin Frozr po 1938.74 kn u
krasan cooler. http://217.14.221.177/StartEU.ashx?_...mnHcX98dPNVpCx
http://mail.microline.hr/ftp/MOL/Ima...gtx-twinfr.jpg
brunex je offline   Reply With Quote
Staro 25.10.2010., 17:44   #138
Postovi: 33,970
Meni izbacuje 2.123kn.
Staro 25.10.2010., 17:50   #139
nino
nino's Avatar
Postovi: 12,613
Cijena 1.911,59 kn.
Nije na skladištu.
Staro 25.10.2010., 17:54   #140
Doink the Clown
Postovi: 6,214
Autor coconut Pregled postova
I ti si se navukao kao ja jučer
VAŽNO!!! Ako u gornjem lijevom kutu ne vidite crveni znak "IQ ZAGREB" -- kliknite na "Tools - Internet options - Delete Cookies - Yes". U protivnome nećete vidjeti točne cijene IQ centra Zagria
Staro 25.10.2010., 20:47   #141
Alfa_R
Alfa_R's Avatar
Postovi: 2,898
Šta, ja smrdim?
Cijena 2.654,99 kn.
Nije na skladištu.
Staro 25.10.2010., 22:19   #142
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,743
Autor Alfa_R Pregled postova
Šta, ja smrdim?
Cijena 2.654,99 kn.
Nije na skladištu.
Kod mene:
Cijena 1.869,11 kn.
Nije na skladištu.
Staro 25.10.2010., 22:33   #143
Alfa_R
Alfa_R's Avatar
Postovi: 2,898
Ocito opera ne obrise kad obrisem kukuje sa 217.14.*
Staro 25.10.2010., 23:58   #144
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Tumor Pregled postova
No pitanje:
Imas P5Q Deluxe ili ne? Sve P45 ploce su PCI-E 2.0.
Staro 01.11.2010., 13:13   #145
brunex
brunex's Avatar
Postovi: 97
Autor nino Pregled postova
Cijena 1.911,59 kn.
Nije na skladištu.
Šta, ja smrdim?
Cijena 2.654,99 kn.
Nije na skladištu.
Autor pinkskin Pregled postova
Kod mene:
Cijena 1.869,11 kn.
Nije na skladištu.
ne, link svakog baci na drugog dobavljača od microlinea i svuda su drukčije cijene.
Staro 04.11.2010., 22:58   #146
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,311
Staro 06.11.2010., 17:27   #147
mario6
Postovi: 45
mario6 je offline   Reply With Quote
Staro 06.11.2010., 17:44   #148
Doink the Clown
Postovi: 6,214
Autor mario6 Pregled postova
Baš sam jučer gledao bila je nešto preko 1100kn, lijepo to ide dolje
Staro 10.11.2010., 23:57   #149
MAGARAC
MAGARAC's Avatar
Postovi: 5,989
Iskoristio sam priliku i recimo zamijenio svoju Gigabyte za MSI GTX470 Twin Frozr II i nije mi ni trunkicu zao. Grafu sam uzeo novu u I.Q. centru i decki su za svaku pohvalu. Trebal sam je dobit jos prije 7 dana ali na zalost stiglo samo 4 kom u HR. Sad su dosle samo 2 i jedna je bila moja i jos sam dobio 5% rabata zbog par pohvala shopu i zbog cekanja.
Kad usporedim Twin Frozr II sa stock hladnjakom, kao nebo i zemlja. 25c stupnjeva hladnija i 3x tisa. Bukom je na razini ref 460 grafi, na auto regulaciji necujna a sa 100% venta kao 460 na 100%, mozda trunku glasnija.
68 stupnjeva u Kombustoru sa automatskom regulacijom.
Grafa ima nesto veci VID 0.987v ali zato bez problema poteze do 800mhz bez ikakvog diranja voltaze. Sa ventom na 100% i 800mhz temperatura je odlicnih 55c.
Oc na stock biosu sa 1.087v 860/1000. Radila je i na 870 ali vise od toga ne, memu nisam htio vise gnjavit. Gigabyte bi u ovom testu stala na 840mhz i na punom manjem taktu meme. Temperatura 61c.
850/960, vise od 30% performnsi gratis!!
Ovo je jedina prava GTX 470 koja se moze nabavit kod nas i tih 100kn razlike u odnosu na ostale sa isplati. Nebi nikome perporucio referentnu grafu jer je hladenje strasno lose i ne dopusta da se iskoristi potencijal kartice. Sa ovakvim hladenjem grafa je u stanju dat performanse gtx 480. Za to joj teba nekih 820/1900 sto ova grafa odradi bez problema.
Zadnje izmijenjeno od: MAGARAC. 11.11.2010. u 19:22.
Staro 30.11.2010., 02:19   #150
Computer_Modder
Computer_Modder's Avatar
Postovi: 610
Nabavio sam sve za i7 komp osim grafe (i SSDa, ali on tek dolazi pocetkom 2011), pa je sad dosao i na graficku red.
Uglavnom, bit cu kratak:
Da li se isplati sad kupiti GTX470 ili cekati jos koji mjesec (da li ce doci nesto u istom cjenovnom rangu a da su performanse znatno bolje). Odnosno, opcenito, uzeti sad ili cekati?
Da li je ova kartica u redu: http://www.adm.hr/product_info.php?c...oducts_id=8810 ili ova: http://217.14.221.177/StartEU.ashx?_...1KtR8d16ihplON
Da li mi netko moze reci tocno kolika je cijena ove u IQ Zagria jer mi malo pokazuje 2060, a malo 2500kn.
Kupujem graficku koja bi mi koristila vise godina, da li je navedni izbor dobar ili bi nesto drugo preporucili?
Nisam nikad imao MSI grafu, a kako ne kupujem jeftinu komponentu i razmisljam dugorocno, zanima me da li je to ok izbor ili sto vec?
Pretpostavljam, 1GB bi trebalo biti dovoljno za 1920×1200 rezoluciju, da vecinu igrica pokrece na full high?
OverClockat necu, ali bi, naravno, htio da mi je komp sto hladniji i tisi.
I eto, opcenito, uz odgovore na postavljena pitanja ako moze savjet neupucenome u svijet grafickih kartica. Ponavljam, ciljam da mi komp sto dulje, bez nadogradnje radi.
Kupovina bi trebala biti sutra, pa ako je moguce da mi date savjete do tad.
Hvala unaprijed svim iskusnim forumasima koji su odlucili izdvojiti 5 minuta i pomoci mi da se ne zahebem u odabiru ne tako jeftine komponente.
Konfa je pod moj komp.
EDIT: Zahvaljujem kolegi Magarcu sto mi je sve objasnio i odgovorio na vecinu mojih pitanja (u temi GTX 460), sutra idem po tu 470 u IQ, valjda ce ih jos imat
Zadnje izmijenjeno od: Computer_Modder. 30.11.2010. u 02:26.
Computer_Modder je offline   Reply With Quote
