Master of the VCR
Postovi: 340
Nova Corsair CX serija napajanja
Pojavila se u prodaji nova serija Corsair napajanja, zovu je "builders series" i sastoji se od tri modela: CX430, CX500 i CX600 - što označava i snagu u watima. Cijene - prihvatljive, CX430 je još jeftiniji od ionako povoljnog CX400 kojeg više neće biti, a što se kvalitete tiče.... recimo da bi brand trebao nešto značiti. Napajanja su tek najavljena prije petnaestak dana: http://www.legitreviews.com/news/9105/ pa nekih ozbiljnih review-a nema, tek utisci korisnika na newegg-u: http://www.newegg.com/Product/Produc...ords%29&Page=1 Napajanja izgleda nisu loša, ali nisu niti poput starog CX400. Najvažnije je da je Corsair smanjio jamstvo na 2 godine i da mu CX napajanja ne proizvodi više Seasonic već CWT. Za one kojima se ne da sve čitati, izdvajam mišljneje jednog korisnika sa newegg-a: "Pros: Its better than the $20 units... Cons: -SLEEVE BEARING FAN = SHORT LIFESPAN. Specs say its double ball-bearing, its not. Fan is model# D12SH-12 which is sleeve bearing, not ball - google it. -Only 2-year warranty, compared to 3-year on previous CX400 model(I wonder why...?) -CX400 was made by SeaSonic, CX430 now made by CWT. Cost Optimization... -CX400 had 30amp 12v rail, CX430 has 28amp 12v rail. More 12v power is what you want with today's PCs. Other Thoughts: Overall, Corsair took a rock-solid PSU(CX400) and replaced it with a cheapo that will probably blow up in 2.5 years once the sleeve-bearing fan dies. Looks like I'll have to find another brand to use in my lower-end builds. A ball-bearing fan is one of the most important requirements of any PSU. It doesn't matter if its the best-built PSU in the world, if the fan dies, its game over pretty quick."
♦ As i was going up the stair ♦ I met a man who wasn't there ♦ He wasn't there again today! ♦ I wish, I wish he'd stay away.♦ Zadnje izmijenjeno od: taip@n. 15.10.2010. u 07:59. |
Postovi: 12,600
Prokurvao se i Corsair kako vidim. Treba pricekati jos misljenja i naravno cijene.
Split resist itself!
Postovi: 4,037
Nazalost nema vise ni dostojne alternative, tj. onog Silverpowera SP-SS400 od 400W u Linksa za 360tak kn, ma urota "untimesa ujj" ![]() Toplo se nadam da ce se nova serija pokazat boljom od Chiefteca/Fotrona/Thermaltake i sl. koji su cijenom tu negdi (300-400kn).
![]() Pomelo mi sig -.- |
#6 | ||
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Dočarat ću vam službenu "izliku" jednog predstavnika Corsaira iz njihovog odjela napajanja: Citiraj:
Lokacija: NA
Postovi: 2,620
LOL |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Nazalost, je ![]() Ono sto mi je zapelo za oko je službeni podatak na Cors stranici:
Sto bi znacilo da ova serija nemoze ostvariti cak niti osnovni 80Plus certifikat, tj. efikasnost iznad 80% (na 20-100% loada). Vjerojatno razlog zbog kojeg ih nema na 80Plus popisu? ![]() BTW ovako bi generalno to trebalo izgledati iznutra (uz eventualne dodatne preinake/ustede na kvaliteti nekih dijelova). ![]() A naravno tu je i cinjenica da su deklarirane snage pri 30°C (u odnosu na standardnih 40/50°C), sto bi znacilo da ni toplinu ne podnose najbolje ... Zadnje izmijenjeno od: dh41400. 15.10.2010. u 16:07. |
Premija
Datum registracije: Mar 2009
Postovi: 1,634
...te garancija od samo 2 godine.
K: 7950GX2, 8800 Ultra, GTX295 |
#11 | |
Postovi: 12,425
Kak nemaš? Seasonic S12II Bronze 380W (cca 380kn) i 430W (cca 430kn) IMHO puno bolja opcija od tih novih CX modela.
Anything Goes Martial Art
Lokacija: Tendo Dojo
Postovi: 542
šta je sa dosadašnjim Corsair CX400 napajanjima kojih još vidim da ima po dućanima? Corsair CX400 to su još uvijek stare zalihe koje je proizvodio Seasonic ili su to već ova nova? pitam jer vidim da ih ima još za kupiti pa dok traju zalihe da si ubodem jedno.
"Water! Why does it always have to be water?!" |
#17 |
Too much busy
Postovi: 1,540
A dobro, nećemo se sad plakati ![]() Neko vrijeme će bit pokojeg rabljenog CX400, a onda će se Seasonic ugurat kao nekakav bestbuy (SS-380GB, SS-430GB). Osobno mi je više žao što nema HX450 i HX520 napajanja. Postali su rijetkost...
It's nice to be important, but it's more important to be nice! |
#18 |
Datum registracije: Sep 2010
Postovi: 3
Prednosti i nedostaci napajanja Corsair CCMPSU-600CXEU
Može li mi netko reći zašto ovo napajanje Napajanje 600W Corsair CMPSU-600CXEU ima SAMO 24 mjeseci garanciju? Obično CORSAIR daje 60 mjeseci garanciju. Da li je tu riječ o nekoj (kvalitetom dijelova) oslabljenoj verziji napajanja? I što znači u praktičnom radu "80% energy efficiency" u odnosu na neko drugo Corsair napajanje (npr. Napajanje 550W Corsair CMPSU-550VXEU) http://www.protis.hr/products/compar...MzgzNjh8JHw%3d Unaprije hvala na odgovorima ako netko zna ![]() |
#20 | |
Od danas pa do sutra
Lokacija: ZAPREŠIĆ
Postovi: 65
bio je u potrazi po čitavom ZG da ga nađe.Svuda se prodaju samo novi cx430. Ne može ga se više ni naručit. Teško da češ ga više naći, sretno u potrazi. |
#24 | ||
Postovi: 12,425
![]() Citiraj:
#26 |
Datum registracije: Oct 2010
Lokacija: ZGB
Postovi: 87
kupio cx430 prije 20 dana . uz sljedecu konfu sAM3 Asrock 880GM-LE - AMD 880G Procesor sAM3 Athlon II X4 640 Memorija DDR3 1333MHz 2x2 GB Kingmax HDD SATA II 500 GB WD Caviar Blue 7.200 rpm, 16MB maticna ima integriranu grafu spojim,startam i nece .probam drugo polovno napajanje ,Fortron 400W pnf ,sve uredno radi .igrao tu i tamo koju igru ,skidao s neta 3 dana radio bez prekida . CX430 sam vratio u radnju ,utvrdili da je neispravno .dobio drugo ,zapakirano ,opet ista stvar . jel napajanje slabo ili ?? |
#29 |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Konačno se pojavio i mali preview CX430 napajanja ... sve sumnje (ukoliko ih je uopće i bilo) su definitivno nestale ![]() BTW razlika između starog CX400 i novog CX430 modela (uz iznimku da se u stvari radi o Sleeve bearing ventu): ![]()
The Secret ... |
#30 |
Eddie
Postovi: 5,505
Sumnje u što?! Ja vidim 2 različita napajanja!
