Staro 25.07.2010., 15:24   #91
Josip79
Lokacija: Lika
Postovi: 107
C1E i Virtualization
Jel mi netko može objasniti čemu služe iz naslova navedene opcije u biosu? I jel bi ih bilo dobro uključiti ili isključiti?
Josip79 je offline   Reply With Quote
Staro 25.07.2010., 23:02   #92
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,286
@oppteron- kod mene je na "all cores". na tu foru se l3 cache daje na raspolaganje svim jezgrama dok je kod "bsp" opcije cache namijenjen jezgri koja je pod opterecenjem ako se nevaram tj ako sam dobro skuzio. neznam da li ima razlike u performansama.
@josip - virtualization ti sluzi kada imas instaliran npr vmware. s time virtualizacija bolje radi/brze
c1e - smanjuje potrosnju dok je komp u idle-u (smanjuje napon i multi). ako overklokiras ovo mozes izgasit
Staro 26.07.2010., 13:08   #93
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
C1E - Enhanced Halt State
"Whenever the OS executes the halt instruction, the CPU enters what is known as the halt state. Architecturally, what's going on in a halt state is the clock signal is shut off to the CPU for some period of time. With no clock signal, none of the logic in the chip will do anything and thus power consumption is reduced. Performance is also significantly reduced; however, the halt instruction isn't usually called during application usage, so the performance aspects of the halt state aren't very important.
The problem with the halt state is that it does nothing to reduce voltage, only current draw by stopping clocks from going to the CPU. Since Power varies linearly with both current and voltage (P = I * V), you're effectively only addressing half of the problem. The Enhanced Halt State, as Intel calls it, does two things: it reduces the clock speed of the CPU by decreasing the clock multiplier down to its minimum value (on the EE 965 series, that's 14x, or 2.8GHz), then reducing the voltage. The clock speed is reduced and then the voltage is dropped, to maintain stability.
Intel insists that the enhanced halt state is a significantly lower power state than the conventional halt state, thanks to the reduction in voltage in addition to the reduction in clock speed. While the standard halt state causes a linear reduction in power, Intel's enhanced halt state causes an exponential decrease in power, potentially offering better power savings than the standard halt state. The real world impact obviously depends on how idle your system happens to be."
Izvor: anandtech.com
Intel Virtualization Technology (VT) Explained
malo stariji clanak ali skuzit ces o cemu se radi ako procitas
wiki
intel.com
Staro 05.08.2010., 18:01   #94
MARVIN
MARVIN's Avatar
Postovi: 77
Phenom II 1055T vs 965 vs Core i5 760
Zanima me koji od ovih procesora (Phenom II 1055T, Phenom II 965, Core i5 760) je najbolji za rad u Premieru, Photoshopu, InDesignu, After Effectsu (CS4 ili CS5)?
Gledao sam malo tablice na Andandtechu i tom's hardwareu i vidim da se recimo u Photoshopu razlikuju.
  • Photoshop CS4 - Ovdje je bolji Core i5 (gledam 750 jer nema 760)
  • Premier CS4 - Ovdje je bolji Phenom II 1055T
  • Dok na Andatechu ima samo Photoshop i bolji je Core i5-750
  • Našao sam još i na Adobeovom forumu ovo, što ne ide u prilog AMD-u.
Zanima me vaše mišljenje jel bolje 6 slabijih jezgri ili 4 jače za obradu videa i slike.
Zadnje izmijenjeno od: McG. 05.08.2010. u 22:29.
MARVIN je offline   Reply With Quote
Staro 19.08.2010., 22:41   #95
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
AMD reduces CPU prices to keep market share
AMD recently reduced prices for about 20 of its desktop processors. According to sources from motherboard players, the price cuts are aimed at defending against competition from Intel.
AMD's quad-core Athlon II X4 640 CPU has seen its price drop from US$122 to US$99, while the dual-core Phenom II X2 555 Black Edition CPU dropped from US$105 to US$93, and the quad-core Phenom II X4 955 and 965 Black Edition both dropped US$26. Most of the company's other processors have seen drops up to US$10.
http://digitimes.com/news/a20100819PD213.html
Staro 07.09.2010., 20:33   #96
Flanker-B
Flanker-B's Avatar
Lokacija: Biograd, Hrvatska
Postovi: 30
Da li se isplati dati 300-tinjak kuna više za Core i5 760, ako ima samo malo bolje performanse od Phenoma II 965 Black Edition?
PS: Matične za i5 su skuplje od AM3 matičnih koje podupiru Phenom II ...x4/x6 sa 140W.
Flanker-B je offline   Reply With Quote
Staro 07.09.2010., 22:07   #97
blue#13
Postovi: 516
Ne isplati se!
blue#13 je offline   Reply With Quote
Staro 07.09.2010., 22:32   #98
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Ne isplati se ni Phenom II X4 965 Black Edition, ako možeš nabaviti Phenoma II X4 955 BE.
vedranzeman je offline   Reply With Quote
Staro 14.09.2010., 02:05   #99
SicoCare
SicoCare's Avatar
Datum registracije: Feb 2010
Postovi: 11
Phenom II X6 na 770 chipset
Je li netko probao upariti taj procesor sa starijom matičnom? Imam Gigabyte GA-MA770-UD3 ploču na koju bi stavio 1055t pa me zanimaju vaša iskustva.
Kupovati novu ploču i memoriju = skup biznis, a ako radi ok na staroj i ako ga mogu dići barem na 3500 MHz ne vidim razlog za mjenjanje matične. Hvala na odgovorima.
Zadnje izmijenjeno od: McG. 14.09.2010. u 15:39.
SicoCare je offline   Reply With Quote
Staro 14.09.2010., 02:13   #100
Wolverine
Wolverine's Avatar
Postovi: 12,431
IMHO ja na pločama s 4+1 regulacijom ne bi baš previše dizao X6. Držat ga na def postavkama je OK ali overclockirat i dizat radni napon ne - tada radije uzet ploču s 8+2 faznom regulacijom.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 15.09.2010., 20:50   #101
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Imam jedno pitanje u vezi 1055T 95W. Da li će doći u Hrvatsku i ako da kad?
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
Zadnje izmijenjeno od: McG. 16.09.2010. u 01:17.
NJUNJO_HR je offline   Reply With Quote
Staro 16.09.2010., 09:37   #102
Postovi: 34,053
Nazovi, pa pitaj
Staro 16.09.2010., 10:29   #103
Wolverine
Wolverine's Avatar
Postovi: 12,431
Nije li ASBIS zastupnik?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 16.09.2010., 10:47   #104
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
uvoze asbis, msan i esys ako se dobro sjecam.
Staro 16.09.2010., 11:27   #105
Vragoder
Drone
Vragoder's Avatar
Lokacija: Senj
Postovi: 396
Pozdrav!
Vrijedi li isto i za AMD Athlon II X4, AMD Phenom II X2 te AMD Phenom II X4 procesore na pločama s 4+1 regulacijom napona? Držati ih na def postavkama, ali ne overclockirat i ne dizati radni napon?
Vragoder je offline   Reply With Quote
Staro 16.09.2010., 11:32   #106
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
ja drzim na takvoj ploci oc-an x6 i nije bas za pohvalit se. bio bih sretniji da je ploca sa boljom regulacijom. vjerojatno bi izvuko i koji mhz vise iz cpu-a.
sto se tice x2 i x4 procesora mogu oni isto ic gore samo ne sa nekim ekstremnim oc-om. kod takvih ploca ocekuj pad/porast napona pri opterecenju.
Staro 16.09.2010., 11:33   #107
Wolverine
Wolverine's Avatar
Postovi: 12,431
Vrijedi za proceve koji imaju TDP od 125/140W jer oni već po defaultu vuku puno struje.
Možeš ti overclockirati ali dizanjem napona će se regulacija napona dosta grijat a postoji mogućnost i da rikne.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 16.09.2010., 11:37   #108
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
kad smo kod rikavanja bit ce da mi sata kontroler odlazi u vjecna lovista. sve su prilike
Staro 16.09.2010., 11:40   #109
Wolverine
Wolverine's Avatar
Postovi: 12,431
Zašto to misliš?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 16.09.2010., 11:51   #110
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
zato jer su mi odjedanput obadva os-a (linux i win) poceli bacat errore, da se nemoze citat sa diska, komp se smrzava itd.
pokusao sam i sa drugim diskom instalirat os i ne prolazi. nakon formatiranja diska javlja mi da disk nije spojen.
probao sam i sa drugim medijima i ista stvar.
ostaje mi jos danas probat sa pci sata hardverskim kontrolerom probat dignut instalaciju pa cemo vidjet.
tako da mi sumnja pada na sata kontroler na ploci.
Staro 16.09.2010., 11:54   #111
Wolverine
Wolverine's Avatar
Postovi: 12,431
Jesi probao vratit taktove na default, podizat radni napon za SB?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 16.09.2010., 11:55   #112
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
nisam, al imam to na umu.
nebi reko da je do oc-a, ali neznas dok neprobas tako da cu i to napravit
Staro 16.09.2010., 11:57   #113
Wolverine
Wolverine's Avatar
Postovi: 12,431
Vrlo vjerojatno je do OC-a pa kontroler je dio SB-a. Digni napon na SB-u i stvar bi trebala biti riješena.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 16.09.2010., 12:06   #114
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
Da, to mi je jasno.
Probat cu kad dodem doma pa javim rezultate.
Staro 16.09.2010., 23:04   #115
SicoCare
SicoCare's Avatar
Postovi: 11
Autor cuks Pregled postova
Na koliko ga mhz-a držiš?
Staro 17.09.2010., 00:17   #116
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
na 3400 su sve jezgre, dok u turbu ide na 4ghz.
@wolw- bit ce da je ipak do voltaze. digao sam nb na 1.25 (prije je bio na 1.125) tako da je sad ok koliko sam stigao isprobat. tnx na tip
Staro 17.09.2010., 10:32   #117
Wolverine
Wolverine's Avatar
Postovi: 12,431
Diži i SB napon jer tamo je kontroler.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.09.2010., 11:06   #118
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
budem pogledao danas ako stignem. bas se i ne sjecam da sam vidio napon za sb. mozda sam i vidio, al se nesjecam.
Staro 21.09.2010., 12:14   #119
ninja666xx
ninja666xx's Avatar
Lokacija: Zdenčina
Postovi: 314
Stigli na test novi phenom II x4 970be athlon II 645 i x6 phenom II 1075T.
Zadnje izmijenjeno od: McG. 21.09.2010. u 20:02.
ninja666xx je offline   Reply With Quote
Staro 21.09.2010., 12:42   #120
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,286
nista neocekivano. umjesto 1075t radije bi uzeo 1055t sa 95w tdp-a.
moram priznat da me athlon 645 ugodno iznenadio. sasvim pristojan proc za budget konfu.
