Staro 09.09.2010., 18:17   #1
dac1
Postovi: 27
Thumbs up Roccat Kone + Roccat Vire
Pozdrav svima!
Evo nakon dvojbe i pitanja koji miš kupiti odlučio sam kupiti Roccat Kone uz kojega dolaze gratis slušalice Roccat Vire i uz to sam kupio Steelseries podlogu za miša!
Prvi dojmovi su fenomenalni, miš je fantastičan a i slušalice su super!
Uz miša dolaze i utezi (5,10,15, i 20g) u praktično pakiranoj kutijici!
evo nekih podataka o mišu:
  • 3200DPI Pro-AIM GAMING SENSOR
    for maximum precision
  • TCU – TRACKING CONTROL UNIT
    for increased tracking performance and reduced Pick-Up-Flight syndrome
  • INTEGRATED TURBOCORE (72MHZ)
    for enhanced processing power
  • ONBOARD MEMORY (128KB)
    for up to 5 Game Profiles – stored directly on the mouse
  • CUSTOMIZABLE LIGHT SYSTEM
    showing the full spectrum of colors
  • 4 EASY TO CLIP IN WEIGHTS
    for individual weight adjustment
  • 10 MOUSE BUTTONS
    8 of them customizable + 4-way wheel
  • ERGONOMIC HYBRID SHAPE
    with optimum grip + comfort
  • 16-BIT ARCHITECTURE
    for accelerated data transfer
  • MOUSE FEET
    ultra-quiet and low-friction
Technical Specification
  • True 3200dpi laser sensor
  • TCU – Tracking Control Unit
  • 1ms response time; 1000Hz polling rate
  • 16-bit data channel; 7080fps; 6.4 megapixel, 20g acceleration
  • 72MHz TurboCore processor unit
  • 128kB memory, update-/flashable
  • 1.65m/s(65 inch per second)
  • Extended USB cable, cable diameter: 3mm
Mouse Size
Maximum width ca. 13.5cm x ca. 7.8cm maximum length
Mouse Weight
118g (133g incl. cable)+4 optional weights in 5g, 10g, 15g or 20g
System Requirements
Windows® XP / Windows® Vista / Windows®7
USB 2.0 Port
CD-ROM Drive
Package Contains
ROCCAT™ Kone – Max Customization Gaming Mouse
Fastclip Weight System (4 weights) with Hard Case
Inari Case Mission Book with ID Card
ROCCAT Driver CD
Quick Install Guide
Evo malo i o slušalicama:
Features
  • ULTRA-LIGHTWEIGHT HEADSET FOR ON THE MOVE
    game, make calls or listen to music without any restrictions in movement
  • IN-LINE MICROPHONE
    shields out background noises and transmits speech distortion-free
  • PREMIUM SOUND QUALITY
    from balanced trebles to gutsy bass
  • PERFECT FIT IN ANY EAR
    thanks to the rubberized design of the earplugs
  • NICELY FINISHEDSOFT CASE
    protects the headset and adapter cables
  • FULL FUNCTIONALITY
    with two additional plug adapters for the iPhone, mp3 players, BlackBerrys, PCs, notebooks, sound systems and portable gaming consoles
Driver Units
  • Frequency response: 18~22,000Hz
  • Sensitivity at 1KHz: 105±3dB
  • Impedance: 32Ω
  • Max. input power: 5mW
  • Drive diameter: Ø14.2mm
Microphone
  • Sensitivity at 1KHz: -38±3dB
  • Impedance: ≤2.2KΩ
  • Directivity: omni-directional
Further Information
System Requirements
3.5mm jack socket required
PC (adapter included), iPhone®, Blackberry®
MP3 Music Players in general, iPhone®, iPod®, Blackberry®, PSP®, NDS™
Package Contains
ROCCAT™ Vire – Mobile Communication Gaming Headset
Headset Cable: 1.20m length
1 x PC Adapter cable: 1.30m length
1 x Laptop Adapter cable: 0.17m length
Soft Transport Bag
Quick Install Guide
Sve u svemu mislim da sam dobro prošao jer miš sam košta oko 600kn a slušalice 250kn a sve zajedno kupljeno u linksu za 599kn (miš+gratis slušalice).
Preporučam miša!
Evo to je malo od mene zasad ,dok ne isprobam miša u igricama!
dac1 je offline   Reply With Quote
Staro 10.09.2010., 18:10   #2
P@nj@bi!!!
P@nj@bi!!!'s Avatar
Lokacija: Pred kompom
Postovi: 29
Trebao si pričekati još mjesec dana kada stiže Kone+ sa poboljšanim senzorom i nekim zanimljivim dodacima kao EasyShift[+], nešto slično kao shift tipka na tipkovnici tako da dobiješ još funkcija za dodijeliti na tipke. Miš zadržava stari oblik samo su malo estetski neke stvari izmijenili. Uglavnom imam i ja taj miš verziju v2 i stvarno sam zadovoljan jer sam isprobao hrpu logitecha i razera i nijedan mi nije dobar kao ovaj miš, naravno to je sve stvar kako kome koji miš paše u ruci.
To što si ti uzeo je dobro jer si dobio slušalice tako da si na neki načn uštedio lovu samo što taj paket miš+slušalice ima smanjenu garanciju na 1 godinu.
P@nj@bi!!! je offline   Reply With Quote
Staro 11.09.2010., 16:56   #3
dac1
Postovi: 27
Autor P@nj@bi!!! Pregled postova
Vidiš ovo sa garancijom nisam znao ,jer sam i pitao u linksu da koja je razlika i zašto je jeftiniji ovaj miš sa slušalicama i nije mi znao reć!
