Staro 07.09.2010., 11:38   #31
Punio4
Punio4's Avatar
Lokacija: Zagreb, Maksimir
Postovi: 437
Divno, a ovi iz IQ centra Zagrie me uvjeravaju da mi je miš ispravan i da je "normalno da se miš trese jer je on tako precizan da i najsitnije pomake prenosi"
Punio4 je offline   Reply With Quote
Staro 07.09.2010., 17:58   #32
++Mate++
Datum registracije: Mar 2009
Postovi: 10
Reci im da ti hoces neispravan koji nije toliko precizan ako su vec tolko bezobrazni.
++Mate++ je offline   Reply With Quote
Staro 07.09.2010., 18:13   #33
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor ++Mate++ Pregled postova
ne nego bi trebao napisati mail logitechu, pričekat odgovor i isprintat to i odnjet tim debilima!
Staro 07.09.2010., 19:06   #34
Punio4
Punio4's Avatar
Postovi: 437
Autor Blue_Fatal1ty Pregled postova
Autor Punio4
Hello,
I have an issue with the mouse cursor jittering left-right when the mouse is subjected to vibrations.
On any surface, when my desk is shaken, most often by the subwoofer positioned under it, the cursor shakes slightly (depending on the DPI, ~5px on 800, no acceleration), even with the mouse pressed firmly on the surface.
It seems to me like the sensor is a bit loose and swings on vibrations.
Is this considered a defect, and if so, is it covered by the warranty?
Thank you for your time.
Autor Logitech Support
Dear Ivan Čurić
Thank you for your e-mail,
It would appear that your product has suffered a hardware failure. It can be very frustrating when this happens, but hopefully the issue can be quickly resolved.
As your product is less then two years old, and as you have not purchased the product directly from us, I would need to refer you to the reseller where you purchased this product as the reseller will deal with the warranty during the first two years after purchase.
For more information regarding our warranty policy, please browse to the following web-site:
http://www.logitech.com/index.cfm/fo...nl&legalitem=4 (UK web-site)
Please do not hesitate to contact us again should you have any further questions or comments regarding our products or procedures.
Kind regards,
Esmond Hoencamp
Logitech Europe SA
Customer Support.
Morat ću se gnjavit s njima ipak...
Staro 05.12.2010., 08:27   #35
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Evo i ja sam vlasnik G500, koji je nasljedio MX 518 i sad, posto mi je ovo prvi mis sa bocnim scrollom imam jedno pitanje...
Naime bocni scroll mi ne radi uvjek i u svakoj aplikaciji..U WMP radi, dok evo recimo obradjujem fotku u PS-u i fotka je pod vecim zoomom tako da se da micati gore dolje i ljevo desno, no medjutim, to uspijevam izvesti samo klasicnim gore dolje scrollanjem, dok ljevo desno ne trza ... Instalirao sam Set Point koji sam dobio sa misem ... trebam li jos nesto uciniti ?
Hvala!
Konfa: Intel Core 2 Duo E 6400, 2.72GHz || Asus P5B Deluxe || 8800 EVGA GTS 320 mb || Super Talent 2x1 gb 800MHz CL5 || Seagate Barracuda 7200.10 320 GB 16 mb || Samsung Spinpoint F1 750 GB 32mb || Seasonic S 12 430W || A+ X-Blade || Logitech Z 5500 || CL X-Fi Xtreme Game || Logitech G500 || Logitech UltraX Flat Desktop || Canon Pixma iP4300 || Samsung ML-2510 || Toshiba Regza 32XV733G
Poggiali je offline   Reply With Quote
Staro 16.12.2010., 18:37   #36
benny_blanco
another brick in the wall
benny_blanco's Avatar
Lokacija: osk
Postovi: 214
pozdrav, evo i sam sam kupio doticni mis tu na forumu, napravim profil za cod4 koji mi se automatski pokrece ali mi neradi pola tipaka, recimo tipke pored ljevog klika uopce nemogu dodjelit nikakvu naredbu?! tako isto i srednja tipka kod palca jel ima netko slicnih problema?! hvala!
benny_blanco je offline   Reply With Quote
Staro 20.12.2010., 15:49   #37
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Autor Punio4 Pregled postova
Ima li itko idući problem:
Kursor se trese na ekranu kad se stol zatrese, iako se miš fizički ne pomakne (priljubite ga uz podlogu i provjerite).
Podignite miš u zrak i protresite ga. Da li se miče kursor?
Poslao sam mail logitechu, i to je navodno čest hardverski problem, problem je u senzoru izgleda.
Najviše mi smeta doma kad stavim jači bas dok gledam film, stol počne vibrirati, i najednom iskoče kontrole i kursor na ekranu...
Evo mene zeza, da iz cista mira pocne trzat kursor, ali meni se ni stol ni nsita ne trese, nego ko da pogodim neku reflektirajucu podlogu ili sta, onda ga moram pomaknut pa se smiri, bez obzira o kojoj podlozi se radi :/ (bio stol, bila podloga za mis)
Staro 20.12.2010., 15:50   #38
alengrosevic
alengrosevic's Avatar
Postovi: 3,793
Autor Poggiali Pregled postova
vidi da ti ispod misa, dolje kod senzora nije doslo prasine pa to zeza. ocisti s stapicem za uho pa vidi jel i dalje zeza...
Staro 20.12.2010., 15:59   #39
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
maa cisto je , a i mis je imao 3-4 dana od nabavke kad je to pocelo, kao da je izgubio na preciznosti, u tih nekoliko dana :/
Staro 24.12.2010., 17:01   #40
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Planiram kupiti ovaj miš pa me zanima da li može normalno raditi bez SetPointa jer sam alergičan na taj bloatware.
Znači da mogu normalno mjenjati DPI i sve bez SP-a?
Staro 24.12.2010., 17:04   #41
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,295
mozes, ali opet ce ti bit potrebno instalirat sp zato da si slozis svoj profil kako ti odgovara. nakon toga ga mozes maknut.
Staro 24.12.2010., 17:08   #42
Veki-os
Veki-os's Avatar
Postovi: 3,996
Znači to je onaj profil koji snimim u miš?
Imam MX518 več par godina i razmišljam o nečem boljem pa mi jedino G500 dolazi u obzir,cjenom,žicom i oblikom
Ne znam da li se uopče isplati mjenjati,igram samo BC2,ne znam dal bi tu osjetio neko poboljšanje obzirom na laser i 5700DPI-a?
Staro 24.12.2010., 17:12   #43
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,295
neznam koliki bi osjetio skok. imao sam prilike probat obadva i nije mi bila neka prevelika razlika u koristenju.
ali, kad sam presao sa svog misa a4 tech x718-f tu sam osjetio skok, ponajvise zbog mogucnosti podesavanja tezine i kreiranja profila.
najbolje bi ti bilo da odes do nekog ducana u kojem bi mogao malo isprobat g500 pa ces tako najbolje znat dal ti se isplati prelazit.
Staro 25.12.2010., 01:15   #44
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Veki-os Pregled postova
imam oba i nekako mi ruka puno bolje leži u G500 i tipke su bolje (kotačić je neusporedivo kvalitetniji).
Sama osjetljivost je neprimjetna.
Staro 25.12.2010., 11:22   #45
Ziiky
Ziiky's Avatar
Postovi: 2,883
Moj upgrade tokom godina je tekao ovako: mx518,g5,g500.
Najmanji skok u napretku sam osjetio prelaskom sa mx518 na g5.
Nedavni prelazak sa g5 na g500 mi je bio olaaaalaaaa.
Prvenstveno me odusevio (i jos uvijek to cini) kotacic i njegova freespin funkcija i kad je aktivirana, a pogotovo kada je deativirana. To je nesto fenomenalno! Potegnes ga 2 puta i na dnu/vrhu si
Srednji klik mi napokon odgovara svojom jacinom i dobro je ukomponiran uz lijevi i desni scroll sto je kod g5 bilo nakaradno.
Na sam mis, ergonomiju i oblik nemam zamjerke vec samo rijeci hvale.
Sve su to misevi vrlo slicni oblikom na koji je moja ruka naviknuta.
Koristim svih 5700dpi uz ugasenu akceleaciju i brzinu (podesene su mi 3 brzine: 2000, 4000-svakodnevno, 5700).
Odziv je trenutan i fluidan puno bolji od g5.
Mislim da ti se prelazak mx518-g500 definitivno isplatiti. Pogotovo ako se 518-aestica da prodati i ubosti g500 tu na trznici.
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Zadnje izmijenjeno od: Ziiky. 25.12.2010. u 11:33.
Staro 26.12.2010., 14:59   #46
Veki-os
Veki-os's Avatar
Postovi: 3,996
Hvala na odgovorima,razmislit ču još o kupnji.
Malo je skup 420kn ali ako bude koji na tržnici po normalnoj cjeni vjerojatno uzimam
Staro 06.01.2011., 04:30   #47
goranmw1
goranmw1's Avatar
Datum registracije: Nov 2010
Postovi: 43
G500 problemi!?
Prošlo je 12h od kupnje dotičnog miša, jako sam zadovoljan sa svime osim scrolla. Naime, kad pritisnem onu tipku da scroll ne "struže" već da se lagano okreće, događa se da za vrijeme surfanja ja kotačić okrećem na jednu stranu i dođe on do željene pozicije, a onda sec. ili dvije nakon se kotačić sam zavrti i pomakne mi stranicu nekud dalje, kud' ga je volja, obično u suprotnu stranu (kao da se kotačić narola pa ga nešto vuće u suprotnu stranu, pojma nemam)! Nisam još imao takva iskustva sa miševima, jest da čovjek za te novce očekuje puno od miša, ali ja bi ipak zadržao pravo da sam scrollam, a ne da "on" to radi bez moje volje . Da li je to normalno, da se žalim ili ??! Rekli su mi u Linksu da ga mogu vratiti u roku 8 dana jer nisam bio siguran kojeg bi, MX 518 ili ovog pa..., ali ako je to normalno, možda ipak ne bi bilo loše razmisliti o zamijeni??!
goranmw1 je offline   Reply With Quote
Staro 06.01.2011., 04:53   #48
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ista stvar mi se događala kod tog hyperscrolla dok nisam naučio tj navikao se kako ovladati sa njime i sad ga koristim precizno i nebi ga mjenjao ni za šta na ovome svijetu. Ajmo rec da mogu dokument od 500 strana zarolat i zaustavit da pogodim unutar 2-5 stranica....
Staro 06.01.2011., 12:43   #49
2 die 4
2 die 4's Avatar
Postovi: 2,280
Da i ja mislim da ti je potrebna samo praksa, ali nisam siguran možda se stvarno radi o defektu, a probaj još malo se igrati s time, pa ako skužiš do sutra da nekaj ipak nevalja odi i zamjeni ga za novi, odnosno reklamiraj to!
RedGreenBlue
2 die 4 je online   Reply With Quote
Staro 07.01.2011., 16:55   #50
Veki-os
Veki-os's Avatar
Postovi: 3,996
Još jedno pitanje prije kupnje,imam Razer Goliathus Control podlogu http://store.razerzone.com/store/raz...ctID.169417000
Zna li netko da li če dobro raditi miš na ovoj podlozi pošto je malo "hrapava" ?
Staro 07.01.2011., 16:57   #51
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Odlično radi na toj podlozi.
fran123456 je offline   Reply With Quote
Staro 07.01.2011., 17:24   #52
Antiša
Datum registracije: Dec 2010
Postovi: 147
I mene to lagano frustrira. No, ajde kolko tolko pretrpim - Ima nekih 9 mjeseci koristim G500,imam osjecaj da ce se taj scroll svaki trenutak raspasti.
Antiša je offline   Reply With Quote
Staro 23.01.2011., 13:30   #53
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Poceo mi je krepavat MX518 nakon ...hmm... otkad je izaso na trziste? Imam ga valjda oko 5 godina, vise?
Nadam se da ce G500 bit dobra zamjena jer su po ergonomiji slicni, a saka mi savrseno pase na MX518.
Staro 23.01.2011., 14:54   #54
asibulj
Misanthrope
asibulj's Avatar
Lokacija: Neumünster
Postovi: 571
Autor IcyTexx Pregled postova
Ja sam prešao sa MX518 na G500. Po meni ovaj će ti biti i više nego dobra zamjena. Nije mi žao ni lipe koju sam dao za njega.
x230
asibulj je offline   Reply With Quote
Staro 23.01.2011., 17:30   #55
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Ja imam i g500 i mx518 sad tu i mogu ti reci da mi skoro isto lezi ruka na oba dva misa, na mx518 mi malo bolje lezi(tj ugodnije je ) nego g500 . Ocito je ovaj g500 malo drugaciji ali nist strasno kao kod g700 di se nikak nisam mogo priviknut. Ova plastika je malo drugacije radjena nego na mx518 sto je daleko bolje jer je hrapava pa ti mis nece izletit iz ruke prilikom nekog ludog manevra sa helikopterom u bc2 . Ali ja cu ipak prijeci na rat 7 dok se okrenu neke pare...
viper je offline   Reply With Quote
Staro 23.01.2011., 17:45   #56
Veki-os
Veki-os's Avatar
Postovi: 3,996
Autor fran123456 Pregled postova
Ovo se pokazalo totalno netočno,miš je radio kao da je kuglični.
Malo sam proguglao i vidio da taj miš nikako ne radi na "mekanim" podlogama pa sam kupio SteelSeries 4HD podlogu koja je napravljena baš za senzor na G500 i na još jednom mišu,zaboravio sam kojem,sad miš radi perfektno
Staro 23.01.2011., 17:58   #57
Dottore
Dottore's Avatar
Postovi: 7,706
vrijedi li ta podliga za G9x
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 23.01.2011., 21:06   #58
asibulj
Misanthrope
asibulj's Avatar
Postovi: 571
Autor Dottore Pregled postova
Prjijtelj ima tu podlogu i RAT7 i kad sam igrao BC2 kod njega imao sam neki osjećaj da snip nekako nije "miran" kao kod mene (G500 + CM Battlepad SSK). Podloga je mekana i stvarno je užitak držati ruku na njoj.
x230
Staro 23.01.2011., 23:01   #59
trpi
de preporucite neku ultra glatku tj brzu podlogu, sto manje trenja, s ovim xurfaceom sam probao svasta i nikako da se zaljepi zauvijek. cak ljepio ljepilima, pa i sa dvostrano ljepljivom trakom al uvijek pogrbavi.
Staro 24.01.2011., 00:13   #60
benny_blanco
Lokacija: osk
Postovi: 214
veki di si u osijeku uzeo tu podlogu i po kojoj cijeni?
