Staro 28.06.2010., 22:28   #91
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Automatski download vuče jedino Engleske i Kineske titlove dok se ručno mogu učitati svi titlovi.
ivand123 je offline   Reply With Quote
Staro 30.06.2010., 22:17   #92
RaNz0
Lokacija: Zagreb/Križevci
Postovi: 346
Question
trebaju li posebni codeci za taj player, ili ih ima integrirane ko vlc?
RaNz0 je offline   Reply With Quote
Staro 30.06.2010., 22:22   #93
Postovi: 7,568
Zadnje izmijenjeno od: McG. 13.01.2012. u 01:23.
Staro 04.07.2010., 00:38   #94
ivand123
ivand123's Avatar
Postovi: 373
Autor VideoLAN
The latest released version of VLC, 1.1.0, that was out a week ago, and has been downloaded half-a-dozen millions times so far, has added GPU acceleration for HD decoding under Linux and Windows. On Windows, as already stated, the code isn't working correctly with AMD Radeon cards.
Therefore, we have been working with AMD on this topic and after common work, we are going to release a new version of VLC, versionned as 1.1.1, that will work with the upcoming ATI Catalyst 10.7 driver. AMD did provide us a beta of this driver and we have verified successfully that GPU acceleration works.
Thanks for your understanding and your support.
Još samo malo čekanja i imat će mo i mi normalnu gpu akceleraciju!
Staro 04.07.2010., 01:15   #95
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
@Baja 001
Pa kolega narafno da mislim na automatski dl, duuh
Lako je ucitati prijevod sa strane, nego sam se ponada da moze "vuci" sa nekih odredjenih stranica prijevod na odabranom jeziku (puno trazim? ). Mozda bude takvo nesto u buducim verzijama...
Staro 04.07.2010., 10:55   #96
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Sn4k3 Pregled postova
@Baja 001
A to je podržano samo sa krivih servera
Staro 10.07.2010., 14:48   #97
Ari
Ari's Avatar
Datum registracije: Jun 2010
Lokacija: Cro
Postovi: 180
Zanima me da li će biti problema ako stavim SPlayer i The KM Player.Za defaultni bi stavio SPlayer jer je brži kod startanja i svega,a KM bi mi bio ako slučajno S ne može nešto otvoriti kao npr: .txt oblik titlova,koji su doduše jako rijetki.
Mislim da nebi trebalo biti sukobljavanja kodeka jer i sad imam osim WMP,K-Lite mega codec pack sa svojim classic playerom i The KM Player,a imao i onaj veliki player koji se dobije u Nero paketu
Ari je offline   Reply With Quote
Staro 10.07.2010., 15:04   #98
Postovi: 7,568
Staro 10.07.2010., 15:46   #99
Ari
Ari's Avatar
Lokacija: Cro
Postovi: 180
Autor McG Pregled postova
Ne bude se ništ poklalo, jer SPlayer uopće ne trebaš instalirati, samo ga raspakiraš u željeni folder. Makar ne znam kaj će ti tolko playera i još k tome K-Lite codec-pack.
Jednostavno si odaberi jedan player i drži se njega, jer nema smisla koristiti jedno 5-6 playera i još K-Lite pored njih.
Deinstalirao sam ovaj Nerov pred nekih pola godine,inače ne želim ih sada micati da nebi nešto poremetio,osjetljivo je to oko kodeka a nemam problema....The KM sam kasnije otkrio i stavio,classic mi je ružan a nisam ga htio micati baš iz razloga da nebi nešto poremetio.
Tu kombinaciju planiram za ubuduće kod nekog novog formatiranja diska koji će doći tko zna kada jer sad imam kvalitetan backup uz Acronis True Image.Znači samo KM i S player,čak i Windows Media Player mislim deinstalirati.
Ovo što kažeš da ne treba instalirati S Player mi je čak i nepoželjno jer onda valjda treba ručno asocirati fajle,kako ih inače može prepoznati dvoklikom na film ako player niti nije u sistemu ?
Staro 10.07.2010., 16:22   #100
Postovi: 7,568
Staro 10.07.2010., 16:27   #101
Ari
Ari's Avatar
Lokacija: Cro
Postovi: 180
Odlično.Portabilnoj verziji prednost u tom slučaju
Staro 21.07.2010., 15:42   #102
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.1
This is a minor release, focused on bugfixing issues, notably
- libVLC improvements and fixes
- Windows video output fixes
- DxVA decoding on ATI cards (you need ATI Catalyst 10.7)
- Fixes for all interfaces: Qt, Mac, Skins, HTTP
- Various decoders and demuxers fixes
- Updated translations
Sultan je offline   Reply With Quote
Staro 21.07.2010., 15:55   #103
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Staro 29.07.2010., 14:01   #104
ivand123
ivand123's Avatar
Postovi: 373
Nemogu nikako natjerati VLC da koristi grafičku kak spada!!! Imam 1.1.1 i Catalyst 10.7 al on neće i neće nikako, kod 720p filma mi je cpu usage oko 20%, a gpu usage stalno na 0%
Staro 30.07.2010., 00:20   #105
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.2
This is a minor release, focused on bugfixing issues, notably:
- fixes in TS and avformat demuxers
- fixes in audio filters for the 'mono' issue
- fix for the direct3d video output that played nothing on old nVidia cards
- updates for somes scripts (youtube, ...)
- fixes for the interfaces
Staro 01.08.2010., 18:13   #106
tutix
tutix's Avatar
Postovi: 4,069
Zna li netko kako napraviti "fini" zoom sa VLC playerom kad je u fullscreenu?
Recimo sa GOM Playerom sam to mogao sa + i - na numpadu ali na VLC-u nigdje to ne nalazim.
Staro 07.08.2010., 11:30   #107
Ergometar
Ergometar's Avatar
Datum registracije: May 2009
Postovi: 141
Izvoli:
Ctrl+ Up/Down Arrow – Increase or Decrease the volume.
Ctrl+ Left/Right Arrow – Forward or Rewind the video.
A – Toggle video in different aspect ratios; keep on hitting ‘A’ on your keyboard to toggle different aspect ratios.
C – Crop the Video; hitting ‘C’ again and again crops the video, horizontally and vertically in turn.
F – Switch to fullscreen and exit fullscreen.
G – Subtitle delay, hitting ‘G’ on keyboard inserts a -50ms delay, hitting ‘G’ twice will insert a -100ms delay, thrice for a -150ms delay and so on.
H – This works as reverse process for ‘G’, i.e. hitting ‘H’ inserts a subtitle delay of +50ms delay.
J- Audio delay of -50ms every time you hit ‘J’
K – Reverse of ‘J’, i.e. hit ‘K’ to get a +50ms audio delay.
M – Mute/un-mute.
N – Play next track from the playlist.
P – Play the Previous track in the playlist.
S – Stop playback
T – Show Time played/ Time left
V – Enable subtitles (if available).
Z – Zoom in and Zoom out.
This a list of general shortcuts, if you want to see more advanced ones, you can go to Tools > Preferences (Ctrl-P) > Interface > Hotkeys settings (check the “Advanced options” box), you can also customize these shortcuts as per your requirements, for better accessibility.
Ergometar je offline   Reply With Quote
Staro 11.08.2010., 20:12   #108
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Hej ekipa iz vaseg iskustva, dali je bolji VLC ili MPC HC...znaci treba mi samo za gledanje filmova bez dodatnih instaliranja nekih codec packova tipa K-lite i sl.
Do sada sam koristio GOM, ali kako mi on vise ne radi kako treba te ne mogu gledati ok .mkv na njemu trazim neku alternativu.
MPC HC sam instalirao...ali ni ovaj VLC ne izgleda lose te po vasem koji je bolji?
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 11.08.2010., 20:31   #109
Rain Man
Lokacija: x
Postovi: 1,447
Ja kao glavni koristim MPC HC, al VLC je stalno instaliran i vise puta uskoci.
Rain Man je offline   Reply With Quote
Staro 11.08.2010., 21:23   #110
win32
win32's Avatar
Postovi: 1,517
Autor Rain Man Pregled postova
Samo jedno pitanje.....kako napraviti da se na MPC HC odmah program otvara u vecem prozoru i da titlovi malo bolje izgledaju.
Uz to mi GOM recimo daje bolju sliku nego MPC HC, ali mi ne valja jer ne cita kako treba neke .mkv fileove sa integriranim titlovima, a instaliranje K-lite packova ne dolazi u obzir.
Dali se ne "kolju" integrirani titlovi od VLC-a sa onima iz MPC HC-a? Te koji player daje bolju sliku?
Staro 12.08.2010., 00:17   #111
Rain Man
Lokacija: x
Postovi: 1,447
Ja sam odabrao MPC HC upravo zbog cinjenice da je on imao vec od davno dobru podrsku za hardversku akceleraciju. Moguca je bila laka integracija vanjskih codeca u player (ffdshow, coreavc). Imao je dobru podrsku za puni raspon boja (0-255) i definitivno mi MPC ima bolju sliku nego GOM. Ja sam se upravo GOM-a rijesio zbog lose slike i forsiranja njihovih codeca. EVR dobro radi, program se dize trenutno, ima mogucnost mijenjanja tipkovnickih kratica...
Za titlove ti ne znam jer ih ne koristim. Koliko se sjecam iz tuđih podesavanja, radili su titlovi dobro, izgledali... normalno. Za otvaranje u vecem prozoru, mislim da nema tu mogucnost.
Staro 12.08.2010., 19:47   #112
win32
win32's Avatar
Postovi: 1,517
Danas sam se poigrao sa MPC HC i ostajem na njemu 100%.
Sve radi kako treba, malo sam podesio neke stvari i to je to.
Moguce da VLC instaliram radi nekih drugih stvari, ali kao default video player mi ostaje MPC HC.
Hvala na savjetima!
Staro 19.08.2010., 09:29   #113
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.3
- fix NULL dereferences in taglib module (CVE-2010-2937)
- fixes in FTP, podcast and DVD access and demuxers modules
- fixes regression in playlist playback order and m3u export
- fixes in Skins2, Qt and Mac interfaces
- update translations for Dutch, Sinhala, Hebrew, Estonian and Spanish
- misc fixes and updates for specific architectures
Staro 23.08.2010., 21:51   #114
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Malo me cudi prikaz titlova kod ovog playera. Nudi samo odredene velicine koje ne odgovaraju nikako.
Na monitoru 20'', Normal velicina titlova je sitana za udaljenost od 2m a Large prekrije preko 1/3 ekrana. Na tv-u je odlicno kad je na Large.
Da li je moguce rucno podesit velicinu?
BlackDwarf je online   Reply With Quote
Staro 23.08.2010., 22:28   #115
Ico_Zg
Ico_Zg's Avatar
Postovi: 604
Može se ručno podesiti:
Preferences/Show All = Video/Subtitles-OSD/Text Renderer/Font size in pixel
Ico_Zg je offline   Reply With Quote
Staro 23.08.2010., 23:18   #116
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Thx. Da, nisam imao cijeli prikaz oznacen.
Staro 24.08.2010., 00:02   #117
Ico_Zg
Ico_Zg's Avatar
Postovi: 604
Nema na čemu.. Malo su zakomplicirali postavke kod VLC playera, osobno ga ne koristim jer mi je draži BsPlayer ali ga imam instaliranog na compu. Ipak je trebalo malo truda da se nađe navedena opcija.
Staro 27.08.2010., 20:13   #118
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
VLC media player 1.1.4
This is a minor security release, mainly aimed at fixing a Windows-only security issue, it also fixes minor issues:
- Windows dll loading security issue, in Qt4 and dmo modules
- fix for folders opening issue on Windows
- updated translations
Staro 30.08.2010., 18:46   #119
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
da li se u Splayeru može kako nariktati da traži hrvatske titlove? kao što nalazi engleske
Staro 25.10.2010., 18:48   #120
Postovi: 7,568
