Staro 10.08.2010., 19:40   #271
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Hi Folks,
Some of you may know about this fix, but I was really upset at the frame rates until I realized what the problem was.
This is for you Nvidia folks that may be wondering why the game is running slow.
I downloaded the steam demo, and part of the installer installed the newest version of Physx, problem is that is installed in in CPU mode, so the game was not using the GPU to render the physics (overloading the CPU and causing low frame rates).
The simple fix for you NVIDA Steam demo folks that may be in the same boat is to uninstall your physx and reinstall Physx manually from your Mafia II steamapps folder under the 3rd folder
In my case it was here:
C:\Program Files (x86)\Steam\steamapps\common\mafia ii - public demo\3rd
Now the game runs rock solid 60 FPS and now the game is amazing. Cars are easier to drive, and the Shooting is easier to target (along with amazing visuals)
Good luck, if this helps one person my work is done
Hi Folks,
fran123456 je offline   Reply With Quote
Staro 10.08.2010., 19:47   #272
Wozniak jR.
humanware
Wozniak jR.'s Avatar
Lokacija: zGb
Postovi: 456
Odigrao malo, cini se zanimljivo. Glazba u igri, 11/10
Wozniak jR. je offline   Reply With Quote
Staro 10.08.2010., 20:01   #273
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
http://i33.tinypic.com/2mozi1h.jpg
Ovo su postavke.
http://i38.tinypic.com/2nqqpdw.jpg
Ovo dobijem sa uključenim FRAPSom, bez FRAPSa dobijem maksimalni fps 43-45 (mjerio par puta)
Njema veze, ostavim tu rezu,sve ostalo isključim i stavim na low, ide kao med.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 10.08.2010., 20:10   #274
k1klop
Postovi: 105
izaso demo time limit unlocker
nisam siguran da smijem stavit link pa necu...
k1klop je offline   Reply With Quote
Staro 10.08.2010., 23:06   #275
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Sve sto je dobro kratko traje. Mogli su barem 2 misije staviti. Auti su mi super kada se ukopca simulacija .... ali nisam uspio poderati gume.
Postavke
Reza
' alt='' border=0>
Vejita je offline   Reply With Quote
Staro 10.08.2010., 23:21   #276
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Meni su isto auti fora sa simulacijom. Nadam se da bu u cijeloj igri bilo još više vrsti auta i kamoina. Onaj stari Peterbuilt mi je najbolje vozilo u igri.
Reinstalacijom physxa je igra proradila i sad ide stvarno dobro sa medium fizikom.
MAGARAC je online   Reply With Quote
Staro 10.08.2010., 23:24   #277
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Probao sam staviti na High physx i zacudo sam dobio visokih 9 fps . I pitanjce. Dali vama nakon sta izađete van iz igre ostane tamno sivi ekran.
' alt='' border=0>
Staro 10.08.2010., 23:38   #278
georgy
georgy's Avatar
Postovi: 408
Probao, super mi se čini.
Ostao i meni zatamnjeni ekran.
Ali, ctrl + altgr + delete (imam Windows 7) i Cancel to riješi.
georgy je offline   Reply With Quote
Staro 10.08.2010., 23:49   #279
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
more mi ko dati linka di da skinem Hvala...
hobitxxx je offline   Reply With Quote
Staro 10.08.2010., 23:51   #280
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Autor hobitxxx Pregled postova
A omfg, Steam, pa koliko se puta još to mora naglasit
xGAME je offline   Reply With Quote
Staro 11.08.2010., 00:00   #281
Beo
Lokacija: United Kingdom
Postovi: 512
Eto pokupio od frenda nvidiju gt220 pa cu nju piknut za fiziku i napravit dva bencha pa bubnem rezultate
Beo je offline   Reply With Quote
Staro 11.08.2010., 00:13   #282
Constantine
Constantine's Avatar
Postovi: 668
Autor Vejita Pregled postova
da,jako puno ljudi ima taj problem.
Constantine je offline   Reply With Quote
Staro 11.08.2010., 00:14   #283
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Autor xGAME Pregled postova
Uberštrudelomfg mislim da misli na time unlocker kako godeter.......
Prekratak demo, nije loš. Preće se igra kad izađe
Michel je offline   Reply With Quote
Staro 11.08.2010., 00:49   #284
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,615
Meni je vladanje auta nekako divlje, iako je na arkade, to se ne da lovit po cesti hehe
Staro 11.08.2010., 01:07   #285
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Vožnja je užasna. Ne znam kako bi trebao odigrati misije u kojima ću morati voziti...preloše.
Stalo sve 5.
Staro 11.08.2010., 01:09   #286
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Autor Hamm Pregled postova
Stalo sve 5.
Bacis se u tuning i rasturis, to ti je sad novi feature u ovoj igri, ali bez neonki molim
Pomelo mi sig -.-
Staro 11.08.2010., 01:21   #287
Lovrix
Lovrix's Avatar
Postovi: 41
Neznam stavio sam "stage2" motor ali cini mi se da ide isto kao i serijski na onom kabrioletu sam to radio
Zadnje izmijenjeno od: Lovrix. 11.08.2010. u 01:27.
Lovrix je offline   Reply With Quote
Staro 11.08.2010., 01:38   #288
Drvoje
Drvoje's Avatar
Postovi: 4,037
Autor HKS Pregled postova
Nitro ti je osnovna "supstancija" za tu vrstu preseransa
Sorry na zayebanciji ali ja se moram iskaliti, jer moja yebena kartulja je za qurac pa mi je cili demo bija mucenje. Sad placem u kutu i cekam Mass (d)Effect 2 da mi ga prijatelj iz zaljeve dostavi brzinom cca 850kb/s kako bi utjesio svoje napaceno biche. Iduca "plata" mi gine na novu (g)rafulju, a vi kolege uzivajte
Pomelo mi sig -.-
Staro 11.08.2010., 02:14   #289
e-one
Civic (ab)user
e-one's Avatar
Lokacija: Zagreb-Dubrava
Postovi: 471
Ne sjećam se kad sam zadnji put neki demo skidao, al ovo bih baš volio probat. Začudio se kad sam vidio da demo ima samo 1gb?? Btw možda sutra/prekosutra upadne GTX470 pa ću ovu 260ku isprobat za fiziku prije nek ju prodam pa napravim neki bench.....
e-one je offline   Reply With Quote
Staro 11.08.2010., 02:34   #290
Blaster32
Blaster32's Avatar
Postovi: 154
Malo promoviram video. Frajer se zabio u drotove pa platio kaznu lol
http://www.youtube.com/watch?v=w29wCS3IJRo
Blaster32 je offline   Reply With Quote
Staro 11.08.2010., 05:05   #291
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Ovo mi se sviđa jer obicno samo ti moras nahebati.
' alt='' border=0>
Staro 11.08.2010., 09:30   #292
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor Drvoje Pregled postova
Na početku se "šuškalo" da će vožnja biti ista kao i u GTA IV što bi bilo ok za razliku od ovog što sad imamo.
Možda nešto pokrpaju do 24.08 ali sumnjam.
Staro 11.08.2010., 11:39   #293
m4x
Postovi: 579
meni je vožnja ok kad se privikneš,ipak su to stari auti koji imaju slabu upravljivost
a možeš ih nabrijat u garaži i onda idu stvarno brzo
u opcijama za vožnju imaš: normal i simulation
evo malo screena
m4x je offline   Reply With Quote
Staro 11.08.2010., 11:48   #294
FitzTN
FitzTN's Avatar
Postovi: 1,615
Nisam baš upućen u igre jer nisam dugo ništa igrao (kad nije Mafia II dugo izlazila ) pa nisam upućen kako se cijene kreću.
Ovih 50, odnosno 60€ mi je puno previše, tko zna kolko će to onda bit u dućanu kod nas
Staro 11.08.2010., 12:16   #295
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor m4x Pregled postova
Jasno. I u Mafia I su bili stariji auti pa je vožnja bila odlično napravljena.
Nije stvar u brzini nego u ponašanju automobila na cesti.
Fino. Budem bacio oko.
Staro 11.08.2010., 13:39   #296
m4x
Postovi: 579
grafika u mafii 2 je stvarno čudna,drukčija od svih sličnih igara,boje su izražene i imam dojam kao da igram na manjoj rezoluciji od 1680*1050
Staro 11.08.2010., 14:01   #297
njoka.
njoka.'s Avatar
Datum registracije: Jul 2010
Lokacija: Vukovar
Postovi: 111
Zainteresiran sam za Mafiu 2 i odigrat cu je kad izadje.Veliki sam fan GTA serijala i nazalost prvu Mafiu nisam odigrao.Zanima me sad nakon demoa,ako mi netko moze odgovorit na jedno pitanje.
Zanima me kakav je grad u igri?
-koliko je interaktivan
-velicina
-dizajn
-i koliko je zanimljivo njegovo istrazivanje
Znam da mozda nije u redu usporedjivati grad u ovoj igri i GTA4 jer igre nisu smjestena u ista razdoblja,ali jednostavno moram znat
njoka. je offline   Reply With Quote
Staro 11.08.2010., 14:36   #298
Beo
Postovi: 512
Eto odvrtio brdo benchova sa gt240 za fiziku i bez. (EDIT)
Eto sve max bez fizike:
min 11 fpsa, max 160, iako kad sam pustio fraps on je zabiljezio min 87 fpsa. Tako da mi je to cudno.
Sa fizikom na High
min 11 fpsa, max 33
A sa nvidijom gt240 za fiziku
min 33, max 177fps
Isplati se uzet neka polovna gt220 ako ima pa ju puknut samo da vrti fiziku ako ste atijevac po pitanju gpu-a
Sve u svemu igra je mrak al grafika mi nekako nije baš , valjda sam previse ocekivo
Zadnje izmijenjeno od: Beo. 11.08.2010. u 15:08.
Staro 11.08.2010., 15:22   #299
Vendetta
Vendetta's Avatar
Postovi: 919
Autor njoka. Pregled postova
-velicina
-dizajn
Skini demo pa provjeri. Ali cini mi se da nije toliko interaktivan ko u GTA4, ne moze se zvat taxi koliko sam skuzija :P
Autor Beo Pregled postova
+1
Sa onom fizikom je puno bolje ali je onda slide show.
Vendetta je offline   Reply With Quote
Staro 11.08.2010., 16:00   #300
BlackZ0r
Datum registracije: Aug 2010
Lokacija: Poreč
Postovi: 57
a eto demo nije loš,iako je vrlo,vrlo sličan jedinici (izgled mape) samo malo bolja grafika..
BlackZ0r je offline   Reply With Quote
