Staro 02.08.2010., 11:52   #781
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Naravno meni ne radi!
Pokrenem tu stranicu, slajdam da ga JB-am i poslje toga se ništa ne događa... hebem ti!!!!
Staro 02.08.2010., 12:26   #782
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
Autor flajpan Pregled postova
Ostali koji ste JB preko jailbreakme - radi li vam MMS?
http://www.9to5mac.com/jailbreakme-facetime-mms-fix-out
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 02.08.2010., 14:10   #783
Pawzilla
Pawzilla's Avatar
Postovi: 314
Evo, ja jailbreakao 4.0 3GS new boot rom preko jailbreakme.com i radi sve
Pawzilla je offline   Reply With Quote
Staro 02.08.2010., 22:10   #784
bas
Postovi: 22
Autor Blue_Fatal1ty Pregled postova
Probaj prvo restorat iphone kao novi uredjaj pa tek onda pokrenut taj jailbrake.
Znam da nikako nisam uspijevao jailbreakat dok nisam restorao iphone.
bas je offline   Reply With Quote
Staro 02.08.2010., 23:31   #785
Pawzilla
Pawzilla's Avatar
Postovi: 314
Jel netko od vas naišao slučajno na iTunes error 23??? Imam 3G-a koji neće dalje od recovery moda
Staro 03.08.2010., 00:09   #786
spawn
spawn's Avatar
Postovi: 8,463
Autor Pawzilla Pregled postova
Jesi li probao sa DFU?
Jesi li probao sa ih8snow bacit ga u onaj "crveni" mod pa onda restore?
Jel imas najnoviji itunes?
Staro 03.08.2010., 00:42   #787
Pawzilla
Pawzilla's Avatar
Postovi: 314
Smile
Sa dfu nejde i imam najnoviji itunes, ali neznam na što misliš kada kažeš crveni mod. iREB ne pomaže kod error-a 23
Uglavnom koliko sam googlao, to je error koji može biti i hardverski i najčešće se pojavljuje kada netko iskopča kabel kod fw update-a
Moja sumnja je da je baseband loše nasnimljen i treba nekako naterati itunse da zaobiđu error 23 i snime neki novi originalni soft 4.0 ili 4.0.1 koji ima novi baseband, pa da se i on odma updejta i na taj način popravi.
Pitanje je samo kako...
Staro 03.08.2010., 02:20   #788
spawn
spawn's Avatar
Postovi: 8,463
Na spiritovoj stranici imas uputstvo kako izvaditi BB iz sluzbenom firmware-a ,probaj tako flashati.
Staro 03.08.2010., 04:05   #789
japa
japa's Avatar
Lokacija: Apsurdistan
Postovi: 248
Hvala flajpan. Evo sve radi, sad se bavim mijenjanjem ikona, tema i sl., al ova Cydia je jako spora i često mi izbaci 504 gateway timeout kad ju pokrenem. Jel jos netko ima slicni problem?
japa je offline   Reply With Quote
Staro 03.08.2010., 16:30   #790
Matko_STR
Matko_STR's Avatar
Postovi: 86
Pozdrav,
Imam iPhone 3G koji je zaključan na AT&T, a koristim ga na T-Mobile... soft 3.1.2.
Ako ja sada na njega stavim 4.0.1. kako da uđem u Safari kada će mi prije tražiti da ubacim AT&T karticu da ga aktiviram?
Matko_STR je offline   Reply With Quote
Staro 03.08.2010., 16:30   #791
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
Autor japa Pregled postova
to izbacuje jer je previse ljudi gore
V.I.P je offline   Reply With Quote
Staro 03.08.2010., 17:15   #792
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Autor Matko_STR Pregled postova
Pozdrav,
Jailbreakaj sa redsn0w, on će odraditi hacktivaciju, ovdje imaš tutorial: http://www.iclarified.com/entry/inde...id=10188&laid=
flajpan je online   Reply With Quote
Staro 03.08.2010., 23:49   #793
knocker
Lokacija: Kaštela
Postovi: 295
ovaj JB za os 4.0 je definitivno najjaci dosad, danas se nadem s likom da mu JB i unlockam iphone i tip me pita kad ce biti gotov, ja se vrtim po trgovackom centru i lovam wi fi signal i nakon 10 min mu ga vracam i uzimam definitivno najlakse zaraden novac
knocker je offline   Reply With Quote
Staro 04.08.2010., 13:07   #794
Pawzilla
Pawzilla's Avatar
Postovi: 314
Moram se pohvaliti. Proradio je i moj novi "mrtav 3G"!!! Rastavio sam ga, prelemljavao sve živo i gledam, nema se tu šta previše lemiti sa pištoljkom... reko idem izmjeriti napon na bateriji. I ono 2.1V, a znam iz iskustva da neće kresnuti ispod 2.7V i spojim na nju direktno trafo, ruknem 9V u nju i mjerim dok se nije digla na 4V (namjerno radi brzog pražnjenja) i nabrzinu sastavim mob i stavim na punjač, ono puni )) i digne se OS! ))) x2
Napunio sam mob do kraja, stavio 4.0.1 i radi ko zmaj, sad još da dođe zadnje kućište s ebay-a i nitko sretniji od mene...
Staro 05.08.2010., 02:00   #795
knocker
Lokacija: Kaštela
Postovi: 295
Pawzilla neces vjerovat, isti slucaj imao prije 2 tjedna.
Staro 05.08.2010., 11:21   #796
Pawzilla
Pawzilla's Avatar
Postovi: 314
Smile
Autor knocker Pregled postova
Sad makar znamo kako popraviti problem
Staro 06.08.2010., 03:47   #797
Ergometar
Ergometar's Avatar
Datum registracije: May 2009
Postovi: 141
Pokusao jailbreakati sa kabelom kupljenim preko E-baya za 8kn...Neki kineski...
Srusilo mi se sve 3 puta za redom dok nisam skuzio u cemu je problem..
Ovo kinesko govno od kabela ima 2 zice manje, za ne povjerovati..
Mislio sam, kabel kao kabel....
aaaaarghh
Ergometar je offline   Reply With Quote
Staro 06.08.2010., 18:42   #798
Roby-V
Postovi: 175
kako se zove onaj program na cydiji koji isključuje nepotrebne programe u iphoneu i ubrzava ga.. sječam se da je trebalo u meniu povuči prst pri vrhu ekrana i onda bi se otvorio prozor i mogle su se isključiti nepotrebne radnje
Roby-V je offline   Reply With Quote
Staro 06.08.2010., 18:58   #799
spawn
spawn's Avatar
Postovi: 8,463
sbsettings
Staro 06.08.2010., 23:45   #800
thesaint255
thesaint255's Avatar
Datum registracije: Dec 2009
Lokacija: Graz
Postovi: 539
Ljudi,ovako neznam ako cu ja biti prvi to tu priopciti ali izasao je JB za (4.0 , 4.0.1) pa na dalje za sve I uredaje =) ETO KAKO!
1, Updatajte Itunes na zadnju verziju
2, Dopustite Itunesu da skine najnoviju verziju firmwarea za vas I uredaj 4.0.1 u ovom slucaju
3, Otvorite safari na vasem I uredaju i unesite ovu adresu: http://jailbreakme.com
4, Povucite gumb da pocnete skidanje CYDIE
VAZNO:Ako slucajno ne vidite tipku na povlacenje tipa kada otkljucavate Iphone ili Ipod refreshajte stranicu =)
DODATAK:
Osobno sam isprobao navedenu metodu na Iphone 3GS new bootrom i imam Cydiu,crackane aplikacije,winterboard itd,ALI NIJE OTKLJUCAN NA SVE MREZE!
DA,OVAJ JB RADI NA NOVIM MC UREDAJIMA,TJ NA SVIM 3GSovima
-ON JAILBREKA VAS I UREDAJ ALI NE OTKLJUCAVA NA SVE MREZE!
7800X3D @ Scythe Fuma 2
ASRock B650I Lightning WiFi
32 GB Corsair Vengeance DDR5-6000
RTX 4070 ti Gamerock
Corsair SF750
Cooler Master NR200P
thesaint255 je offline   Reply With Quote
Staro 07.08.2010., 00:12   #801
Roby-V
Postovi: 175
Autor thesaint255 Pregled postova
DODATAK:
sta radi i na 2g
Staro 07.08.2010., 00:15   #802
thesaint255
Lokacija: Graz
Postovi: 539
tako je,ali pitanje ako 4.0 moze na 2g
EDIT:Receno je da sve I uredaje JB,ali ovo mi je 1. vijest da 2g moze imati 4.0,mislim,ako na 3g nema najvaznijih mogucnosti zato jer nije dovoljno hardwerski jak,kamoli moze 2g
Corsair SF750
Staro 07.08.2010., 00:17   #803
spawn
spawn's Avatar
Postovi: 8,463
DODATAK:
iphone se otkljuca ovako:
Nakon JB-a ides na sources, kliknes na repo666.ultrasn0w.com pa na ultrasn0w pa na INSTALL. I tzo je to.
Staro 07.08.2010., 00:19   #804
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
DODATAK:
http://forum.pcekspert.com/showpost....&postcount=771
Staro 07.08.2010., 00:19   #805
thesaint255
Lokacija: Graz
Postovi: 539
Nezelim te vrijedati prijatelju,ali to nije moguce,to se prije moglo na 3.1.2 na 3Gs,ali od 3.1.3 bez saved par vaznih stvari nema teorije da ga mos otkljucati
Jelc,bezobraznik XD
Corsair SF750
Staro 07.08.2010., 00:27   #806
Roby-V
Postovi: 175
2g i 3g su hardwerski isti samo što 3g ima navigaciju
Staro 07.08.2010., 02:22   #807
spawn
spawn's Avatar
Postovi: 8,463
Jelc,bezobraznik XD
Probaj pa ces vidjeti. Vec sam ih masu otkljucao. A ako ne vjerujes posalji mi 50 kn i phone pa cu ti ga j otkljucat
Staro 07.08.2010., 02:25   #808
knocker
Lokacija: Kaštela
Postovi: 295
thesaint: iphone OS 4.0 i 4.01 rade s ultrasn0w otključavanjem na sve mreže.
Staro 07.08.2010., 12:09   #809
thesaint255
Lokacija: Graz
Postovi: 539
Idem probati,ako uspije imate pivu od mene,jer znam da s 3.1.3 nisam mogao
Corsair SF750
Staro 07.08.2010., 12:17   #810
flajpan
flajpan's Avatar
Postovi: 1,796
@thesaint255 Nema što ne uspjet: http://blog.iphone-dev.org/post/9018...grow-ultrasn0w
Version 1.0-1 of ultrasn0w works for:
* iPhone4 baseband 01.59
* 3G/3GS basebands 04.26.08, 05.11.07, 05.12.01 and 05.13.04
