Staro 12.06.2010., 11:09   #271
joe black
Datum registracije: Jun 2010
Postovi: 23
Ja sam imal samo sfrkane žice, znači bez utičnice, sad sam ih zalemil al nisam ništ dobil.
joe black je offline   Reply With Quote
Staro 21.06.2010., 16:49   #272
serke
serke's Avatar
Postovi: 49
Koliko sam skužio iz gore navedene tablice moja parica nije loša, samo ne znam zašto je SN Margin down toliko manji?
Svejedno ću pitati Mudrace : koliko bi mogao potegnuti?
Anybody ?
Zadnje izmijenjeno od: serke. 23.06.2010. u 16:19.
serke je offline   Reply With Quote
Staro 21.06.2010., 18:47   #273
Ico2005
Ico2005's Avatar
Lokacija: Slavonija ravna
Postovi: 466
Što te CRC errors znače?
Ico2005 je offline   Reply With Quote
Staro 21.06.2010., 20:29   #274
Postovi: 23,636
Općenito CRC error je greška kontrolnog zbroja a kod adsl - a evo par tumačenja / primjera:
What causes CRC errors?
adsl crc errors, whats normal?
Staro 02.07.2010., 05:58   #275
Ahab
Lokacija: Slavonija
Postovi: 37
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 11.2 11.9
Attenuation (dB): 26.0 14.9
Output Power (dBm): -2.0 6543.6
Attainable Rate (Kbps): 20344 1603
Rate (Kbps): 4703 316
MSGc (number of bytes in overhead channel message): 59 16
B (number of bytes in Mux Data Frame): 146 14
M (number of Mux Data Frames in FEC Data Frame): 1 1
T (Mux Data Frames over sync bytes): 1 2
R (number of check bytes in FEC Data Frame): 0 16
S (ratio of FEC over PMD Data Frame length): 0.9932 1.4675
L (number of bits in PMD Data Frame): 1184 169
D (interleaver depth): 1 1
Delay (msec): 0 0
Super Frames: 225082 225080
Super Frame Errors: 24 2117
RS Words: 0 15305440
RS Correctable Errors: 0 33865
RS Uncorrectable Errors: 0 N/A
HEC Errors: 17 25802
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 241652269 3176839105
Data Cells: 4895041 92276707
Bit Errors: 0 2053739
Total ES: 351 546
Total SES: 33 280
Total UAS: 61 4381234
Recimo da sam zadovoljan, osim što veza ponekad pukne (a kome ne?), osim što je sumnjiv ovaj Output Power.
Međutim, ispod je screenshot od prije godinu i pol (isti modem, ista T-Com linija s razlikom što sam u ono vrijeme promer plaćao Iskonu) kad mi je veza pucala svakih pola sata, DL bio 4x manji od deklariranog a ping do 1700ms (često sam se u to vrijeme dopisivao s Tscumom pa se zato još poneka sličica pronađe u kompu).
Koliko god čitao ovu temu, nije mi jasno jer mi se ovaj stari izvještaj čini bolji od sadašnjeg, čak bih rekao odličan.
Modem je prastara Kasda a stanje je trenutno ovakvo:
Mode: ADSL2+
Status: No Defect
Downstream Upstream
Delay (msec): 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 351 546
Total SES: 33 280
Name:	Capture_ADSL Statistics_08012009.png‎
ID:	11051   Click image for larger version
ID:	11052   Click image for larger version
Ahab je offline   Reply With Quote
Staro 12.07.2010., 10:31   #276
Night
Lokacija: Dbk
Postovi: 1,328
Autor Ahab Pregled postova
Parametri linije nisu jedino što utječe na stabilnost i brzinu veze. Kod tog prošlog slučaja je vjerojatno problem na Iskonovoj strani, jer koristiš HTovu liniju, ali promet ide preko Iskonovih servera, i onda ako tamo nemaju dovoljan kapacitet imati ćeš slabiju brzinu, eventualno i pucanja veze.
Night je online   Reply With Quote
Staro 12.07.2010., 15:23   #277
razor_061
MPower
razor_061's Avatar
Lokacija: Zabok, Zagorje
Postovi: 100
Link Information
Uptime: 12 days, 1:10:14
Modulation: G.992.5 annex B
Bandwidth (Up/Down) [kbps/kbps]: 315 / 4.703
Data Transferred (Sent/Received) [MB/MB]: 2,39 / 14,98
Output Power (Up/Down) [dBm]: -1,0 / 0,0
Line Attenuation (Up/Down) [dB]: 22,5 / 36,5
SN Margin (Up/Down) [dB]: 17,5 / 12,5
Vendor ID (Local/Remote): TMMB / IFTN
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 52
HEC Errors (Up/Down): 0 / 24
Kolko bi se dalo s tom na max? Pošto mi nigdje ne piše.. I kako natjerati ove u t-comu da povuku nove žice?
razor_061 je offline   Reply With Quote
Staro 22.07.2010., 05:50   #278
Hellgion
Lokacija: Vt
Postovi: 18
Uploaded with ImageShack.us
Molim ako moze misljenje o mojoj parici?
Zadnje izmijenjeno od: Hellgion. 22.07.2010. u 06:18.
Hellgion je offline   Reply With Quote
Staro 27.07.2010., 20:58   #279
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
jel ima kakve veze ak je od splittera do routera 15m kabla?
norecx je offline   Reply With Quote
Staro 27.07.2010., 23:58   #280
kill
Datum registracije: Jun 2003
Postovi: 533
ne, pošto ima još xxxx m i prije splittera
kill je offline   Reply With Quote
Staro 30.07.2010., 12:47   #281
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
otkad mi je na adsl2+ brzina mi se smanjila za 14kbps,mogu li u ruteru kako vratiti na adsl modulaciju?thomson st780wl
Staro 06.08.2010., 01:00   #282
nino
nino's Avatar
Postovi: 12,613
Moze procjena kvalitete linije kod mene?
SNR Margin (dB):..........15.6 19.0
Attenuation (dB):.........21.0 10.0
Output Power (dBm):....20.3 12.3
Staro 06.08.2010., 01:07   #283
Postovi: 23,636
Usporedi sa ovim postom za početak.
Staro 06.08.2010., 01:24   #284
nino
nino's Avatar
Postovi: 12,613
Hvala nikky, treba editirat 1. post pa ubacit ovo gore jer sam gledao pocetak samo.
Kako vidim, linija je cisto u redu, osim sto mi odskace Output Power (dBm):....20.3
Staro 06.08.2010., 04:03   #285
borisko
Lokacija: .com
Postovi: 519
Vjerojatno posljedica ovog veceg zagusenja (moguce da si daleko od centrale) ili jednostavno krivo ocitanje...
borisko je offline   Reply With Quote
Staro 13.08.2010., 01:40   #286
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
imam pitanje,propusnost parice mi je 2178kbps,trenutno imam stavljen softverski paket od 1mbit,da nazovem t-com i kažem da mi stave 2mbit,jel bi se spojilo onda na nekih 1.6 - 1.7 mbps,hvala
Staro 13.08.2010., 10:13   #287
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Spojio bi ti se on na tih 2Mbita i imao bi max brzinu 1.7Mbita ali pitanje je dali bi bilo pucanja veze.
Staro 13.08.2010., 13:56   #288
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
sad sam opet očitao propusnost,trenutno je 2560kbps,pa valjda nebi pucala veza,jel mogu to oni odmah promjeniti?
Staro 13.08.2010., 15:32   #289
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Nazovi ih i traži da ti ograniče brzinu na 2Mbita, i to bi trebalo biti dosta brzo.
Staro 13.08.2010., 15:47   #290
stifmeister
Datum registracije: Dec 2009
Lokacija: *
Postovi: 122
nazvao sam 0800 900,i prijavio kvar,čekam tehničara da nazove,btw ovo mi je profil no.1
stifmeister je offline   Reply With Quote
Staro 13.08.2010., 20:28   #291
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
Zadnje izmijenjeno od: norecx. 14.08.2010. u 00:25.
Staro 21.08.2010., 22:37   #292
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
neki dan su mi opet vratili na staro,rekli su da je to automatski prebačeno zbog velikog broja alarma na liniji???no ipak su opet prebacili na 2mbit,al neželim da opet vrate
Staro 22.08.2010., 15:07   #293
borisko
Lokacija: .com
Postovi: 519
Autor norecx Pregled postova
Ovime si u principu sam sebi objasnio što se događa.
Tvoja linija poprilično oscilira po pitanju propusnosti i najvjerojatnije ostalih čimbenika koji utječu na liniju.
Bakrene parice, loša infrastruktura, bla bla, podložno vremenskim uvjetima, bla bla...znači nije stabilno i zato se desi da ti je propusnost u jednom trenu 2000kbps, u drugom 2500kbps, u trećem 1800kbps...i onda se linija ruši, puca.
Pogledaj u thread "Upute za rješavanja problema sa ISP-om" i probaj napraviti sve što smo spomenuli. Kreni od svoje kućne instalacije te zatim prijavi kvar u T-com da pošalju nekoga da pogleda gdje dolazi do problema.
Ovisno koliko si udaljen od centrale. Ako si u mjestu koje je jako udaljeno od centrale ili je jednostavno loša mreža, objasniti će ti da veću brzinu nisu u stanju isporučiti i to je to, ali tad ćeš bar konkretno znati
Svakako javi što se i kako riješilo
Staro 27.08.2010., 01:58   #294
stifmeister
Lokacija: *
Postovi: 122
izmjenio sam kabel u kući i sad mi se stabilno spaja na 2016kbps i tako već par dana
Staro 27.08.2010., 03:35   #295
razor_061
MPower
razor_061's Avatar
Postovi: 100
Kako natjerati T-Com da povuče nove žice od centrale pa do mene, tj po cijeloj ulici?
Staro 27.08.2010., 08:04   #296
Ico2005
Ico2005's Avatar
Postovi: 466
Mislim da bi ti Mudrinić trebao biti u bližem srodstvu.
Staro 02.09.2010., 14:30   #297
Mogy
Hala Madrid!
Mogy's Avatar
Postovi: 1,323
dali zna neko di to nađem na speedtouch 780wi? šta samo trebam u cmd upisat ip config ili još nešto treba?
edit: našao sam
Mogy je offline   Reply With Quote
Staro 07.09.2010., 00:41   #298
VuXs
√uメ丂
VuXs's Avatar
Lokacija: WrboWec - paradise city
Postovi: 8
Autor Sa_Stilom Pregled postova
Yebemu, nemrem z editirat, pa da nastavim:
Koliko bi ja mogao čupat?
I šta napraviti da se parica poboljša? Dali se može nekoga platiti (Tcom, Iskon) neki treći provider da... kad recimo prelazim na njih da mi srede nove instalacije i sve... ?!
pa ako imas buzhir instalacije se promijene bez problema..
-ako imas vise telefona..koristi samo JEDAN splitter..iz njeg spoji ostale telefone..a ne na svaku uticnicu splitter..
ako imas kucu..onda ufrci spojeve..ako si u zgradi..zamoli tehnicara da ti makne spoj s reglete i da ga ufrce..
Ponovit ću još jednom, nešto što mi je savjetovao jedan tehničar i upalilo je.
Rekao je prvo da skinem utičnicu i da žicu direkt zalemim na žice iz utičnice, kako bi smanjio broj spojeva. Odjednom sa max 8Mbits i brdo grešaka, dobio sam 13-14Mbits (kada sam bio na Amisu) i uzeo 24Mbis.
Rekao mi je još ako imaš svoj modem, rastavi ga i zalemi također žicu na modem, ali to se nisam usudio napraviti.
Eto, sada imam mogao bi reći vrlo dobru vezu
Pa eto, probajte možda vam pomogne.
iss..pa kad lijepo zice ufrces isto ti je kao i da lemis..istina da su u uticnicama one zicice lose..ali ako ne zelis lemiti dobro ces napraviti ako ih i ufrces unutar uticnice..
lemiti na router ŽICU..wtf..pa to je parica..a konektori na par milimetara..pa kaj da ti to neki stroj zalemi...
Autor Ico2005 Pregled postova
tocno to
jedino ak imas dobrog tehnicara pa pozove montere da promjene barem jednu supljinu kabla ili promijene paricu u zracnom kablu..ali da dobijes novu mrezu..nikada..pa cak ni' onda..
VuXs je offline   Reply With Quote
Staro 26.09.2010., 12:02   #299
adam2204
adam2204's Avatar
Datum registracije: Feb 2010
Postovi: 40
Valja ovo kaj, bas se ne kuzim?
adam2204 je offline   Reply With Quote
Staro 03.10.2010., 16:27   #300
norecx
norecx's Avatar
Lokacija: Zagorje
Postovi: 19
da li postoji t-comov glavni tehnicar u zagrebu,da ne moram razgovarati s ovim iz zaboka?
