Staro 16.12.2004., 01:45   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
CATALYST Windows XP 64-Bit Edition - BETA 3
Za ponosne vlasnike dotičnog OS-a izašla je i treća beta, ATI se naravno kao i uvijek ograđuje od onog kaj vas može snaći sa njima
The BETA display drivers found here are offered AS IS, without warranty of any kind, and have NOT been completely qualified by ATI. Usage of these drivers are without support of any kind, and you use them at your own risk.
ATI does NOT recommend installing these drivers in systems used for mission critical operations or where productivity of any kind is a concern.
Unless you are very comfortable with installing and un-installing drivers, we DO NOT recommend that you use the drivers provided here. These BETA drivers are NOT SUPPORTED by ATI Technical Support or any other ATI department....i bla-bla..
http://www.ati.com/support/drivers/w...=12&submit.y=9
Staro 16.12.2004., 02:12   #2
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
a kaj se ti vraže jedan ne hvališ sa svojom novom zvjerkom???
Ili to čekaš dal bude radila na taktovima PE pa da onda svima slavodobitno objaviš??
pinsla je offline   Reply With Quote
Staro 16.12.2004., 11:38   #3
Jelc
Super Moderators
Postovi: 17,485
Ma ne
Radila je ona na default taktu cca 5 minuta
Pa sutra se bum hvalilo, onak fino uz Žuju, ovak nije fora
Staro 16.12.2004., 11:54   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma matori gad, šuti i vrti
Budeš ti platio to, ne brini se...pivom i klopom.
Staro 16.12.2004., 12:14   #5
Jelc
Super Moderators
Postovi: 17,485
Još samo sutra dobijem najnoviji soft za VIVO, lagani reinstal OS-a i to je to
I puknem gore neki noviji BIOS, tak jasno...
Staro 16.12.2004., 14:18   #6
pinsla
pinsla's Avatar
Postovi: 1,860
i kolki je pomak u performansama u odnosu na 9800 onak odokativno?
malo te jedino sad proc koči te grafe vole užasno jak proceve da ih iskoristiš u potpunosti
Staro 16.12.2004., 14:30   #7
Jelc
Super Moderators
Postovi: 17,485
Pravo zboriš
9800 PRO/XT je sa 2500MHz-a bila full iskorištena, ovo đubre bi bolje radilo sa nekim jačim...samo kaj će nova ploča i proc malo pričekati, od ovog kaj je na tržištu mi se nikaj nije svidjelo.
