Postovi: 76
Jako tezak problem
Nametnula mi se "slika" koja je .html document. Nisam uspio maknut s nortonom ,ad-om i HJT-om Logfile of HijackThis v1.98.2 Scan saved at 19:49:04, on 14.12.2004 Platform: Windows XP SP1 (WinNT 5.01.2600) MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106) Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\System32\Ati2evxx.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\system32\spoolsv.exe C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\system32\Ati2evxx.exe C:\WINDOWS\Explorer.EXE C:\Program Files\Windows ControlAd\WinCtlAd.exe C:\Program Files\Windows ControlAd\WinCtlAdAlt.exe C:\WINDOWS\System32\cmd32.exe C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe C:\Program Files\Norton SystemWorks\Norton AntiVirus\navapsvc.exe C:\Program Files\Norton SystemWorks\Norton Utilities\NPROTECT.EXE C:\PROGRA~1\NORTON~1\SPEEDD~1\nopdb.exe C:\WINDOWS\System32\ctfmon.exe C:\Program Files\CashBack\bin\cashback.exe C:\Program Files\BullsEye Network\bin\bargains.exe C:\WINDOWS\System32\ir.exe C:\WINDOWS\System32\svchost.exe C:\Documents and Settings\Edi\Desktop\HijackThis.exe R3 - URLSearchHook: (no name) - {CA0E28FA-1AFD-4C21-A8DC-70EB5BE2F076} - C:\Program Files\SurfSideKick 2\SskBho.dll O4 - HKLM\..\Run: [Windows ControlAd] C:\Program Files\Windows ControlAd\WinCtlAd.exe O4 - HKLM\..\Run: [SurfSideKick 2] C:\Program Files\SurfSideKick 2\Ssk.exe O4 - HKCU\..\Run: [SurfSideKick 2] C:\Program Files\SurfSideKick 2\Ssk.exe To ostane nakon kaj sve izbrisem s HJT-om. Mogu izbrisat i s add/remove programs ali to se svejedno vraca. ta slika je ovdje a ima "removal instructions" koji me vodi ovdje http://213.159.117.130/?affid=NAT-1 Dajte pomozite jer sam stvarno ocajan. |
#2 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Re: Jako tezak problem
Postovi: 76
Probo sam i to samo kaj nije uspjelo. No rijesio sam problem. Ta me "reklama" vodi na stranicu od nekog anti-spyware programa (zamisli) i poslo sam mail njihovom tehnical supportu i decki su u roku 2h odgovorili. Isprike bla bla bla... i dali mi 2 nacina da se tog rijesim. Ako ce neko imat slicnih problema nek vidi ovo: Ovo je neki programcic lagani (oko 10KB) pa ga sam pokrenete http://www.smart-security.info/removal.html A ovo je nacin bez ikakve pomoci sa strane Right click at the very top of the screen it should appear as a standard options menu. - Select Properties - Desktop tab. - Click "Customize Desktop" button at the bottom. - Select "Web" Tab. - Uncheck "Security" checkbox. ![]() |
