Postovi: 11,642
Memtest86+ 2.11/4.0
Dakle, izašla je nova verzija Memtesta. Dobro poznati program za testiranje stabilnosti i ispravnosti memorije, ostatak o istom se, vjerujem, već zna ![]() Change log: New Features:
Bug Fixes:
Instructions for use:
DL Link: 2.0 DL Link: 2.0 beta 15 Homepage |
Postovi: 4,707
Bravo Razer, i hvala Razer... Sad mogu izmucit Ballistixe jos malo vise. |
Secret Undercover Agent
Datum registracije: Sep 2004
Lokacija: Parallel Universe
Postovi: 1,130
Evo vec ima i 2.01.. *** Enhancements in v2.01 : *** * New Features o Added support for 45 nm Mobile Core 2 w/ 3 Mo L2 o Added support for i945GM/PM/GME & i946PL/GZ o Added support for iGM965/iGL960/iPM965/iGME965/iGLE960 o Added detection for SiS 649/656/671/672 o Added detection for i430MX/i430TX o Added an optional beep mode (pass completed w/o error) o Pass duration 20% reduced o Removed the blinking cursor o Reverted Test #0 to cached * Bug Fixes o Solved a major bug in Memory Address Errors Reporting o Patched for Intel-Powered Mac o Corrected Intel 3-Series (P35/X38) chipset init o Corrected a bug with SPD Display and ESB6300 o Correct a detection bug on P965/G965 C-Stepping o Solved a incoherency with pass progress indicator o Patched Makefile to compile on x86_64 o Bootable Memtest86+ ISO more compatible
"I can resist everything except temptation" |
Lokacija: Malaysia
Postovi: 96
Memtest86+ v2.11.iso * New Features o Added support for Intel Core i5 (Lynnfield) CPU o Added support for Intel P55 Southbridge o Added support for Intel PM45/GM45/GM47 Mobile chipset o Added support for Intel GL40/GS45 Mobile chipset * Bug Fixes o Corrected DDR2/DDR3 detection on Intel x35/x45 o Corrected detection on some Core i7 CPU o Fixed a bug with some AMI BIOS (freeze at startup) o Various bug fixes
Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 |
Lokacija: doma
Postovi: 964
Datum registracije: Jul 2003
Postovi: 167
Memtest86+ v4.00 *** Enhancements in v4.00 : *** * New Features o Major Architectural changes o First pass twice faster (reduced iterations) o Detect DDR2/3 brands and part numbers on Intel DDR2/3 chipsets o Added detection for Intel "Clarkdale" CPU o Added detection for Intel "Gulftown" CPU o Added detection for AMD "Magny-Cours" CPU o Added detection for Intel XMP Memory o Added for CPU w/ 0.5/1.5/3/6/12/16/18/24MB L3 o Added "clean" DMI detection for DDR3/FBDIMM2 o Better detection of Integrated Memory Controllers * Bug Fixes o Corrected detection for Intel "Lynnfield" CPU o Corrected detection for AMD 45nm K10 CPU o Solved crash with AMD Geode LX o Complies with SMBIOS 2.6.1 specs o Fixed compilation issues with gcc 4.2+ o Many others bug fixes PS : Memtest86+ "3.00" was skipped and renamed 4.00 in order to avoid confusion with the original Memtest. Download |
Postovi: 11,642
Memtest86+ V4.00 (22/09/2009)
Memtest86+ V2.11 (22/12/2008) |
Lokacija: Malaysia
Postovi: 96
Memtest86+ ver.4.10 * New Features o Added support for Core i7 Extreme CPU (32nm) o Added support for Core i5/i3 (32 nm) o Added support for Pentium Gxxxx (32 mn) o Added support for Westmere-based Xeon o Added preliminary support for Intel Sandy Bridge o Added support for AMD 6-cores CPU o Added detection for Intel 3200/3210 o New installer for USB Key * Bug Fixes o Corrected a crash at startup o Many others bug fixes Pre-Compiled Bootable ISO (.zip) http://www.memtest.org/download/4.10...+-4.10.iso.zip Pre-Compiled Bootable Binary (.zip) http://www.memtest.org/download/4.10...st86+-4.10.zip Auto-installer for USB Key (Win 9x/2k/xp/7) http://www.memtest.org/download/4.10/memte...b.installer.zip Pre-Compiled package for Floppy (DOS - Win) http://www.memtest.org/download/4.10/memte...4.10.floppy.zip
Lokacija: Malaysia
Postovi: 96
