|  26.04.2010., 16:30 | #721 |
| Premium Datum registracije: Nov 2007 Lokacija: VG
					Postovi: 1,758
				AMD Phenom II X6 Processors Start Shipping
			 Retailers have started shipping AMD's Phenom II X6 series of desktop six-core processors. The Phenom II X6 is AMD's first consumer six-core processor for desktops, which intends to compete with Intel at aggressive price-points. AMD is starting the series with two models, the Phenom II X6 1055T and Phenom II X6 1090T Black Edition. German retailer VV Computer priced the 1055T under 200€ at 198.7€, while the 1090T Black Edition goes for a little over 300 €, at 309.9€. The Phenom II X6 1055T runs at 2.80 GHz, with Turbo Core speed of 3.30 GHz, while the Phenom II X6 1090T Black Edition runs at 3.20 GHz with 3.60 GHz of Turbo Core speed, and an unlocked bus multiplier to help overclocking. Both chips have 9 MB of total cache, and TDP of 125W.Izvor: techPowerUp Zadnje izmijenjeno od: McG. 30.09.2010. u 15:30. |
|  11.05.2010., 14:46 | #722 |
| Premium Datum registracije: Mar 2006 Lokacija: Opatija
					Postovi: 34,005
				__________________ "Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein |
|  13.05.2010., 02:21 | #725 |
| MadModerator Datum registracije: Sep 2002 Lokacija: N/A
					Postovi: 5,195
				 | AMD 2010 mainstream, ultrathin notebook platforms unveiled  Both the ultrathin and mainstream platforms feature 45-nm microprocessors, DDR3 memory support, and a new M880G chipset with DirectX 10.1-class Radeon HD 4200 integrated graphics. AMD has maintained DirectX 11 support for higher-end visuals on Danube through the use discrete graphics cards. The updated hardware should provide a nice bump in performance, while the transition to a 45nm CPU and more efficient chipset will help deliver better battery life. The chips are expected to appear in at least 135 different products from vendors including HP, Dell and Lenovo, starting from the end of this month. This includes 109 design wins for Danube (mainstream) and 26 for Nile (ultrathin). 2010 AMD Ultrathin Notebook Platform (codenamed Nile)Izvor: TechSpot
				__________________ skupi-dupi-du, skupi-dupi-du, pam pam... pf |
|  13.05.2010., 09:15 | #727 |
					Postovi: 34,005
				 | Bilo bi i vrijeme da AMD isporuči neki laptop proc koji se ne grije k'o svinja i troši struje k'o mutav.  Čipseti, pogotovo oni s integrušama, su im napredniji od konkurencije, ali ih koče 'lošiji' (ne u smislu performansi, nego potrošnje i zagrijavanja) procesori.
				__________________ "Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein Zadnje izmijenjeno od: McG. 13.05.2010. u 15:22. |
|  14.05.2010., 11:08 | #729 | |
| Moderator Datum registracije: Apr 2005 Lokacija: Vancouver, BC // Zabreg, Maximir
					Postovi: 12,425
				 | Citiraj:
  Evo ovdje imaš lineup modela
				__________________ ''Of all the things I've lost I miss my mind the most'' Mark Twain | |
|  15.05.2010., 13:11 | #730 |
| Sir Paški Datum registracije: May 2007 Lokacija: Split
					Postovi: 356
|  02.06.2010., 16:17 | #732 |
| ------- Datum registracije: Aug 2005 Lokacija: -
					Postovi: 7,568
				Demonstracija Quad-Core 32nm Llano i Dual-Core 40nm Ontario  procesora
			 AMD demonstrated its first Fusion APU (accelerated processing unit), which is a "fusion" between a processor and a graphics processor. The first such processor in the works is based on the 32 nm silicon fabrication technology, codenamed Llano, and fuses a quad-core processor with a DirectX 11 compliant GPU. AMD's Rick Bergman showed off a wafer of the Llano APUs, but it didn't stop there. Rick surprised the press when he went on to claim that the APU can power Aliens vs. Predator in DirectX 11 mode, with a reasonable level of detail, which was demonstrated.Izvor: techPowerUp i TweakTown Zadnje izmijenjeno od: McG. 30.09.2010. u 17:52. |
|  03.06.2010., 00:14 | #733 | |
| Premium Datum registracije: Sep 2006 Lokacija: Daruvar
					Postovi: 1,744
				 | Citiraj:
 Evo tu test AVP-a u dx11 modu i igra je dosta zahtjevna, testirana je na 5870.
				__________________  Zadnje izmijenjeno od: McG. 03.06.2010. u 00:58. | |
|  19.06.2010., 18:40 | #735 |
					Postovi: 7,568
				 | Od svega nekoliko Watta do 10W budu trošili oni za mobilne uređaje, te za sve vrste prijenosnih računala. Od nekoliko desetaka Watta, po do 100W budu trošili desktop modeli. |
|  30.06.2010., 17:18 | #736 |
| Premium Datum registracije: Jan 2009 Lokacija: Cro
					Postovi: 1,034
				 | Kupio bi AM3 ploču, vjerojatno Formula IV od asusa. Zanima me hoće li Zambezi (Bulldozer) bit podržan na ovoj ploči? Načitao sam se svakakvih informacija (na primjer da će bit pin kompatibilan i da će radit s 890FX čipsetima, ali i da će zahtjevat AM3rev2). Pa ako netko zna informaciju koja je bar iole vjerodostojna molim ga da napiše i da stavi link od kud ju jue pokupio. Zadnje izmijenjeno od: McG. 30.06.2010. u 19:00. |
|  30.06.2010., 23:32 | #737 |
					Postovi: 7,568
				 | Novi 32nm procesori bazirani na Bulldozer arhitekturi budu dolazili u kombinaciji s novim čipsetom i novim socketom.  Bilo je već riječi o tome na ovoj temi, a svi detalji se budu znali 24.08. ove godine, kad AMD na Hot Chips konferenciji, službeno predstavi nadolazeće procesore i platforme. |
|  03.08.2010., 17:42 | #738 |
| Banned Datum registracije: Dec 2009 Lokacija: Šibenik
					Postovi: 144
				buldožder
			 ima li zasad novosit o bulldozerima ili nista prije hot chipsa, zanima me dali ce oni pasati na najnovije trenutno dostupne generacije am3 socketa jer uzet cu sad asrock 890gx extreme 3 , dakle to je am3 i najnoviji chipset pa bi na nju privremeno stavio athlona x2 pa bi iduce godine udrio po nadogradnji, ali onda moram bit siguran da ce bulldozeri pasat na nju, dakle ima li kakvih novosti osim hot chipsa koji je 24.8, neki kazu da ce pasat a neki da nece, ja vjerujem da bi mogli pasat ali samo na trenutno par najnovijih chipseta. |
|  03.08.2010., 19:59 | #739 |
					Postovi: 7,568
				 | Umjesto da pričekaš da se sve razjasni i da AMD predstavi nove procesore i čipsete, ti budeš sad kupil AM3 ploču i samim tim se ograničil na izbor nadolazećih procesora koje bude taj socket mogel udomiti. AM2+ i AM3 ploče budu podržavale samo neke (jer tak jasno da bude naglasak na nove AM3 r2/AM3+ ploče) Bulldozer procesore i sve novotarije koje dolaze s novom arhitekturom ne budu radile na trenutačno aktualnim pločama. Istu stvar su prije koju godinu doživjeli vlasnici prvih AM2 ploča koji su jedva čekali nove Phenom II i Athlon II, procesore, pa su kasnije došli na hladan tuš - ovisno o modelu i proizvođaču ploče. Primjera radi, za nove Llano procesore, tj. Fusion modele ti ne gine nova ploča i novi čipset, jer sadašnje uopće nisu spremne udomiti 32nm višejezgrene procesore s integriranom grafičkom jezgrom. Zadnje izmijenjeno od: McG. 03.08.2010. u 20:05. |
|  03.08.2010., 21:15 | #740 |
					Postovi: 144
				 | isuse pa sta to pises, nista  te nisam skuzio, ako sam dobro shvatio oces rec da ce na trenutno najnovije am3 ploče ic samo neki bulldozeri a drugi ne , ipak ne uzimam nikakvu am2 nego am3 sa trenutno najnovijim chipsetom , samo informativno cekanje 2011 ne dolazi u obzir jer ko zna kako cu proc polugodiste tako da mi je bolje sad uzet, pitanje je samo dali uzet ploču i npr phenom x2 koji mozda mogu otkljucat pa ga kasnije prodat , dodat neke pare i kupit buldoždera ili jednostavno uzet 1055t , prvo sta ti savjetujes, btw odakle ti to o podrsci samo nekih ? EDIT: btw zar ove najnovije ploče u biti nemaju am3 r2 ?? Zadnje izmijenjeno od: s3t hooligan. 03.08.2010. u 21:24. |
|  03.08.2010., 23:51 | #741 |
					Postovi: 7,568
				 | Odakle mi da budu trenutačne AM2+ i AM3 ploče podržavale samo određene procesore bazirane na Bulldozer arhitekturi? Sva dosadašnja AMD-ova priopćenja lijepo iscrtavaju kojim smjerom bude se kretala nova arhitektura, pa baci pogled - imaš materijala diljem ove teme kolko te volja. Sadašnje AM3 ploče bazirane na 800 seriji čipseta budu (ovisno o dobroj volji proizvođača i revizije BIOS-a) podržavale prvi val Bulldozer procesora. Slično kak su prvi Phenom II 920 i 940 procesori išli samo na AM2+ ploče, mada su pripadali novoj generaciji procesora, da bi cijela AM3 serija kasnije zasjala na tada novim AM3 pločama. Dosad je AMD samo poboljšaval postojeću K8 i K10 arhitekturu, pa ništ čudno da su danas aktualni Phenom II i Athlon II procesori bez većih problema kompatibilni sa starijim AM2+ pločama. Bulldozer je pak sasvim nova arhitektura i AMD nakon dugo vremena uvodi konkretne promjene i pripremaju nove AM3 r2 ploče - bilo da se budu finalni proizvodi zvali AM3+ ili nekaj slično tome. Još k tome u novim verzijama čipseta za desktop i mobilne platforme, namjeravaju integrirati USB 3.0, umjesto da ko na sadašnjim AM3 pločama koriste čipove drugih proizvođača. Čisto za primjer, nadolazeći 32nm Llano procesori arhitekturalno nisu puno drukčiji od sadašnjih Phenom II i Athlon II modela, kad su tak i tak bazirani na istoj i malo dorađenoj K10 arhitekturi. Zahvaljujući integriranoj DX11 grafičkoj kartici i bez obzira na sličnosti s postojećim procesorima, zahtijevaju novi socket i čipset. S druge strane, Intel već ima spremne LGA-1155 i LGA-2011 platforme, te nove P/H/Q 65, 67 i X68 čipsete, a procesori nisu (baš ko i Llano) tolko različiti od sadašnjih modela, ali o međusobnoj kompatibilnosti s aktualnim LGA-1156 i LGA-1366 platformama nema ni govora. Nove ploče i čipseti su neizbježni s novom Bulldozer arhitekturom, tak da ne bude ništ čudno ako velika većina sadašnjih AM3 (a pogotovo AM2+) ploča ne bude u potpunosti podržavala sve nadolazeće Bulldozer procesore. Kaj budeš ti kupil i da li ti se isplati čekati da vidiš službenu podršku za tvoju već sad zacrtanu ASRock 890GX ploču - ovisi samo o tebi. Zadnje izmijenjeno od: McG. 04.08.2010. u 00:19. |
|  04.08.2010., 00:50 | #742 |
					Postovi: 144
				 | ma nemora bit asrock moze i ona asus m4a89gtd pro ali sve je to isto,radi se o 890gx chipsetu i am3 socektu , to ce mi bit velik problem jer mi se neuzima 1055t ako ce za 3 mjeseca doc skroz nova serija i tom procu ce se cijena prepolovit , ako bar prvi bulldozeri budu isli na sadasnji am3 socket ja cu bit relativno zadovoljan, btw dali bi se 24.8 trebalo doznat sve sa detaljima ?? |
|  04.08.2010., 09:06 | #744 |
					Postovi: 7,568
				 | Bulldozer procesori budu na tržištu tek početkom i sredinom 2011., a za tri mjeseca budu se još uvijek prodavali i proizvodili sadašnji procesori. S tim da AMD u pripremi ima još nekolko novih Phenom II i Athlon II model prije "zalaska njihove karijere". Ti ishitreno planiraš kupnju, umjesto da se strpiš ta tri tjedna do objavljivanja konkretnih novosti o novoj arhitekturi i da onda kupuješ kaj te volja. AM3 ploča i procesora bude i dalje u prodaji, a Bulldozer arhitektura bude se zahuktala tek tokom 2011. godine. AMD bude na ovoj konferenciji i do kraja godine samo službeno predstavil novu arhitekturu, a masovna proizvodnja i proizvodi na policama su rezervirani za sljedeću godinu. |
|  04.08.2010., 13:54 | #745 |
					Postovi: 144
				 | zasto mi kazes da se strpim ta 3 tjedna , kad ce se znati konkretne novosti o bulldozerima , ja cu definitivno cekat da budem tocno siguran sto cu moci kupiti a sto necu tj da znam sto ce pasat na am3 od tih bulldozera, kad ce se to doznat ? ja 20.8 idem u split sa hvara i htio bih prije skole tj prije 6.9 sastavit komp , hocu li dotad znati sto ce biti s bulldozerima ? Zadnje izmijenjeno od: McG. 04.08.2010. u 15:37. |
|  05.08.2010., 16:39 | #746 | |
					Postovi: 7,568
				 | Citiraj:
 Pošto ti kupuješ novu konfiguraciju više od pol godine prije nego Bulldozer proizvodi ugledaju svjetlo dana, ama baš nitko ti nije u stanju dati točan odgovor u vezi s podrškom za buduće procesore. | |
|  05.08.2010., 17:12 | #747 | |
					Postovi: 144
				 | Ovo sam sad kopirao s njihove stranice s tog bloga. Citiraj:
|  05.08.2010., 17:19 | #748 |
					Postovi: 7,568
				 | Ti čitaš i pročitano tumačiš onak kak ti paše.  Ovo kaj si citiral i općenito cijeli blog (kad prvo stižu Opteroni bazirani na Bulldozer arhitekturi, pa tek onda ostatak ponude) se odnosi na nove Opterone i njihovu kompatibilnost s postojećim serverskim pločama i G34 socketom. Nisam ti ja kriv kaj ti sad pošto-poto kupuješ novi kompjuter, pa sam sebe hoćeš utješiti da bude 890GX ploča bez problema udomila novi Bulldozer. Nove ploče, novi socket i novi čipseti dolaze skupa s Bulldozer arhitekturom i za to imaš dokaza diljem zadnjih par stranica. Ponavljaš ono kaj sam ti rekel prije nekolko postova, a uostalom, ako si tolko siguran da bude Bulldozer išel na AM3 ploče, čemu uopće ispituješ - kupi kaj te volja i čekaj da izbace nove procesore. Zadnje izmijenjeno od: McG. 05.08.2010. u 21:32. |
|  05.08.2010., 17:39 | #749 |
| Premium Datum registracije: Oct 2006 Lokacija: Dubrovnik
					Postovi: 2,583
				 | McG, skidam kapu.. meni su živci popustili već na 113x postu. Jednostavno pustiš čovjeka neka tvrdi kako on to hoće kad već ne sluša druge a pita za savjete. @s3t: uzmi to što si naumio i miran PCE! |
|  05.08.2010., 17:45 | #750 |
| Torrent freek Datum registracije: Mar 2005 Lokacija: Split
					Postovi: 3,948
				 | Tko čeka, ne dočeka...tako uglavnom zavši kupnja ljudi koji konstatno čekaju. Imaš novce? Kupi šta si htio i amen, jer čekajući Bulldozer ćeš čekat dugo. Prvo predstavljanje, pa drugo dok se pojavi kakva zanimljiva ploča, pa treće dok padnu cijene, pa četvrto... Doć će Uskrs, a još ćeš čekat  Ja kad san prelazio sa 939 socketa sam malo zaksnio, pa sam imao istu dvojbu kao i ti, uzet AM2 koji je već neko vrijeme bio u igri ili čekat AM3. I mogu ti reć da mi je drago da nisan čeka, jer da san čeka, vjerovatno bi i danas imao soc 939  Uzmi lipo AM3 (po meni se na AM2+ više ne isplati ić, eventualno ako imaš rame) i imaš solidnu konfiguraciju, a onda šta budućnost donese, možeš to naknadno prodat pa uzet Bulldozer, a možeš i ostat na tome, sumnjam da će razlike u performansama (ako isključimo Benchmark) bit ogromne  Meni je i trenutna AM2 platforma overkill za 90% mog dnevnog rada...
				__________________ |
