Staro 03.05.2010., 20:28   #511
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
BC2 u punom sjaju je jedna od najljepših igri na PCu i nema usporedbe s mw2 koji nakon par sati igranja bc2 izgleda kao da je dvije godine star.
BC2 je dokaz da dx11 može izledati super i ne biti prezahtjevan.Po meni najbolja igra za usporedbe novih grafi,pored stalkera i crysisa.
Staro 04.05.2010., 22:11   #512
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Up until now, the third DirectX 11 compliant graphics SKU by NVIDIA, which was referred to as "GeForce GTX 460" has some confirmation in its naming, NVIDIA refers to it as "GeForce GTX 465". Some of its lesser known specifications that have come to light are: Clock speeds of 607 MHz (core), 1215 MHz (shader), and 801 MHz or 3206 MHz effective (memory). With a 256-bit wide GDDR5 memory interface, the card will feature 1 GB of memory. NVIDIA is said to have managed a TDP of 215W. The price-range targeted by this SKU is US $259 to $299. If market positioning of this SKU is anything to go by, the GTX 465 should be competitive with ATI Radeon HD 5850 and HD 5830.
TechPowerUp!
fran123456 je offline   Reply With Quote
Staro 04.05.2010., 22:16   #513
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Autor MAGARAC Pregled postova
+ Metro 2033
Matth€w je offline   Reply With Quote
Staro 05.05.2010., 02:22   #514
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Staro 05.05.2010., 09:07   #515
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Đizus, ovo čudo 3 slota zauzima, koja Zalmančina
Iako, meni su se oduvijek više sviđali referentni modeli ali kod ove grafe stvarno je potreban što bolji hladnjak, a na cijenu neću ni pomišljati kolika će biti...
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 05.05.2010. u 09:19.
Staro 05.05.2010., 09:44   #516
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
uff.. e ovo je vec interesantno
V.I.P je offline   Reply With Quote
Staro 05.05.2010., 11:01   #517
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,873
čisto me zanimaju temperature koje će biti sa ovim hladnjakom.
Ivo_Strojnica je online   Reply With Quote
Staro 05.05.2010., 11:05   #518
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Review doticnog hladnjaka ( Zalman vf3000n ) :
http://www.guru3d.com/article/zalman-vf3000n-review/
New GeForce 400 Series Member Named GeForce GTX 465, Clock, Speeds Surface
Clanak : http://techpowerup.com/121583/New_Ge...s_Surface.html
Staro 05.05.2010., 11:18   #519
Doink the Clown
Postovi: 6,214
Autor xulos Pregled postova
Još da su ga namontirali na nekakvog Fermija umjesto GTX285...
Uglavnom,, 44DBa buke koju proizvodi neće nimalo smetati usere koji kupuju takvu hladnjaču, jer to je clocking tool jelte
55 celzijevaca u full loadu je svakako bitna stavka, a cijena?
Ajmo se kladit da nije raspoloživa
Staro 05.05.2010., 11:18   #520
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
GTX 470 Zotac 2575kn,nije uopće loše.
@Klaun, jesu onda iznad 3100,ne boj se.
Zadnje izmijenjeno od: thedream. 05.05.2010. u 13:43.
Staro 05.05.2010., 11:53   #521
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Staro 05.05.2010., 13:15   #522
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
5 soma kuna?? -_-'
Staro 05.05.2010., 13:35   #523
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Fućkaš i cijenu i temeprature, pa kak je to teško?
Nebi ja tak nekaj u kompu, bakar smrdi, ima ga dost i bit će na meti kradljivaca. Moram se zaletit jedan dan tu u naselje jedno, možda nađem koju
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 05.05.2010., 14:20   #524
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Hladnjak je tezak je 430 grama :
http://www.zalman.com/eng/product/Pr...ad.asp?idx=390
Sto se tice cijene nece bit ispod 450-500 kn pogotovo ak na kutiju napisu fermi ready
Staro 05.05.2010., 16:02   #525
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Sviđa mi se što se Zalman u zadnje vrijeme uozbiljio i prešao sa bakrenog cvijeća na ozbiljne coolere. Sudeći prema reviewu, ovaj cooler je odličan.
Staro 05.05.2010., 16:59   #526
Jackson
Postovi: 648
Nije dual nego triple core Znam da je era dualaca gotova i zato sam se prebacio.
4850 više ne može na max detaljima vući rezoluciju 1600, to je stvar.
MP je posebna stavka, tu mi se stvarno gadi što sve ljudi rade da dobiju bolji fps ili neku drugu prednost (tipa ono igranje na golemom kontrastu... suludo).
Ali svejedno, moj je point da se štedi u developmentu na optimizaciji. Jer ako jedna igra može dobro izgledati i dobro raditi, može i druga. Igra dobije bolje ocjene u reviewovima ako dobro izgleda nego ako je dobro optimizirana. Neki developeri paze na to (npr. Mass Effect 2 izgleda bolje od 1, a treba ti slabiji komp, ili Supreme Commander 1 ima bolju grafiku od 2, ali zato puno glađe radi).
Jackson je offline   Reply With Quote
Staro 07.05.2010., 02:40   #527
ThePornstar
Postovi: 4,403
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 07.05.2010., 10:45   #528
thedream
thedream's Avatar
Postovi: 5,458
Staro 07.05.2010., 13:06   #529
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Galaxy GTX 470 GC Version Graphics Card Unveiled :
http://www.techpowerup.com/img/10-05-06/30a.jpg
http://www.techpowerup.com/img/10-05-06/30b.jpg
http://www.techpowerup.com/img/10-05-06/30c.jpg
http://www.techpowerup.com/img/10-05-06/30d.jpg
http://www.techpowerup.com/img/10-05-06/30e.jpg
Clanak : http://techpowerup.com/121729/Galaxy..._Unveiled.html
Ovako ruznu karticu nisam skoro vidio, ali mi se svidja ovo s dizanjem ove zujalice da ispuses prasinu . I pazi na colleru FERMI GPU inside
Staro 07.05.2010., 13:13   #530
thedream
thedream's Avatar
Postovi: 5,458
Meni se baš sviđa,netko je napisao,dobro ide uz Gigabyte ploče. Zanimljiv dizajn,ništa ružniji od stocka,po meni.
Vuče mi malo na Borg-ovu kocku.
Zadnje izmijenjeno od: Wolverine. 07.05.2010. u 14:03.
Staro 07.05.2010., 15:11   #531
Overhaul
Overhaul's Avatar
Postovi: 517
Ma odlicno izgleda kartica, jos da je to neki ala carbon, ili metal, jos bolje.
Fala qrcu da su prestali s onim naljepnicama kretenskih daz/poser "heroina"
u kich maniri na tako skupom i ozbiljnom komadu hardvera.
Bem im ja, ko je kinezima dopustio da se primaju "designa"
i pokrenu taj modni trend prije par godina. Nadajmo se da vise ni jedna
DirectX11 kartica nece imat tih kicastih nakarada po sebi.
Cudim se inace da nitko osim sapphirea ne primjenjuje vapor chamber?
Na gtx 4xx bi trebalo to okej funkcionirati. I msi je vec mogao napraviti
onu svoju twin frozr superpipe varijaciju?
Overhaul je offline   Reply With Quote
Staro 07.05.2010., 16:36   #532
Postovi: 7,568
Gigabyte GeForce GTX 480 and GTX 470 Graphics Cards: DirectX 11 Battlefield - potrošnja od 130W za GTX 480 GPU dok vrti Blu-ray.
Staro 07.05.2010., 17:52   #533
Mad_Duke
Autor McG Pregled postova
Taman za jedan low power HTPC :P
Staro 07.05.2010., 18:01   #534
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
+ Winter edišn (brrrr)
Staro 07.05.2010., 20:07   #535
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
ovo ne izgleda lose
Inno3D GeForce GTX 470 HAWK
DeadMan+ je offline   Reply With Quote
Staro 07.05.2010., 20:59   #536
thedream
thedream's Avatar
Postovi: 5,458
Autor DeadMan+ Pregled postova
ovo ne izgleda lose
Ljepotica,ko moja GTS250. A i ovo silent,sa tri zujalice,hm..big no,no IMO. Možda za njihove pojmove tišine.
Staro 07.05.2010., 21:28   #537
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
ha? pa bolje 3 na manje okretaja nego jedan na milijardu
Staro 08.05.2010., 00:17   #538
Doink the Clown
Postovi: 6,214
ovo ne izgleda lose
3 venta?
O bože mili, žalim sve buduće vlasnike tog modela
Staro 08.05.2010., 01:05   #539
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
3 venta?
pa o cemu vi pricate?
AC ventovi su tihi, znam iz iskustva, a i vecina (objektivnih) reviewa to potvrdjuje, tako da ne razumijem cemu zabrinutost
Staro 08.05.2010., 01:08   #540
Doink the Clown
Postovi: 6,214
Ne znam, jednostavno je moj subjektivni dojam da tri venta na takvoj grijalici ne mogu biti tiha, pogotovo ne kad je grafa u loadu, neka me slobodno netko razuvjeri kad kupi dotičnu karticu
