Staro 17.04.2010., 14:44   #3781
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Rotel + Diamondi
Flikoman je offline   Reply With Quote
Staro 18.04.2010., 22:10   #3782
warlock25
warlock25's Avatar
Postovi: 2,327
Evo ubo sam pjacalo rotel ra-01 i spojio na komp prek aux1
Sad imam tam za birat aux1,aux2,tape,cd,tuner,phono i preout - za sto to sluzi?
Staro 18.04.2010., 22:43   #3783
Don
je gladan!
Don's Avatar
Postovi: 1,698
Da si u google ukucao preout dobio bi 510.000 rezultata
Don je online   Reply With Quote
Staro 19.04.2010., 00:34   #3784
warlock25
warlock25's Avatar
Postovi: 2,327
ma znam al lijenost je danas na vrhuncu
Staro 19.04.2010., 00:43   #3785
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor Don Pregled postova
On je lijen...Ali Don ti spamaš
Moram malo
Preout:
Pre-out simply passes the preamp signal to external amplification (all preamps/processors need these) and/or bypasses the internal amplification stage (if a receiver is preamp). The volume is still controlled by the preamp device however. All preamps/processors have pre-outs but not all receivers (usually lower end do not...these are limited as all-in-one packages)
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 19.04.2010., 11:05   #3786
domis
Lokacija: Hrvatistan
Postovi: 4,164
@flikoman
daj malo ispuši prašinu iz kompa, jedva sam prepoznal tx650
Staro 19.04.2010., 11:42   #3787
Juan
Juan's Avatar
Postovi: 294
I, kak napreduju radovi na idućem projktu?
Šta je ono bilo, sph176 uz dt254 u D'Appolito konfiguraciji?
Ja se iduće bacam na back loaded horne sa 208 sigma driverima.
Juan je offline   Reply With Quote
Staro 19.04.2010., 13:11   #3788
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Autor domis Pregled postova
@flikoman
Jesam, baš danas
Inače, što se tiče zvuka, sad nakon par dana burn in-a, moram reći da sam zapanjen
Zaista svima preporučujem ovaj mod na svojim X-Fi karticama. Napominjem, nije moguće na baš svima.
Staro 24.04.2010., 17:48   #3789
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
Pozdrav...jedno pitanje za vas.
E-MU 0404 USB (AK4396) ili Pro-Ject USB Box (Burr-Brown PCM2702)?
Namjena - isključivo kao eksterni DAC.
CA DacMagic mi je malo preskup.
Ph03n1x je offline   Reply With Quote
Staro 24.04.2010., 18:05   #3790
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Autor Flikoman Pregled postova
Jesam, baš danas
Ti si ovo radio sa svojom?
http://www.overclock.net/sound-cards...will-void.html
http://www.head-fi.org/forums/f46/ho...no-56k-226975/
Ja već neko vrijeme razmišljam o tome,kao i da ju oklopim (EM shield). Navodno je problem što se počne zagrijavati prilično,koliko čitam.
Zadnje izmijenjeno od: thedream. 24.04.2010. u 18:12.
Staro 24.04.2010., 20:13   #3791
Don
je gladan!
Don's Avatar
Postovi: 1,698
Autor Juan Pregled postova
Da, no odustao sam od "kopija".
Trenutno sam na štivu o TL-u i udubio sam se u par knjiga pa dok si malo ne posložim u glavi ništa od samogradnje.
Imam neku ideju, no pričekati će jer planiram napraviti jedan par za vjeke vjekova
Koliko dođe par tih širokopojasnih?
Staro 25.04.2010., 11:10   #3792
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Aha, upravo to.
Još ću kratko spojiti ili zamijeniti 4 kondenzatora kod LM-a sa Elna Silmic II.
EM Shield nisam niti neću stavljati.
Staro 26.04.2010., 18:23   #3793
newalss
Raindrops keep fallin'...
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Autor Ph03n1x Pregled postova
Nisam čuo proj-ject kako svira ali bi ga uzeo kada bi mi dvojba bila ova tvoja.
Radi E-MU o.k. ali nije ono što ti treba; solidno pojačalo za slušalice, xlr ulazi za mikrofon, direct monitoring bla bla, ništa ti to očito ne treba a platit ćeš.
"I told my parents that when I grew up I wanted to be a musician.They said it had to be one or the other"
newalss je offline   Reply With Quote
Staro 28.04.2010., 08:48   #3794
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Na moje iznenađenje, upravo mi je došao još jedan Elna Cerafine 1000uF 16V audiofilski hifi kondenzator. Lik iz Hong Konga mi ga obećao besplatno, pošto mi je prvi dosta kasnio.
No, uglavnom, to je savršeni kondenzator za modanje X-Fi kartica, pa ukoliko netko treba, slobodno mi se nek javi. Imam samo jednog, skroz novog.
Staro 04.05.2010., 18:21   #3795
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
Eto napokon sam si ubo DAC, no nije nikakav fancy šmensi, ali radi jako dobro na mom skromnom sustavu. Naime za razliku od dosadasnje audigy se (koja je davala zadovoljavajući sound) DAC daje malo širu sliku muzike te kvalitetnije visoke, srednje i niske tako da tko god se odluci na ovakav DAC kao moj nece pogrijesiti pogotovo zbog toga sto je jako jeftin te uz to omogućuje promjenu OPAMPA te tako možete birati zvuk koji želite. No ipak uz njega se ne dobije nista tako da na Vama ostaje izbor napajanja, kabela te izradnje kutije.
Moguće ga je naručiti sa ebaya na ovom linku
gbijelic je offline   Reply With Quote
Staro 04.05.2010., 19:24   #3796
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Autor gbijelic Pregled postova
Izgleda jako dobro. Baš bi ga trebali usporediti s npr mojom modanom karticom.
Što se tiče opampova, najviše se hvale sljedeći:
AD8620AR, AD8620BR, LM4562 te OPA627 i OPA637.
Staro 04.05.2010., 19:50   #3797
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
šteta što nismo blizu, al ipak sam ga uspio usporediti sa DAC-om Beresford 7520 od kolege i razlike nije bilo, ali ipak to je bilo na njegovom sistemu koje košta par puta više od mojega...sve u svemu ja sam jako zadovoljan pa napokon kad mi je izvor na nekom višem nivou mogu krenuti na promjenu zvučnika pa onda opampova, jerbo džaba ti dobar sistem ak je izvor shit
Staro 04.05.2010., 23:06   #3798
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
U potpunosti se slažem.
Makar imam namjeru kroz neko vrijeme kupiti Asus Xonar ST ili STX, ovu ću si vjerojatno ostaviti (Extreme Music) i lemiti i dalje po njoj iz puke zabave i da još nešto naučim. Imam još dosta toga na umu, al nedovoljno sredstava.
Primijetio sam da se dosta ova tema zapustila u zadnje vrijeme
Staro 04.05.2010., 23:13   #3799
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
Ha nema se para da se kupuju nove stvari...meni je slucajno eto uletio ovaj DAC pa se sad igram ...za xonar st kolko sam čitao svi koji su je čuli kažu da je best buy, nadam se da cu uskoro imat prilike ju čuti pa javim
Staro 06.05.2010., 02:54   #3800
domis
Postovi: 4,164
evo meni nakon skoro mjesec dana ponovo proradila optika.
isel sam malo overclockat proc tek tolko da mi glatko ide dirt2 i proradi...zašt, ne kužim...isto ko i ne kužim zašt je prestala raditi
komp se očito bunil jer je radil na defaultu
Staro 10.05.2010., 12:53   #3801
Doom
Émile Flournoy
Doom's Avatar
Lokacija: Chicharija
Postovi: 1,529
Postoji li neki dobar dac do 100E da ima optički ulaz i može raditi samostalno bez spajanja na računalo ?
Trenutni htpc sa Asus Xonar DX-om bi zamjenio sa wdtv liveom pa bi zvuk trebao biti bar u klasi Xonara.
Imao sam stari wdtv koji je u usporedbi sa Xonarom zvučao dosta mutnije.
Staro 10.05.2010., 13:53   #3802
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Slično pitanje imam i ja.
Pošto su mi svi dijelovi rezervirani, samo čekam uplate na račun, pa šaljem dijelove nakon toga, zanima me što je bolje kupiti?
Asus Xonar Essence ST/STX (nadogradio bih sve opampove u LM4562)
ili
DAC (cijena do 1400kn).
Pitam prvenstveno zbog toga jer je trenutno Asus Xonar ST nedostupan u Linksu, a doći će, ako bude, kroz najmanje 10 dana.
Hvala
Staro 10.05.2010., 14:18   #3803
reverzibilni
Lokacija: ri
Postovi: 97
baš se pitam di je taj ST nestao......
jednostavno sam ga morao uzet..... ima sam na posudbi stx i bogami je nadsvirao moju dx...
dac do 1400kn nemaš bolji od essencea.......
ima sam na probi i CA dacmagic (preko 2000kn), pa se ni on nije pokaza boljim.....
ostali (jeftiniji) su bili lošiji od, ili u rangu sa, DX....
doduše svi isprobani DAC-ovi su bili spajani isključivo preko usb-a..... osim CA.....
reverzibilni je offline   Reply With Quote
Staro 10.05.2010., 14:22   #3804
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Autor reverzibilni Pregled postova
Zvao sam ih i rekli su minimalno 10 dana. Ti daješ glas ST kartici znači?
Staro 10.05.2010., 14:49   #3805
reverzibilni
Lokacija: ri
Postovi: 97
jap....
kolikogod puristi pričali o nužnosti odvajanja zvuka od pc-a (u vidu externih dac-ova sa posebnim napajanjima), ja ipak ponajviše cijenim moje uho.......
kad sam kupovao xonar dx alternativa je bio project usb dac...... nakon par sati slušanja (iako je razlika bila vidljiva momentalno), kupio sam dx......
u međuvremenu sam posluša većinu dac-ova dobavljivih u hr... i jedino me ca dacmagic mrvu pokolebao......ali onda sam se dokopa xonar stx-ice..... a sad i st varijante (koja je još mrvu bolja).......
zaključak:
xonar dx je bestbuy kartica (i to daleko najbolji).... alternative u tom cijenovnom razredu nema.....
st/stx je jedan od najboljih (i najpovoljnijih) načina da pc pretvorite u pravi hi-fi izvor zvuka.....
Staro 10.05.2010., 14:53   #3806
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
jap....
zaključak:
Hvala!
Izgleda da Links neće imati ST ili STX, pa ću vjerojatno morat kupit D2X!
Jel ti imaš koju ST ili STX dobavljivu?
Staro 10.05.2010., 15:01   #3807
reverzibilni
Lokacija: ri
Postovi: 97
imam samo DX.......
koja je trenutno rezervirana.....
ali vjeruj mi...... nema nikakve razlike u zvuku između dx i d2x.....
znači plaćaš duplo za isti zvuk i par dodatnih fičura......
Staro 10.05.2010., 16:39   #3808
Doom
Émile Flournoy
Doom's Avatar
Postovi: 1,529
Za DX znam da je Best buy, u odnosu na stari wdtv, Sony dvd player i Audigy4 daje puno čišći i prirodniji zvuk.
Od CA D300se cd playera ipak nije bolja, taj player i dalje spajam analogno na ht reciver jer ima puno prirodniji zvuk od Dac-a ugrađenog u reciver, svih zvućnih koje sam imao i Denon dvd playera koji je koštao 2500kn.
Možda je netko od vas imao priliku poslušati Zero DAC sa ebaya, na stranim forumimam ga dosta hvale a nije ni pretjernao skup.
Staro 10.05.2010., 16:54   #3809
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
U mogućnosti sam nabaviti Supersonic USB DAC za 900kn.
http://www.audiofil.net/Forum/forum_posts.asp?TID=9507
http://www.audiofil.net/data/upload/...istem_novo.JPG
Sad me zanima jel se isplati kupovat Asus Xonar D2X naspram toga i davat dodatnih 400kn?
Staro 10.05.2010., 17:07   #3810
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
Samo bih dodao da za dobar izvor zvuka treba imati i pojačalo i zvučnike i naravno odgovarajuće kabele da bi se mogla donijeti konačna odluka...tako da džaba ti ulaganje u super ultra izvor kad nemoš čut njegov maximum
