Staro 04.04.2010., 21:24   #31
Dottore
Dottore's Avatar
Postovi: 7,711
MX518 R.I.P.
Neprestanog gejmanja CS punih 6 godina od kada sam kupio. Otišao je scroll , lijeva tipka
Ne znam koji bi uzeo ni do koje svote.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 04.04.2010., 21:33   #32
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor Dottore Pregled postova
MX518 R.I.P.
Ako te već toliko vremena dobro služio zašto ne uzeti novoga opet?
http://www.adm.hr/product_info.php?c...oducts_id=2780
C L O W N I N G A R O U N D
Staro 04.04.2010., 21:35   #33
Dottore
Dottore's Avatar
Postovi: 7,711
aaa tako je pao sa 6 godina košta 386kn.
Budem opet nabavio
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 04.04.2010., 22:02   #34
Dottore
Dottore's Avatar
Postovi: 7,711
kakav G500 donja površina pad ima?
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 04.04.2010., 22:21   #35
2 die 4
2 die 4's Avatar
Postovi: 2,284
Molim, kaj, koga, gdje??????!!!!!!
RedGreenBlue
Staro 04.04.2010., 22:22   #36
dtrixxx
Lokacija: _
Postovi: 193
Ni ja nisam skonto...
Uzmi ti opet mx518,to je klasika
dtrixxx je offline   Reply With Quote
Staro 04.04.2010., 22:23   #37
Dottore
Dottore's Avatar
Postovi: 7,711
skatez ?
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 04.04.2010., 22:52   #38
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
isto ko G5 ima i definitivno uzmi G500, a ne MX518. neusporedivo.
Shockre je offline   Reply With Quote
Staro 05.04.2010., 00:31   #39
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Takođe preporuka(g500).....samo je pitanje dal ces se navuknut na malo meksi scroll ( u originalu je zamiljen bez granicnika za prekid....hyperscroll,genijalna stvar kad se kreces po netu i pdfovima i svemu sta ima dost scrollanja....prekidi na scrollu se aktiviraju gumbom na gornjoj strani). U igrama mi je dosta reaktivniji nego 518....
Staro 05.04.2010., 01:25   #40
2 die 4
2 die 4's Avatar
Postovi: 2,284
ako pitaš kakav je G500, eto ljudi odgovoriše, a ja samo mogu potvrditi!
Genijalan miško!
RedGreenBlue
Staro 05.04.2010., 01:36   #41
ninja666xx
ninja666xx's Avatar
Lokacija: Zdenčina
Postovi: 314
Pošto sam vlasnik g9x i g500 miševa onda ih mogu i usporediti na vlastitim zapažanjima....kao prvo svaki ima nešto posebnije ali opet je to sve isto....g9x je više custom iliti više tjuning miš po tome što možeš mjenjati led boje koje hoćeš da ti svijetle, možeš memorirati do 5 kombinacija tipki na njega, mijenjati gripove(dobiješ ih 2 uz njega), ja osobno imam još jedan dodatni koji je veliki grip gumirani tak da je onda isto ko i g500 velik i super leži u ruci, minus mi je što ima jednu tipku manje.a g500 je stvarno mrak leži u ruci,možeš spremiti jedanu kombinaciju tipki, ima tipku više, koja dobro dođe u fps-ima. DPI je identičan, sad je na tebi koliko misliš love izdvojiti, ali kao bast buy svakako g500, a i osobno ga više koristim....tak da odmah trk po njega...
ninja666xx je offline   Reply With Quote
Staro 05.04.2010., 01:46   #42
Dottore
Dottore's Avatar
Postovi: 7,711
kakav minus ima? gledam onako usporedbu MX518 vs G500.
G9x ne leži nikako opet ću imati problema s privikavanjem na ruci.ipak morat ću strpiti dva tjedna od gejmanja CS i TF2
anway B58 stvarno neprezican, svaki kill gubim
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 05.04.2010., 02:22   #43
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ima minus taj scroll,sad zavisno od publike...jedni ga dizu u nebesa drugi kazu da je "utter shit"..... ja bum realno rekel....cak i na prekidima je malo premekan "klik" kotačića.... a sad,ja se navikao i u COD4 veoma dobro vidim koje mi je oruzje pred buljom
Nekima josh smeta i znojenje...no ja nisam naisao na mish kod kojeg mi se ruka ne znoji pri intenzivnijem napucavanju.
Staro 05.04.2010., 11:07   #44
fanATIk
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,021
To je ipak više do skilla nego do miša... Tko zna igrat, razvaljuje i s B58 i s G500. Tko ne zna, uzalud mu svi progejmerski miševi ovog svijeta.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 05.04.2010., 13:02   #45
Dottore
Dottore's Avatar
Postovi: 7,711
Autor fanATIk Pregled postova
to istina stoji. prekjučer sam igrao s mx518 i dosta sam razvalio. dok sam prešao na B58 i fali mi prezicnost, oblik miša ( znaš ono s velikog na malog ) .Mx518 ima najmanji hod tipki u odnosu na B58.,
Možda mene stvarno smeta sporost, oblik miša ( veći dlan ruke ) jer 6 godina ostavilo traga navike
Igrao sam na podlozi Func Surface 1030 ( dva puta ) i već trenutno na Razer Mantis Speed ( dvije godine )
Prije MX518 igrao na B58 bar 2-3godine
u CS settings
MX518 sensitivity 1.1 ( defaultne postavke u Setpoint , CPL mousefix)
B58 sensitivity 2.3
CS igram dosta dugo od verzije 1.1 sve do danas :P
I sad možeš skužiti da znam igrati
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 05.04.2010., 18:06   #46
dtrixxx
Lokacija: _
Postovi: 193
Frend mi ima g500 i meni nekako ispada retavo napravljen,ozada pretezak a sprijeda prelak bez obzira na uteg.
Staro 07.04.2010., 23:42   #47
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,658
Za nekih 200kn možeš kupiti Sharkoon FireGlider i i bit ćeš zadovoljan....
Zadnje izmijenjeno od: locks. 08.04.2010. u 00:09.
Staro 08.04.2010., 23:40   #48
Gumby
Gumby's Avatar
Datum registracije: Feb 2003
Lokacija: Velika Gorica
Postovi: 499
Evo jedan interesantan review/usporedba G500 i MX518
http://www.youtube.com/watch?v=vsqoH...eature=related
Napomena: review ima 3 dijela
Doctor!!!...
Doctor!!!...
MY BRAIN HURTS...
Gumby je offline   Reply With Quote
Staro 09.04.2010., 01:21   #49
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
bože u prvom djelu je vec tolko gluposti da sam zgasio.... wrist fatigue? Šta bi taj reko da ga odvedem na radne akcije na viksu Frajer si je zvadil scroll jer mu je miš pretežak? LOL
If you like heavy mice you're idiot.....kakav review
Staro 09.04.2010., 02:40   #50
veve
woot!!!
veve's Avatar
Postovi: 2,501
Pa ima smisla to sto on prica, a sad kak kome je to bitno i koje su potrebe to ovisi o samom korisniku
@Dottore
Ako ti je MX518 bio dobar onda ga ponovno uzmi jer je provjereno i znas na cemu si
Ja sam recimo presao sa MX518 na DA, bolje mi lezi u ruci i manje mi se ruka umara za vrijeme CSa.
veve je offline   Reply With Quote
Staro 09.04.2010., 06:52   #51
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ima smisla to ak ti neko kaže da ak voliš nešto da si idiot? Superiška,razina ovog reviewa je u ravnini s intelektualnim nivoom recenzenta
Staro 09.04.2010., 12:02   #52
veve
woot!!!
veve's Avatar
Postovi: 2,501
Autor trouble Pregled postova
Ocito je da nisi pogledao review do kraja, jer je lik ulozio svoje znanje i vrijeme te je detaljno sve objasnio. Istina da je prvi dio malo dosadan jer je uvod i to veoma dugi, ali ostatak reviewa je dobar.
To sto je on pretjerao sa izrazavanjem jer je mogao samo reci "Teski misevi nisu dobri itd..." je njegov problem i u tom trenutku se gubi profesionalnost reviewa.
Staro 10.04.2010., 15:09   #53
peltierzg
peltierzg's Avatar
Postovi: 70
Razer Deathadder... sklad tehnologije i savršenstva, sa tim nećeš sigurno pogriješiti.
Pozz
peltierzg je offline   Reply With Quote
Staro 10.04.2010., 22:24   #54
locks
Lokacija: Vukovar
Postovi: 3,658
Meni je recimo Razer bolje odgovarao od Logitecha pa preporuka ide za Deathadder ili Imperator...koji je malo skuplji.
Staro 11.04.2010., 16:09   #55
explorer 4
explorer 4's Avatar
Postovi: 517
g500 svakako odličan i precizan miš
explorer 4 je offline   Reply With Quote
Staro 14.04.2010., 18:30   #56
Memphis
Postovi: 1
Čitajući ovu temu vidim da su ovi preporučivani miševi više orijentirani za igranje (naravno da su iskoristivi i za običan rad, ali možda ima i jeftinijih koji bi meni služili), pa me zanima preporuka nekog ergonomskog miša za rad. Nisam do sad nikad koristio (ni isprobao) neki ergonomski miš, radim sa običnim Logitechovim miševima (do 100kn), ali sam u zadnje vrijeme osjetio da me ruka-zglob počinje boliti. Miš bi mi koristio za rad u CAD-u i normalno služenje sa kompjuterom. Svaki savjet je dobrodošao...
Memphis je offline   Reply With Quote
Staro 06.05.2010., 13:45   #57
Vrga
Lalalallalaaaaaa
Vrga's Avatar
Datum registracije: Mar 2009
Postovi: 521
a čuj, s obzirom da sam na kompu cirka 12 sati+ svakodnevno, na mx 518, i iskreno... nikad me al nikad me nije zglob bolio, mislim da ti se isplati uzet neki ergonomski. prorondaj po firmama i provjeri neki koji ti fino leži u ruci, nemoj ko bena ić uz preporuke direkt. dosta nas koji se kunemo na mx518, se kunemo najviše zbog navike i odbijanja navikavanja na neki novi
al činjenica stoji da se mx518 drži sasvim pristojno dan danas.
Vrga je offline   Reply With Quote
Staro 06.05.2010., 15:38   #58
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 974
jedini je bed što je ružan za popizdit ...za standardan rad m500 je sasvim fin
raliSHA je offline   Reply With Quote
Staro 06.05.2010., 15:52   #59
Vrga
Lalalallalaaaaaa
Vrga's Avatar
Postovi: 521
Autor raliSHA Pregled postova
word.
Staro 06.05.2010., 18:59   #60
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,885
ja sam i uzeo lachesisa sa ebaya pa budemo vdijeli,ni ovaj nije loš na recenziji.
