Zaključane teme
Staro 11.03.2010., 12:17   #1
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Lian Li PC-T1R Spider Case
Lian Li is entering the bench table market with a few different models soon. We reported about the traditionally shaped ones, as well as the Spider PC-T1 just last week, during our stay at CeBIT. The PC-T1 supports system board in the mini-ITX form factor. Lian Li and Case King were kind enough to arrange for a sample right away, thus we are proud to present you the first review of the most unique test bench - ever. The unit we got is almost the final version, with most of the features set in stone. Lian Li did mention that they are looking into fitting a normal 5.25 inch bay intstead of a slim-line drive on the PC-T1.
The Lian Li PC-T1 should sell for around 150 €, but this price - while likely - is not final.
* Incredibly sweet looks
* Elaborate design
* Not too many small parts
* Very good cable management possibilities
* Open system means no extra noise from fans
* Easy access to hardware components
* Angle of legs may be adjusted
* Available in black or red
* Not really usable as a test bench
* Be prepared to spend some time for assembly - it is unique after all
* If you are a dud at assembling IKEA furniture, read the manual.
* No I/O
* Leg joints are somewhat weak, but Lian Li is improving that for the retail version
Izvor: techpowerup
bluefluid je offline
Staro 11.03.2010., 12:19   #2
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
ukratko cu samo.. ocajno..
V.I.P je offline
Staro 11.03.2010., 12:27   #3
SetH
SetH's Avatar
Lokacija: ZG/Borongaj
Postovi: 3,324
bilo već,koliko znam
SetH je offline
Staro 11.03.2010., 12:49   #4
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
koji ste vi party pooperi
Staro 11.03.2010., 13:46   #5
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Grozno je bilo već ili ne...
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline
Staro 11.03.2010., 13:50   #6
Mad_Duke
Predobro!
To se zove dizajn!
Staro 11.03.2010., 14:44   #7
marko_zg
marko_zg's Avatar
Postovi: 243
To se zove govno, a i komponente su banana. Inace tom kucistu su jedina svrha sajmovi di trebaju komponente izloziti da se vide pa onda su mogli natrpati nesto tu a ne ovu sirotnju, pa barem da su jadnici stavili bolji cpu hladnjak da to lici na nesto lol.
marko_zg je offline
Staro 11.03.2010., 15:14   #8
Mad_Duke
Autor marko_zg Pregled postova
Ček, sad smo došli do toga da su komponente govno hahaha
Ajde da čujem zašto je ovo govno?
http://www.pohrani.com/?1r/5Q/1KbKIajn/finishedon.jpg
http://www.pohrani.com/?3I/ao/2yLaRC...piderfloor.jpg
Staro 11.03.2010., 15:17   #9
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
ljepo zamisljeno, no katastrofa stane sam mini ATX ploca, cist me zanima kad i grafu neku stavil gore cim bi ju stegnio...i sve to samo za 150€
Dobro me ovo nasmijalo
zamisli da ti klinac uleti s nekim predmetom u "kuciste" (ako se to tak moze nazvati)...bilo bi veselja .
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline
Staro 11.03.2010., 16:40   #10
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Ja već vidim klinku kako sam žličicom mi kopa po matičnoj...
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Mortal je offline
Staro 11.03.2010., 16:46   #11
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
C L O W N I N G A R O U N D
Doink the Clown je offline
Staro 11.03.2010., 18:48   #12
marko_zg
marko_zg's Avatar
Postovi: 243
Haha pa govno je, kuciste koje bi trebalo sluziti kao izlog za prave komponente a gore ide mini atx ploca, pa to je lol. Uostalom sta moze dobro biti u komadu zeljeza koje izgleda jeftino sklopljeno i u obliku je pauka. Cak i ovaj LIAN LI logo je ruzan hehe. Mislim ukusi su razliciti al ono...........
marko_zg je offline
Staro 12.03.2010., 10:18   #13
Mad_Duke
miniITX ploča koja može služiti kao HTPC u ovoj konfiguraciji. A sama stvar bi se predobro uklopila na podu nekog većeg dnevnog boravka kaj je futuristički više dizajniran. Čisto stvar ukusa. Zato i takva cijena. Za ljude kaj to žele čisto zbog izgleda nek to i plate. Moja jedina zamjerka je kaj portovi od matične (i grafe) idu prema "naprijed", a ne iza. Mislim da bi puno bolje izgledala stvar u tom slučaju.
Staro 14.03.2010., 10:23   #14
domis
Lokacija: Hrvatistan
Postovi: 4,164
dajte dobro promotrite sliku i recite što jako ne štima na njoj
domis je offline
Staro 14.03.2010., 10:35   #15
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Ovo je GOVNO,a ne "kuciste"....da,moze sluzit jedino za neki izlog komponenti,ali meni ovo izgleda onak..za povratit...pogotovo to sto su portove od maticne okrenuli na krivu stranu......
Pošten trgovac: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15...
- prije mi je bio nick "xTreme Gamer" (profil je isti ali sam promjenio nick)
xtreme96 je offline
Staro 14.03.2010., 10:44   #16
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,685
Autor domis Pregled postova
Hebote kud stavili pržu
Lenovo LOQ || AMD Ryzen 5 8645HS / 16 GB DDR5 / 1TB Micron M.2 2242 / 1TB Sandisk Extreme nvme M.2 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk Plus / nVidia Geforce GT 730 / FreeBSD 14.3
tomek@vz je offline
Staro 14.03.2010., 16:46   #17
SetH
SetH's Avatar
Postovi: 3,324
stvarno mi nije jasno tko će to kupit
SetH je offline
Staro 14.03.2010., 18:38   #18
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,767
pauk ima 8 nogu, a ne 4. škrti lian li.
rendula je offline
Staro 14.03.2010., 19:54   #19
borny
Too much busy
borny's Avatar
Postovi: 1,540
Autor rendula Pregled postova
baš o tome razmišljam kad ono na dnu threada...
borny je offline
Zaključane teme
