Staro 18.02.2010., 13:50   #631
ojpi
ojpi's Avatar
Postovi: 1,127
Autor Mar Pregled postova
Jeste možda probali u opcijama od vašeg YT accounta namjestit preferiranje HD streamova (na kompu) i onda probali gledati preko WDTV-a?
Misliš na ono playback setup u account opcijama? Stavljeno mi je na "I have a fast connection. Always play higher-quality video when it's available." ali mi se nakon nekog vremena iz ne znam kojeg razloga uvijek vrati na "Choose my video quality dynamically based on the current connection speed."
ojpi je offline   Reply With Quote
Staro 18.02.2010., 15:41   #632
njezic
AV-TV-SAT-GAMING {FREAK}
njezic's Avatar
Postovi: 22
Wink Can not play Videos in HD from Youtube?
Evo, to se isto pitanje provlači na njihovom forum support-u:
=> Can not play Videos in HD from Youtube?
Izdvojeno:
Yesterday I tried one of my favourites HD videos in YouTube (Resolution 720p), and it was impossible to achieve High Resolution quality !! It was showed in low resolution !! I remember two weeks ago watching the same video on HD quality! What is the problem? Anything has changed? I have selected "Always better definition" on Youtube user options but no result....
What I need to do to be able to watch again these videos on High Definition?
I have the same problem after upgrade to firmware version 24. Before hd played fine from YouTube, after the upgrade the same movie clips are not in hd anymore...
Uglavnom, nowi firmware donosi vrlo dobru doradu YouTube interface-a (npr. Playlist opcije), ali s druge strane nedefinirano određivanje rezolucije koju želimo kortistiti kod reprodukcije?!
njezic je offline   Reply With Quote
Staro 18.02.2010., 21:05   #633
ojpi
ojpi's Avatar
Postovi: 1,127
Vrlo jednostavno, youtube iz nekog razloga više neda hd na wd... Samo mislim da to oni neće priznat...
Staro 19.02.2010., 18:29   #634
chvarko
Beaker
chvarko's Avatar
Lokacija: 45°29`N 16°47`E
Postovi: 87
Autor ojpi Pregled postova
Preformulirao bi to u:
WD iz nekog razloga više ne daje HD sa YouTube-a (jer na PC-u radi normalno)
Beaker's Ballad
chvarko je offline   Reply With Quote
Staro 19.02.2010., 20:18   #635
ojpi
ojpi's Avatar
Postovi: 1,127
Autor chvarko Pregled postova
Ja mislim da youtube neda wd-u da se moze gledat hd video prek njihovih uređaja... To sam i napisao.
Staro 19.02.2010., 20:32   #636
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,326
Moguce ALI nevidim sto bi youtube dobio time ? Manje korisnika ? Hocu reci da mislim da je ipak nesto do firmwarea u WDTVL i da to treba postat pod bugove pa da isprave sto prije. Nije bas da gledam youtube preko WDTVL (nisam ga zato kupio ) ali ponekad i pogledam nesto . Radije bi gledao vimeo fileove koji su bolje rezolucije i kvalitete u vecini slucajeva .
Staro 19.02.2010., 21:04   #637
leteci
leteci's Avatar
Postovi: 89
Official WD answer:
Dear Juan,
Thank you for your reply.
I received a reply back from engineering. It appears that YouTube will no longer allow non-browser based players to play HD content. This is accordance with their rules and regulation that we have to adhere to. I apologize but you will not be able to play HD content from YouTube on the WD TV Live.
Sincerely,
Leonard B.
Western Digital Service and Support
http://support.wdc.com
leteci je offline   Reply With Quote
Staro 19.02.2010., 21:07   #638
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,326
Eto misterija rjesena, youtube blokira HD content na WDTVL . Nista , sad nek WDTWL firmware napravi update sa WEB browserom i podrskom za tipkovnicu/mish pa da surfamo kako treba
Staro 21.02.2010., 17:48   #639
chvarko
Beaker
chvarko's Avatar
Postovi: 87
Jel netko probao skinuti HD materijal (720p ili 1080p) sa YouTube downloaderom (na HDD/stick) te reproducirati na WDTV Live-u (kad već ne podržava (više) on-line gledanje u HD rezi.
Ja probao sa dva YouTube downloadera i meni ne radi (a uvjerava me čovjek da mora raditi).
Probao i u mp4 (sa "YouTube downloader 3000") i u avi (sa "YouTube downloader HD"), ali uvjek WD L izbaci:
Unable to play the selected file. Please refer to the user manual for a list of supported file formats.
P.S.
Ide sa "YouTube Downloader Version 2.5.3" (thx MytByte)
Beaker's Ballad
Zadnje izmijenjeno od: chvarko. 22.02.2010. u 09:23.
Staro 23.02.2010., 23:54   #640
Caligula
Caligula's Avatar
Postovi: 245
Izašao Prerelease Firmware 1.02.14 za testiranje
Nema još podrške za DVD menije
Link
Caligula je offline   Reply With Quote
Staro 24.02.2010., 02:17   #641
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Autor Caligula Pregled postova
Link
Zanimljivo, čini se da su dosta toga popravili sa SMB/W7 konekcijom (inače nije lako riješiti da radi bez greške ).
- Barney Stinson
Staro 24.02.2010., 08:44   #642
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Fala im, napokon se netko sjetio:
· Added new category in Photo/Video to view by date.
Staro 24.02.2010., 09:49   #643
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,326
Hmm, sto je ovo ?
"Added European language input for keyboard. "
Jel to znaci da WDTVL podrzava tipkovnicu ?????
Staro 24.02.2010., 12:18   #644
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Autor Lewis Pregled postova
Hmm, sto je ovo ?
Hmmm, mislim da je prije layout za onu virtualnu...
- Barney Stinson
Staro 24.02.2010., 13:00   #645
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
ma meni je sve to ok, jebesh YT, DVD Menu i sl., samo da poprave problem s desync. titlova
danij3l je offline   Reply With Quote
Staro 24.02.2010., 13:25   #646
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,326
znaci sad mozemo upisati www.đurđa.com umjesto www.durda.com ?
Staro 24.02.2010., 13:50   #647
njezic
njezic's Avatar
Postovi: 22
Wink YouTube Downloader Version 2.5.3
...Ide sa "YouTube Downloader Version 2.5.3"
Testiran => "YouTube Downloader Version 2.5.3"
Ovo je izvrsno, radi caputure u najvišoj rezi koja je "raspoloživa" i pohranjuje lokalno na disk u mp4 formatu.
Više se ne mora brinuti o brzini (propusnosti) internet linije i trzanju slike, odnosno da li će isti materijal biti dostupan ili će ga netko skinuti u međuvremnu (ili zabraniti prikazivanje).
Međutim, neće skinuti full HD 1080 iako je raspoloživ na YouTube, već skine samo HD varijantu 720 linija?
Staro 24.02.2010., 14:33   #648
ojpi
ojpi's Avatar
Postovi: 1,127
Probal sam ovaj beta firmware i opako me jebe sa playanjem filmova prek mreže. Uopće neće, pa onda radi tromo poslije i sa diska... Samo se vrti ono plavo ili crni ekran. Sa starim radi savršeno. Nemojte isprobavat, moja preporuka.
Staro 24.02.2010., 16:44   #649
wdtvlive
Datum registracije: Feb 2010
Lokacija: Novi Sad
Postovi: 6
Šteta zbog titlova.
Da li je neko probao novi B-rad, kažu mijenja i boju i veličinu titla.
wdtvlive je offline   Reply With Quote
Staro 24.02.2010., 16:48   #650
wdtvlive
Lokacija: Novi Sad
Postovi: 6
Probaj ga isključiti iz utičnice 30-tak sekundi, poslije bi trebao da proradi. Kod mene je bio sličan slučaj.
U pravu ste, MKV fajlove pušta poslije 1-2 minuta čekanja. Fontovi jesu veći ali se prikazuju skoro na sredini ekrana. Ništa ne valja, a jesu smotani.
Zadnje izmijenjeno od: wdtvlive. 24.02.2010. u 18:27.
Staro 04.03.2010., 00:22   #651
Hrjax
Postovi: 307
Evo nabavio i ja samo za 600 kn i jos 200 kn za apacer 320 gb
(moram sam se malo pohvalit )
Kako ga mogu bezicno spojit na net?
I jos nesto,stavio sam HR titlove i č i ć se prikazuju kao ono neko ''retardirano e'',dok se ž i š UOPCE ne vide...npr ne pise ''zašto'' nego ''za to''
Kako da to rjesim?
Zadnje izmijenjeno od: Hrjax. 04.03.2010. u 10:10.
Hrjax je offline   Reply With Quote
Staro 05.03.2010., 11:09   #652
mahoona
mahoona's Avatar
Postovi: 284
Postavi encoding na Central European - 1250 da bi ispravno prikazivao čćžšđ
mahoona je offline   Reply With Quote
Staro 05.03.2010., 11:12   #653
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,282
@hrjax - ja sam stavio pod encoding windows-1250 jer mi na central european nije prikazivao znakove kako treba, pa eto, imaj i to na umu.
Staro 05.03.2010., 11:47   #654
mahoona
mahoona's Avatar
Postovi: 284
Autor Čuks Pregled postova
Krivo sam ja napisao , znam da 1250 mora biti u nazivu, heh.
Staro 05.03.2010., 12:57   #655
Hrjax
Postovi: 307
Hvala vam obojici na pomoci. Koji bezicni wireless stickovi rade na njemu?
Staro 05.03.2010., 13:05   #656
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,282
evo liste sa podrzanim adapterima . pogledaj dal se koji moze nabavit kod nas. mislim da je cak bilo vec govora o tome u ovoj temi pa potrazi
Staro 06.03.2010., 02:14   #657
Hrjax
Postovi: 307
Ako stavim taj wireless stick i ucitavam s PC-a, hoce li biti laga?
Staro 06.03.2010., 02:40   #658
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Autor Hrjax Pregled postova
Kojeg laga bog te mazo? Pa nije da se igraš na WDTV-u
- Barney Stinson
Staro 06.03.2010., 10:22   #659
Postovi: 34,046
Netko je napisao da wlan veza nije dovoljna za 1080 materijal, a za 720 materijal je bio knap tako da nemoj očekivati čuda od wlana.
Staro 06.03.2010., 15:32   #660
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,282
radije spoji zicom. tako si siguran da ce raditi kako treba
