#151 |
Lokacija: Malaysia
Postovi: 96
CPU-Z 1.53.2 - updated -fix CAS for Clarkdale -released 15.02.2010 This is internal beta version and without validation.
Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 |
#152 |
Lokacija: Malaysia
Postovi: 96
#153 |
Lokacija: Malaysia
Postovi: 96
#154 |
Lokacija: Malaysia
Postovi: 96
CPU-Z 1.54 -32bit CPU-Z 1.54 -64bit * Intel Core i7-880, Core i5-680, Core i3-550 processors. * Intel Xeon 5600 line (32nm) processors. * AMD Phenom II X6, Sempron II, Turion II, Turion II Ultra and Athlon II Mobile "Caspian" processors. * NVIDIA GeForce 320M chipset. * AMD 870/880G/890GX + SB800/SB850 chipset. * Introduction of validation rooms.
#155 |
Lokacija: Malaysia
Postovi: 96
#156 |
Lokacija: Malaysia
Postovi: 96
#157 |
Datum registracije: Jul 2003
Postovi: 167
CPU-Z v1.55 * VIA VX900/VX900M and VN1000/VN1000M chipsets. * Intel Core i5-760, Core i7-875K and Core i5-655K processors. * Intel Core i7-940XM, 840QM, 740QM mobile processors. * Intel Core i5-450M, 540UM, 430UM, Core i3-370M mobile processors. * Intel Pentium P6000 processor. * New parameter in cpuz.ini : UseDisplayAPI x86 (zip) x64 (zip) x86/x64 (installer) za Win98 (zip) |
#158 |
Premium spammer
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
#159 |
Lokacija: Malaysia
Postovi: 96
#160 |
Lokacija: Malaysia
Postovi: 96
CPU-Z 1.57 ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-setup-en.exe ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-32bits-en.zip ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-64bits-en.zip * Intel Xeon "Westmere-EX" support * GPU frequency report on Intel Sandy Bridge processor * AMD Zacate/Ontario processors support * Report TDP on main page when available * Cores clocks on floating menu * P67/H67 stepping report
#161 |
Postovi: 167
CPU-Z v1.58 * AMD FX "Bulldozer" processors family (K15) * AMD Llano processors family (K12) * Intel Sandy Bridge-EP processors preliminary support x86 (zip) x64 (zip) x86/x64 (installer) |
#162 |
Postovi: 167
CPU-Z v1.61 * Intel CedarTrail platform. * VIA VX11 chipset. * Intel Xeon E5 processors. * Fix wrong CPU clock speed under Win8. x86 (zip) x64 (zip) x86/x64 (installer) |
#163 |
Postovi: 3,793
#164 |
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
Ekipa, imam jedan problem sa CPU-Z... Naime, komp se smrzne sekund nakon sto pokrenem validaciju i prisiljen sam napraviti restart... Event Viewer ne pokaziva nikakav problem i svi ostali slicni programi (HWInfo, aida64) rade normalno... Validation link mi ipak stigne na mail, okacio sam ga u potpis... E sad je baza u tome sto se ovo dogadja samo kad je instaliran Pentium G3258 na MSI B85-G43 ploci, ako je gore i5-4570 CPU-Z radi ko podmazan. Ima li tko slicnih problema? |
#165 |
Datum registracije: Apr 2011
Postovi: 3,784
Vidiš da ti program piše bedastoće (core voltage 0.36V). Jesi probao s drugom verzijom programa? Isto tako, da li je na ploči najnoviji bios? CPU je inače stabilan, testirano? |
#166 |
Lokacija: ST
Postovi: 398
Ma to je idle napon, dobro pise. Koristim zadnju verziju, nisam pokusava sa starijom, racunam novije-stabilnije, ali budem probao... Na ploci je zadnja verzija BIOSa... Nisam pretjerano testirao stabilnost, sat vremena sa aida64 stres testom, 4.5GHz@1.250 temperature ne prelaze 60C... Inace nema nikakve razlike proc bio OC-an ili ne, CPU-Z svejedno radi problem. |
