Staro 10.12.2009., 19:40   #481
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor flajpan Pregled postova
Da, ovi koji imaju novi bootROM - samo tethered JB, zasad.
kak se provjeri koji imaš bootROM...
danc00 je offline   Reply With Quote
Staro 10.12.2009., 19:50   #482
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Na windowsima ovak:
To check iPhone 3G/3GS bootrom version:
Put your iphone in DFU mode.
(Connect your iPhone to iTunes, turn off, click power+home button for 10 seconds, leave POWER button after 10 seconds, holding HOME button)
iTunes will detect your iPhone in recovery mode.
Go To:
Start->Control Panel->Device Manager
In Universal Serial BUS Controller, you will find Apple Mobile Device USB Driver
Right Click and go to Properties, go to Details tab and select "Device Instance Path" from the drop down list box.
In that information, u will find [iBoot-359.x] at the end.
Ili ako je jailbreakan, samo ga restartaj, ako se normalno upali imaš staru verziju, ako traži restore (ona slika s kablom) onda imaš novu.
Staro 10.12.2009., 22:34   #483
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
A nova se neda unlockat ili šta?
Jer ja sam svojeg unlockal al nije wifi radil pa sam maknul unlock(makar nisam isprobal ono kaj si mi kasnije rekel "reset network")
Staro 10.12.2009., 22:48   #484
flajpan
flajpan's Avatar
Postovi: 1,796
Sve se da jedino što jailbreak "traje" samo dok je iphone uključen - ako se isključi/restartira JB se poništava i moraš ga ponovno odradit (i tako kod svakog gašenja/restarta).
Onaj savjet je dao geohot:
It appears some users are having wifi issues. Try a "Reset Network Settings". If you are still having wifi issues, see here. They don't appear to be caused by my software. Also, this just enables custom MobileConfig files. To fully enable tethering, go here on your iPhone and download a MobileConfig file for your carrier. Watch out for carrier fees for tethering.
Staro 11.12.2009., 00:16   #485
kviki0107
Postovi: 19
IPhone 3gs 32gb
Imam problema nakon što sam napravio jailbreak s blackrainom ! Svaki put kad mi se izprasni baterija moram napravit restore ili kad ga stavim na iphonu mi se pojavi da ga moram spojit na itunes i kad ga spojim moram napravit restore!jeli tko imao takvih problema i kako ih rješit!!
kviki0107 je offline   Reply With Quote
Staro 11.12.2009., 00:28   #486
Spirit
Spirit's Avatar
Postovi: 723
a jel tko probao sa Pwnage toolom na MAC-u
dal radi full JB, a ne blackra1nom...
Spirit je offline   Reply With Quote
Staro 11.12.2009., 00:33   #487
Optik
________
Lokacija: .
Postovi: 774
Pitanje vezano za iPhone 2G 8Gb (prva verzija, za Americko trziste), jeli radi kod nekoga offline maps tj jeli moguce koristenje bez vanjskog gps modula. Ako i radi, koji program i na kojoj verziji firmware-a. Znaci nesto tipa kao google maps samo da ne vucem podatke stalno sa neta nego da ih imam ocitane za jedan grad (primjer Zagreb). Sada, kada mi treba nesto, spojim se preko wifi-a i povucem sve podatke, otkacim se sa mreze i normalno mogu koristiti mapu za 2-3 kvarta dok dalje ne moze. Bio bi zahvalan na bilo kakvoj pomoci
Optik je offline   Reply With Quote
Staro 11.12.2009., 01:08   #488
georgy
georgy's Avatar
Postovi: 408
Optik- pogledaj ovu temu.
Malo je kompliciranije, ali ja sam uspio.
Ako ti treba karta za Zagreb- javi
georgy je offline   Reply With Quote
Staro 11.12.2009., 19:02   #489
rokoko
In Rainbows
rokoko's Avatar
Postovi: 715
Imam namjeru kupit Iphone 3G 8GB uskoro, ako se nadje neki povoljan ovdje na trznici pa bih ga volio otkljucat na Tele2 i jailbreakeat. Bio sam citao na nekom forumu da ima problema sa tele2 kartica zbog pina, al moguce da je to bilo prije cca ~1god. Jel i dalje ima tih problema ili?
Hvala
"Success can only be achieved with a kind of pioneer spirit and repeated use of three tools: failure, introspection and courage." - Soichiro Honda
Zadnje izmijenjeno od: rokoko. 11.12.2009. u 19:15.
rokoko je online   Reply With Quote
Staro 11.12.2009., 21:23   #490
Optik
________
Lokacija: .
Postovi: 774
Autor georgy Pregled postova
Budem svakako, hvala ti !
Btw, ovako brzinski sto sam vidio, morat cu stavit noviju verziju, jeli netko radio sa winpwn-om na Win7 64bit? Nekakva druga preporuka.
Ps.georgy-slobodno ti posalji kartu, nemoj se ustrucavat i ako imas jos kakav koristan tip
Staro 14.12.2009., 00:05   #491
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Jel radi vama iBluetooth iPhone 3GS FW3.2.1? Meni nikak neće raditi......
Staro 14.12.2009., 00:13   #492
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor rokoko Pregled postova
Hvala
Meni na 3G 16GB radi bez greške.
Autor danc00
iBluetooth ne radi na 3Gs
Staro 14.12.2009., 21:54   #493
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
s čim još odradit JB osim sa blackrainom, jer mi se nekako generalno ne sviđa kako mi se mob ponaša...
Staro 14.12.2009., 21:58   #494
flajpan
flajpan's Avatar
Postovi: 1,796
Imaš jedino pwnage tool za OSX: tutorial
iH8sn0w kaže da će u petak tražiti beta testere za sn0wbreeze (port pwnage toola na win).
Evo, pogledaj di se treba prijaviti pa probaj upast među testere: http://ih8sn0w.com/
Staro 15.12.2009., 08:36   #495
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor Gabre Pregled postova
Znači to je do toga, loš JB tool? Ni meni se ne sviđa generalno kak mi se mob ponaša ...
Kakvih imaš ti problema?
To bi recimo trebal biti bolji način za JB od blackrain-a?
PWNAGE sam koristil na 3G verziji i nisam imal nikad problema, dok sad na 3GS + blackrain zna biti smiješnih stvari, recimo pokazivač baterije, malo je na 82% pa ga stavim punit i odma padne na 18%, ili obratno....ili druge kombinacije. Al nemrem bez JB pa se moram pomirit s tim...
Staro 15.12.2009., 23:57   #496
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Imam pitanjce, nabavio sam 3g i napravio restore, stavio je najnoviju verziju 3.1 (predpostavljam), kvaka je u to me sto nemam ovu T-Mobile sim karticu se moze kak izbjec taj pocetni screen? (u kojem mi javlja da nemam karticu odgovarajuceg operatera)?
A ova verzija u prvom postu je stara po dosta....
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 16.12.2009., 00:09   #497
rocky6
Adriaaaaaan....
rocky6's Avatar
Postovi: 278
Pitanje, imam novi 3gs sa firmware 3.1.2. i modem firmware 05.11.07 (čini mi se) uglavnom kad ga jailbreakam sve ok, međutim nakon restarta, gašenja i sl. traži ponovno da se napravi restore. Jel to znači da se još uvijek čeka potpuni jailbreak ili što? Možda glupo pitanje, novi sam korisnik pa nije mi još sve sjelo , hvala na odgovoru.
rocky6 je offline   Reply With Quote
Staro 16.12.2009., 00:16   #498
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
đuro - najbolje da nabaviš neku simpa/098 karticu, to je najkvalitetniji naćin aktivacije moba, nakon toga ideš na JB, pa unlock.. to moraš sa blackra!n-om napravit, nema drugog načina
Staro 16.12.2009., 00:28   #499
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Ma evo jesam radi, mob, sa blackrainom sam usao u njega samo nema mreze, kako dalje
Do sad mi je samo stajao za onaj emergency call, sad nakon black raina sam usao bas u mob...
Stavio sam i cydiu..
Staro 16.12.2009., 00:30   #500
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor rocky6 Pregled postova
A hebote led, ajd da se o tome prićalo u sredini teme pa nemreš nać, al da si samo pročital par postova iznad našel bi odg....znači gledaj par postova iznad kaj je kolega flajpan napisal,
Staro 16.12.2009., 00:58   #501
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
LoL mora da me ova vecera usporila malo, sam u blackrainu skinem i instaliram blacksn0w i to je to, radi...
Boze sacuvaj sve sam mogao napraviti u 2min
Staro 16.12.2009., 12:42   #502
rocky6
Adriaaaaaan....
rocky6's Avatar
Postovi: 278
Autor danc00 Pregled postova
Ma novi sam u svemu tome pa još nisam baš sve pojmove pohvatao, uglavnom vjerovatno će izaći nekakav jailbreak gdje se neće pojavljivati taj problem nakon restarta, jel?
Staro 16.12.2009., 13:07   #503
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Kak meni sve radi netrazi me nikakav restore, a gasio sam ga par puta?
Cak nitit ovaj wifi problem nemam, zapravo cak i bolje hvata, evo na poslu imam jedan hotspot koji sam jedva hvatao sa ostalim mobovima, sa iphoneom je pun signal
Zadnje izmijenjeno od: Gjurovski. 16.12.2009. u 13:18.
Staro 16.12.2009., 13:55   #504
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor Gjurovski Pregled postova
Pa kad imaš stari bootROM, pa piše ti par postova iznad...
Pa imaš 3GS ili koji, kad si ga unlockal prek blackra1n wifi ti radi??
Staro 16.12.2009., 14:06   #505
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Iphone 3g 8gb, napravio sam prvo restore i update, ova verzija firmware mi je:3.1.2 sa ovim modem firmwareom: 05.11.07
Radi wifi normalno, igre jos nisam ubacivao\appove nisam stigao moram se regat prvo na itunesu...
Staro 16.12.2009., 15:45   #506
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 457
to je problem samo sa 3gs da se nakon restarta mora ponovitia jaillbrake , 3g radi bez greške!
dart_tom je offline   Reply With Quote
Staro 16.12.2009., 15:59   #507
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Neznam nisam upucen, jucer sam ga dobio i poceo prckati po njemu a informacija previse, na svakom forumu po 10 tema...
Tko bu to sve isao listat sad
Staro 18.12.2009., 14:19   #508
Optik
________
Lokacija: .
Postovi: 774
Koliko god pojacam vanjski zvucnik on je i dalje tih !? Koje je rjesenje?
Koliko god da ga pojacate uvijek je on poprilicno tih. Problem toga je platnena membrana koja se nalazi na rupicama za zvucnik koja bi trebala sprijeciti ulazak prasine. Da nebi bilo zabune, to se NE radi o membrani zvucnika. Postoje 2 rjesenja za ovaj problem.
  • Prvo rjesenje ovog problema je da sa iglicom ili iglicastim predmetom probusite tu membranu na 2-3 mjesta i razlika u zvuku je ogromna. Pazite gdje busite, da nebi probusili mikrofon (on takodjer ima membranu na plastici).
  • Drugi nacin je rastavljanje svoga ljubimca na proste faktore i uklanjanje te iste membrane.
Razlika je ogromna, sada ga ne smijem pojacavati do kraja jer se prepadnem
Osobno sam napravio prvo sa iglicama pa sam ga rastavio, razlike u jacini zvuka nema. Vama na volju, ovisno o tome koliko ste vjesti i koliko se zelite zafrkavati.
Tutorial za rastavljanje iPhone 2G : http://www.ifixit.com/Guide/Repair/I...na-Cover/441/1
Na istom linku, na home pageu mozete pronaci tutorial i za 3G kao i za 3GS.
Nadam se da ce nekome koristiti
Staro 18.12.2009., 23:29   #509
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Ja svojeg ne bušim za niš
Staro 18.12.2009., 23:46   #510
tech
Postovi: 1,687
Ja ni ne vidim potrebu za glasnijim zvučnikom, kad zvoni čujem ga sasvim dobro.A potrebu za, stavljanjem cajki i puštanjem istih u tramvaju da ceo narod čuje, nemam.
Nego, ima koja pametna igrica za uzeti na app storu, svega sam se naigral već, sada opet rasturam po Gears-ima
