		#961 |
				Lokacija: Sveta Nedelja
					Postovi: 24
		 Isusti... Moram priznat da je kul kad naraste, al kaj je fakat tolko otrovna? Jel to onaj jako brzi mali gad? Nešto si mi jednom davno spominjao o njima...
	“I think we can put our differences behind us. For science. You monster.”  |
		#962 | |
			Datum registracije: Apr 2003
				Lokacija: RI
					Postovi: 4,918
   ova ima najgoru kombinaciju,jedna od najbržih i najotrovnijih...u biti,bez dvojbe,vjerujem da je oboje.radije bi da me ubije nego da proživljavam posljedice ugriza ![]() ima ekipa na stranim forumima...pa imaš bites report,par njih se javilo...da ih ej ugrizla,strašni bolovi...teško se riješiš toga zauvijek,godinama te zna "presječ" kao da ti netko nož zabije u ledja,jetra i bubrezi pate,srce takodjer...nije smrtonosna,ali za dijete ili starca ne garantiram... ali nema pravila,ovisi dal ti uopce ubrizga otrov...i u kojoj količini.
		#965 |
			 Xulos :)
					Postovi: 7,570
		 Mislim da poecilotherie imaju gadniji ugriz : http://www.bighairyspiders.com/poec.html "My jaw muscles clenched shut and I couldn't open my mouth for about 10 minutes. Around 11am the next morning I was paralyzed for about 2+ hours. Any time I would move any part of my body it would immediately cramp up. Once the cramps stopped I could hardly move because my muscles were so sore and if I moved my arms, legs, feet... in certain directions they would cramp so I had to move carefully. By that night I was still getting cramps but they weren't as painful or frequent. For the next two weeks I was still getting cramps in my legs and pain in my hands and joints. I also noticed that I lost some muscle mass in my chest. Then I woke up and my left shoulder joint was in intense pain. After two weeks of still having symptoms from the bite and the feeling that I was melting away and now with this pain in my shoulder I decided to go to the doctor. I happen to know a Doctor from India (where the Mysore Ornamental is from) who worked in India and treated many tarantula and snake bites. He put me on steroids and pain killers and ran a bunch of blood tests. happened in the beginning August and now I am fine but occasionally get cramps in my legs and hands." Poecilotheria regalis : http://www.mtsociety.com/imagesOL/pic_regalis.jpg Znak da nediras   : http://www.minizoo.donetsk.ua/P.regalisF4.jpg
	The Rich pays to win. The Poor spends to lose.  |
		#966 | |
				Lokacija: RI
					Postovi: 4,918
   Samo Stromatopelma ima gadniji...najgadniji od svih...Poechiloterie nemaju tako gadan ugriz (ali isto vrlo otrovne!)...imam regalisa...a prema iskustvima ljudi,nije tako strašno.Čak je dosta čest i "dry bite",dakle suhi ugriz,bez otrova   Ali Poechiloterie i Pterinochilusi nemaju tako aktivan otrov...Heteroscodra i Stromatopelma su straight from hell ![]()
		#967 |
			 Xulos :)
					Postovi: 7,570
		 Pa hebemu eto ti gore link i najvazniji citat.    Mislim da poecilotherija ima jaci otrov od maculate. Fino je lik objasnio sta mu je bilo.Iako kak si rekao na teraristici , stromatopelma je kraljica ![]()
			The Rich pays to win. The Poor spends to lose. Zadnje izmijenjeno od: JuiceBox. 28.11.2009. u 02:57.  |
		#968 | |
				Lokacija: RI
					Postovi: 4,918
   ništa ti to ne znači,nekoga udari jače nekoga slabije...činjenica je da maculata svih udara i to žešće...u prosjeku,svaki treći ugriz poec. stvori ajmo se blago izrazit problem...pogledaj bites report na arachnoboards.com i na reptile.uk ![]() prema tome,uvjeren sam da maculata ima dosta jači otrov...čitaj,vidjet ćeš ![]()
			Zadnje izmijenjeno od: Thoroughbred B. 28.11.2009. u 03:15.  |
		#969 |
					Postovi: 24
		 Samo nemojte tu stavljat opet linkove sa slikama ugriza bilo zmija, bilo pauka, jer ih uvijek moram pogledat i uvijek mi se život nanovo zgadi.  ![]()
		#971 |
				Lokacija: RI
					Postovi: 4,918
		#972 |
			 fanATIčni AMDovac
				Lokacija: KC-ZG
					Postovi: 1,312
		 Malo setanja po sumi  ![]() http://www.imagesforme.com/show.php/...1120091675.jpg http://www.imagesforme.com/show.php/...1120091666.jpg I nocno cudoviste sa zutim laserima ![]() http://www.imagesforme.com/show.php/...1120091612.jpg
			Zadnje izmijenjeno od: micek_kc. 29.11.2009. u 21:47.  |
		#975 |
					Postovi: 7,326
		 Moja mrcina se jučer malo izležavala  ![]() http://www.imagesforme.com/show.php/...9112009886.jpg http://www.imagesforme.com/show.php/...9112009887.jpg  |
		#977 |
			 RAKIJA
			Datum registracije: Aug 2008
				Lokacija: Orahovica
					Postovi: 76
		 Vrste tarantula o kojima se govori da je otrov jak govori se s razlogom jer su baš u top mjestima po jačini tog otrova. Ljudi znaju povračat, grčevi, bolovi jako oko ugriza, nesvjestica i slične grozote koje mogu trajatz danima. Da to ne bude najgore, mislim da se pauk zove "smeđi australski pauk" koji kada ugrize uzrokuje raspadanje tkiva na velikom radiusu oko ugriza. Ljeka nema. Jedini ljek su elektrošokovi koji na tom mjesti privremeno neutraliziraju otrov, ali več nakon par minuta otrov počinje djelovat iznova. Njagore je što se ugrižene osobe se same moraju pucat strujom i to više puta dnevno. U australiji je raširen i pauk je veličine kovanice od 50 lipa cca. TB ako znaš o čeme pričam ispravi me jel nisam previše informiran osim od onog šta sam gledo na diskoveriju...  |
		#978 | |
				Lokacija: RI
					Postovi: 4,918
 crna udovica je za njih beba ![]() što se tarantula tiče,dobro si rekao ali bude to i puno gore...bolovi su po cijelom tijelu i svi koji su ih proživjeli su rekli da nikad jače bolove nisu osjetili...otrov pojedinih uzrokuje višegodišnje iznenadne bolove koje opisuju i uspoređuju s probadanjem noža u tijelo takodjer,otrov stromatopelme može biti i s smrtnim posljedicama ukoliko ubod bude blizu prsa i prsnog koša jer vrlo vjerovatno u tom slučaju paralizira i srce
		#979 | |
					Postovi: 8,219
 ![]() Da drugi nemoraju tražit, 3 dan nakon ugriza: http://www.imagesforme.com/show.php/...erbiteDay3.jpg 9 dan nakon ugriza: http://www.imagesforme.com/show.php/...erbiteDay9.jpg EDIT: eo sad na hostingu slike, sada moraju radit iako meni i tamo rade
			Sent from AS/400. Zadnje izmijenjeno od: Pupo. 08.12.2009. u 21:03.  |
		#980 | |
			 Pijem samo KAJ
				Lokacija: Vž
					Postovi: 2,691
		#982 |
			 Beskorisna bitanga...
				Lokacija: Sesvete (Zg)
					Postovi: 6,956
		 Očito injicira neki litički enzim koji počinje probavu žrtve odma kad ugrize ili kontaminacija nekim mikrobom jer ovo ziher nije samo paralitički otrov napravio, vjeroajtno bi se moglo napraviti antiserum koji bi samnjio oštećenja...
	-- Have a nice day...  |
		#984 | |
				Lokacija: RI
					Postovi: 4,918
 ali uzrok takvog djelovanja odnosno raspadanje tkiva je u "Sphingomyelinase D" bakterijskom proteinu...
		#985 |
			 sto da napisem ?!
					Postovi: 880
		 POZOR ! gadljivost kod nekih !!! Zadnje izmijenjeno od: Jelc. 08.12.2009. u 22:04. Razlog: mda....  |
		#986 |
			 Super Moderators
			Datum registracije: May 2002
					Postovi: 17,485
		 Dečki-suzdržite se ubuduće od ovakvih stvari i nemojte monopolizirati temu. Ovo je opća tema o kućnim ljubimcima a ne news-grupa o paucima ![]()
		#987 |
			 RAKIJA
				Lokacija: Orahovica
					Postovi: 76
		 Upravo te slike su ugriz tog pauka. Jer mislim da kada sam čito o tome otrovu da su te slike bile pribodene na toj stranici Što se tiče otrova paukova koje spadaju u porodicu tarantula. Čito sam da njihov, kao što mi kažemo otrov, svrstavaju baš u vrstu probavnog enzime. Kada tarantula ubrizga iz svojih otrova taj "otrov" on razgrađuje žrtvu u kašu tipa tjesto i onda to posisaju. I da kažem ako se itko odluči imat tarantulu da kao podlogu ne stavlja pjesak ili nešta kao pjesak. Tarantule srču pljen iliti usisavaju u sebe tu kašu. Ako pjesak koji je zaljepit na to dospije u nju može vrlo lagano uginuti.  |
		#988 | |
			 8-bit Gen.
				Lokacija: Giethoorn - ZG
					Postovi: 3,159
 cekajte ljudi, kakva je ovo SF slika? U procesu obnavljanja, ljudsko tkivo dobiva strukturu paukove fizonomije dijelova tjela? ![]() ![]() I to ovako "skladno" mu se uklopljava kao nadomjesni dio    Pa ovo ce pomaknuti granice u protetskoj industriji pomagala... crni humor, ali stvarno mi je blesava ta slika. |
		#989 |
			 RAKIJA
				Lokacija: Orahovica
					Postovi: 76
		 Pa evo ti i OT odgovor. Kao prvo ovdje nikako tkivo ne poprima paukovi fizionomiju več se ovdje ljepo vidi kako se tkivo raspada, trune i gubi črvstoću. Ukratko ono što smo rekli da se tkivo razgrađuje i kašu... Ovo što vidiš je trulo i zagnojeno tkivo koje je zašiveno da ostane na mjestu. Ili barem se nadaju da će ostat u komadu =\  |
		#990 | |
			 8-bit Gen.
					Postovi: 3,159
				OT II - Peter Parker bez mirovinskog staža
   Pregledao sam ostale slike i mada im izvori i nisu bas nesto kredibilni, presao i nastavak ove slike. Ali i dalje mi "razdvojeno tkivo" previse izgleda kao muskulatura tarantulinih nogu i ponesto bolje elaboriran, ali ne potpuni tip predocavanja mita koji je autor zamislio. Znaci ne dovodim u pitanje dokle moze dovesti stanje nakon ugriza. Cak i od jos manjih stvorenja od pauka. Samo mi ove slike nisu legle kao nesto sto bih uzeo sa sigurnoscu. Nema potrebe da idem vaditi sliku pa crtati sto vidim na toj slici. Ionako je debeli OT u ovoj ipak sasvim ugodno benignoj temi kucnih ljubimaca i "daleko od "otrovnije" tematike. Eventualno da Jelc izreze ovaj dio i baci u zasebnu temu. No imamo vjerovatno ugodnijih tema ![]()  |
