Staro 24.11.2009., 15:00   #241
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,349
CENZURAAAAAA .
BTW jel ima sanse da se na to cudo spoji nekako USB keyboard pa da sluzi i za surfanje ? To bi bio poso za B-rada pretpostavljam .
Staro 24.11.2009., 15:00   #242
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,295
a jesi zajeban
btw, ovo slobodno obrisi
EDIT: @lewis - i meni je to palo na pamet, samo nikako da covjeku javim da to proba slozit. meni je pala na pamet neka bezicna tipkovnica, sto bi bilo jos bolje
Staro 24.11.2009., 15:03   #243
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,349
Autor Čuks Pregled postova
a jesi zajeban
Zicna/bezicna svejedno samo da je USB i moralo bi sljakat cool. Tada bi to bio full multimedia uredjaj jer bi lako mogo vrtit online video i sve pa cak i forume .
Staro 24.11.2009., 15:05   #244
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor tor Pregled postova
Evo, da ne bude zabune, da ja sam ne poštujem pravila. Ovak ok?
Savršeno
Nadam se da se ne ljutis to je bilo samo u sali
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 24.11.2009., 15:06   #245
leteci
leteci's Avatar
Postovi: 89
A to mu je 100% palo na pamet, ako je ikad upisivao išta sa malo više znakova preko onog daljinskog
leteci je offline   Reply With Quote
Staro 24.11.2009., 17:22   #246
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Sram te bilo!
Nego, ja radije ostavim crno nego da mi pojede sliku sa strane, tako da radim najčešće zoom 1.1 i to je to. Tu i tamo 1.2.
Poveća mi telka pa vidim iovak i onak
MC
Staro 24.11.2009., 21:15   #247
chvarko
Beaker
chvarko's Avatar
Lokacija: 45°29`N 16°47`E
Postovi: 87
Zašto kad reproduciram DVD materijal (.vob), na kojem postoje chapteri, ne mogu preskakati chaptere.
Koju god datoteku .vob otvorim materijal kreće od "prve sekunde" i onda ostaje samo premotavanje (max. 16x)
Postoji li bar mogućnost (za bilo koji video) "Go to", kako bi odmah skočio na npr. pola filma?
chvarko je offline   Reply With Quote
Staro 24.11.2009., 21:26   #248
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Nema toga
Ja motam 16x začas dođe do pol filma
Bed je jedino ako film je u banani pa ne radi seeking...
Gledao sam baš American Virgin, puko film na pola, i nema seeking, pa sam dobio mali popizditis, i pusti dalje s kompa
MC
Staro 24.11.2009., 21:42   #249
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,228
Da li je moguće titlove pomicati po vertikali? Nekako su mi titlovi previše "podignuti".
Kruno M je online   Reply With Quote
Staro 24.11.2009., 22:19   #250
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Ja još nisam skužio kako, ako netko skuži, neg javi
MC
Staro 24.11.2009., 22:24   #251
mahoona
mahoona's Avatar
Postovi: 284
Totalan debakl, dođem doma, hoću pustiti film, ne vidi đubre ni jedan jedini kompjuter u mreži, ne pomažu restarti, odštekavanja. Youtube radi uredno...prebrzo sam se poveselio da me novi firmware spasio. Ovo mi je sad još gora situacija, kaj da mu radim?
Jel mu mogu vratiti tvornički firmware, pa opet ovaj novi staviti? Mislim da ide sutra na reklamaciju.
mahoona je offline   Reply With Quote
Staro 24.11.2009., 22:28   #252
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,778
vjerojatno ce te lagano odjebati i reci da ti doma nes ne stima s postavkama mreze
Staro 24.11.2009., 22:33   #253
mahoona
mahoona's Avatar
Postovi: 284
Autor rendula Pregled postova
Mogu me znaš već kaj. Jučer navečer sam uredno pogledao film, ugasio uređaj i danas hoću pogledati film, upalim ga i nema teorije da otvori ili napiše ikakvu poruku kad stisnem Network shares! Ako kod njih bude htio browsati mrežu, vrlo rado ću ispasti kreten
Edit: odoh pronaći račun i pripremiti mrtvaca
Staro 24.11.2009., 22:50   #254
mis
Postovi: 60
ima fora za brzo premotavanje .
Prvo se stisne premotavanje (rev ili ff) i zatim gumb za chaptere (prev ili next), onda preskace film po 10 minuta
mis je offline   Reply With Quote
Staro 24.11.2009., 22:59   #255
tech
Postovi: 1,687
@mahoona voljan sam ga udomiti na cca tjedan dana, čisto da se uvjeriš da nije kod tebe problem
Staro 24.11.2009., 23:07   #256
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Ja ga udomim na 2-3 dana, pa ga cijelog raskopam
MC
Staro 24.11.2009., 23:24   #257
mahoona
mahoona's Avatar
Postovi: 284
Brzo bi mi ga vratili kad bi vidjeli kakve sve feature ima
Staro 24.11.2009., 23:29   #258
tech
Postovi: 1,687
Ne, al ozbiljno jesi probao kod nekog drugog?Vidio sam ga u akciji par puta i sve je radilo kak spada.
Staro 24.11.2009., 23:46   #259
mahoona
mahoona's Avatar
Postovi: 284
I meni je nakon upgradea firmwarea proradio odlično! Dotad nije htio uvijek vidjeti sve shareove na računalima. Ali danas uopće ne želi vidjeti nijedan komp pod Network shares, a uredno mu mreža prema netu radi i streama sa youtubea bez problema. I mogu ga pingati sa kompa. Samo kad na njemu odem na Network shares, ništa, niti error niti onaj kružić da nešto radi, kao da nisam stisnuo gumb.
Staro 24.11.2009., 23:55   #260
tech
Postovi: 1,687
Cudno...Si probao b-rad firmware?
Staro 24.11.2009., 23:57   #261
mahoona
mahoona's Avatar
Postovi: 284
Upravo ga pripremam i čekam da žena ode spavat, onda ja nastupam sa usb stickom
Edit: Ni ovaj zadnji b-radov firmware ne pomaže, ništa se ne događa kad odem na network shares, ili file management, crko je mali sam od sebe...šmrc
Zadnje izmijenjeno od: mahoona. 25.11.2009. u 00:38. Razlog: probao
Staro 25.11.2009., 10:46   #262
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Sad sam se pogubio, ti si na XP?
MC
Staro 25.11.2009., 11:41   #263
mahoona
mahoona's Avatar
Postovi: 284
Ne vjerujem kaj ja sve prolazim sa ovim uređajem, ajde savjet kaj da radim.
Kako sam napisao u gornjim postovima, jučer navečer dođem doma i hoću pogledati film. Upalim WD-a, pustim ga par minuta, i hoću odabrati film. No međutim, kad sam stisnuo Network share opciju ne dogodi se baš ništa! Niti grešku ne baci, niti onaj kružić da nekaj radi, ništa! Odem na postavke mreže, mreža je ok, probam youtube - radi, probam Pandoru - radi. Odem opet na Network share, ništa. Ne radi ni File management. Ugasim uređaj, odspojim mrežu, struju....pustim ga par minuta, upalim nazad, spojim na mrežu, pustim par minuta, pokušam na Network share - ništa. Kao da prokletu tipku OK nisam ni stisnuo.
Youtube radi, pingam Wd sa kompa, ali neće mrcina na lokalnu mrežu. Lokalna mreža uredno radi, 7 računala na mreži 4 sedmice (jedan je moj komp, ostalo susjedi), 3 xp-a, međusobni shareovi rade ko sat.
Skinem onaj originalni firmware 1.01.00 i nakrcam ga na wd, odradi svoje, reboota, uredno se podigne sustav, vidim da je stari firmware (ima onu Wireless opciju), probam iste stvari kao i prije, opet ništa! Ugasim, upalim, mijenjam portove na switchu, resetiram router, budem prost, žena me gleda u čudu, ružno. Skinem onda B-radov 0.2.1 firmware, nakrcam njega, reboot, sve ok, digne se, sve radi osim Network share. Koma. Mislim, crko je skroz, pronalazim račun i ambalažu, vratim 1.0.11 firmware da me ne bi na servisu zezali. Probam još jednom sa tim firmwareom, opet ništa. Ugasim uređaj iz struje, pripremim ga za današnje odnošenje na servis.
Ujutro mi ne da vrag mira i prije nego sam ga stavio u kutiju mislim si idem ga još jednom probati, čisto da ne ispadnem kreten na servisu. Spojim ga na struju, upalim, odem na Network share i znate kaj je bilo!?
Staro 25.11.2009., 12:36   #264
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,228
Stvarno si baksuz (bez uvrede). Meni se slična stvar desila. Upalim WD odem na network share i ništa, odem do stroja da provjerim da li je upaljen, naravno je. Opet do WD-a i neradi. Hm, odem do kompa i probam pristupiti disku koji je spojen na WD i to potraje par sekundi (prvo nije bilo WD-a na network listi, al se pojavio). Opet odem do WD-a, networka share i proradilo. Sada evo već par dana "surfam" po WD-u gledam čaćkam i sve radi bez problema...
Staro 25.11.2009., 12:37   #265
hrki
Lokacija: ZG - VŽ - KR
Postovi: 279
proradio?
hrki je offline   Reply With Quote
Staro 25.11.2009., 12:57   #266
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,295
@mahuna - jeis probao mijenjat ethernet kabel? mozda to pomogne
Staro 25.11.2009., 13:30   #267
mahoona
mahoona's Avatar
Postovi: 284
Je proradilo. Sad me živo zanima kad dođem doma kako će biti. Nisam probao mijenjati kabel, kabel sam sam pred dva mjeseca provukao po kanalici, testirao sam ga, radi bez greške. Ne znam više kaj da sumnjam. Mislim, da je do kabela ne bi Internet radio na WD-u. Da uspijem otvoriti Network share i da mi javi neki error, rekao bi ok, nije sve posloženo kako spada, ali jednostavno njemu su jučer jednostavno umrli Network share servisi i ni makac. I nikakve preinake nisam radio na mreži, samo sam WD-a držao ugašenog iz struje cijelu noć. I kak da ja sad objasnim nekome u servisu da imam poluispravni uređaj, kad sad sve radi?
Staro 25.11.2009., 15:34   #268
chvarko
Beaker
chvarko's Avatar
Postovi: 87
Autor mahoona Pregled postova
Je proradilo... I nikakve preinake nisam radio na mreži, samo sam WD-a držao ugašenog iz struje cijelu noć.
Bilo je dovoljno i 10-ak sekundi bez napona.
Vidjet ćeš jel će se ponavljati.
Staro 25.11.2009., 18:27   #269
fango
Postovi: 22
.. uzeo sam s popisa Linksys WUSB100 (No Revision) usb wireless, medjutim nisam uspio dobiti nikakav signal u postavkama uredjaja, prateci upute pdf niti ne vidim opciju "please specify network type" vec samo "automatic" gdje ne nadje nista i "manual" gdje trazi ip address .. hm, bas citam da taj stick uopce nece raditi na wd-u, ne znam zasto ga drze na popisu bez obzira na reviziju .. molim preporuku za neki drugi koji koristite, a da radi .. ili ce ovaj eventualno raditi nakon nadogradnje wd-a?
unaprijed zahvalan!
fango je offline   Reply With Quote
Staro 26.11.2009., 10:43   #270
mahoona
mahoona's Avatar
Postovi: 284
Samo da javim da je uređaj jučer normalno radio, pogledao sam film, sve prošlo bez problema, uredno browsa po mreži. Jedino sam primjetio da je malčice sporiji prilikom browsanja po folderima nego dosad. Baksuz veliš? Jesam
