1
Postovi: 3,609
Hdd Led zafrkava
Imam ploču asus p4p800-e deluxe kućište je coolermaster centurion 590,kada spojim žicu na ploču od ledice stalno svijetli probao sam je okrenut onda uopće ne svijetli hard je SATA,dali netko zna možda u čemu je problem,hvala. P.S flešo sam ploču na zadnji firmware,ali nije ni to pomoglo. |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
a da ne spajaš žicu od power led... odnosno na konektor.. ? |
1
Postovi: 3,609
ne spajam. |
1
Postovi: 3,609
šta nitko nebi znao u čemu je problem ? |
#5 | |
Datum registracije: Apr 2008
Postovi: 1,517
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Malo sam bacio oko po Asusovim sajtovima i cini se da je problem u slijedecem: "Just an FYI... historically, the LED has been driven in PATA with a signal known as /DASP, this is an active-low signal called "Drive Active / Slave Present" and a PATA drive asserts this signal when processing a command. If I understand it right, in SATA, instead of a wire-based protocol, we have a serialized packet-based protocol, so there was no driving of an LED in the initial specification. Revisions to the specification have since commandeered one of the pins on the power connector for use as a /DASP signal to drive an LED. However, to do that you obviously can't be using a MOLEX->SATA power adapter, you need a motherboard that natively supports SATA. The 3112 you mention attempts to be a native SATA solution, it doesn't act merely as a PATA->SATA converter. Therefore, they may not have done the DASP- signal internally. Another option would be one of the new 4+ port SATA RAID adapters that has LEDs on the adapter board itself." ... "If your SATA's are connected to the VIA VT8237 (SouthBridge) the hard drive activity light is unsupported and 99% of the time the "lights" will not work. However, if you have SATA's connected to the Promise-378 Controller than the hard drive activity lights will work. " Dakle, ukratko taj tip kontrolera nema podrsku za SATA HDD LED signalizaciju. Zadnje izmijenjeno od: dh41400. 26.11.2009. u 15:38. Razlog: Asus nadopuna |
