Staro 06.10.2009., 01:45   #1
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
Preslabo napajanje ili ipak ne?
ovak napajanje CHIEFTEC gps 550W
konfa core i5.....gigabyte p55-ud3....ram 4 gb corsair 1600MHZ....i sad 2 puta 4850 i jedan hard od 250 gb......el ce napajanje izdrzati to nekih par meseci dok ne skupim za jace ?
hobitxxx je offline   Reply With Quote
Staro 06.10.2009., 01:54   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,573
Hoce.
Staro 06.10.2009., 02:00   #3
hobitxxx
hobitxxx's Avatar
Postovi: 412
SIGURNO htio sam racunati sa onim wat calculatorom ali nema tak novih komponenti.....znaci mou biti miran i uzeti grafu jos jednu?jer sam vec pital prije jer sam htel staviti vec jos jednu na ovu konfu bila je druga ploca gore pa su mi pricali da nece biti dosta.....
Staro 06.10.2009., 05:39   #4
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor hobitxxx Pregled postova
Neznam bas nebi se kladio da ce izdrazati.Ja bi se prije brinuo o zagrijavanju grafa zato sto i jedna takva sa stock coolerom se jako grije a kamoli dvije takve na tako malom razmaku
Autor xulos Pregled postova
Hoce.
Na temelju cega tvrdis da 100% hoce?
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 06.10.2009., 06:55   #5
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Oni ionako izbacuju nebuloze od vrijednosti ...
Da, slobodno ju uzmi. Radit ce normalno 100%, a jedino ces trebat dodatni 6-pin PCI-e adapter.
... jer sam vec pital prije jer sam htel staviti vec jos jednu na ovu konfu bila je druga ploca gore pa su mi pricali da nece biti dosta.....
Pitao si na krivom mjestu ...
Ako ti nasa rijec nije dosta, onda bi ovi rezultati s 410W Cuftecom trebali biti ...
The Secret ...
Staro 06.10.2009., 19:44   #6
hobitxxx
hobitxxx's Avatar
Postovi: 412
e hvala ma ne brine mene zagrijavanje vec drugi accelero ceka u ormaru.....samo mi je napajanje malo na knap pa me zanimalo.....znaci radit ce ok fala decki....
