Terminirani determinator
Lokacija: Kamanje
Postovi: 298
Outlook Express nakon nekog vremena prestane raditi
Imam problem sa Outlook Expressom verzija je 6. Nakon nekog vremena kad racunalo radi nemogu vise slati mailove,znaci prvih 15-20min sve radi normalno i mogu slati ali kasnije izbacuje grešku "0x800ccc0f". Probao sam instalirat Thuderbird,ali se javljala ta greska i ondje. Imam na racunalu NOD 32 i Spybot S&D ali i kad njih iskljucim ,i dalje ne radi. Pomagajte jer mi je mail jako bitan,i nemogu svako malo resetirat racunalo. |
Postovi: 12,613
Hmm, ja ubacim error u gugl i vidi http://www.google.hr/#hl=hr&source=h...30a96a47a6f331 Opsirno = http://support.microsoft.com/kb/813514 Navodno ti pop serveri nisu ok? Ciji mail imas i preko kojeg providera si spojen? Code:
Error 0x800ccc0f OL2002: "Error 0x800ccc0f: Connection to the Server Was Interrupted" Error Message When You Try to Send or Receive an E-Mail Message Source: Microsoft Knowledge Base Article - 329916 SYMPTOMS When you try to send or receive an e-mail message in Outlook 2002, you may receive an error message similar to the following: Error 0x800ccc0f: Connection to the server was interrupted. CAUSE This problem may occur if you have an antivirus e-mail protection utility enabled, which checks the mail as it comes in from your Post Office Protocol (POP) server. RESOLUTION To resolve this problem, disable the antivirus e-mail protection utility, and then manually add the POP server name in the E-mail Accounts dialog box in Outlook. To manually add the POP server setting, follow these steps: 1. Start Outlook. 2. On the Tools menu, click E-mail Accounts. 3. Click View or change existing e-mail accounts, and then click Next. 4. In the E-mail Accounts dialog box, click Add. 5. Click POP3, and then click Next. 6. Type the correct information for your POP3 mail server, and then click Next. 7. Click Finish.
Datum registracije: Jul 2009
Lokacija: croatia - zg
Postovi: 30
![]() http://www.tiscali.co.uk/help/email/...x800ccc0f.html ili http://support.microsoft.com/kb/813514 --> 3. i 4. točka . .sorry nino, nisam vidla da si u medjuvremenu napisao post prije mene.. ![]() |
Lokacija: Kamanje
Postovi: 298
Mail je od T-coma znaci, i njihov sam korisnik. Guglao sam ja i isprobao dosta toga ,ali nista nije palilo. Postavke za mail i pop server su dobre sigurno,a probao sam ih i ponovo upisivat. |
It's all a joke
Lokacija: unknown
Postovi: 445
da li si probao sa nekim registy repair toolom mal skenirat i sredit ak ima nekih problema
Once you realize what a joke everything is, being the Comedian is the only thing that makes sense. |
Postovi: 270
Reci mi NOD je na HR jeziku ili eng? HR verzija je imala problema s mailovima i sa outlookom. |
Lokacija: osijek
Postovi: 16
ta greška ti znači da nisi spojen na net, (provjeri ping), ili da nešto softwareski to blokira poput FW, virusa, antivirusni program itd. |
Lokacija: Kamanje
Postovi: 298
Probao sam ocisti registar sa nekim registry cleanerom ,i nije pomoglo. Na internet sam spojen sigurno,a problem se javlja i kad iskljucim FW,NOD i Spybot. Jel moguce da NOD radio u pozadini,iako ga se iskljuci? Na hrvatskom jeziku je NOD,znaci mogla bi u tome bit greska. |
Postovi: 12,613
Lokacija: Kamanje
Postovi: 298
