Postovi: 18,905
ITG xpPhone runs Windows XP
Granted, the xpPhone look more like a tablet than a mobile phone, but the cellular call feature is all there and that makes it a phone all right. Huge 4.8 touchscreen, QWERTY keyboard, AMD processor, 512MB or 1GB RAM and both SSD and HDD storage are the best bits of its hardware. Investment Technology Group or ITG is the China-based manufacturer that stands behind the xpPhone. Well, it may sound like another iPhone wannabe, but it is definitely not. The xpPhone is way more powerful than a smartphone. It's more like a netbook with phone capabilities. As a beginning let's see what's inside this gadget - AMD Super Mobile processor, 512MB or 1GB RAM, from 8 to 64GB SSD plus from 30 to 120GB HDD (yes both included), 1.3 megapixel camera and various ports - VGA, USB, earphone, microphone, dock connector and SIM slot. ![]() ![]() Controlling the xpPhone will be more than easy thanks to the 4.8-inch WVGA TFT touchscreen and the sliding-out QWERTY keyboard, accompanied with D-pad on the left and numpad on the right side. Right in between there is also a small touchpad, while the two mouse buttons are right next to the D-pad. ![]() Full pack connectivity is also onboard - Wi-Fi, quad-band GSM or CDMA, HSDPA/HSUPA thanks to the built-in 3G modem, Bluetooth, GPS and optional WiMax. The bands and frequencies will vary for the different countries and carriers (currently listed for AT&T, Vodafone and Orange). Considering the fact this fellow runs Windows XP (we think it might be good idea to test it with the new Windows 7 too), the battery life seems strong enough - 5 hours talk time or 5 days of standby, while using it as a regular netbook gives you 7 to 12 hours of power autonomy. Update: ITG didn't publish the physical dimensions of the device so we used the official photos to calculate them, based on the screen size. It turns out that the xpPhone will measure about 158 x 75 x 16 mm. Added to the weight of 400 grams it's certainly one of the largest phones we have ever seen. The ITG xpPhone will be available in white, red and black colors, but the price and release date remain unknown. You can pre-order it right now, directly from the company official web site. No payment is required at this stage, just filling a form. Source
Postovi: 4,204
4,8 inch pocket book ![]()
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Slin slin, mama i ja bih to :P Preemocna stvarcica, jest da je velik, ali mislim da bi svejedno nasao mjesta u dzepu za njega, kad bih imao love naravno. Ovako mogu samo nastavit slinjenje ![]() |
Postovi: 18,905
Imaš mini touchpad, malo veći nego onaj na Samsung Omniji... ![]() Taj džep bi onda morao biti malo bolje sašiven jer stvarčica nije nimalo lagana, 400 g, brate mili...
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ajde ajde nije 400g 2kile sta je to za pravog muza ![]()
#9 | |
Hejter
Postovi: 6,521
Na webu doduse nude pre - order ... Nije 400g previse , ja bi drage volje nosio ovakvih 400g , odnosno 400g kaj moze sve kaj moze ovaj geđet ![]() |
Rambus 3xtr1m
Postovi: 2,694
Da li je netko saznao cijenu ovoga? Meni je ovo genijalna stvar! Ali kako se telefonira? Šta ima program u xp "telefoniranje" |
#11 | |
P.E.B.K.A.C.
Postovi: 2,304
xpphone
Ok ovaj dan sam cekao ujedno i razlog zasto sam odustao od Netbook-ova, iako je ovo tek probijanje leda isto kako je napravio Asus sa EEEpc-em usudio bi se reci da je ovo jednake tezine, iako su jos dosta skrti sa infom kakav se CPU nalazi nutra:http://www.xpphone.com/en/product/specification.html ![]() ![]() Citiraj:
Malo je velik ![]() ">
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Zadnje izmijenjeno od: Gjurovski. 21.01.2010. u 23:06. |
P.E.B.K.A.C.
Postovi: 2,304
EEEpc ti stane recimo?
Nervozni poštar
Datum registracije: Mar 2008
Postovi: 258
koji smisao ovog proizvoda? radje uzeti asus ee
nVIDIA+INTEL=klasika This message is hidden because Crash009 is on your ignore list. |
Postovi: 4,707
