Staro 18.09.2009., 18:02   #1
domy_os
domy_os's Avatar
Postovi: 18,960
ITG xpPhone runs Windows XP
Granted, the xpPhone look more like a tablet than a mobile phone, but the cellular call feature is all there and that makes it a phone all right. Huge 4.8 touchscreen, QWERTY keyboard, AMD processor, 512MB or 1GB RAM and both SSD and HDD storage are the best bits of its hardware.
Investment Technology Group or ITG is the China-based manufacturer that stands behind the xpPhone. Well, it may sound like another iPhone wannabe, but it is definitely not. The xpPhone is way more powerful than a smartphone. It's more like a netbook with phone capabilities.
As a beginning let's see what's inside this gadget - AMD Super Mobile processor, 512MB or 1GB RAM, from 8 to 64GB SSD plus from 30 to 120GB HDD (yes both included), 1.3 megapixel camera and various ports - VGA, USB, earphone, microphone, dock connector and SIM slot.
Controlling the xpPhone will be more than easy thanks to the 4.8-inch WVGA TFT touchscreen and the sliding-out QWERTY keyboard, accompanied with D-pad on the left and numpad on the right side. Right in between there is also a small touchpad, while the two mouse buttons are right next to the D-pad.
Full pack connectivity is also onboard - Wi-Fi, quad-band GSM or CDMA, HSDPA/HSUPA thanks to the built-in 3G modem, Bluetooth, GPS and optional WiMax. The bands and frequencies will vary for the different countries and carriers (currently listed for AT&T, Vodafone and Orange).
Considering the fact this fellow runs Windows XP (we think it might be good idea to test it with the new Windows 7 too), the battery life seems strong enough - 5 hours talk time or 5 days of standby, while using it as a regular netbook gives you 7 to 12 hours of power autonomy.
Update: ITG didn't publish the physical dimensions of the device so we used the official photos to calculate them, based on the screen size. It turns out that the xpPhone will measure about 158 x 75 x 16 mm. Added to the weight of 400 grams it's certainly one of the largest phones we have ever seen.
The ITG xpPhone will be available in white, red and black colors, but the price and release date remain unknown. You can pre-order it right now, directly from the company official web site. No payment is required at this stage, just filling a form.
Source
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 18.09.2009., 18:12   #2
Facelessone
Facelessone's Avatar
Postovi: 4,205
4,8 inch pocket book
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 18.09.2009., 19:21   #3
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
E to je nest prebolesno i opasno preveliko.
Staro 18.09.2009., 19:26   #4
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Zanima me jel i miša dobiješ s time
Staro 18.09.2009., 19:43   #5
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Slin slin, mama i ja bih to :P
Preemocna stvarcica, jest da je velik, ali mislim da bi svejedno nasao mjesta u dzepu za njega, kad bih imao love naravno.
Ovako mogu samo nastavit slinjenje
D-I-A-B-L-O je offline   Reply With Quote
Staro 18.09.2009., 20:21   #6
domy_os
domy_os's Avatar
Postovi: 18,960
Autor pinkskin Pregled postova
Imaš mini touchpad, malo veći nego onaj na Samsung Omniji...
Autor D-I-A-B-L-O Pregled postova
Taj džep bi onda morao biti malo bolje sašiven jer stvarčica nije nimalo lagana, 400 g, brate mili...
Staro 18.09.2009., 21:33   #7
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ajde ajde nije 400g 2kile
sta je to za pravog muza
.i.
Razer Blade 15
Staro 29.09.2009., 18:28   #8
Ivche
Ivche's Avatar
Lokacija: Sveta Nedelja
Postovi: 57
ček malo ovo fkt postoji?
Ne znam baš, po meni mobiteli ne bi trebali preći neku određenu masu i veličinu, a treba nosit 400g u džepu...
Ivche je offline   Reply With Quote
Staro 30.09.2009., 21:29   #9
Router
Hejter
Postovi: 6,521
Autor Ivche Pregled postova
Jos nije dostupno za kupnju , dakle postoji samo teoretski Na webu doduse nude pre - order ...
Nije 400g previse , ja bi drage volje nosio ovakvih 400g , odnosno 400g kaj moze sve kaj moze ovaj geđet
Staro 02.10.2009., 01:29   #10
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Da li je netko saznao cijenu ovoga?
Meni je ovo genijalna stvar! Ali kako se telefonira? Šta ima program u xp "telefoniranje"
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 21.01.2010., 22:56   #11
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
xpphone
Ok ovaj dan sam cekao ujedno i razlog zasto sam odustao od Netbook-ova, iako je ovo tek probijanje leda isto kako je napravio Asus sa EEEpc-em usudio bi se reci da je ovo jednake tezine, iako su jos dosta skrti sa infom kakav se CPU nalazi nutra:
http://www.xpphone.com/en/product/specification.html
From US $400 to $650
A phone that has recently stirred up quite a bit of interest is ITG's xpPhone, a MID-like device that runs on Windows XP, has finally got its price tag. According to ITG, the xpPhone will be available with a US $400 to US $650 price tag (3,000 - 4,500 Chinese RMB) depending on the version, or to be precise, depending on the configuration.
The xpPhone still features a mysterious "AMD Super Mobile CPU" and will be available with either 512MB or 1GB of memory. The storage also has wide variety of HDD from 30GB to 120GB and SSD options ranging from 8 to 64GB. It has a 4.8-inch 800x480 TFT touch screen and almost every connectivity option that you might need.
In order to come up with a phone that runs on Windows XP OS, the guys from ITG had to come up with some pretty neat technologies like the one that pulls the phone from standby mode when there is an incoming call or a message, as well as a neat dial-up interface.
All in all, it does look quite neat but we'll hold our final judgment until we see some reviews. Unfortunately, ITG is still holding back on the availability date for both China and the rest of the world.
Izvor: http://www.fudzilla.com/content/view/17301/1/
Malo je velik
">" type="application/x-shockwave-flash" width="425" height="350">
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Zadnje izmijenjeno od: Gjurovski. 21.01.2010. u 23:06.
Gjurovski je offline   Reply With Quote
Staro 21.01.2010., 23:21   #12
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Brijem da ima pol kile sa baterijom.
Btw, to se nosi u torbi na leđima? Jeeer, ne stane mi u džep.
Staro 21.01.2010., 23:23   #13
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
EEEpc ti stane recimo?
Staro 12.02.2010., 19:14   #14
BraBUS
Nervozni poštar
BraBUS's Avatar
Datum registracije: Mar 2008
Postovi: 258
koji smisao ovog proizvoda?
radje uzeti asus ee
nVIDIA+INTEL=klasika
This message is hidden because Crash009 is on your ignore list.
BraBUS je offline   Reply With Quote
Staro 13.02.2010., 00:27   #15
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor Gjurovski Pregled postova
Autor BraBUS Pregled postova
radje uzeti asus ee
