Staro 05.09.2009., 14:45   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
TvAnts + HRT2 = 0
Zna li netko zašto TvAnts više ne funkcionira za HRT2?
Tj. nikada nema dovoljno "buffera" za gledanje...
Treba neke custom servere ili!?
Prije se fino dalo pogledat tu i tamo, sad buffer ne prelazi 20% i u naboljem slucaju se moze uhvatit 1s slike svakih 1-2h.
Za nas koji 20g placamo pretplatu, a upadamo u onih 20% koji nemaju ni analogni ni digitalni signal, to je jedina nada za tekme i sl...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 06.09.2009., 13:37   #2
thopok
Lokacija: Splity
Postovi: 3,003
OiV + HRT = ?
A što na to kaže OiV?
Staro 06.09.2009., 14:22   #3
Mad_Duke
Autor estugarda Pregled postova
Piše ti Zagreb - Istok???
Anyway, satelitska nije skupa, a ako placas tu magicnu pretplatu dobis preko nje skoro djabe za gledat nase programe!
Staro 06.09.2009., 15:00   #4
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Autor thopok Pregled postova
Tko to zna!? Ja mislim da je OiV samo broj telefona i izlika za nesposobnost i krađu HRT-a.
Zvao sam ih 2 puta da dođu i izmejre signal.
Prvi put su našli signal na onom malom televizoru. I to na cesti ispred moje kuće. U dvorište nisu ulazili. Rekli su, nije potreebno. Osobno mislim da nisu nasli ništa, ali dobro. Nakon toga sam privatno provjerio i ako se dobro sjećam (bilo je davno) do mene dolazi 3 refleskija signala. Slika se analogno sa 3 vanjske riblje kosti i 2 pojačala na par minuta može donekle namjestiti (još uvijek je gotovo negledljivo) ali onda zapuše vjetar i negdje pomakne granu na jednom od 3 mjesta refleksije, i slike nestane.
To sam javio OiVu i HRTu (čak razmejnio 10-20 mailova sa ljudima na najvišoj poziciji koji su svi redom nepismeni i nekulturni), i njihov službeni odgovor je bio:
"Žao nam je, upadate u onih 5% (u stvaronsti puno više - većina mojih susjeda) koji zbog konfiguracije terena ne primaju signal".
Na moju molbu dobio sam cinični popust od 5% za sat opremu i to samo ako kupuejm u nekim trgovinama koje su mi preporučili. I koliko ja znam još se na onu preptlatu plaća dodatno za satelit. E to je nešto što neću napraviti nikad. Ali spremam se polako i pratim situaciju. Kod prvog kaosa koji se kod njih desi, tuzit cu ih. I trazit cu povrat svih pretplata u posljednjih 20 godina.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.09.2009., 15:10   #5
thopok
Lokacija: Splity
Postovi: 3,003
To nije točno.
Staro 06.09.2009., 17:36   #6
Berax0r
Berax0r's Avatar
Postovi: 623
Ako imaš ADSL, rokni MaxTV i gotovo
Berax0r je offline   Reply With Quote
Staro 06.09.2009., 18:03   #7
Mad_Duke
-cut -
Kao sto je netko vec rekao. Ili uzmi maxTV ili si stavi satelitsku i ubaci HRT karticu. mislim da kosta par desetaka kuna godisnje!
Staro 06.09.2009., 18:20   #8
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
To nije točno.
Onda se plaća nešto godišnje. Ili jednokratno. Nije bitno. Nije stvar novca, nego principa.
Ako već plaćam porez na TV prijem kako je to zakonski regulirano u obliku pretplate, onda i hoću taj prijem. Jer to što oni kažu da nemam sreće što sam u tih 5% koji ne mogu primati signal, a istovremno mi tu uslugu naplacuju 20g., je u najmanju ruku licemjerno. Zapravo je to najobičnija krađa u ostatku svijeta, ali u Hrvatskoj, eto, nije. Ma doći će i to na red jednom. Ali onda cu ja biti spremniji.
Ali sve je to OT totalni.
Ja sam vas pitao za TvAnts. Postoji li kakva caka? Neki novi server ili sto li vec? Jer prije je to uredno radilo, a sad je gotovo nemoguce ulovit više o par sekundi.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 07.09.2009., 13:58   #9
thopok
Lokacija: Splity
Postovi: 3,003
A očito nema interesa za to. Ovo je također trebalo premjestit u prikladniji pdf.
Ni to nije točno. Bitno je samo posjedovanje prijamnika.
U mom kraju uopće nema signala HRT-a. Što da radim i, ako se ništa ne može učiniti, trebam li plaćati RTV pristojbu?
To očito nije tako lako ostvarit.
