Staro 18.08.2009., 09:10   #61
Zmalamuth
Inquisitor DeathWatch
Zmalamuth's Avatar
Lokacija: Zagreb-Rijeka
Postovi: 918
Ima nas jos, bez brige.
Samo da naprave MP kao i W:ET i igrat cu ga slijedecih 5 godina, kao i original.
Sad samo cekamo da izadje.
i7 4770K cooled by Noctua NH-D14
Asus Sabertooth Z87
Corsair Vengeance Pro 2x8Gb 1866Mhz
EVGA GTX 1080 - 8gb -FTW GAMING
Logitech G500 & G510 Keyboard
OCZ Vertex4 256gb/Samsung SSD 850 Evo 500G /640Gb WD Black/2TB WD Black/3x2TB WD in sharkoon docking station
LG GH22
Corsair HX620W
Corsair Carbide 678c
Arctic Bionix F140mm x3
Phillips Brilliance 240PW - 24'''
Zmalamuth je offline   Reply With Quote
Staro 18.08.2009., 10:57   #62
Nybelung
Mislim da je izašla igra i da zasad ima "Objective", "Stopwatch" i "TDM" mod za MP. Vjerojatno se igra na 8 mapa..
Konačno neka pucačina koja se neće igrat na Deathmatch.
Staro 18.08.2009., 11:08   #63
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Super jedva čekam da probam
sinisa1989 je online   Reply With Quote
Staro 18.08.2009., 22:27   #64
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Već sam pet postova pobrisao...ako se ne ograničite na "igra je vani" i kakva je počinjem djelit ...
Staro 18.08.2009., 22:51   #65
Jelc
Super Moderators
Postovi: 17,485
Dugo je trebalo...
Wolfenstein Client Patch 1.1
1.1 Update List
When on the purchase upgrade confirmation screen, ESC now cancels the purchase instead of returning to the menu.
Sounds added for navigating menus.
In order to prevent names from running off the screen, character limit has been reduced to 10 characters on names
Fixed issue causing the Healing icon to remain after dying.
Sprint functionality has been modified so user can sprint longer, but has longer duration before being able to sprint again
Global chat now disables properly if disabled through the Server Launcher.
Fixed bug causing the grenade ammo indicator to reflect having one more grenade in your inventory.
End-of-round countdown voice-over takes priority over objective status voice-overs.
When a round ends, the scoreboard will default to the chat window.
Truck model in Canals has been updated so it is easier to complete the objective
Clan Tag text box in the Options Menu has been realigned
Audio countdown has been readjusted
The kill ticker color has been adjusted to the proper team color
MP43 melee attack speed has been slightly decreased
Added Quick voice chat that can be binded via the console (the new binds are _needEngineer, _needMedic, _needSoldier, _needHealth, _needAmmo)
Both teams should now be able to mute users properly
Soldier arm when holding Kar 98 has been improved
Reduced how far packs are thrown
Reduced how far grenades are thrown
Removed a chair near the crucifix in Canals to prevent the crucifix from dropping into an area where it could not be reached
Control options now feature separate binds for Use (resurre
ct, objectives) and Item (Ammo, Health, Satchel)
Choosing a random map rotation will work properly now
Added ability to change cross hair appearance through the menu
Fixed issue causing the crouch icon to remain after dying
http://www.fileshack.com/file.x/1500...ient+Patch+1.1
Staro 18.08.2009., 23:10   #66
ante2
ante2's Avatar
Postovi: 1,313
aaaaaaaaaaaa ????
kad je ono izasla igra kad je patch tu ????
igra izasla prije pola sata a patch cca 15 min nakon toga to se zove briga za kupce
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 18.08.2009., 23:58   #67
denied
denied's Avatar
Postovi: 1,193
Malo sam preletio patch ali kolko vidim nema neki "crash" fixeva nego većinom kozmetika....tak da pretpostavljam da će biti ugodno za igranje
U svakom slučaju bolje što prije patch nego poslije - to se zove ažurnost
Uglavnom jedva čekam da ju odigram
denied je offline   Reply With Quote
Staro 19.08.2009., 01:25   #68
Neo-ST
Neo-ST's Avatar
Postovi: 8,442
Nije loša igra za sada, komadi tijela lete svugdje i tako
Kratki gameplay:
Ja cijelo vrijeme čujem Pabla Francisca u igri - "get down!"
Zadnje izmijenjeno od: Neo-ST. 19.08.2009. u 01:37.
Staro 19.08.2009., 04:04   #69
ante2
ante2's Avatar
Postovi: 1,313
evo danas sve nesto zlo i naopako
prvo dojdem doma i najdem ribu kako pliva leđno tj krepala
pa onda da utopim tugu krenem sa ovom igrom i eto jos veca tuga, mislim je ljepo izgleda ali brat zar sve igre u zanje vrijeme moraju imat okus konzole i ovu plasticnu grafiku (malo me podsjeca na Time shift koji je -2)
ajde nije bas sve crno bar kad nesto pukne srapneli ljepo lete
odo spat
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 19.08.2009., 09:44   #70
ivo1950
ivo1950's Avatar
Postovi: 172
Stavia san 1.1 patch i sve radi savrseno,pocetak igre je predobar,krvi i djelova tjela koliko oces...
bez gravitacije,lete i pucaju
ivo1950 je offline   Reply With Quote
Staro 19.08.2009., 09:45   #71
Roberto
Roberto's Avatar
Postovi: 2,648
Gledam po forumima, dojmovi su podijeljeni. Kao i uvijek
Bilo je odavno jasno da će igra imati konzolaški okus, odmah čim su rekli da će ju radit i za konzole
Nadam se da ima dosta za igrat outdoor, RTCW je imao zakon misija po vanjskim prostorima, i danas ih je gušt igrat.
Zadnje izmijenjeno od: Roberto. 19.08.2009. u 10:43.
Staro 19.08.2009., 10:28   #72
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Igra je dobra iako nisam ljubitelj FPS-a.
Maloprije uzeo sikeru i razovarao sam se. Mlati samo horizontalno.
Staro 19.08.2009., 10:45   #73
ivo1950
ivo1950's Avatar
Postovi: 172
Ima dosta onih prepreka,kao u RTCW,za prolazit ih imas neki veil,(sands of time u PoP)
jedva cekan da se pocne MP igrat,jer kad predes prvu misiju rijesia si 7%
Zadnje izmijenjeno od: ivo1950. 19.08.2009. u 11:13.
Staro 19.08.2009., 11:24   #74
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,244
Onaj gore navedeni video isječak gameplaya mi tako izgleda kao COD, čak sam i u jednom trenutno pomislio - ma koje igre je izašao nastavak?
Staro 19.08.2009., 12:50   #75
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
A sta je sa MP? Nema jos servera ili se ceka "ono"?
Ja ga jasno vidim ali niti ja njega mogu pogodit niti on mene vidi.
Zadnje izmijenjeno od: BlackDwarf. 19.08.2009. u 13:08.
Staro 19.08.2009., 14:14   #76
ivo1950
ivo1950's Avatar
Postovi: 172
ja mislin da za mp treba original,btw stavi patch,ja dosad nisan vidia bugova
Staro 19.08.2009., 14:18   #77
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Patch sam stavio odmah nakon instalacije. Ma ovo nije bug, nego metak zapinje za tu lampu i prostor prema kutiji.
Malo su naporni oni brzi u mantilu.
Evo jos malo:
Kako se ja pomakao tako se pojavljuje ova mrlja. Ne bi bas rekao da je pokriveno teksturom.
Zadnje izmijenjeno od: BlackDwarf. 19.08.2009. u 16:59.
Staro 19.08.2009., 21:41   #78
Neo-ST
Neo-ST's Avatar
Postovi: 8,442
Nakon malo igranja, ipak mi nije nešto...
Nekako odaje feeling da je na brzinu sklepana, grafika ništa posebno, AI ništa posebno...
Staro 19.08.2009., 23:29   #79
Terminator02
Terminator02's Avatar
Postovi: 602
Znači ništa od evergreena-a
Jel ovo radia ID software?
Terminator02 je offline   Reply With Quote
Staro 19.08.2009., 23:44   #80
media_plejer
Postovi: 115
Prvi wolf bio je zakon jer je bio zakon,
RTCW je pravi wolfenstein 3d shooter napravljen na najboljem engine-u do tada (koji je temelj hrpe dobrih igara).
Sada ovoliko godina nakon RTCW izlazi novi wolf, koliko dobar i ionativan bi morao, i mogao biti da zadovolji standarde nakon hrpe prožvakanih pucačina u rupi između dva izlaska.
Gledo sam koliko je AvP3 pljuvan nakon gameplay prezentacije, a izgleda odlično i ima inovativne elemente.
Nisam u tom biznisu i ne znam koliko inovativnosti osim grafike se još može unijeti u industriju, a ovaj nastavak je preočito loše sklepan da se proda na staroj slavi pa ga ni grafika ne spašava jer je nema.
media_plejer je offline   Reply With Quote
Staro 19.08.2009., 23:51   #81
ivo1950
ivo1950's Avatar
Postovi: 172
Presa 40%,ipak mi se cini RTCW dosta bolji,ovdi u svakoj misiji se zavlacis pod zemlju te se vracas u bazu.Uvik te isprate isti likovi koji poginu te su sljedecu misiju opet zivi
Ima dosta stvari iz drugih igara sklepanih u ovo.
Štit
Iste zenske ka sa RTCW-a
neko tumor stvorenje i tesla gun
Staro 20.08.2009., 05:04   #82
Atrax
Atrax's Avatar
Postovi: 553
Istina, dosta toga je reciklirano iz starog Wolfa, ali iskreno, meni ne smeta.
Igra me poprilično iznenadila. Misliš si to je Wolf, mora bit dobar, al takav stav sam imao i o nekim drugim igrama prije nego što su izašle, pa kad izađu-ćorak, ni blizu kao original.
Engine je malo "last year", ali vidi se da su se potrudili dotjerat ga, nema mutnih tekstura sve je više manje HD kolko vidim, AA i AF na mjestu, tako da što se estetike tiće, ja zadovoljan. Odlično se vrti, to je zapravo bitno.
Likovi izgledaju malo plastično, kao da imaju celofan navučen preko sebe, al to je već traženje dlake.
Sami gameplay meni odličan, red akcije, red upgrejdanja, red razgovora itd, igra mi se čini nekak uravnoteženom, igrao sam 3 sata u komadu i nisam se "uhvatio" u dosadi ili tako nešto.
Odlično su napravili animacije protivnika kad ih pogodiš, baš sam malo isprobavao sa snipom, pogodim ga u koljeno frajer se primi za tu nogu, malo kao zatetura i počne šepat unatrag. Pogodak u glavu-frajer pada. Pogodak malo niže-lik se primi za vrat i polako pada dok ne iskrvari. Znam, malo morbidno ali ne viđamo to često zadnje vrijeme u igrama pa je fora
AI općenito mi se čini OK, neću reć pametan, al za razliku od večine koje smo gledali u nekim igrama zadnjim, bar nisu retardirani i priglupi; znaju se sakrit, znaju flankat (više-manje), kad pojuriš prema njima pokušavaju pobjeć i ponovno pronać zaklon i tako to...
Istina, igra ima nešto drukčiji feeling nego stariji wolf, ali opet meni paše.
Nadam se da će multi bit kvalitetan i zabavan kao prije, mislim da je to zapravo najbitnija karika u ovoj igri, kao kod CoD-ova, koga briga za SP
Ne znam zašto, al igra me nekak podsjeća na Far Cry 2. Stvara privid open worlda i free roaminga a zapravo nije. To malo razbije linearnost. I dobro je što u gradu na ulicama kad su borbe, ima alternativnih ruta i prolaza, za flankanje, pa nije sve baš skriptirano i strogo određeno.
Zamjerke idu eventualno radaru koji je očito osmišljen za priglupe, jer te doslovce navodi u centimetar u koju ulicu trebaš skrenut.
I čini mi se da je možda malo pre lagana igra, igram na onoj predzadnjoj težini (hard čini mi se) i nije baš neka frka. Na Uber je vjerojatno taman kak treba.
Evo, to je moj osvrt na igru, ugodno sam iznenađen. Nadam se da će MP bit dobar da me drži do izlaska MW2.
Uopće nisam bio zapaljen za igru, slučajno saznao da je izašla, i na kraju ispada da me najviše oduševila od svih FPS-a zadnje vrijeme. Nema tu ništa spektakularno, ali je baš čista kvalitetna zabava (za moj ukus), bez ikakvih frustracija.
I, btw, već je prvi patch vani (mislim da se odnosi na MP dio), pa ko voli http://www.gamershell.com/download_49904.shtml
Atrax je offline   Reply With Quote
Staro 20.08.2009., 08:47   #83
ivo1950
ivo1950's Avatar
Postovi: 172
posto jos nema servera i treba original moze se preko hamachia igrat MP
c/p
Create an Offline Account. There is no servers to browse to, nor a place to store your account yet.
Activate your console by Ctrl + Alt + Tilde(~)
Type com_allowconsole 1 so that your console is easily accessible.
Download Hamachi. VPN "virtual" LAN Client since there are no servers you can browse to while in-game. Configure, and connect to someones virtual LAN hosting a wolf2mp game.
Open wolf2mp.exe and bring down the console ~ again. Type connect (ip goes here) and enjoy
Staro 20.08.2009., 09:11   #84
Delta S4
She`s back...
Postovi: 983
A stvarno izgleda ko COD... Ne zanima me zapravo SP dio igre. Jedino što je kod Wolfensteina doista bitno je MP.
Često pokušavam dokučiti što je to kod WETa bilo toliko dobro. Čini mi se da je to kombinacija simpatične grafike, interesantnih mapa, odličnog feelinga prilikom borbe i još puno malih sitnica. Ali dvije po meni najbitnije stvari u toj igri su duhovitost (karikirani likovi i genijalni glasovi koji izgovaraju one poruke) i otvorenost cijelog projekta (korisnici mogu izrađivati svoje mape, modove, oružja, uniforme...i nisu ograničeni onime što dolazi uz samo igru).
Quake Wars je pao na obje ove posljednje stavke. Igram ga, ali nije ni sjena WETa. Ovaj novi Wolfenstein...ne znam. Ne čini se niti duhovit, a niti da će imati podršku za razne korisničke modifikacije. Bojim se da me čeka razočaranje. Ali kupiti ću ga iz zahvalnosti za silne stotine sati zabave koje mi je pružio jedan, jedini (i nikad ponovljivi?) WET. Pa nek stoji na stalaži, dok ja igram WET
Delta S4 je offline   Reply With Quote
Staro 20.08.2009., 10:00   #85
svebee
Lokacija: /
Postovi: 2,053
Meni se sviđa podsjeća na COD, ali to smatram dobrom stranom.
http://www.youtube.com/watch?v=DcM5TKGAHXA
p.s. bombe nemrem bacit nazad ni da sam neznam kaj
svebee je offline   Reply With Quote
Staro 20.08.2009., 10:38   #86
Nybelung
Autor Delta S4 Pregled postova
Ne zanima me zapravo SP dio igre. Jedino što je kod Wolfensteina doista bitno je MP...
..Ali kupiti ću ga iz zahvalnosti za silne stotine sati zabave koje mi je pružio jedan, jedini (i nikad ponovljivi?) WET.
Eto, u startu imaš pogrešna očekivanja.
Ovaj Wolf je tek "nastavak" na igru RTCW, a ne WET2.
Enemy Territory je jedan serijal, a Wolfenstein i Quake su drugi (i treći).
Staro 20.08.2009., 11:28   #87
Roberto
Roberto's Avatar
Postovi: 2,648
Nisam još zaigrao, ali ono što sam dosad vidio na netu nije me impresioniralo.
Ono što me je oduševilo u RTCW je bila dobro osmišljena priča koja te postepeno vodi kroz igru, raznolikost misija i dobra atmosfera. Bilo je dobrih misija svih vrsta na svim mogućim terenima koje si morao na različit način igrati.
Ovo mi ostavlja dojam nabrzinu sklepane igre u kojoj su sve misije na isti kalup. Iritira me i to što nakon 5 minuta igre već uleti u spiku Veil, pa lebdiš bez gravitacije, pa usporavanje vremena... Novotarije koje se meni osobno ne sviđaju, a i ne sviđa mi se što su tu od početka igre. RTCW je bio bolji i po tome što je imao manje tih SCI-FI elemenata i bili su bolje ukomponirani.
I grafika mi se čini nekako preplastična...
No dobro, vjerojatno ću zaigrat i sigurno nije loša igra, samo što sam ja očekivao malo više nakon toliko godina od RTCW.
Staro 20.08.2009., 11:33   #88
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Muka mi je od tumbanja po gradu. Skoro svaki put se vracam na isto mjesto a pogotovo u dvorcu. Odem gore da bi dosao u istu prostoriju i tako jos triput...
Staro 20.08.2009., 11:53   #89
ivo1950
ivo1950's Avatar
Postovi: 172
Blackdwarf imas onu kucu iz koje se ide na misije i u koju se vraca
Btw dobri su oni koji nevidljivi sa nozevima koji te napadaju sa leđa i smiju ti se
Staro 20.08.2009., 12:34   #90
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Pa znam da imam kucu ali stalno se tumba iz jednog dijela u drugi.
