Staro 23.07.2009., 21:23   #991
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Ja sve sta trazim nađem na MU i vec jako dugo nisam koristio RS jer ima i cekanje i strahovito losu brzinu.
' alt='' border=0>
Vejita je offline   Reply With Quote
Staro 23.07.2009., 23:14   #992
Big Guy
RPG player
Postovi: 1,574
@Demon Hunter
imaš 5000 MB, ali od 2 u noći do 10 ujutro trošiš 10% tako da možeš skinuti 50 000 MB dnevno
@weaponx
sve ovisi koliko ti treba
frend je htio uzeti premium, ali sam mu ja rekao da skida free jer ionako malo skida
ali meni je premium jako dobar jer kada skidam sam na statičkoj vezi i to ide brzo pa mi treba brzina i promet
da, dobili su pare, ali oni hoće još....
@Vejita
da, free useri loše prolaze kod RS, a to je zato da ih se natjera na kupovanje premium accounta, ali zato premium ima brzinu do 500 Mbit i max 50 GB prometa dnevno, i što se tiće mene je isplativo dati tih 50 kn ako dosta skidate
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 25.07.2009., 21:12   #993
Demon Hunter
Postovi: 999
Nisam znao za ovih 10% tijekom noći. To je nešto novo?
Demon Hunter je offline   Reply With Quote
Staro 25.07.2009., 22:03   #994
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,519
Autor Demon Hunter Pregled postova
od 19.3.2009.
HappyHours for Premium customers
March 19, 2009
We will now implement HappyHours for our Premium customers, so you can use our infrastructure in the best possible way. Currently, the HappyHours will be active from 2 a.m. until 10 a.m. Central European Time since that is the only time during which there is unused bandwidth left. During that time, only 10% of the data volume you download will be charged to your traffic balance. So if you download 300 Megabytes during HappyHours, only 30 Megabytes will be accounted. This applies also if you use RapidPoints or TrafficShare for your downloads.
The amount of unused traffic that can be accumulated has been raised from 12 Gigabytes to 15 Gigabytes.
Please note that this has to be regarded as a test, and we can reverse the modifications or change the time and percentage rate of the HappyHours at any time if neccessary.
imaticx je online   Reply With Quote
Staro 27.07.2009., 10:51   #995
Demon Hunter
Postovi: 999
Koristim Premium već 3 godine(ako ne i više) no u zadnjih pola godine ne skidam nešto puno, pa valjda zato nisam ni primjetio
Staro 27.07.2009., 19:33   #996
gamer21
Postovi: 37
Namjeravam si kupit premium acc, ali kako nema karticu sam namjeravo preko HR resellera
uzet www.condurarapid.com.
Pa ma zenima jeli ko kodnjih kupovao,jeli sigurno preko njih kupovat ( da nisu neki muljatori koji zele samo lovu zgrabit).
gamer21 je offline   Reply With Quote
Staro 27.07.2009., 20:09   #997
svebee
Lokacija: /
Postovi: 2,053
http://rapidshare.com/resellers.html
odaberi Croatia. sve je ok
svebee je offline   Reply With Quote
Staro 27.07.2009., 20:28   #998
gamer21
Postovi: 37
Ok, thx
Staro 27.07.2009., 20:47   #999
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Uzimao sam ja od njih 6mj acc i nije bilo problema.
' alt='' border=0>
Staro 28.07.2009., 15:31   #1000
Big Guy
RPG player
Postovi: 1,574
ako niste primjetili sada premium useri mogu dati 1 bod svakih 5 minuta (što bi bilo 288 boda u 24 sata)
i da znate kako to ide:
digitalac Canon Powershot A480 Silver koji sam naručio sa RS-a za bodove je konačno stigao
nisam morao platiti nikakvu poštarinu ni aparat, ali samo morao platiti prokletu carinu od 180 kn na 105 eura vrijedan digitalac
ali sve u svemu dobio sam fotć za 180 kn što nije loše, ima 10Mpix, 3.3 optički zoom i radi, za mene, dobre slike tako da hvala RS
Staro 02.08.2009., 14:52   #1001
Cvele89
Lokacija: ...
Postovi: 141
Imam problem.
Kupio sam premium acc i instalirao flashget i podesio sve, ali kada krenem skidati nešto preko flashgeta, skine mi file, ali mu je veličina 5kb.
Linkovi su aktivni i kad skidam preko mozzile sve je ok, ali flashget skida fileove i veliki su 5kb makar nisam ništa prije skidao tj. napravljen promet mi je 0 mb bio.
U čemu je problem?
Cvele89 je offline   Reply With Quote
Staro 02.08.2009., 16:45   #1002
Postovi: 34,050
Zašto FG? Instaliraj si jdownloader pa će sve biti ok.
Staro 02.08.2009., 17:45   #1003
Big Guy
RPG player
Postovi: 1,574
ili još bolje Internet download manager tj IDM
Staro 02.08.2009., 19:20   #1004
Cvele89
Lokacija: ...
Postovi: 141
Isti problem s IDM.
JDownloader skida bez problema.
Hvala svima.
P.S. Pohvale članu tihomir2. Kupio sam o njega RS acc. Javio sam mu se. On je rekao da kad pošaljem bon da on meni šalje acc.
Ja kupio/poslao vip bon od 35 kn.
On meni kroz par sati username i pass i eto sve radi.
Staro 10.08.2009., 08:20   #1005
yaya
Kupila premium i ukraden
...dakle kolka je vjerojatnost da kupis premium i za 2 dana ti ga ukradu,e to se meni desilo, kupila sam ga od nekog ovako za 50 kn i eto, sad posto sam ja sumnjicav tip, mislim da mi je isti to i napravio..ali pitanje dal je ista vjerojatnost kradje ako se kupi direktno od njih i moze li se nekako zastititi, primijetiti ti linkovi koji vode hackeru ili kome vec, kud ce suza neg na oko jbg..kud bas mene, al prilicno sam sigurna da kupovat vise necu
Staro 10.08.2009., 08:28   #1006
F@NTOM
Darth Pope
F@NTOM's Avatar
Lokacija: localhost
Postovi: 225
Ako se radi o rapidshareu, jesi ukljucila onaj security lock?
F@NTOM je offline   Reply With Quote
Staro 10.08.2009., 08:28   #1007
yaya
ma jesam ukljucila sam..
Staro 10.08.2009., 10:02   #1008
F@NTOM
Darth Pope
F@NTOM's Avatar
Lokacija: localhost
Postovi: 225
A ne znam. Jedino ti ostaje da se javis rs supportu. Meni su vratili acc kad je bio hackiran.
Staro 10.08.2009., 10:54   #1009
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,797
Uvijek provjeri Adress bar prije nego što upišeš pass, zbog phishinga:
http://i20.tinypic.com/2yzgahk.png
http://www.sunbeltsoftware.com/alex/...34882348pa.png
To su stranice napravljene da izgledaju kao rapidshare s namjerom da ti ukradu acc, naravno
Javi se RS supportu i trebali bi ti vratiti acc.
EDIT:
Zapravo, prvo se javi onome od koga si kupila - on treba kontaktirati RS.
Staro 10.08.2009., 12:01   #1010
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
hm, mozda su te haknuli a mozda je i taj racun koji si kupila haknut nekome pa ga je rs support jednostavno vratio vlasniku....
Munjara je offline   Reply With Quote
Staro 10.08.2009., 12:03   #1011
Doktor-X
Doktor-X NetWork
Doktor-X's Avatar
Lokacija: .
Postovi: 291
ako nemaš od paypal-a transaction ID zaboravi na RapidShare Support
Doktor-X je offline   Reply With Quote
Staro 10.08.2009., 14:53   #1012
yaya
da da zaboravila sam vec...ne racunam s tim acc, hvala ljudi
Staro 10.08.2009., 15:35   #1013
khm
Lokacija: Slavonija
Postovi: 1,200
Autor flajpan Pregled postova
Lix.in nije phishing, to je zastita linkova od auto. botava koji prijavljuju abuse
khm je offline   Reply With Quote
Staro 10.08.2009., 19:17   #1014
lVlark
All rights reversed
Lokacija: Zagreb Awesomeness: 10000
Postovi: 85
Autor yaya Pregled postova
To je i problem. Taj acc koji si kupila je vjerojatno bio ukraden, pa ga je vlasnik samo vratio u svoje vlasnistvo.
lVlark je offline   Reply With Quote
Staro 14.08.2009., 15:30   #1015
Big Guy
RPG player
Postovi: 1,574
novosti sa RS-a
kako znate RS je nedavno uveo referrer bodove (bodovi koje dobivate kada netko koristi link na vaš file ili pa vaš referrer link da kupi novi premium account)
i sada je za izradu 1 mjesečnog accounta potrebno 5000 bodova i 1 referrer bod
ovo je dobro i ne dobro jer ako imate 100000000000 bodova a nemate barem 1 referrer bod ne možete napraviti novi premium account
zato bi bilo bolje da se napravi opcija biranja
- 10 000 bodova za 1 account
- 5000 bodova i 1 referrer za 1 account
btw
poslao sam mail RS-u sa tim prijedlogom
Staro 14.08.2009., 15:53   #1016
neumrli
Dubwise
neumrli's Avatar
Postovi: 307
Autor Big Guy Pregled postova
Bilo bi lijepo kada bi takve firme slusale prijedloge potrosaca, no njima je samo do sto veceg profita.
neumrli je offline   Reply With Quote
Staro 15.08.2009., 10:43   #1017
Big Guy
RPG player
Postovi: 1,574
hehe, da istina
ali to i je njima u interesu jer taj referrer bod je samo zahebancija zbog koje bi oni mogli početi gubiti ljude, a to je ono što oni ne žele
i RS mi odgovorio
Hello,
thank you for your report or suggestion.
We have sent your message to our development department.
Many things have already been reported. We take note of every report, but
unfortunately we can not answer every email.
Thank you for your understanding.
Best regards,
Tobias
RapidShare Support
Staro 21.08.2009., 23:28   #1018
svebee
Lokacija: /
Postovi: 2,053
Otkad do kad ovo važi?
Set up a new Premium Account with 30 days duration. - 1998 points (special offer)
Staro 22.08.2009., 01:39   #1019
tiki66
tiki
tiki66's Avatar
Postovi: 2,754
Autor svebee Pregled postova
Mislim od danas ili jucer, a cuo sam da ce trajati oko 4 tjedna... ali to nista nije 100% sigurno
Staro 22.08.2009., 01:41   #1020
svebee
Lokacija: /
Postovi: 2,053
Arrow RapidShare PREMIUM račun 1 mj. (brzopotezna nagradnjača)
RapidShare PREMIUM račun (do 20.09.2009.)
Neznam gdje da stavim, ako nije dozvoljeno neka se briše. Ali evo, nudim pa tko stigne - stigne
