Staro 21.07.2009., 18:29   #1
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
Nvidia ForceWare 190.38 WHQL driveri
This is a WHQL-Certified driver for GeForce 6, 7, 8, 9, 100, and 200-series desktop GPUs and ION GPUs.
New in Release 190.38
  • Adds support for OpenGL 3.1
  • Adds support for CUDA 2.3 for improved performance in GPU Computing applications. See CUDA Zone for more details.
  • Includes several new control panel features and numerous bug fixes. More information can be found in the release documentation.
  • Adds a new user-controlled power management setting for select GeForce 9-series and later graphics cards (cards must already support more than one power state). This option allows users to set a performance level for each DirectX or OpenGL application. (Vista & 7)
Existing Support:
  • Supports single GPU and NVIDIA SLI technology* on DirectX 9, DirectX 10, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel X58-based motherboards.
  • Installs PhysX System Software version 9.09.0428.
  • Supports NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here.
  • Supports GeForce Plus Power Pack #3. Download these FREE PhysX and CUDA applications now!
  • Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
  • Supports Microsoft’s new DirectX Compute API on Windows 7. (Vista & 7)
*Note: The following SLI features are only supported on Windows Vista and Windows 7: Quad SLI technology using GeForce 9800 GX2 or GeForce GTX 295, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support.
Windows XP
Windows XP x64
Windows 7 & Vista
Windows 7 & Vista x64
Sultan je offline   Reply With Quote
Staro 22.07.2009., 20:26   #2
dean225
DD9512
dean225's Avatar
Postovi: 1,869
dosta dobri driveri, ali imam osjecaj da su graficke, bar ove nove gtx 260-295 jako neiskoristene!!!
dean225 je offline   Reply With Quote
Staro 22.07.2009., 20:27   #3
Razer
Razer's Avatar
Postovi: 11,642
Autor dean225 Pregled postova
Ma šta kažeš?!
Staro 22.07.2009., 21:53   #4
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
a ako cemo realno nema se sta s njima igrat. Ok, mozemo svrsavati na to jel nesto na nekoj ide za 80 a na drugoj na 89 FPS ili da nam neki stari naslov drzi na 300 lock ali igara nema. Ovo sitno i sto se pojavi prije par godina vecina nas ne bi taknula stapom od 12m. I bez obzira na takve srusene standarde opet je sve vise-manje fuj
Staro 22.07.2009., 23:27   #5
BeroVK
Lokacija: Vinkovci
Postovi: 780
Kao sto greg kaze dzaba dobri drajveri kad se nema sta igrat s njima
BeroVK je offline   Reply With Quote
Staro 22.07.2009., 23:59   #6
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
koda su bitne igrice,
glavno da ima novi CTRL Panel !
TO ja tražim od drivera
Pizz je offline   Reply With Quote
Staro 23.07.2009., 11:10   #7
xarfaxus
xarfaxus's Avatar
Datum registracije: May 2009
Lokacija: Zagorje
Postovi: 53
imam 185.xx drivere i updejtam na te 190.38 i u svim igrama je slika zamućena nekim bojama i onda se vratio na 185 drivere i sve u redu u driverima je problem,stoga ove drivere ne preporučam,inače grafa je evga gts 250 1gddr3.
xarfaxus je offline   Reply With Quote
Staro 23.07.2009., 18:32   #8
Mephsto
Mephsto's Avatar
Postovi: 199
Ah, a baš sam pobrisal Need For Speed Undercover jer sam popiz... s grafikom i preformansama!!!
Idem instalirati i probati par igara da vidim dal ima kakve promjene u odnosu na 185.85
Mephsto je offline   Reply With Quote
Staro 27.07.2009., 23:52   #9
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
ja stavio već 190.40 betu :P
Staro 28.07.2009., 22:46   #10
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Skinio sam nove drivere za grafu 8800 GT, 190.40 i od kako su mi gore svako malo me izbacuje samo iz Fallout-a 3 kada igram i baca BSOD, nesto vezano uz neki .dll. Posto vec laganini pucam jer u slobodno vrijeme igram, a BSOD svako malo iskaca i plavi ekran mi vec lagano ide na jetra....da se vratim na 190.38 posto se to pocelo desavati od kako sam promjenio drivere!?
Sa 190.38 sam presao na 190.40 jer su zezali nesto media player-i (km, gom, vlc...uglavnom nisu davali sliku).....i od kako sam stavio 190.40 filmovi rade kako treba, ali samo Fallout 3 mi baca plavi ekran i svako malo restart.
Zna netko u cemu je problem jer se to desava samo kada igram Fallout 3, dok recimo na svemu ostalome sve radi kako treba. Cak sam probao i CPU vratiti na default, ali problem je i dalje tu. Temperature su kako treba i nema nikakvih povecanja nego sto je inace tj. hladno je unutar kucista......sav harveraj je dobro hladen i nema pregrijavanja.
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 28.07.2009., 23:53   #11
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
beta je beta....
a i mozda je doslo do nekog klanja ako se ovi stariji nisu dobro deinstalirali.
Staro 28.07.2009., 23:59   #12
win32
win32's Avatar
Postovi: 1,517
Autor greg SE Pregled postova
beta je beta....
Ocistio sam sve sa Driver Sweeper-om...kompletno sve drivere od nVidi-e i PhysX-a i vratio na 190.38 pa cu vidjeti kako ce sada biti.
No ne kuzim kako samo odjednom BSOD baca......ako nastavi probati cu format c, a ako ni to ne pomogne onda je nesto otislo u vjecna lovista...hmmmm...nadam se da sam u zabludi i da je sve ok.
No, da se nesto shebalo onda bi bacalo "blue screen" i u nekim drugim igrama, aplikacijama...a ne samo u Fallout-u 3...ilil..!?
Edit:
BSOD i dalje.
prime95 vrti sasvim uredno, isto tako bench. za GPU vrti bez greske.
Sta dalje!? Format c?
Zadnje izmijenjeno od: win32. 29.07.2009. u 00:31.
Staro 29.07.2009., 01:06   #13
alengrosevic
alengrosevic's Avatar
Postovi: 3,779
eto stavio sam 190.38 drivere i sve radi odlicno, nikakve BSOD-ove ili probleme nisam vidio...
alengrosevic je online   Reply With Quote
Staro 29.07.2009., 01:12   #14
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
190.38 na win 7 x64 meni radi bez greske
igrao sam Call Of Juarez Bound in Blood, Prototype, GTR Evolution... sve
DeadMan+ je offline   Reply With Quote
Staro 29.07.2009., 10:10   #15
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor win32 Pregled postova
Edit:
BSOD i dalje.
reinstal fallout...
BTW: i ja sam puko te drivere i sve šljaka kak treba (vista 32).
Staro 29.07.2009., 20:50   #16
win32
win32's Avatar
Postovi: 1,517
Bio je na kraju format c
Idem sada vidjeti dali je BSOD i dalje tu...ako je skrenit cu.
Cisto informativno.....ako mi baca BSOD usred igre, a inace nikada sta bi moglo biti u pitanju? Dali je moguc kvar nekoga hardveraja i kojega!?
Edit:
BSOD i nakon format c! Nesto u vezi nv4.dll.....!?
Ima netko ideju sta je u pitanju i zasto samo Fallout, a kada sve ostalo radim na kompu sve sljaka kako treba i bez greske.
Vrti prime95, GPU bench......nema gresaka.
Sada googlam i vidim da hrpa ljudi ima isti problem! Ocito je stvar u driverima i navodno su ok 178.24. ili da se promjeni u reg. editu Paged pool Size..hmm.....
Edit br. 2:
Stvar je bila u driverima. Jednostavno novi driveri ne rade kako treba sa mojom grafickom ili se kolju sa nekim drugima. Googlajuci sam naisao podatak u vezi tih drivera tako da sam stavio 185.85 i promjenio Paged pool size te sada sve radi kako treba. Posto je radilo i prije prckanja po Regystri-u vratiti cu tu postavku na default vrijednost.
Inace dali je netko od vas probao to promjeniti i sta je time uopce dobio?
LP
Zadnje izmijenjeno od: win32. 29.07.2009. u 23:35.
Staro 03.08.2009., 20:40   #17
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Perfektno rade već treći dan.
Staro 03.08.2009., 23:35   #18
alengrosevic
Postovi: 3,779
eto ja sam se urekao kad sam rekao da je sve ok, sad to povlacim
eto i na winxp i na win7 imam sljedeci problem sa 9800 gtx+: udjem u winse, sve je ok i sve radi normalno. udjem u igru (trenutno cod4 i kriza warhead) i vent se pod opterecenjem digne na cca 80-100%. kad se vratim u windowse, vent i dalje radi na 100%. malo je iritirajuce slusati tu turbinu u kucistu, pa sam se posluzio sa riva tunerom za prvu ruku. koliko vidim nisam jedini, ima jos slucajeva...
http://forums.nvidia.com/index.php?showtopic=102550
Staro 04.08.2009., 00:21   #19
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
ne moras za to ici daleko, i ja sam se gore zalio na isti problem.
Kako mrzim neka 3rd party rjesenja za probleme koji ne bi smjeli postojati (razlog zasto vise ne idem na ati ni da me sjekirom tjeraju ) problem rjesen vracanjem starih drivera.
Staro 05.08.2009., 12:56   #20
alengrosevic
Postovi: 3,779
probao sam i sa 190.56 ali problem je i dalje tu, tako da sam morao ici nazad na 185.85 i na njima sve radi ok...
vidis sa ATI-em nikad nisam imao problema, gro kartica i nikad ovakva s**nja...
ah sto ces, jedni imaju problema s ovima drugi s drugima, kako ti se posreci...
Staro 05.08.2009., 13:15   #21
wireless_os
wireless_os's Avatar
Postovi: 613
Ja sam isto probao ove drivere i imao sam BSOD na Fallout 3, tak da sam stavio 186.18. Ali imam jedno pitanje. Prije nego sam stavio ove nove, ima sam neku verziju a ne sjecam se koju...jel ima neka 190.xx prije ove zadnje? Naime sa tom verzijom sam igrao igre na 8800GS u full hd rezi bez ikakvog trzanja. Nedavno sam spojio novi monitor da bas vidim kak ce igre se vrtiti. Ocekivao sam lose performanse no sve je radilo super.
Ali sada sa 186.18 Fallout nije igriv na toj rezi. Postavke igre nisam mjenjao... Ima netko kakvu ideju? Kad nisam gledao koju verziju imam prije mijenjanja...
Intel Celeron G1820
ASRock H81M-HDS
8 GB Kingmax
23'' LG Flatron W2361V
NVIDIA GeForce GTX 960
Samsung Spinpoint F1 @ 1 TB
INTEL SSD - 120 GB
LC POWER LC6650GP3 V2.3
Antec Sonata Elite
MX 518
Logi tipkovnica neka..
NuForce usb DAC
wireless_os je offline   Reply With Quote
Staro 16.08.2009., 21:15   #22
win32
win32's Avatar
Postovi: 1,517
Autor wireless_os Pregled postova
Hmmm...meni Fallout 3 radi jedino ok sa 185.85 driverima. Probao sam i ostale no baca BSOD. No nisam radio update Winsa ni nista pa bi mozda sada nakon sto sam napravio update i radilo sa nekim novijim driverima, ali mi se ne mjenja trenutno nista sta napokon radi kako treba.
Staro 17.08.2009., 15:18   #23
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Kakva je situacija s Omega driverima, zadnji su izasli na osnovi 169.21 Forcewarea i zanima jel to cemu, konkretno za AGP kartice koje mi se dosta kolju u 3D-u, pogotovo ova 6600/6800 serija...
Staro 17.08.2009., 15:37   #24
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Dizel Pregled postova
ja na svojoj bivšoj 6600 GT GS nisam nikakve razlike primjetio. probaj pa vidi.
Staro 17.08.2009., 16:33   #25
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Evo nakeljio tu Omegu 2.169.21 i vidjet cemo hoce li i ovo praviti probleme.
Staro 18.08.2009., 08:50   #26
thedream
thedream's Avatar
Postovi: 5,458
Nisam znao gdje da postam pa se ispričavam,CoD2 tema je valjda već prašnjava koju godinu,a radi se o mobilnoj nvidia grafi i Forcewareima, nije HW problem,nije SW,sve igre rade super,stavio sam posljednje mobilne drivere 110mb su,ništa okrljašteno,za 8400M G grafu sa 128mb,laptop je ASUS F3S sa 4gb rama i C2D na 2.00,imam glup problem da sve igre rade odlično na nativnoj rezi osim CoD2 koja me uporno izbacuje nakon početnog miniload ekrana u Visti.
Igra je original,popatchana zadnjim 1.3 patchom,driveri zadnji,reinstalirao Vistu,opet isto,ali samo u ovoj hebenoj igri,inače,informacije radi,nije neka usporedba,ali ja na svom kompu igru vrtim odlično,mislim isto je Vista,pa da to isključimo,i nvidia grafa,ne može se baš usporediti,ali da i to isključimo.
Ne znam šta da još probam,pokrene mi console launcher i baci neki 2D error,24bit,8bit gluposti neke pišu i 1024x768,attempting,bla bla,meni je reza 1280x800 ili koliko već,15.4-vorka je standardan monitor.
Ne znam da li da instaliram .inf od ovih stolnih drivera,pa malo tamo sprčkam, buni me što sve proklete igre rade osim ove,i sve se pokreću,i rastežu na 15-20 fps . Samo ovo ne.
