Staro 22.07.2009., 13:19   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Gdje kupiti gumene kopče za vent?
Ima li gdje za kupiti one gumene kopče koje dolaze s nekim ventilatorima u kutiji, npr. Zalmanovim 120mm?
http://www.awd-it.com/scripts/prodVi...M-F3+120mm+Fan
C L O W N I N G A R O U N D
Staro 22.07.2009., 13:31   #2
danex
danex's Avatar
Datum registracije: May 2009
Postovi: 378
imas u feniksu te gumice
Staro 22.07.2009., 15:30   #3
Doink the Clown
Postovi: 6,214
Našao... naručio
Staro 22.07.2009., 15:39   #4
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
a "ima" ih i u Hardveraju
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 22.07.2009., 16:04   #5
Zmalamuth
Inquisitor DeathWatch
Zmalamuth's Avatar
Lokacija: Zagreb-Rijeka
Postovi: 918
ima, ima, ako zelis cekat 8 mjeseci na njih.
"Been there, done that"
i7 4770K cooled by Noctua NH-D14
Asus Sabertooth Z87
Corsair Vengeance Pro 2x8Gb 1866Mhz
EVGA GTX 1080 - 8gb -FTW GAMING
Logitech G500 & G510 Keyboard
OCZ Vertex4 256gb/Samsung SSD 850 Evo 500G /640Gb WD Black/2TB WD Black/3x2TB WD in sharkoon docking station
LG GH22
Corsair HX620W
Corsair Carbide 678c
Arctic Bionix F140mm x3
Phillips Brilliance 240PW - 24'''
Zmalamuth je offline   Reply With Quote
Staro 28.07.2009., 08:11   #6
Doink the Clown
Postovi: 6,214
Evo stigla mi ponuda jučer od Feniksa za ove gumene kopče, prevrnuo sam se od smijeha kad sam to vidio
br.Naziv artiklaJed. mj.
KoličinaPDV
Prodajna
cijena
Iznos
stavke
1Cooler Xilence VIJCI gumeni za ventilatore, za zatvoreni sistemkom1,002217,5017,50
2Dostava robekpl1,002245,0045,00
UKUPNO: 62,50
Staro 28.07.2009., 11:36   #7
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
nazovi ih i pitaj da ti pošalju u kuverti običnom poštom. ako se nekome od zaposlenika da naravno,
doći će te oko 5kn max ta 'dostava',
a ti njima uplatiš sve to skupa prije na račun kao što si i ovo planirao.
snađeš se
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 28.07.2009., 11:41   #8
Doink the Clown
Postovi: 6,214
Autor TomRi Pregled postova
snađeš se
Postavio sam to pitanje za slanje poštom obično u mailu i nisam dobio odgovor, valjda im se ne da
UPDATE - ipak su se javili majstori da će poslati poštom obično nakon moje prethodne uplate na žiro račun
Zadnje izmijenjeno od: Doink the Clown. 28.07.2009. u 15:16.
Staro 28.07.2009., 15:29   #9
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
i platit ces 17,50 kuna za jednu kopcu? znaci, treba ti minimalno dvije, 35 kuna....... pa kupi se dobar ventilator za te pare .
ili ide vise komada u jednom komadu pakiranja?
Staro 28.07.2009., 15:30   #10
Doink the Clown
Postovi: 6,214
4 komada su u paketu, zvao ja i provjerio
Staro 11.02.2010., 20:28   #11
luks 88
luks 88's Avatar
Postovi: 477
jel imate problema kod stavljanja tih kopči, ja imam Noctuine original kaki i skroz su mekani, sve me strah ih ić stavljat
luks 88 je offline   Reply With Quote
