03.07.2009., 01:43 | #1 |
Postovi: 553
Catalyst 9.7 BETA
Catalyst 9.7 (beta version at the time of writing) adds three new OpenGL extensions and continues to improve advanced features such as Geometry Shader (now a geometry shader can access to 16 textures samplers and 4096 uniforms!). Let’s see the new extensions: * GL_EXT_pixel_buffer_object: This extension brings the support of PBO (Pixel Buffer Object) to Radeon video cards. This extension is useful because it allows asynchronous texture loading and thus improves texture loading… But Catalyst graphics drivers already support PBOs via the GL_ARB_pixel_buffer_object. So, actually, GL_EXT_pixel_buffer_object does not bring new feature. * GL_EXT_provoking_vertex: This extension is used when flat shading is enabled (GL_FLAT). The provoking vertex of a primitive is the vertex that determines the constant primary and secondary colors when flat shading is enabled. This extension is supported in ForceWare since version 185.66. * GL_EXT_vertex_array_bgra: allows to fetch a vertex component (mainly color componant) from a Direct3D color array where color is stored as BGRA. This extension avoids to perform the swizzling in the vertex shader. This extension is supported in ForceWare since version 181.00 Graphics driver information: - Operating System: Windows XP 32-bit SP2 - Drivers Version: 8.630.0.0 – Catalyst 09.7 (6-10-2009) - ATI Catalyst Version String: 09.7 - ATI Catalyst Release Version String: 8.63-090610a-082777E-ATI Ovo je ukratko sažetak, evo link sa popisom OpenGL eksenzija i slično http://www.geeks3d.com/20090630/ati-...gl-extensions/ Za sada samo za XP, bar kolko ja vidim, ne daje mi google ništa za vistu. Pa eto, ko ima XP i volju za probat http://www.megaupload.com/?d=KYXNVKC8 Kolko sam uspio pohvatat po postovima, u 9.7 control panel ima novi layout i neke nove postavke za podesit. Također, neki lik kaže da XP driveri na Visti daju nekih 30% bolje performanse, al u to se ne bih štel mešati. |
07.07.2009., 14:52 | #2 |
Lokacija: SGE
Postovi: 92
uu odlično jedva čekam finalnu verziju |
07.07.2009., 19:44 | #3 |
Lokacija: Miami, 1984, Ferrari F40
Postovi: 903
Zašto svi tako žurno čekaju novu verziju CCC-a? Nisam još nikakvih loših iskustava imao zbog drivera, očito vi ostali jeste
07.07.2009., 21:27 | #5 |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
07.07.2009., 21:54 | #6 | |
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
još sam na 8.12 čekam release notes pa da vidim jel 9.7 nešto bolji, makar sumnjam jer 9.6 ima pad performansi baš u onome što (jedino) koristim, ET;QW http://www2.ati.com/relnotes/Catalys...ease_notes.pdf page 6 Citiraj:
a kako idu nove verzije drivera, nabrijavaju ih za novije aplikacije(igre) dok stare padaju u zaborav i onda dolazi upravo do toga, pada performansi naspram STARIH drivera koji rade bolje (u toj nekoj igri npr) tako da po meni, ako netko ne igra najnovije igre(za koje je rađen driver npr) može i profitirati od starijih drivera, ne srljati bez razmišljanja odmah na download + install (osim ako pročita u release notes da je došlo baš do nekog poboljšanja za tu određenu igru)
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera |
20.07.2009., 12:59 | #8 |
Lokacija: Zabok
Postovi: 1,620
9.6 su mi puno stabilniji od prošlih verzija. Sa 9.5 sam imao česta zamrzavanja prilikom igranja COD4. Neznam zašto. Uglavnom sa 9.6 je sve ok, nadam se da na 9.7 nisu neš previše prčkali po optimiziranju starijih igara.
Svi elektronički uređaji rade na bijeli dim! Kad dim izađe uređaj više ne radi!!! |
20.07.2009., 16:52 | #9 |
Flaccitra
Lokacija: Vinkovci
Postovi: 276
Evo link za cat 9.7 WHQL, takvi će biti i na službenim stranicama http://www.ngohq.com/graphic-cards/1...vista-7-a.html |
20.07.2009., 18:56 | #10 |
Lokacija: Zd
Postovi: 4,685
Link na toj stranici za Vistu/Win7 ne radi, onaj za xp radi... Edit: evo nasa sam link za nove catalyste, 9.7 (8.630) Vista/Win7 WHQL, x86 & x64: http://www.pctreiber.net/filebase_redirect.php?fid=9507 |
20.07.2009., 23:26 | #11 |
Baja!
Lokacija: Sisak
Postovi: 761
Ispricavam se sto sam glup, ali do neki dan nisam nikada koristio ATI karticu, i sad imam zamjenski komp, koji ima radeon X550, ali ja se ne snalazim tu bas, pa da pitam jel zna tko da li ovi drajveri pasu na tu karticu Sada koristim 9.3.1, to sam skinuo sa njihove stranice, ali ja neznam da li je problem u drajverima ili sta, ali kad god pokrenem cabal online, slika mi se jednostavno smrzne, i nemogu nista nego resetirati komp. Pa ako netko mozda zna neke starije drajvere koji 100% rade sa ovom grafickom, bio bih vam jako zahvalan. Hvala lijepa. |
21.07.2009., 08:55 | #12 | |
Propali Amigaš
Lokacija: Nin
Postovi: 6,959
21.07.2009., 10:47 | #14 | |
Lokacija: SGE
Postovi: 92
15.08.2009., 18:28 | #16 |
Lokacija: Zabok
Postovi: 1,620
Skinuo sam to sranje od drivera te mi je kao i svaka serija od 9.4 pa na dalje pregrijavala karticu koja je na default clocku i otišla mi memorija. No dobro, nadam se da će sve dobro proći sa reklamacijom
