Staro 28.08.2004., 22:04   #1
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Exclamation Nova konfa... 2put...
Uskoro kupujem novi komp:
Midi Tower, EVER POWER CX-5365, 500 W, fan speed control + USB, ATX 2
Cooler for case PAPST N2/GLLE, 9dB, 80mm
MBO EPOX, s. 754, 8HDA5+, VIA K8T800, BUS 1600 MHz, serial ATA RAID, 7.1 zvuk, DDR 400, 2xLAN, ATX 2
AMD Athlon 64 3200+, 2200 MHz, 512kb c., socket 754, BUS 1600 MHz, BOX
Zalman A7000B-Cu, svi socketi
RAM, 512 MB, DDR, PC-3500, 433 MHz, KINGMAX
VGA SAPPHIRE ATI Radeon 9800PRO 256BIT, 128 MB, with TV out & DVI
2 X HDD MAXTOR 160 GB, serial ATA, 7200 o/min., 8 MB cache
DVD ROM Drive, 16x 48x, TEAC, bulk
DVD pisač, DVD±RW & DVD±R, NEC ND-3500A, 16x, dual layer 8.5 GB, bulk
Slušalice 5.1, ZALMAN, ZM RS-6F, Theatre 6, 5.1 zvuk
Mon. 19" LG, F900P, 30-111 kHz, 0.24 mm, FLATRON
Cijena konfe: 12099
Mislim kupovati u HG-SPOTu...
Molima vaše savjete!!!!!!!!!!!!!!!!
LuXor je offline   Reply With Quote
Staro 28.08.2004., 22:44   #2
darth_maul
Lich
darth_maul's Avatar
Postovi: 201
Re: Nova konfa... 2put...
Kaj nije 64 3200+ na 2000 Mhz-a??
Athlon64 3400+ 512kb/ABIT K8V MAX3
2x WD RAPTOR 36gb@RAID 0
Pioneer DVD+RW d.l. + Lg DVD-rom
Leadtek 6800gt@400\1100
2x 512 ddr Kingmax, 433Mhz
Chieftec,Midi DRAGON+Antec 550w
Samsung 19" Dynaflat SM997DF
SB Live! 5.1 + Creative 5.1 P580
2001:22,236/2003:12,429/2005:5,344
darth_maul je offline   Reply With Quote
Staro 28.08.2004., 22:48   #3
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Nije da sam 100% siguran, ali...
Clawhammer A64 3200+ 2Ghz 1Mb L2
Newcastle A64 3200+ 2.2Ghz 512kb L2
Staro 28.08.2004., 23:14   #4
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Zamijeni trgovinu i kuciste !
Za kuciste Chietec Midi dragon ili Office series i 360W chieftec.
Trgovina savjet od svuda po malo.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 28.08.2004., 23:15   #5
elvis
elvis's Avatar
Lokacija: %
Postovi: 465
Cijena konfe: 12099
Obavezno drugo napajanje, a ne Everpower 500W, brojke varaju. Radije uzmi neku kombinaciju kućište + kvalitetniji PSU (350-450W), ili zajedno od nekog poznatijeg branda kao Antec, Aopen, Chieftec i sl.
IMHO RAM možda i drugi, pogotovo ako je SuperRAM, ako je HC može i ostati, iako ne bi štetilo da je na većoj nazivnoj frekvi, ali ako nećeš OC-at nije potrebno. Između ostalih brandova, razmisli o 2*Supertalent 512MB, koji je dosta jeftin uz solidne performanse.
my 2 cents
elvis je offline   Reply With Quote
Staro 29.08.2004., 02:02   #6
No123
Lokacija: Grad na Dravi
Postovi: 580
Kuciste je odlicno, ja imam takvo ali sam napajanje zamjenio s Enermaxom
No123 je offline   Reply With Quote
Staro 29.08.2004., 21:02   #7
LuXor
Lokacija: Bjelovar
Postovi: 752
Točno!
Newcastle jezgra ima 512KB L2 cache (dakle duplo manje od Clawhammera), pa joj je AMD povečao frekvu za 200MHz, kako bi se popunila razlika u performansama
Staro 29.08.2004., 21:22   #8
zek0
zek0's Avatar
Postovi: 422
još samo da zamjeniš trgovinu i napajanje...
ja sam dosad kupovo u hgspotu ali više neću jel su u zadnje vrijeme jako počeli kakat...
Brišem sve šta se može obrisat!
zek0 je offline   Reply With Quote
Staro 30.08.2004., 21:25   #9
LuXor
Lokacija: Bjelovar
Postovi: 752
Da, vidio sam ga od tebe, negdje na forumu (ovome neravno) si objavio slike (nešt oko hlađenja), i vrlo mi se svidjelo ( pogotovo jer ima 5+1 ventova )
Staro 02.09.2004., 20:17   #10
LuXor
Lokacija: Bjelovar
Postovi: 752
Ima li tko iskustva s montiranjem Zalmana A7000B-Cu na EpX EP KDA3J ploču, jer se bojim da zalman neće stati?????????!!!!!!!!!
Staro 03.09.2004., 14:06   #11
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Everpower kuciste pa izvrsno....c,c,c,c,c
Imao ga i NIKAD vise, krivo ga pogledas iskrivi se.
Svakipu kod vadjena maticne je bilo muke sa stavljenjem je nazad u kuciste jer se kuciste naherilo.
EVrpower je SMECE kao i napajanja ( MAxpower) tako i kucista.
Radje investiras u Chgieftec Office series.
Grunf je moj idol!
Staro 03.09.2004., 14:19   #12
vudu2
vudu2's Avatar
Lokacija: Sisak
Postovi: 1,058
Ili u Anteca sa Antec 350w napajanjem. Za nekih 650kn dobiješ sve to. Apsolutni best buy
vudu2 je offline   Reply With Quote
Staro 03.09.2004., 14:26   #13
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Upravo to Chiefetc ili Antec , mislim da je Chieftec nesto jeftini od Anteca, Antec ima bolji ispravljac od chiefteca dok chietfec to kompenzira nesto visim naponima.
Grunf je moj idol!
Staro 03.09.2004., 14:43   #14
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Tjha ... po defaultu - NE
Sad - za NF3 ploče NE ZNA, ali ...
Treba otpiliti jedan kraj držaća da ne smeta kondenzator na Epox pločama NF 2 serije.
Dali su to ( napokon ) ispravili bi trebalo pogledati na Zamanovim stranicama pod compatability
Staro 03.09.2004., 17:04   #15
No123
Postovi: 580
Mozda je to slucaj s EverPower kucistima za 150 kn, nemam pojma ali moje je kostalo 550kn i sigurno se nece nikada iskriviti
Staro 03.09.2004., 21:33   #16
LuXor
Lokacija: Bjelovar
Postovi: 752
Mislim da bi uzeo Chieftec Big Tower u Info Gami i 420/460 napajanje...
Staro 03.09.2004., 21:34   #17
LuXor
Lokacija: Bjelovar
Postovi: 752
Koji model:confused:
