Staro 01.09.2008., 12:28   #1
Bratija
Postovi: 129
IntelBurnTest
vidim da nitko ne pise o ovome, bas me zanimaju misljenja...
http://www.xtremesystems.org/forums/...d.php?t=197835
Code:
Description:
Linpack by Intel(R) is an extremely stressful program that will
put even the most powerful X86/X64 CPU in the world at its knees. Load temp
under Linpack will be up to 22*C higher than the competing software Prime95.
This program will make usage of Linpack easier and more practical.
Keep in mind, use this program at your own risk. By using this program, you
agree that neither I nor Intel shall be responsible for including, but not
limited to: burned up CPU, fried motherboard, spontaneous room temperature
increase, hair loss, or mental stress.
Benefits of using Linpack:
1. More accurate than Prime95 Small FFTs/Blend.
2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually
   something like 8 minutes Linpack vs 40 hours under Prime95).
3. Use the same stress-testing engine that Intel uses to test their products
   before they are packed and put on shelves for sale.
Bratija je online   Reply With Quote
Staro 01.09.2008., 12:33   #2
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
citam raspravu, zvuci zanimljivo
DeadMan+ je offline   Reply With Quote
Staro 01.09.2008., 12:34   #3
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Evo skida se pa cu probati.
Staro 01.09.2008., 13:10   #4
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,280
meni se ugrijao jedno 5°c vise nego prime i kaze da mi nije stabilan...
jedino mi ne ulijeva bas povjerenje to sto program koji testira stabilnost
procesora nemoze/nezna tocno ocitat takt na kojem radi procesor?
kaze 3600mhz umjesto 3200.
malo mi smijesno to, najblaze receno. ne dizem voltazu na temelju ovog testa....
rodney je offline   Reply With Quote
Staro 01.09.2008., 13:35   #5
hehe, evo vam program za ubijanje proca zašto imam filing da ćemo na tržnici imati nekoliko E8x00 procova
nego, ja ga baš kurim na poslu, na E4400. jebote, na 1,3V, 68'C occt 2.0.0 je maximalna temp 50. 18 °C ga je prehajcao
Staro 01.09.2008., 13:37   #6
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Čemu to silovanje?! Šta si želite dokazat?!
Staro 01.09.2008., 13:42   #7
Da skurimo ove procove koje imamo i da nam starci onda kupe E8600
ma ja ovo neću primjenjivati na svom Wolfiju, ali Allendalea na poslu gazim
Staro 01.09.2008., 13:57   #8
joco7
clon: joco7 i kloker1974 i martina7 i maja_kokolari blake
Postovi: 138
suludo...
joco7 je offline   Reply With Quote
Staro 01.09.2008., 15:15   #9
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Autor -POP- Pregled postova
Programer
Staro 01.09.2008., 15:43   #10
Bratija
Postovi: 129
nije stvar dokazivanja, nego da ako je istina ovo sto pise, ljudi koji clockaju svoj procesor mogu usparati dosta vremena... ovo o silovanju se moze primjeniti na overclocking opcenito, al to je tema za sebe...
Staro 01.09.2008., 16:12   #11
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
Kad sam prvi put testirao - temperatura je bila manja nego u Orthosu za 3°C..I kaže da nema errora..
Međutim, čudno mi je bilo kad sam vidio da prema njihovim rječima 10-15 min ovog testa odgovara testiranju Primeom/Ortosom po desetak sati pa sam napravio mali "test". Dodatno sam spustio voltažu na procesoru i testirao ga ponovo. Intel Burn Test je prošao bez problema (cca 15min.) i nakon toga upalim Ortos i nakon 25 min mi izbaci error..
Tako da je imho Orthos/Prime još uvijek bolji način testiranja stabilnosti
"The objective of war is not to die for your country, but to make the other bastard die for his."
dzeneral je offline   Reply With Quote
Staro 01.09.2008., 17:13   #12
Rain Man
Lokacija: x
Postovi: 1,447
Ja ostajem kod prime95. Dok mi je on pokazao da nema problema obicno ih nije bilo u koristenju. Ovo silovanje neznam kakvih testova je pokusaj proizvodaca tih softvera da se uguraju medju ustaljene programe za testiranje.
Rain Man je offline   Reply With Quote
Staro 01.09.2008., 20:14   #13
mskvorc1
mskvorc1's Avatar
Postovi: 288
Ja bi još malo pričekao s time. Vidio sam da se ekipa na XtremeSytems ozbiljno zagrijala za taj program, odnosno neki ga već koriste kao referentni, a s druge strane ima ekipe koja je rekla da im je IntelBurnTest prošao, a Prime nije. Opet, program je za sada dogurao do verzije 1.6, dok su starije nekim ljudima prolazile, 1.6 im ne prolazi...
mskvorc1 je offline   Reply With Quote
Staro 01.09.2008., 20:21   #14
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
ne palim se na visoke temp, da odmah bude jasno, zbog nekih izjava gore.
svaki program je koristan ako pokazuje stabilnost mašine,
ALI ne znam kome vjerovati, Prime95 radi preko noći (dakle preko 10-15h u komadu) i sve 5., tj. nema grešaka.
a ovaj sruši komp u roku 10 minuta, ne želi proći ni na 3.6, 3.4 niti 3.2GHz!
(voltaže nisam išao dizati više od onih isprobanih 24h Prime-om jer mislim da nema potrebe,
pošto se nikada se nije rušio u Prime-u, a niti u radu ma koliko on naporan bio kroz prošlih 7 mjeseci koliko je setup takav,
pa ne vidim smisao dizat ih niti imam vremena kemijati)
možda ovaj prog fakat iscrpi CPU više od Prime-a, i baci error. ali čemu?
da bude poznat i jedinstven na net-u?
da svi pričaju kako je 'bacio najnovije CPU-e na koljena'?
kako piše na stranici otkuda se skida taj ''.exe''
to mi je kao da stavim auto u ler i ciglu na gas, ode u blokadu,
i onda gledam kada će se raspast mašina kroz sat, dva ili manje?
dok u normalnim uvjetima rada neće otići ni za 15 godina...
http://www.youtube.com/watch?v=Or5qif80xQo&NR=1
http://www.youtube.com/watch?v=0POwsgyj16g&NR=1
http://www.youtube.com/watch?v=VCc-l...eature=related
http://www.youtube.com/watch?v=kxExh...eature=related
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
Zadnje izmijenjeno od: TomRi. 01.09.2008. u 20:58.
TomRi je offline   Reply With Quote
Staro 01.09.2008., 21:58   #15
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,753
Autor TomRi Pregled postova
Mah...
Ovo izgleda kao jos jedna sprdacina nadrih programera. Ipak, veseli vidjeti malo humora Intelovaca:
http://www.intel.com/cd/software/pro...eng/266857.htm
Pogledati "Ease of Use" dio.
Programer
Staro 01.09.2008., 23:08   #16
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Srce me boli od ovih videa, pogotovo zbog honde. Idioti.
BladeRunner je offline   Reply With Quote
Staro 01.09.2008., 23:27   #17
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ne shvacam...
Realno, nikad neces postic te temperature normalnim koristenjem, pa cemu ovo?
I Prime95 je po meni overkill.
Staro 01.09.2008., 23:42   #18
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Autor Rain Man Pregled postova
prime95 i orthos kao i occt meni ne zele prolazit nikako @4GHz... stavio ja 1.7V ili trenutnih 1.58V...
U SVAKOJ aplikaciji radi savrseno, od 3dcmarka, PS-a pa nadalje, nikad da bi se restarto kao sto se dogodi cim upogonim jedan od ovih stability testova...
Spoiler alert!
Staro 06.07.2009., 07:08   #19
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Need a Gigabyte latest BIOS?
GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz
G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2)
G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1)
Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 SP1
stasio je offline   Reply With Quote
Staro 06.07.2009., 15:14   #20
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Danas:
IntelBurnTest 2.3
- Added latest Linpack binaries and patched for AMD CPUs
- Added Xtreme Stress Mode (Right-click the "Start" button)
Staro 06.07.2009., 15:15   #21
Razer
Razer's Avatar
Postovi: 11,642
Hvala na svim updateima stasio
Staro 07.07.2009., 23:06   #22
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Nema problema.
Staro 06.02.2010., 13:13   #23
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
