Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Uskoro kupujem novi komp: Midi Tower, EVER POWER CX-5365, 500 W, fan speed control + USB, ATX 2 Cooler for case PAPST N2/GLLE, 9dB, 80mm MBO EPOX, s. 754, 8HDA5+, VIA K8T800, BUS 1600 MHz, serial ATA RAID, 7.1 zvuk, DDR 400, 2xLAN, ATX 2 AMD Athlon 64 3200+, 2200 MHz, 512kb c., socket 754, BUS 1600 MHz, BOX Zalman A7000B-Cu, svi socketi RAM, 512 MB, DDR, PC-3500, 433 MHz, KINGMAX VGA SAPPHIRE ATI Radeon 9800PRO 256BIT, 128 MB, with TV out & DVI 2 X HDD MAXTOR 160 GB, serial ATA, 7200 o/min., 8 MB cache DVD ROM Drive, 16x 48x, TEAC, bulk DVD pisač, DVD±RW & DVD±R, NEC ND-3500A, 16x, dual layer 8.5 GB, bulk Slušalice 5.1, ZALMAN, ZM RS-6F, Theatre 6, 5.1 zvuk Mon. 19" LG, F900P, 30-111 kHz, 0.24 mm, FLATRON Cijena konfe: 12099 Mislim kupovati u HG-SPOTu... Molima vaše savjete!!!!!!!!!!!!!!!! |
#2 | |
Lich
Datum registracije: Jun 2004
Postovi: 201
Re: Nova konfa... 2put...
Athlon64 3400+ 512kb/ABIT K8V MAX3 2x WD RAPTOR 36gb@RAID 0 Pioneer DVD+RW d.l. + Lg DVD-rom Leadtek 6800gt@400\1100 2x 512 ddr Kingmax, 433Mhz Chieftec,Midi DRAGON+Antec 550w Samsung 19" Dynaflat SM997DF SB Live! 5.1 + Creative 5.1 P580 2001:22,236/2003:12,429/2005:5,344 |
al se nekad dobro jelo...
Postovi: 3,312
Nije da sam 100% siguran, ali... Clawhammer A64 3200+ 2Ghz 1Mb L2 Newcastle A64 3200+ 2.2Ghz 512kb L2
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Zamijeni trgovinu i kuciste ! Za kuciste Chietec Midi dragon ili Office series i 360W chieftec. Trgovina savjet od svuda po malo.
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
#5 | |
Lokacija: %
Postovi: 465
IMHO RAM možda i drugi, pogotovo ako je SuperRAM, ako je HC može i ostati, iako ne bi štetilo da je na većoj nazivnoj frekvi, ali ako nećeš OC-at nije potrebno. Između ostalih brandova, razmisli o 2*Supertalent 512MB, koji je dosta jeftin uz solidne performanse. my 2 cents ![]() |
#7 | |
Lokacija: Bjelovar
Postovi: 752
Newcastle jezgra ima 512KB L2 cache (dakle duplo manje od Clawhammera), pa joj je AMD povečao frekvu za 200MHz, kako bi se popunila razlika u performansama ![]() |
Postovi: 422
još samo da zamjeniš trgovinu i napajanje... ja sam dosad kupovo u hgspotu ali više neću jel su u zadnje vrijeme jako počeli kakat... ![]()
Brišem sve šta se može obrisat!
#9 | |
Lokacija: Bjelovar
Postovi: 752
Lokacija: Bjelovar
Postovi: 752
Ima li tko iskustva s montiranjem Zalmana A7000B-Cu na EpX EP KDA3J ploču, jer se bojim da zalman neće stati?????????!!!!!!!!! |
#11 | |
Headbangig Grunf!
Postovi: 4,373
Imao ga i NIKAD vise, krivo ga pogledas iskrivi se. Svakipu kod vadjena maticne je bilo muke sa stavljenjem je nazad u kuciste jer se kuciste naherilo. EVrpower je SMECE kao i napajanja ( MAxpower) tako i kucista. Radje investiras u Chgieftec Office series.
#12 | |
Lokacija: Sisak
Postovi: 1,058
Headbangig Grunf!
Postovi: 4,373
Upravo to Chiefetc ili Antec , mislim da je Chieftec nesto jeftini od Anteca, Antec ima bolji ispravljac od chiefteca dok chietfec to kompenzira nesto visim naponima.
#14 | |
Ekspert iz sjene ...
Lokacija: New Eden
Postovi: 3,801
Sad - za NF3 ploče NE ZNA, ali ... Treba otpiliti jedan kraj držaća da ne smeta kondenzator na Epox pločama NF 2 serije. Dali su to ( napokon ) ispravili bi trebalo pogledati na Zamanovim stranicama pod compatability ![]() |
#15 | |
Lokacija: Grad na Dravi
Postovi: 580
#17 | |
Lokacija: Bjelovar
Postovi: 752
