Postovi: 18,851
Sharkoon Flexi-Drive S2S - SDHC to SATA adapter aka "modularni" SSD
Simply insert the desired number of SDHC cards (max. 6) into the Flexi-Drive's slots. The card's individual memory capacities merge into one and are available as a single drive then. Benefit from this flexible, convenient memory solution that can be used as a normal 2.5" SATA HDD providing the advantages of a SSD: no noise emission, low power consumption and shock resistance. ![]() ![]() Features: • Fast modular SSD storage solution • Memory size flexibly adaptable via SDHC memory cards (SLC/MLC) • SATA interface (SATA I and II) • 2.5" format • Zero noise emission, low power consumption, shock resistance • No drivers or software required Specifications: • Use up to 6 SDHC cards as RAID0 • 6 slots for SDHC cards (4-32 GB) • Supports SDHC cards only • Flexible memory capacity • Dimensions: 70 mm x 100 mm x 9 mm (W x L x H) Package content: • Flexi-Drive S2S Je li netko slučajno probao ovu stvarčicu? ![]() http://www.sharkoon.com/html/produkt.../index_en.html http://www.links.hr/index.php?naziv=...kl=051.400.007
Lokacija: NA
Postovi: 2,620
koncept zanimljiv, ali stvar je preeeeeskupa. |
Lokacija: Splity
Postovi: 3,003
To je i meni privuklo pažnju , ali ![]() |
Lokacija: Histria
Postovi: 1,242
Ako sam skužio, to je nekakva tiskana ploćica koja ima 6 utora za SD kartice (6x16gb=96gb? s time da se kartice opet kupuju posebno a svakih 16gb dodanih 200 kuna) u aluminijskom kućištu od 2.5'' i cijenom od 700 kuna. Znači ako hoću disk od 96gb moram potrošiti oko 2000 kuna? I to za jedan 2.5'' (zašto 2.5''?) NEprenosivi sata disk? Kul. ![]() ![]() ![]() |
Lokacija: x
Postovi: 1,447
Koje su brzine citanja, pisanja? |
