Staro 17.04.2009., 08:50   #2131
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,682
ili odes u msconfig -> boot i tamo obrises vistin...
Staro 18.04.2009., 19:17   #2132
dario_cile
Troll
dario_cile's Avatar
Lokacija: Doboj
Postovi: 282
Autor Problem Pregled postova
problem je to sto nigde nemam vistinog...
Bolje džaba ležati nego džaba raditi
dario_cile je offline   Reply With Quote
Staro 19.04.2009., 04:28   #2133
thopok
Lokacija: Splity
Postovi: 3,003
Jasno da nema.
Treba potražit teme u kojima je već riješen taj "problem".
Bootloader ostao nakon Viste?
I nekoliko stranica prije u ovoj temi…
Staro 29.04.2009., 18:16   #2134
Facelessone
Facelessone's Avatar
Postovi: 4,203
:whistle:
Microsoft Windows Vista and Server 2008 SP2 FINAL RTM xxxxxxx
Service Pack 2 for Windows Vista has reached the Release to Manufacturing stage
In addition to a number of security and other fixes, the following new features will also be added:
* Windows Search 4.0 (currently available for SP1 systems as a standalone update)
* Feature Pack for Wireless adds support for Bluetooth 2.1
* Windows Feature Pack for Storage enables the data recording onto Blu-ray media
* Windows Connect Now (WCN) to simplify Wi-Fi configuration
* Improved support for resuming with active Wi-Fi connections
* Enables the exFAT file system to support UTC timestamps, which allows correct file synchronization across time zones
* Support for ICCD/CCID smart cards
* Support for VIA 64-bit CPUs
* Improves audio and video performance for streaming high-definition content
* Improves Windows Media Center (WMC) in content protection for TV[
* Provides an improved power management policy that is up to 10% more efficient than the original in some configurations
Windows Vista and Windows Server 2008 will share a single service pack binary, reflecting the fact that their code bases were joined with the release of Server 2008.
Unlike prior Service Pack releases of both Windows Vista and Windows XP, Microsoft has decided to release Service Pack 2 in the form of an OEM Preinstallation Kit to OEM partners 60 days after the date of Windows 7 General Availability.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 30.04.2009., 17:22   #2135
tocka
Postovi: 175
mogao si i linkat odma
tocka je offline   Reply With Quote
Staro 08.05.2009., 15:06   #2136
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,508
ja nikako s tom vistom na zelenu granu
Nakon par pokusaja prelaska na Vistu, idem opet pokusati i opet se javljaju problemi. Slozio sam sve, sve programe instalirao, najnovije drivere.... i onda problem.
- BSPlyer mi uopce nece otvoriti film ili seriju. samo se zablokira i moram ga "nasilno" ugasiti.
- Compro DTV i DVBViewer (programi za tv karticu) isto se uopce nece pokrenuti, krenu se loadati pa stanu. I nista ne pomaze osim logouta ili restarta (cak nekad nece ni onda proraditi).
i sad se opet vratih na XP, isti programi, isti driveri i sve radi ok, bez greske. Znaci problem je u Visti. Nisam jos probao ovu leaked verziju Viste SP2, ali bas me zanima, cim nadem vremene isprobat cu.
- svi zadnji driveri instalirani
- Bsplayer zadnja verzija + codeci koje nudi za instalirati
- XVID codec
- ac3filter
- ffdshow
- vista - svi updateovi
U cemu je problem da nije kompatibilno sa Vistom ili se nesto kolje? Jel netko imao takvih problema?
Staro 08.05.2009., 15:35   #2137
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Ovdje imaš rješenje problema sa video playerima:
http://forum.pcekspert.com/showthread.php?t=142972
Staro 15.05.2009., 15:50   #2138
gbijelic
gbijelic's Avatar
Lokacija: Oslo
Postovi: 806
dali se je tko igrao sa ovim opcijama...ima li kakvog efekta?? za stolno racunalo mislim
gbijelic je offline   Reply With Quote
Staro 15.05.2009., 17:04   #2139
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
Autor gbijelic Pregled postova
Privitak 9603
A ostavi ga da balansira..ako je stolno...:-)
boris87 je offline   Reply With Quote
Staro 23.05.2009., 17:39   #2140
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Inst. Vistu sinoć, prvi dojam je da je to KATASTROFA, nepregledno, Windows Explorer neupotrebljiv, video fileovi rade po svojoj volji (par sekundi iz sredine, pa izpočetka, kao da netko mixa)... ne mogu se promjenit ikonice za foldere... volim imat folder sa MP3-em i filmovima da svaki ima svoju ikonicu... za prebacivanje datoteka ili brisanje pita te 55 puta jel oš il neš to obrisat? ma daj....
Što reći nego napola odrađen OS (smeće), probati ću za koji dan Win7, kad uhvatim vremena, inače se vraćam na XP...
http://img845.imageshack.us/img845/7167/croatia240animatedflagg.gif
Remixer je offline   Reply With Quote
Staro 23.05.2009., 17:40   #2141
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
E DA, zaboravih napisat bitnu stvar, slika mi je mutna i slova imaju nekakvu crvenu pozadinu/sjenu, to mi je isto bilo na jednoj staroj verziji XP-a, i eto sad na Visti, kad bi vistu usporedio sa autom... to bi bio TRABANT ili konjska zaprega.
Staro 23.05.2009., 17:48   #2142
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Mhm, glavno da si prosro gro sranja po OSu a nisi pročitao ni neke najvažnije "cake"
Npr, isključivanje user account controla (ono što te pita 100 puta za sve), ikone se mogu promjeniti , za video fileove... koristi bolji player.
Tekst... mutan... a da uključiš clear type?
Napola je odrađen u početku kao i XP, sa SP1 Vista kuca ko švicarski sat, odličan OS
Hrpu stvari trebaš napraviti po instalaciji Viste, ali kad utrošiš tih pol sata za uštimavanje miran si.
blaa
Staro 23.05.2009., 17:51   #2143
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
da ti ne koristis kakve hmm(modifiicirane)windowse ili bas licencirane..
Staro 23.05.2009., 18:17   #2144
Atrax
Atrax's Avatar
Postovi: 553
Autor Remixer Pregled postova
...video fileovi rade po svojoj volji
prvi put čujem za tako nešto
normalno da se mogu promijenit....
za prebacivanje datoteka ili brisanje pita te 55 puta jel oš il neš to obrisat...
treba samo ugasit Vistin UAC. Al naravno, da bi to znao, trebalo je pročitat post-dva o Visti Ili googlat nedaj bože.....
nepregledno, Windows Explorer neupotrebljiv...
vista "tvornički" dolazi takva kakva jest, a u par vrlo jednostavnih koraka se sve vrlo lako da naštimat i prilagodit svakom korisniku.
brljezgaš gluposti, i flejmaš bezveze, niti jedan konkretan (i prije svega TOČAN i PROVJEREN) argument nisi dao.
Vista je Vista, dakle nije XP, dakle drukčiji OS, dakle treba mu i drukčije pristupit.
Vista mi se na ovom kompu ponaša identično kao XP, al naravno tek nakon što sam ju prilagodio svojim potrebama, tu mislim i na sami izgled, znači layout prozora, menija i slično, a to sve sve može fino naštimat, samo treba imat malo volje naučit nešto novo a ne ko pijan plota držat se nečeg.
Što se Win7 tiće, probao sam zadnji onaj RC, dobar je, ali ne primječujem bitnu i neku ozbiljnu razliku od Viste (tu ne mislim na "komzetiku", to me ne zanima ionako), ako ti se Vista nije svidjela, neće ni Win7, jer po svemu što si napisao, imam dojam da očekuješ "remake" XP-a, a ne novi OS.
Ja sam uz Vistu prvih 2 tjedna izgubio živaca i živaca jer sam uporno pokušao od nje napravit XP, al treba shvatit da to ne ide tak, jednostavno je drukčiji OS, i neke stvari drukčije obavlja. Treba "prokužit" Vistu, i skužit kaj treba kak naštimat. A ista priča je i sa Win7, tako da, mislim da ti ni sedmica isto neće leć.
Ovi problemi koje su naveo su tvoji konkretni, pa umjesto da se raspitaš ima li itko riješenje ili neka saznanja, da si recimo googlao malo...Ne, ti popljuješ OS kojim se ne želiš naučit koristit.
I da, BTW, SP1 je obavezan za Vistu, neznam jel ga imaš gore, bez njega je Vista neupotrebljiva praktički, to je definitivno istina.
Tako da, moja preporuka ti je da si daš više od dan i pol za testiranje i recenziranje nekakvog komada softvera poput OS-a.
Atrax je offline   Reply With Quote
Staro 23.05.2009., 18:21   #2145
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Autor hammer_of_thor Pregled postova
-Isključio sam naravno user account, ali velim da je glupo što to moraš ručno prčkat.
-Ikonu promjenit i bude prikazana pola sekunde i onda se vrati na ono što je bilo prije.
-bolji player? A TO JE???
-clear type je bio uključen, isto je i kad je na standard, i prisutan je samo na npr. tabovima i slično, a tu sad kad pišem ovaj text (crna slova, bijela pozadina) je slika super. Ne pomažu postavke na monitoru..........
Staro 23.05.2009., 18:25   #2146
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
OK, sorry
Čujemo se onda za 2 tjedna, znam da je 1.5 dana malo
Imam SP1......................
Staro 23.05.2009., 18:36   #2147
Atrax
Atrax's Avatar
Postovi: 553
OK, sorry
Ne moraš se ispričavat, niko te ne napada, al velim, nemožeš u dan i pol procijenit kakav je neki OS. Možda ti se ni nakon 6 mjeseci nebi svidio i nebi lego, al ćeš nakon dulje provedenog vremena imat konkretne razloge zašto ti ne valja i šta ti ne štima. Za dan i pol ja uspijem instalirat drivere i programe koji mi trebaju, a di je još naštimavanje i podešavanje svega.
Zbilja smo u ovoj temi pregazili hrpu problema i upita oko Viste, tak da ovdje možeš praktički sve nać šta ti treba.
A tu je uvijek i
Staro 23.05.2009., 18:42   #2148
hammer_of_thor
Postovi: 5,430
A moraš ručno da, kao i hrpu stvari na dotičnom OSu, ali kažem ti, kad se nauči šta se treba uštimat i kako to napraviiti, u pol sata-sat nakon instalacije kad sve podesiš imaš švicarski sat
Nebi trebalo biti tako, možda imaš kakvu sumnjivu verziju
Neznam... koji koristiš?
Meni ni na WMP, ni na KM Playeru, ni na VLC playeru nikad nikakvih problema
Nije lako naviknuti se na Vistu, definitivno, i ja sam ju bio brisao i vračao XP par puta, no kad sam jednom naučio ove cake o podešavanju i malo se naviknuo na Vistu, nikad više se nebi vratio na XP
Indexsiranje diskova i superfetch isključit, ReadyBoost također, ima tu podosta stvari za podesit, da ručno, ali malo se potrudiš i imaš OS na kojem je milina raditi
blaa
Staro 23.05.2009., 18:54   #2149
Atrax
Atrax's Avatar
Postovi: 553
Indexsiranje diskova i superfetch isključit, ReadyBoost također..
Ok za indexiranje i ready boost( i još jedno barem 10-ak bezveznih servisa), al zakaj SuperFetch? Sam nekaj propustil?
Ako išta drugo, vista mi se podiže puno brže od XP-a, pod time mislim i na startup aplikacije (antivirus, CCC i MSN), trenutno se podižu, bez čekanja. Šta nije superfetch zaslužan za to? Moguće da živim u zabludi....
I btw, kad smo već kod podizanja Viste, sve se upali, ali moram jedno pol minute pričekat da se LAN spoji il šta mu već radi, ne znam. Uglavnom, kod sata gdje mi je ikona ona, prvo je crveni X gore, tad se ne mogu ni spojit, neki programi mi ne reagiraju, sve dok se ne pojavi žuti uskličnik, e tek onda se mogu spojit na net, al do tada ne reagira nekih pol minute. Iritira.
Imam od Tcoma router, Dlink 584T.
I svaki put kad palim komp, moram se ponovno spajat na net, na XP mi nije bilo tak. To je isto muka jer se rijetko spoji iz prve.....Jel to onaj smrdljivi IPv6 kriv možda?
Staro 23.05.2009., 19:03   #2150
hammer_of_thor
Postovi: 5,430
Hmmm, ja superfetch isključujem, ali to je od usera do usera.
Osobno dovoljno mi je brzo kad komp i bez tog servisa diže aplikacije. Trpanje programa u RAM za koje windowsi misle da ću ja pokrenuti mi ne treba
Neznam dali si išta propustio, i ne živiš u zabludi
Ja sam isto prije sa Kasdom morao čekati nakon paljenja 30ak sekundi dok se ne pojavi uskličnik pokraj kompova kod sata, i tad sam mogao na net, sad imam Siemens Gigaset SX 763 i u njemu su svi podaci tako da čim upalim komp imam net iste sekunde, nema više konektanja
A IPv6 se mora isključiti, inače stoji cijelu vječnost na onome registering you computer... makar se već i na tom dijelu može na net, iritira jako
blaa
Staro 23.05.2009., 19:24   #2151
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Autor Atrax Pregled postova
A tu je uvijek i
Istina, moram pročitat sve, čim uhvatm vremena.
Staro 23.05.2009., 19:29   #2152
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Imam best player, i Winamp, sad sam pregledao hrpu file-ova i samo neki tak ''trzaju''...
E da, IPv6 sam čak sam skužio da se mora isključit, grrr
-neću se vračat na XP, barem ne na ovom hardu, imam XP inst. na drugom
E da, ako smijem reći da je XP puno brže odlazio u standby i podizanje sustava, ali vidjet ću još nakon tjedan dana kak' će mi se činit Vista...
Staro 24.05.2009., 14:57   #2153
Hunt.ONE
ЬГΛY.Z0ИЗ
Hunt.ONE's Avatar
Lokacija: Sisak
Postovi: 258
S readyboostom, stick 2gb.. meni nakon boot screena digne sve programe, sve iz traja u roku par sekundi.
Odlicno je
This post is copyrighted ©
Hunt.ONE je offline   Reply With Quote
Staro 24.05.2009., 18:55   #2154
Atrax
Atrax's Avatar
Postovi: 553
E, upravo to! Ajt, bar je još netko upoznat sa mojim mukama...I'm not alone!
A pogotovo ovo drugo, ide minutu "registering your computer to network..." bla bla bla, iste sekunde se on spoji (vidim po antivirus i MSN da se spoje), al IE ne mogu opće otvorit. Ugasio sam taj IPv6, al opet ostaje to da se moram svaki put konektat ponovno.
Kompić ima isti router ko ja, ima XP, i stalno mu je spojen na net, čim ga upali, odma na netu. Tak da nije do routera vjerojatno. Tj., možda jest do routera, ali u postavkama njegovim, a na tom polju sam laik popriličan(net, routeri LAN i slično...).
Trebo bih Tcom nazvat, možda će znat, ak nitko ovdje ne zna.
Staro 24.05.2009., 19:04   #2155
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,737
Hmpf. Svasta. Vista Enterprise x64 SP1, DHCP hendla dnsmasq 2.35-1 na Debian etchu - adresa je dodijeljena unutar nekoliko sekundi od dogmizavanja na desktop.
OTOH, gdje imam (mrezni) problem jest pri pristupanju Samba shareu (passwordom zasticenom), niti username niti password ne zele ostati zapamceni nakon restarta, unatoc, dakako, stiskanju "Remember my password" kvacice. Unutar te iste Viste, virtualni XP taj feature odradjuje besprijekorno.
Programer
Staro 24.05.2009., 21:46   #2156
tocka
Postovi: 175
Oce vise taj SP2, kaj cekaju?
Zasto je jos uvjek dostupan samo msdn ljudima?
Staro 24.05.2009., 22:05   #2157
žile
žile's Avatar
Postovi: 3,074
Otvara mi sve prozore u windowed modu,ne u full screenu.Jel se to može gdje podesit?
žile je offline   Reply With Quote
Staro 24.05.2009., 23:42   #2158
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,508
26. izlazi za skinuti, 30. na updateu (tako sam procitao negdje na microsoft stranicama)
Staro 25.05.2009., 14:22   #2159
tocka
Postovi: 175
oke, fala na info
Staro 25.05.2009., 14:38   #2160
Hunt.ONE
ЬГΛY.Z0ИЗ
Hunt.ONE's Avatar
Lokacija: Sisak
Postovi: 258
ima jedan cudan update na sp2 koji mi uspori komp za popizdit, nisam mogao naci koji, ali spustanje prozora ili bilo kaj slicno kao da imam p200...
